Retrofit Cruise control (B7 A4)
tiagmt
New Member
Portugal
Hello, i own a 2005 A4 Avant 2.0tdi b7, it have steering wheel with multifunction, phone and voice and the module is 8E0 953 549 Q . After installed the Cruise Control handle 4E0 953 521B, i did both coding on engine activation and steering chose the Cruise Control bit.
It doesnt work and give me This faults:
00895 Cruise control Distance 37-00 and the fault 18107 on engine.
O dont know if i was supposed to do some wiring modifications...
Hope someone can help,
Best retards,
Tiago
PetrolDave
Westbury, UK
C?ID=1423
Please post a full unedited VCDS Auto-Scan of your B7 A4.
I've done several CC retrofits on the B7 and never had to make any wiring changes.
Did you make sure that both the SWSM supports cruise (not all do on the B7) and that the cruise switch was in the off position when you did the coding/activation changes?
tiagmt
New Member
Portugal
Thanks you for response, how can i post picture?
Also, i think that the Cruise Control wasnt on off position when i did coding.
Can i disable everithing then enable again with the Cruise off?
What is the swsm? Is the SMLS?
Regards
