"No ROD file found"
IWMTom
C?ID=313572
I'm having the same problem as was encountered in this thread after retrofitting a Discover Pro Nav to my Mk7 Golf.
Currently using the latest stable release of VCDS (17.8.1), auto scan as follows:
Friday,29,December,2017,01:18:54:15053
VCDS Version: 17.8.1.0 (x64)  HEX-V2 CB: 0.4401.4
VIN: WVWZZZAUZFW063529   License Plate: NY14EYS
Mileage: 36173km-22476mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 42 44 47 52 5F
VIN: WVWZZZAUZFW063529   Mileage: 36173km-22476miles
47-Sound System -- Status: Cannot be reached 0100
   Part No SW: 04L 906 021 M    HW: 04L 907 309 B
   Component: R4 1,6L EDC   H22 5517
   Revision: 84H22---
   Coding: 01110012034505092000
   ASAM Dataset: EV_ECM16TDI01104L906021M 002009
   ROD: EV_ECM16TDI01104L906021P.rod
   VCID: 2F381B8A979EE0AFF3B-807A
2813 - Accelerator Position Sensor (G79)
          P2122 00 [032] - Signal too Low
                    Mileage: 36092 km
                    Date: 2017.12.28
                    Time: 18:08:46
                    Coolant temperature: 87 °C
                    Intake air temperature: 69 °C
                    Voltage terminal 30: 12.600 V
                    Unlearning counter according OBD: 38
                    Accelerator pedal travel: raw value: 0.00 %
                    Accelerator pedal: sensor voltage 1: 772.0 mV
                    Accelerator pedal: sensor voltage 2: 371.2 mV
                    Accelerator pedal: switch positions-Bit 0: 0
                    Starter control: Interlock- or P/N-signal-Bit 0: 81
                    Limitation: torque: 0.0 Nm
                    Control Module temperature: 20.9 °C
2815 - Accelerator Position Sensor 2 (G185)
          P2127 00 [032] - Signal too Low
                    Mileage: 36092 km
                    Date: 2017.12.28
                    Time: 18:08:46
   Part No SW: 5Q0 907 379 CK    HW: 5Q0 907 379 G
   Component: ESC           H31 0472
   Revision: 00000000    Serial number: 61924000004104
   Coding: 01FA8AA11426096F037C060241CC2580512890C06082A4F3F440F078C002
   VCID: 0748932A5FAE98EF1BB-8052
   Part No SW: 5G0 907 426 Q    HW: 5G0 907 426 Q
   Component: AC Manuell    H02 0907
   Revision: 00001K06
   Coding: 00120104202100001000000000000000
   VCID: 392C25D259DA3E1F5DF-806C
1048834 - Functional Limitation due to Energy Management
          B10CD 00 [008] -  -
                    Reset counter: 160
                    Mileage: 36004 km
                    Date: 2017.12.27
                    Time: 13:09:35
                    Voltage terminal 30: 11.4 V
                    Auxiliary heater: in stages-Enabling for auxiliary heater operation: Enabling stage 1
                    Auxiliary heater: in stages-Act.val.: 1
          P1719 00 [008] - -
                    Reset counter: 160
                    Mileage: 36154 km
                    Date: 2017.12.29
                    Time: 00:45:50
                    Voltage terminal 30: 13.7 V
   Part No SW: 5Q0 937 084 AG    HW: 5Q0 937 084 AG
   Component: BCM MQBAB M   H18 0134
   Serial number: 01011419800065
   Coding: 03000842C241027B0BA44080B10403281000000000000000000000000000
   ROD: EV_BCMBOSCH_013.rod
   VCID: 7DA4F1C20D72C23F317-8028
   Component: WWS    140710  042 0551
   Serial number:         140712045121
   Subsystem 2 - Part No SW: 5Q0 955 559 A    HW: 5Q0 955 559 A  Labels: 5Q0-955-547.CLB
   Component: RLS  037 0059
   Serial number: S3Y14M07D24H06M32S31
   Coding: 00A8DD
   Serial number: 000000000ZY1416330NQ
   Serial number: 00000000000030073175
   Part No SW: 5Q0 919 294 E    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0048
   Revision: --------    Serial number: 39331419901969
   Coding: 0071051001
   VCID: 3D2431C24DF2023F717-8068
   Part No SW: 5Q0 907 572 D    HW: 5Q0 907 572 D
   Component: ACC Bosch MQB H05 0304
   Serial number: 18071476510203
   Coding: 00000300FE0739
   VCID: 382A20D662D02717A21-806C
   Component: AirbagVW20    014 0386
   Serial number: 003MLR0796S.
