Understanding VCDS measuring values for DPF troubleshooting
witchcraftz
Canada
HC437830 (2nd hand?)
I cannot for sure say what caused my DPF problem, the vehicle was purchased damaged and rebuilt.
At the time of purchase there were no CEL/errors, after rebuild was completed and the vehicle delivered it immediately started showing this error.
I haven't even insured it or driven it very far except for twice just for 15-20 min at speed (with temp insurance) to try to get the engine to perform a regen.
It seems to drive fine for now.
When the DPF light+CEL came on. I tested it in vagcom and it read:
soot measured = 0.12
soot calculated = 40
So I tried a forced regen (as pers VDS procedure) but it wouldn't go, and after I got:
soot calculated = 60
Considering it went from no CEL to crazy plugged in 154 km (according to the logged data) I'm not sure what to think.
Can someone please educate me on what values I should be reading and checking to see if the DPF is really plugged?
Here are some logged values
DPF values at engine RPM 2000
IDE00433 Particle filter: oil ash volume 0.03 l
IDE00434 Particle filter: soot mass calculated 60.00 g
IDE00435 Particle filter: soot mass measured 0.35 g
IDE04092 Diesel particle filter bank 1 3.40/---/--- kPa
IDE04652 Exhaust gas jet volume in particle filter 131.1 m³/h
IDE05357 Current temperature in NOx reducing catalytic converter 51.4 °C
IDE07744 Particle filter: air pressure sensor 1 bank 1: raw value 34 hPa
IDE07747 Particle filter: differential pressure sensor 1 bank 1: offset 2 hPa
Engine Idle
IDE00167 Exhaust temperature 1 bank 1 108.2 °C
IDE00169 Exhaust temperature 2 bank 1 59.8 °C
IDE00347 Air mass: actual value: 13.24 g/s
IDE00350 Air mass: specified value 250.0 mg/stroke
IDE04045 Exhaust gas pressure EP1:0.26 kPa
IDE04090 Exhaust temperature bank 1 S1/S2/S3/S4: / 134/105/79/49 °C
IDE04468 Air mass at air mass meter 1 48.5 kg/h
IDE07801 Mass airflow sensor 1 bank 1 airflow: raw value 533.1 mg/stroke
IDE04045 Exhaust gas pressure EP1:0.24 kPa
IDE04092 Diesel particle filter bank 1 1.30/---/--- kPa
IDE04652 Exhaust gas jet volume in particle filter 49.7 m³/h
IDE04653 Simulated particle filter surface temperature 21.0 °C
IDE07716 Particle filt.inlet temp.sens.1 bank 1: raw value 41.3 °C
IDE07718 Particle filter outlet temp.sens.1 bank 1: raw value 19.4 °C
IDE07744 Particle filter: air pressure sensor 1 bank 1: raw value 13 hPa
IDE07745 Particl.filt.: different.press.sensor 1 bank 1: adaptat. value 13 hPa
IDE07748 Particl.filt.: differential pressur.sensor 1 bank 1: dyn.offset 0 hPa
2000 RPM
IDE00167 Exhaust temperature 1 bank 1 107.3 °C
IDE00169 Exhaust temperature 2 bank 1 62.9 °C
IDE00347 Air mass: actual value: 38.97 g/s
IDE04045 Exhaust gas pressure EP1:0.89 kPa
IDE04090 Exhaust temperature bank 1 S1/S2/S3/S4: / 152/115/82/50 °C
IDE04468 Air mass at air mass meter 1 135.5 kg/h
IDE07801 Mass airflow sensor 1 bank 1 airflow: raw value 588.8 mg/stroke
IDE04045 Exhaust gas pressure EP1:0.84 kPa
IDE04652 Exhaust gas jet volume in particle filter 141.0 m³/h
IDE04653 Simulated particle filter surface temperature 32.1 °C
IDE07716 Particle filt.inlet temp.sens.1 bank 1: raw value 55.6 °C
IDE07718 Particle filter outlet temp.sens.1 bank 1: raw value 30.9 °C
IDE07744 Particle filter: air pressure sensor 1 bank 1: raw value 32 hPa
IDE07745 Particl.filt.: different.press.sensor 1 bank 1: adaptat. value 32 hPa
And full autoScan
