- Joined
- Feb 1, 2017
- Messages
- 134
- Reaction score
- 47
- Location
- Oulu, Finland
- VCDS Serial number
- C?ID=229426
Hey!
Car: Vw Passat CC, 2.0 TDI, MY14
The owner of the car was with another person who had used the OBD11 software in the car. After using the program, lane assist had disappeared from the car. Based on the fault code log, the original coding has been lost.
- How could this original coding sequence be known to make the lane assist function work?
- Is it possible for the car in question to have the tail lights switched on for all light settings? (Nordic countries)
- Can I disable start / stop for that car?
1. Round
2. Round
1. Round
Saturday,22,February,2020,15:00:36:00464
VCDS Version: 19.6.2.2 (x64) HEX-V2 CB: 0.4508.4
Dealer/Shop Name: J.P - V3lmu
VIN: WVWZZZ3CZEE505926 License Plate:
Mileage: 137700km-85562mi Repair Order:
Chassis Type: 3C-VW46 (7N0)
Scan: 01 03 08 09 10 14 15 16 17 18 19 25 2E 37 3C 42 44 46 47 4F
52 53 55 56 61 62 65 69 6C 72 77 A5
VIN: WVWZZZ3CZEE505926 Mileage: 137700km-85562miles
Address 01: Engine (J623-CFGC) Labels: None
Part No SW: 03L 906 018 TL HW: 03L 907 309 AE
Component: R4 2.0l TDI H28 9978
Revision: 41H28--- Serial number: 00000000000000
Coding: 0019003A042401080000
Shop #: WSC 73008 205 00000
ASAM Dataset: EV_ECM20TDI01103L906018TL 003002
ROD: EV_ECM20TDI01103L906018RK.rod
VCID: 074B9B0B8FAD293F88F-8052
4987 - Cylinder 4 Glow Plug Circuit (Q13)
P0674 00 [096] - Electrical Fault
Mileage: 137119 km
Date: 2020.02.09
Time: 12:44:47
Engine speed: 875.00 /min
Normed load value: 43.1 %
Coolant temperature: 45 °C
Intake air temperature: 1 °C
Ambient air pressure: 950 mbar
Voltage terminal 30: 12.240 V
Unlearning counter according OBD: 24
Electric auxiliary heater: shut-off conditions-Bits 0-7: 0
Electric auxiliary heater: relay activation-Bits 0-7: 0
Preheat time: 0 ms
Glow status-Bits 0-7: 0
Glow cycles above temperature threshold-Bits 0-7: 7
Glow cycles above temperature threshold-Bits 0-7: 83
Glow cycles below temperature threshold-Bits 0-7: 0
Glow cycles below temperature threshold-Bits 0-7: 1
Outside air temperature: -0.0 °C
Address 03: ABS Brakes Labels: 3AA-614-109.clb
Part No SW: 3AA 614 109 AP HW: 3AA 614 109 AP
Component: J104 C2 450M V44A 0030
Revision: --H07--- Serial number: 00000007163738
Coding: 0002489
Shop #: WSC 05311 000 00000
VCID: 7BA3F7FBCFE57DDF9C7-802E
Part No SW: 3AA 907 044 BD HW: 3AA 907 044 BD
Component: Climatronic H03 0404
Revision: 00001K01
Coding: 071400C849
Shop #: WSC 00015 115 00000
VCID: 73B3DFDBEB35359FC47-8026
9481988 - Air Quality Sensor
B10AF 04 [008] - Internal System Fault
Reset counter: 80
Mileage: 135750 km
Date: 2020.01.25
Time: 21:41:01
Address 09: Cent. Elect. (J519) Labels:. 3AA-937-087.clb
Part No SW: 3AA 937 087 R HW: 3AA 937 087 R
Component: BCM PQ47 H++ 422 0474
Revision: BD422001
Coding: 000C000000000000008C0088B40011E42355040865202D20E480E72400C9
Shop #: WSC 12345 123 61029