   VCID: 7F580BCA077ED02F23B-802A
   Belt Pretensioner left:
   Component: BeltPretRevFL  H35 0341
   Serial number: 34169677B18071470845
   Coding: 333135
   Belt Pretensioner right:
   Component: BeltPretRevFR  H35 0341
   Serial number: 34169676B22071441063
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 002 107 14
   Serial number: 357670000009E46DA01%
   Subsystem 4 - Part No SW: -----------    HW: 480 002 107 14
   Serial number: 3586700000079C61301P
   Subsystem 5 - Part No SW: -----------    HW: 480 401 707 14
   Serial number: 3516502BF15F3C32C17N
   Subsystem 6 - Part No SW: -----------    HW: 480 401 707 14
   Serial number: 3526502AB15F3C34C23I
   Subsystem 7 - Part No SW: -----------    HW: 480 401 707 14
   Serial number: 3556502A515F3C328318
   Part No SW: 5Q0 953 507 DD    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 21071404400531
   Coding: 0C00
   ROD: EV_SMLSKLOMQB_009_VW37.rod
   VCID: 7BA0FFDA1366CC0F0F3-802E
   Part No SW: 5G1 920 941     HW: 5G1 920 941
   Component: KOMBI         204 4270
   Coding: 27A51A002780060001883A011400000000000000
   VCID: 6696BEAE78E461E7C0D-8032
   Part No SW: 5Q0 907 530 T    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1188
   Revision: --------    Serial number: 0002258229
   Coding: 030100040B087300EF00005C080F00010001050000000000000000000000
   ASAM Dataset: EV_GatewLear 011016
   ROD: EV_GatewLear_011.rod
   VCID: 42DE423E340C7DC70C5-8016
   Component: E221__MFL-DC1  H16 0038
   Serial number: 27140001791070034295
   Coding: 2CFFFF
   Serial number: 0087543903
          U1101 00 [009] - Active
                    Reset counter: 117
                    Mileage: 36092 km
                    Date: 2017.12.28
                    Time: 18:31:39
                    Supply voltage: Terminal 30: 12.2 V
                    Terminal 15: On
   Serial number: 13071402090651
   Coding: 00110220D001048000001000
   VCID: 40DA48363A006FD71A1-8014
   Serial number: 00000000000003258255
   Coding: 1D0000
   Coding: 8103
   ROD: EV_SteerAssisMQB_010.rod
   VCID: 41DC4D32310A66DF15F-8014
Address 47: Sound System
   Serial number: 12071401100511
   Coding: 00110020DE01048000801000
   VCID: 3FD84BCA47FE102F63B-806A
   Serial number: 00000000000003351145
   Coding: 050000
   Part No SW: 3G0 000 021 D    HW: 3G0 035 021 E
   Component: MU-H-LND-EU   053 0814
   Serial number: A710A0XX002969
   Coding: 02730001FF00000051111101008808101F0207F4012001009F
   Shop #: WSC 00046 000 00000
   ROD: N/A
   VCID: 117CBD7221EAD65FC5F-8044
   Component: ABT_High  H42 0022
   Serial number: VWZ8Z9M23009SW
   Subsystem 2 - Part No SW: V03 959 800 QQ    HW: -----------
   Component: ECE 2017  --- 0157
   Component: Gracenote2---  --- 1015
No ASAM data for: "EV_MUHig6C3Gen2HBAS" (VW37)
23 Faults Found:
1555 - ROD - Unknown Error Code
          - 00 [009]
                    Reset counter: 117
                    Mileage: 1048574 km
                    Time: 00:00:00
13697024 - ROD - Unknown Error Code
          - 00 [009]
                    Reset counter: 109
                    Mileage: 1048574 km
                    Time: 00:00:00
15361024 - ROD - Unknown Error Code
          - 00 [009]
                    Reset counter: 109
                    Mileage: 1048574 km
                    Time: 00:00:00
2571 - ROD - Unknown Error Code
          - 00 [009]
                    Reset counter: 109
                    Mileage: 1048574 km
                    Time: 00:00:00
0512 - ROD - Unknown Error Code
          - 00 [008]
                    Reset counter: 157
                    Mileage: 1048574 km
                    Time: 00:00:00
0513 - ROD - Unknown Error Code
          - 00 [008]
                    Reset counter: 158
                    Mileage: 1048574 km
