Working on an 06 Jet TDI that had a number of issues we have cleaned up as you will see in the codes. We have gotten everything squared away and are down to just the 02511. After clearing the codes the light went away and prior to cycling the key you could sit in the seat and the passenger airbag light would go off. Cycle the key and the code comes back.
Clear the code and reset the calibration for the seat sensor and the same thing. I am not sure I am letting it "reset" long enough. Should I get some kind of ok after recalibrating? I see the little spinning icon saying VCDS is communicating with the module but that seems normal. I am newer to VCDS.
Also in looking at the measuring blocks everything looks correct. Graphing the seat pressure it goes from about 65 or so to 250 or so with an occupant so that would seem to indicate the sensor is "seeing" an occupant. Somewhat of a head scratcher that it would see the sensor and sense the difference down to as finite as hand pressure but be out of range.
The vehicle was in an accident and had low or no voltage for an extended time. I think that was the cause of some of the other codes ie low voltage at the buss. Other issues were caused as we worked to replace the front clip.
Any suggestions?
Thanks Tom
Any suggestions?
Thanks Tom
Wednesday,11,March,2020,18:34:33:10220
VCDS Version: 19.6.2.2 (x64) HEX-V2 CB: 0.4508.4
VIN: 3VWCT81K16M850628 License Plate: 2006 WHITE
Mileage: 268110km-166595mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 42 44 46 47 52 56 62 65
72 7D
VIN: 3VWCT81K16M850628 Mileage: 268110km-166595miles
62-Door, Rear Left -- Status: Sporadic communication error 1000
Address 01: Engine Labels: 038-906-016-BEW.lbl
Part No SW: 03G 906 016 AC HW: 028 101 223 9
Component: R4 1,9L EDC G000DG 7551
Revision: --H05--- Serial number: VWZ7Z0F4710137
Coding: 0050078
VCID: 6491AAD50259C1E74DD-8030
005661 - Glowplug for Cylinder 4 (Q13)
P161D - 000 - Open Circuit
Fault Status: 01110000
Mileage: 267395 km
Time: 00:00:25
Voltage: 11.86 V
Bin. Bits: 00001000
Temperature: 0.0∞C
Bin. Bits: 00110000
Readiness: 1 1 0 0 0
Part No SW: 02E 300 043 HW: 02E 927 770 AE
Component: GSG DSG 070 1126
Revision: 04507000 Serial number: 00000608181114
VCID: 51FF73016DEB444F16B-8004
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Revision: 00H11001
Coding: 0021122
VCID: 73B3D989B7B7565FC47-8026
Part No: 1K0 820 047 FQ
Component: Climatic PQ35 120 0606
VCID: 78A9EEA5AED13507F15-802C
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 Q HW: 3C0 937 049 Q
Component: Bordnetz-SG H46 1501
Revision: 00H46000 Serial number: 00000000501602
Coding: 14018E234004150007140000001400000028770B5C0000
VCID: 372B2D99E34FFA7F38F-8062
Component: Wischer 261106 020 0501
Coding: 00065535
Shop #: WSC 00066
10 Faults Found:
Fault Status: 00101100
Reset counter: 13
Mileage: 267395 km
Voltage: 11.40 V
Reset counter: 13
Mileage: 267395 km
Voltage: 11.40 V
01505 - Bulb for Blinkers; Rear Right (M8)
Reset counter: 32
Mileage: 267686 km
Voltage: 14.50 V
Reset counter: 32
Mileage: 267187 km
Voltage: 14.25 V
Reset counter: 13
Mileage: 267395 km
Voltage: 11.45 V
Reset counter: 13
Mileage: 267395 km
Voltage: 11.45 V
Reset counter: 6
Mileage: 267531 km
Voltage: 13.25 V
Reset counter: 6
Mileage: 267944 km
Voltage: 12.40 V
Fault Status: 00101010
Reset counter: 13
Mileage: 267395 km
Voltage: 11.45 V
Reset counter: 13
Mileage: 267395 km
Voltage: 11.45 V
Part No SW: 8E0 035 593 D HW: 8E0 035 593 D
Component: SDAR SIRIUS H03 0060