VCID: 49CF5D33D9B91F4F5EB-801C
Subsystem 1 - Part No SW: 3C8 955 119 F HW: 3C8 955 119 F Labels: 1KX-955-119.CLB
Component: WWS464 140513 010 0604
Serial number: 140513
Coding: 00B795
Subsystem 2 - Part No SW: 5Q0 955 547 HW: 5Q0 955 547 Labels: 5Q0-955-547.CLB
Component: RLFS 024 0042
Serial number: Y13M06D20H04M03S22S1
Coding: 0228DD
Address 10: Park/Steer Assist (J791) Labels:| 3AA-919-475.clb
Part No SW: 3AA 919 475 H HW: 4H0 919 475 E
Component: PARKHILFE PLA H06 0026
Revision: -------- Serial number: 56231314100755
Coding: 358207
Shop #: WSC 80093 222 69422
ASAM Dataset: EV_EPHVA2C000000000 002009
ROD: EV_EPHVA2C000000000.rod
VCID: 40D94017EA03DE07895-8014
Address 14: Susp. Elect. (J250) Labels:. 3C0-907-376.clb
Part No SW: 3C0 907 376 A HW: 3C0 907 376
Revision: 00000000 Serial number: 27051300860001
Coding: 010180
Shop #: WSC 05314 000 00000
VCID: 270BFB8B6FED093FA8F-8072
Part No SW: 5N0 959 655 AA HW: 5N0 959 655 AA
Component: J234__70H VW10 HI 2118
Revision: 26019000 Serial number: 003L7PBZV3RY
Coding: 0012360
VCID: 7CA1F4E7CAEB7AE795D-8028
Subsystem 1 - Serial number: 6332MTS616881443
Subsystem 2 - Serial number: 6342MTS651821423
Subsystem 3 - Serial number: 6351HTS6SND52CKJ
Subsystem 4 - Serial number: 6361HTS6RKG52CKR
Address 16: Steering wheel (J527) Labels:| 3C0-953-569.clb
Part No SW: 3C5 953 501 BL HW: 5K0 953 569 T
Component: LENKS.MODUL 016 0140
Revision: FF010042 Serial number: 20130605200689
Coding: 218A270001
VCID: 70B9D0D79A230E87395-8024
Component: E221__MFL-TK6 H07 0022
Coding: E20000
Address 17: Instruments (J285) Labels:| 3C8-920-xxx-17.clb-SRI1
Part No SW: 3C8 920 880 Q HW: 3C8 920 880 Q
Component: KOMBI H04 0611
Coding: 140D00
VCID: 3A2D32FF8CDF84D7C71-806E
Address 18: Aux. Heat Labels: 1K0-815-007.clb
Part No: 7N0 963 272 C
Component: Standheizer 044 4840
Revision: 00044000 Serial number: 09024302000000
Coding: 0031032
VCID: 353721C3A9416BAF2A3-8060
Part No SW: 7N0 907 530 AN HW: 7N0 907 530 AN
Component: J533 Gateway H56 1642
Revision: H56 Serial number: 130613F1000875
Coding: 469006
VCID: 7CA1F4E7C6EB7AE795D-8028
Part No SW: 3AA 959 799 C HW: 3AA 959 799 C
Component: IMMO 090 0407
Revision: 00090000 Serial number: VWZCZ000000000
VCID: 48C95837CEB3E647415-801C
Component: ELV 029 0380
3C0905861J ELV 029 0380
Part No SW: 5N0 035 342 G HW: 5N0 035 342 G
Revision: A1001003 Serial number: 7664905313
Coding: 010100
VCID: 2B0307BB73052D5F4C7-807E
Address 37: Navigation (J0506) Labels:. 1T0-035-680.clb
Part No SW: 1T0 035 686 C HW: 1T0 035 686 C
Component: RNS-MID H09 5238
Revision: AB001001 Serial number: VWZ6Z7N6159082
Coding: 04050002010000A0200F
VCID: 34311CC7AE3B72A71DD-8060
Subsystem 1 - Part No: 1T0 919 859 B
Component: EU West V11 8117
00862 - Antenna for GPS Navigation (R50/R52)
Fault Status: 00100111
Reset counter: 114
Mileage: 128528 km
Date: 2014.03.12
Time: 12:43:11
Part No SW: 3AA 907 566 C HW: 4G0 907 566
Component: J769 SWA MasterH02 0010