                    Time: 00:00:00
0517 - ROD - Unknown Error Code
          - 00 [008]
                    Reset counter: 157
                    Mileage: 1048574 km
                    Time: 00:00:00
0518 - ROD - Unknown Error Code
          - 00 [008]
                    Reset counter: 158
                    Mileage: 1048574 km
                    Time: 00:00:00
0522 - ROD - Unknown Error Code
          - 00 [008]
                    Reset counter: 157
                    Mileage: 1048574 km
                    Time: 00:00:00
0523 - ROD - Unknown Error Code
          - 00 [008]
                    Reset counter: 158
                    Mileage: 1048574 km
                    Time: 00:00:00
0527 - ROD - Unknown Error Code
          - 00 [008]
                    Reset counter: 157
                    Mileage: 1048574 km
                    Time: 00:00:00
0528 - ROD - Unknown Error Code
          - 00 [008]
                    Reset counter: 158
                    Mileage: 1048574 km
                    Time: 00:00:00
1637 - ROD - Unknown Error Code
          - 00 [009]
                    Reset counter: 117
                    Mileage: 36092 km
                    Date: 2017.12.28
                    Time: 18:32:39
3073 - ROD - Unknown Error Code
          - 00 [009]
                    Reset counter: 109
                    Mileage: 1048574 km
                    Time: 00:00:00
3084 - ROD - Unknown Error Code
          - 00 [009]
                    Reset counter: 109
                    Mileage: 1048574 km
                    Time: 00:00:00
2565 - ROD - Unknown Error Code
          - 00 [009]
                    Reset counter: 109
                    Mileage: 1048574 km
                    Time: 00:00:00
6720 - ROD - Unknown Error Code
          - 00 [009]
                    Reset counter: 120
                    Mileage: 36092 km
                    Date: 2017.12.28
                    Time: 19:13:48
5681 - ROD - Unknown Error Code
          - 00 [009]
                    Reset counter: 109
                    Mileage: 1048574 km
                    Time: 00:00:00
1564 - ROD - Unknown Error Code
          - 00 [008]
                    Reset counter: 160
                    Mileage: 1048574 km
                    Time: 00:00:00
6666 - ROD - Unknown Error Code
          - 00 [009]
                    Reset counter: 109
                    Mileage: 1048574 km
                    Time: 00:00:00
7193 - ROD - Unknown Error Code
          - 00 [009]
                    Reset counter: 117
                    Mileage: 36092 km
                    Date: 2017.12.28
                    Time: 18:31:57
7194 - ROD - Unknown Error Code
          - 00 [009]
                    Reset counter: 117
                    Mileage: 36092 km
                    Date: 2017.12.28
                    Time: 18:31:57
7201 - ROD - Unknown Error Code
          - 00 [009]
                    Reset counter: 117
                    Mileage: 36092 km
                    Date: 2017.12.28
                    Time: 18:31:57
End----------(Elapsed Time: 01:47, VBatt start/end: 12.2V/12.2V)-----------
Thanks in advance <3
PetrolDave
Westbury, UK
C?ID=1423
Have you tried the 17.12.0 beta?
IWMTom
C?ID=313572
I figured that if the problem was supposed to have been resolved in 17.3.1 as per the linked thread, then the beta wouldn't be necessary - nevertheless, I installed the 17.12.0 beta and experienced the same issue.
The error is "Unable to find a .ROD file for: EV_MUHig6C3Gen2HBAS 001115 (VW37)".
i've had a look inside the UDS_EV folder and whilst there are similar names (infact, matching EV_MUHig6C3Gen2HBAS), there are none ending in VW37, only the following:
This is the same for both the standard and beta installations. I'm stumped!