Revision: 00000000 Serial number: AUZ4Z7F0012850
VCID: 2A0D04ED20FD5797B71-807E
Reset counter: 228
Mileage: 267395 km
Part No SW: 1K0 909 605 AB HW: 1K0 909 605 AB
Component: 69 AIRBAG VW8R 034 8000
Revision: 05034000 Serial number: 003B6D06XN4D
Coding: 0013881
VCID: 6C81C2F5EA8989A705D-8038
Subsystem 2 - Serial number: 6332MSME12461C625
Subsystem 3 - Serial number: 6342MSME14587E21E
Subsystem 4 - Serial number: 6351HSME0B43284DC
Subsystem 5 - Serial number: 6361HSME0B474D03A
Subsystem 6 - Serial number: 63727SME087F191DE
Subsystem 7 - Serial number: 63827SME0B230A760
02511 - Control Module for Seat Occupied Recognition (J706)
001 - Upper Limit Exceeded - Intermittent - MIL ON
Part No SW: 1K0 953 549 AS HW: 1K0 953 549 AS
Component: J0527 036 0070
Coding: 0012021
VCID: 03538949E71766DFD47-8056
Component: E0221 002 0010
Part No SW: 1K0 920 973 D HW: 1K0 920 973 D
Component: KOMBIINSTRUMENT 3HL 1610
Revision: V0003000 Serial number: VWZ7Z0F4710137
Coding: 0023203
Shop #: WSC 02641 067 57207
VCID: 2E0508FD1C153BB76B9-807A
Reset counter: 13
Mileage: 267395 km
Time: 01:22:58
Address 19: CAN Gateway Labels:. 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 H HW: 1K0 907 951
Component: J533__Gateway H12 0150
Revision: H12 Serial number: 31001069140761
Coding: 3FBF0B620F001002
VCID: 2C0102F52A0949A745D-8078
Reset counter: 11
Mileage: 267385 km
Time: 00:25:49
Reset counter: 12
Mileage: 267395 km
Time: 01:22:59
Part No SW: 1K5 919 965 A HW: 1K5 919 965 A
Component: Kompass 005 0003
Revision: 00005000 Serial number: 1293324T294J03
Coding: 0000003
VCID: 392F2BA1D55BEC0FCEB-806C
Component: IMMO 3HL 1610
Part No SW: 1K0 959 701 P HW: 1K0 959 793 L
Component: J386 TUER-SG FT 1127
Revision: 32008001 Serial number: 00000549069021
Coding: 0001205
VCID: 3B2331A9DF67DE1FDC7-806E
Reset counter: 45
Mileage: 260291 km
Fault Status: 00111000
Reset counter: 43
Mileage: 255372 km
00105 - Signal Central Locking SAVE/LOCK Drivers Side
Reset counter: 45
Mileage: 239907 km
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.070 H07 1806
VCID: 34311A95F23911671DD-8060
Part No SW: 1K0 959 433 CD HW: 1K0 959 433 CD
Component: KSG PQ35 RDK 051 0215
Revision: 00051000 Serial number: 00000000000000
Coding: 13900F880186281B0904058FB0880F0488DC00
VCID: 74B1DA95B2B95167DDD-8020
Fault Frequency: 15
Reset counter: 38
Mileage: 267894 km
Time: 03:15:54
Address 47: Sound System Labels: 3C0-035-456.clb
Part No: 1K6 035 456 A
Component: 08K Audioverst. 0005
Revision: 00003000 Serial number: 00000000017377
Part No SW: 1K0 959 702 P HW: 1K0 959 792 L
Component: J387 TUER-SG BT 1127
Revision: 32008001 Serial number: 00000541469030
Coding: 0001204
VCID: 3C2132B5DA69D927D5D-8068
Part No SW: 1K0 035 180 G HW: 1K0 035 180 G
Component: Radio DE2 145 0176
Revision: 00145000 Serial number: VWZ4Z7F2131867
Coding: 0010401
VCID: 2411EAD542D981E78DD-8070
Part No SW: 1K0 959 703 Q HW: 1K0 959 795 J
Component: J388 TUER-SG HL 1115
Revision: 12005001 Serial number: 00000000670782
Coding: 0001168
VCID: 3E2538BDCC75CB37FB9-806A
Component: RDK 0420
Coding: 0100101
Part No SW: 1K0 959 704 Q HW: 1K0 959 794 J
Component: J389 TUER-SG HR 1115
Revision: 12005001 Serial number: 00000000671631
Coding: 0001168
VCID: 3FDB45B9CB7FC23FF0F-806A
00935 - Electric Window Motor; Rear Right (V27)
Fault Status: 00100101
Reset counter: 13
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
VCID: 2D070FF1111340AF523-8078
End----------(Elapsed Time: 01:42, VBatt start/end: 13.8V/14.0V)-----------