Revision: 00H02000 Serial number: 6PZ 010 316-09
Coding: 0000174
VCID: 392F2DF385598FCFCEB-806C
Subsystem 1 - Part No: 3AA 907 568 C
Component: J0770_SWA_Slave_H02 0010
Subsystem 2 - Serial number: 6PZ 010 316-29
Subsystem 3 - Serial number: 5F11.06.1300H02000AMS14130ÿ
Subsystem 4 - Serial number: S14130ÿ
02853 - Warning Lamp for Lane Change Assistance (in left exterior mirror) (K233)
Fault Status: 00101010
Reset counter: 76
Mileage: 135608 km
Date: 2013.01.01
Time: 00:00:00
Part No SW: 3C8 959 701 HW: 3C0 959 793 C
Component: TUER-SG FT 002 0555
Revision: 12110009 Serial number: 0007099389
Coding: 0210FF
Shop #: WSC 05311 115 00000
VCID: 6D87C9A38D11E36F123-8038
Slave Driver:
Subsystem 1 - Part No SW: 3C8 959 703 D HW: 3C8 959 795 Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 004 0501
Serial number: 00000003520518
Coding: 010098
132610 - Motors for Rear Central Locking
B122C 01 [008] - Electrical Failure
Reset counter: 82
Mileage: 135745 km
Date: 2020.01.25
Time: 21:30:23
132866 - Switch for Rear Central Locking
B122E 29 [008] - Signal Implausible
Fault Frequency: 9
Reset counter: 112
Mileage: 135745 km
Date: 2020.01.25
Time: 21:30:24
Part No SW: 5N1 909 144 P HW: 5N1 909 148 J
Component: J500__APA-BS KL.299 1202
Revision: 1BH04737 Serial number: 00131230085201
Coding: 0000258
VCID: 3FDB43EB9B7DA1FFF0F-806A
Address 46: Central Conv. Labels:. 3C0-959-799-46.clb
Component: 09 KESSY PQ47 090 0367
Coding: 00900A0001C60E763604941572004F0B605C0013240798
Subsystem 4 - Part No: 3AA 962 243 B
Component: GEB.F.Heckoef 0810
Address 47: Sound System Labels: 3C0-035-456.clb
Part No SW: 3C8 035 456 G HW: 3C8 035 456 G
Component: DSP 10 Kanal 0100
Revision: 00H03001 Serial number: 75814000128704
VCID: 2C0104A77A0B2A6745D-8078
Part No SW: 7N0 907 532 HW: 7N0 907 530 AN
Component: EZE_2 H56 1642
Coding: 01030108
VCID: 6FBBD3AB879D117F20F-803A
Subsystem 1 - Part No SW: 6R0 959 591 HW: 6R0 959 591
Component: J245/J878 H04 0054
Serial number: 320200040413
Coding: 000006
Subsystem 2 - Part No SW: 3C8 919 204 A HW: 3C8 919 204 A
Component: Analoguhr 005 0004
Part No SW: 3C8 959 702 HW: 3C0 959 792 C
Component: TUER-SG BT 002 0555
Revision: 14110009 Serial number: 0007115793
Coding: 0210FE
VCID: 6E85CEAF801718772B9-803A
Slave Passenger:
Subsystem 1 - Part No SW: 3C8 959 704 D HW: 3C8 959 794 Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 004 0501
Serial number: 00000003507949
Coding: 010098
Part No SW: 3AA 907 801 H HW: 3AA 907 801 H
Component: J540 EPB4 VW-86594 0010
Revision: H19 Serial number: 00000001123128
Coding: 0022167
VCID: 363526CFB44760B7239-8062
Address 55: Headlight Range (J745) Labels:. 5M0-907-357-V3.clb
Part No SW: 5M0 907 357 F HW: 7L6 907 357 C
Component: AFS-ECU H04 0111
Coding: 07B200104F000200
VCID: 372B2BCBBFCD99BF38F-8062
Subsystem 1 - Part No SW: 1T0 941 329 A HW: 1T0 941 329 A Labels: 3D0-941-329.CLB
Component: LeiMo links H06 0007
Coding: 390000