EDIT: It would seem in the final auto-scan of the linked thread, the user is running on the AU37 version of the .ROD file successfully - am I to just copy this and rename it to end VW37? I presume since it worked for that user, it may work for myself? Still though, why has VCDS not picked up on this?
EDIT 2: I tried copying and pasting the AU37 version and renaming it to be the VW37 and still received the same error - I can only presume that inside the file, there is some form of naming scheme that VCDS reads, so changing the filename alone doesn't help anything.
EDIT 3: Looking at the differences in auto-scan data between mine and the other users, I believe the reason VCDS isn't picking up the fix that was done for the other user is due to the difference in component identifier; although the two parts are very similar, my component is MU-H-LND-EU and theirs was MU-H-ND-EU.
Not finding a ROD file is not unusual when modules that don't belong in a particular car get retrofit. I'm confident we can make a work-around for this once we're back in the office next week.
However, there's something that strikes me as puzzling/wrong here: Part No SW: 3G0 000 021 D. That just doesn't seem right at all.
IWMTom
C?ID=313572
I agree, it does seem a bit bizarre - it could be perhaps due to how the seller of the retrofit kit has modified the unit to bypass the component protection?
The unit is fully operational, only I can't code it to activate the USB module, and remove the reference to the sound system module (it doesn't have one!). I believe the unit was sourced from an R-Line vehicle judging by the start up screen.
So you reckon this can be resolved? :)
Ooo, could you verify my forum account too please? I registered my cable today, same email.
Thanks in advance!
IWMTom
C?ID=313572
Happy new year! Just flagging this up so y'all can pop this issue on your job queue :)
It might take us a few days to get caught up from our holiday break. Please feel free to bump again if you haven't heard anything toward the end of the week.
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Long story short, Uwe has already pointed towards the culprit. The part number being off is part of the problem, this specific ASAM ID is not present in the VW37 platform and the Component ID doesn't match the part number (3G0-035-021-* should be MU-H-TND-EU, while MU-H-LND-EU should be 3G0-035-022-*) which begs the question what the heck did you purchase there?! I certainly would not want to have that in my car for several reasons, especially not if I ever plan to take the car to a dealer or resell it - ever.
As Uwe indicated, we could add a workaround - though with this totally self induced situation I am tempted to reject that approach due to legal concerns. I will however leave the final decision to Uwe, once I got the go ahead - it gets taken care of.
IWMTom
C?ID=313572
I purchased the retrofit kit from VagTec UK, for which they've provided a component protection removed (modified) MIB2 Discover Nav Pro unit (brain and display).
I'd imagine the modified software is what's playing havoc here, but I'll give them a bell and ask what's going on. They've got a decent reputation from what I can see, so am not sure what's happened here.
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Besides the legal implications of a component protection removal, from what I see the issues we are having here are NOT related. Some data indicated that this may have been an Audi unit that was re-programmed with some but not all VW information - due to the (in my opinion) Frankenstein way of programming, VCDS cannot make any sense of the data at hand (and nor would the factory tool).
Anyway, workaround implemented - will be part of the next data version/update.
IWMTom
C?ID=313572
I don't disagree with you, this certainly does seem a really obscure issue - I've spoken to someone at VagTec and he doesn't seem to know what the problem is either - I believe VagTec UK just buy the stock in from the Poland main company as they're just a franchisee, so I don't think they know too much about what goes down in terms of unit modification.
Thanks for your hard work guys, you really do some good stuff! Any idea when the next update will be pushed?
IWMTom
C?ID=313572
Do you have any idea when the next update will appear?
IWMTom
C?ID=313572
Back in January when I was having this issue, I was able to code my unit using the "PCI" German version of VCDS, however the English version still wouldn't work.
I've recently scanned my car and found that since updating to the new version, neither the German nor English version of VCDS can understand my unit, quoting the same issue.
Has the workaround been removed? For your reference, it's spitting out "No ASAM data for: "EV_MUHig6C3Gen2HBAS" (VW37)" due to the software part number being wrong (still no idea why!).
Thanks in advance :)
Sebastian
Magdeburg, Germany
HN0-nnnnnn
We're about to publish a new version, please check the download page within the next couple of days and let us know if this is fixed with the upcoming update.
IWMTom
C?ID=313572
Will do, thanks mate :)
IWMTom
C?ID=313572
I've tried the new version, and I'm still getting the same issue. This was working back in January on the German version as advised previously (and still does on the copy I have on version 17.8.1), however my interface isn't licensed to use it any longer, so I cannot run an adaptation.
Fresh autoscan attached:
Saturday,19,May,2018,15:40:39:15053
VCDS Version: 18.2.1.2 (x64)  HEX-V2 CB: 0.4411.4
Mileage: 45968km-28563mi   Repair Order: 1
Scan: 01 03 08 09 10 13 15 16 17 19 42 44 52 5F 6C
VIN: WVWZZZAUZFW063529   Mileage: 45968km-28563miles
   Revision: 84H22---
   VCID: 2F381B8A979EE0AFD8D-807A
   Revision: 00000000    Serial number: 62386000000027
   VCID: 0748932A5FAE98EF30D-8052
   Revision: 00001K06
   ROD: EV_ACManueBHBVW37X_003_VW37.rod
   VCID: 392C25D259DA3E1F769-806C
   VCID: 7DA4F1C20D72C23F1A1-8028
   Coding: 00A8DD
   Coding: 0071151001
   ROD: EV_EPHVA18AU3700000_002_VW27.rod
   VCID: 3D2431C24DF2023F5A1-8068
   VCID: 382A20D662D02717897-806C
   VCID: 7F580BCA077ED02F08D-802A
   Coding: 333135
   Coding: 333135
   Coding: 0C00
   ROD: EV_SMLSKLOMQB_013_AU37.rod
   VCID: 7BA0FFDA1366CC0F245-802E
   Coding: 27A51A002780260001887A011400000000000000
   Shop #: WSC 12345 102 209715
   VCID: 6696BEAE78E461E7EBB-8032
   ROD: EV_GatewLear_011_VW37.rod
   VCID: 42DE423E340C7DC7273-8016
   Coding: 2CFFFF
                    Reset counter: 1
                    Mileage: 45794 km
                    Date: 2018.05.17
                    Time: 18:18:31
                    Supply voltage: Terminal 30: 12.0 V
                    Terminal 15: On
   VCID: 40DA48363A006FD7317-8014
   Coding: 1D0000
   Coding: 8103
   VCID: 41DC4D32310A66DF3E9-8014
   VCID: 3FD84BCA47FE102F48D-806A
   Coding: 050000
   Coding: 02730001FF00000051111101008808001F0404D40120010097
   Shop #: WSC 00046 123 12345
   ROD: N/A
   VCID: 117CBD7221EAD65FEE9-8044
          - 00 [009]
                    Reset counter: 1
                    Mileage: 45794 km
                    Date: 2018.05.17
                    Time: 18:13:08
15360512 - ROD - Unknown Error Code
          - 00 [009]
                    Reset counter: 1
                    Mileage: 45794 km
                    Date: 2018.05.17
                    Time: 18:13:03
          - 00 [009]
                    Reset counter: 1
                    Mileage: 45794 km
                    Date: 2018.05.17
                    Time: 18:13:03
   Coding: 01730201C2002017000040
10489856 - No Basic Setting
          B2010 00 [009] -  -
          [RearView system not calibrated]
                    Reset counter: 3
                    Mileage: 45968 km
                    Date: 2018.05.18
                    Time: 19:41:45
                    passive
13705478 - Databus
          [message Parkhilfe_01 not received]
                    Reset counter: 3
                    Mileage: 45968 km
                    Date: 2018.05.18
                    Time: 19:41:46
                    passive
End----------(Elapsed Time: 01:41, VBatt start/end: 12.2V/12.2V)-----------
Thanks again.
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Problem found, the fix was accidentally removed during a related change. Fixed permanently now, I'll make a revised version/update available next week.
IWMTom
C?ID=313572
Thanks for the swift response, glad to hear you've found it!
I'll let you know how I get on when the new update is out :)