Subsystem 2 - Part No SW: 1T0 941 329 A HW: 1T0 941 329 A Labels: 3D0-941-329.CLB
Component: LeiMo rechts H06 0007
Coding: 390000
Address 56: Radio (J0506) Labels:. 1T0-035-680.clb
Reset counter: 114
Mileage: 128528 km
Date: 2014.03.12
Time: 12:43:11
Part No SW: 7N0 907 534 HW: 7N0 907 530 AN
Component: Batt.regelung H56 1642
Coding: 330F1859
VCID: 71BFD5D391A9078F36B-8024
Component: J367-BDM H07 0180
Serial number: 30158019111491558753
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 3AA 907 273 D HW: 3AA 907 273 D
Component: RDKBERU30 H09 0010
Serial number: 10000000224597
ASAM Dataset: EV_RDKBERU30 003012
ROD: EV_RDKBERU30_003.rod
VCID: 353721C3A5C16BAF2A3-8060
Address 69: Trailer (J345) Labels:. 1K0-907-383-V2.clb
Part No SW: 1K0 907 383 F HW: 1K0 907 383 F
Component: ConWysTrailer H07 0100
Revision: 3A001001 Serial number: 00000132425721
Coding: 0100000100000000
Shop #: WSC 00007 223 174336
VCID: 303910D75A234E87795-8064
Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
Part No SW: 3C8 907 441 HW: 3C8 907 441
Component: J772__Rearview 0040
Revision: 00H11000 Serial number: 525PA8-J348221
Coding: 0020008
VCID: 678BBB8BA36DC93F68F-8032
Address 77: Telephone (J412) Labels:| 3C8-035-730-A.clb
Part No SW: 3C8 035 730 D HW: 3C8 035 730 D
Component: Telefon 022 0946
Revision: -------- Serial number: 35502105016965
Coding: 020100000000000000000101
ASAM Dataset: EV_UHVPremi 002708
ROD: EV_UHVPremi.rod
VCID: 2411EC871E5BE2278DD-8070
9457171 - Right audio channel for speech/telephone
B104E 13 [024] - Short to GND
Intermittent - Confirmed - Not Tested Since Memory Clear
Reset counter: 114
Mileage: 124802 km
Date: 2019.08.12
Time: 18:30:18
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 3AA-980-654.clb
Part No SW: 3AA 980 654 D HW: 3AA 980 654 A
Component: MFK_Gen1 H09 0300
Serial number: 0193669662
Coding: 01010200010202110200040000010000
ASAM Dataset: EV_47X 001639
ROD: EV_47X.rod
VCID: 392F2DF389D98FCFCEB-806C
5701632 - Control Module Incorrectly Coded
U1014 00 [009] - -
[ERR_ECU_WRONG_CODED]
Reset counter: 41
Mileage: 124795 km
Date: 2019.08.12
Time: 18:06:03
End----(Elapsed Time: 02:10, VBatt start/end: 12.1V/12.0V. VIgn 11.9V)-----
2. Round
Saturday,22,February,2020,15:08:21:00464
Mileage: 137700km-85562mi Repair Order: 2. kierros
Coding: 0002489
Revision: 00001K01
Coding: 071400C849
Revision: BD422001
Coding: 00B795
Coding: 0228DD
Coding: 358207
Coding: 010180
Coding: 0012360
Coding: 218A270001
Coding: E20000
Coding: 140D00
Coding: 0031032
Coding: 469006
Coding: 010100
Coding: 0000174
Coding: 0210FF
Slave Driver:
Coding: 010098
Coding: 0000258
Coding: 01030108
Coding: 000006
Coding: 0210FE
Slave Passenger:
Coding: 010098
Coding: 0022167
Coding: 390000
Coding: 390000
Coding: 330F1859
Coding: 0020008
ROD: EV_47X.rod
U1014 00 [009] - -
Reset counter: 74
Mileage: 137707 km
Date: 2020.02.22
Time: 15:00:28
End----(Elapsed Time: 02:05, VBatt start/end: 11.8V/11.8V. VIgn 11.7V)-----