Chassis Type: AU (5Q0)
Scan: 01 02 03 08 09 15 16 17 19 42 44 52 5F 75
VIN: Mileage: 57759km-35889miles
5F-Information Electr. -- Status: Malfunction 0010 (I recently disconnected the battery so suspect that is what caused this error)
Address 01: Engine (J623-CRUA) Labels: 04L-907-309-V1.clb
Part No SW: 04L 906 021 D HW: 04L 907 309
Component: R4 2,0L EDC H23 8278
Revision: 85H23---
Coding: 011D0012032410080000
Shop #: WSC 48433 001 1048576
ASAM Dataset: EV_ECM20TDI01104L906021D 001013
ROD: EV_ECM20TDI01104L906021D.rod
VCID: 2649DBDD59710172E6-8072
5188 - Diesel Particle Filter
P2463 00 [167] - Excessive Soot Accumulation
Mileage: 57759 km
Date: 2016.11.20
Time: 20:53:25
Coolant temperature: 26 °C
Intake air temperature: 21 °C
Voltage terminal 30: 11.860 V
Counter for regeneration time of diesel particle filter: 0.00 s
Particle filter: kilometers since last regeneration: 155077 m
Particle filter: soot mass measured: 0.62 g
Particle filter: soot mass calculated: 60.00 g
Particl.filt.: differential pressur.sensor 1 bank 1: dyn.offset: 2 hPa
Readiness: 0 0 0 1 1
Part No SW: 0D9 300 041 N HW: 02E 927 770 AQ
Component: DQ250-6F MQB H52 4506
Revision: 03252204 Serial number: TFK01404171357
Shop #: WSC 00066 790 00221
ROD: EV_TCMDQ250021.rod
VCID: 234FC2C92A43F45A81-8076
Part No SW: 5Q0 907 379 K HW: 5Q0 907 379 F
Component: ESC H31 0371
Revision: 00000000 Serial number: 51664000000032
Coding: 01FA6AA124210973007E020381C42580562490004081A4B200 630050C002
Shop #: WSC 01383 790 50316
VCID: 448D6155CF0DD362D8-8010
Address 08: Auto HVAC (J301) Labels: 5G0-907-426.clb
Part No SW: 5G0 907 426 Q HW: 5G0 907 426 Q
Component: AC Manuell H02 0907
Revision: 00001K06
Coding: 00020104200100000000000000000000
ROD: EV_ACManueBHBVW37X_SK48.rod
VCID: 397300A1B8CF9E8ABB-806C
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-BV1.clb
Part No SW: 5Q0 937 087 M HW: 5Q0 937 087 M
Component: BCM PQ37BOSCH 028 0106
Revision: -------- Serial number: 86582405140399
Coding: 000018424041804169E4400000040300100000000000000000 0000000000
Shop #: WSC 00066 790 00195
ASAM Dataset: EV_BodyContrModul1UDSBosc 013005
ROD: EV_BCMBOSCH_013.rod
VCID: 458B7C51C437EA6ACF-8010
Subsystem 1 - Part No SW: 5GM 955 119 HW: 5GM 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 140628 043 0581
Serial number: 140720182857
Part No SW: 5Q0 959 655 T HW: 5Q0 959 655 T
Component: AirbagVW20 009 0825
Serial number: 003MHM00HW3U
VCID: 51A35801007F36CA63-8004
Occupant Detection:
Subsystem 1 - Part No SW: 4M0 959 339 A HW: 4M0 959 339 A
Component: BF-Gewichtss. H05 0016
Serial number: IBH0000J14000100PW0%
Coding: 30325A
Subsystem 2 - Part No SW: ----------- HW: 480 002 105 14
Serial number: 357000000009FC05CF0/
Subsystem 3 - Part No SW: ----------- HW: 480 002 805 14
Serial number: 35800000000FFCC4EF0H
Subsystem 4 - Part No SW: ----------- HW: 480 402 205 14
Serial number: 35100029B15C4213B05W
Subsystem 5 - Part No SW: ----------- HW: 480 402 205 14
Serial number: 3520002AB15C4211410L
Subsystem 6 - Part No SW: ----------- HW: 480 401 006 14
Serial number: 3550002A51617D24C06$
Front Sensor Passenger:
Subsystem 7 - Part No SW: ----------- HW: 480 401 006 14
Serial number: 3560002A31617D24B38%
Address 16: Steering wheel (J524) Labels: 5Q0-953-549.clb
Part No SW: 5Q0 953 521 P HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0155
Revision: FF028028 Serial number: 20140529400177
Coding: 0410
Shop #: WSC 66564 385 16448
ROD: EV_SMLSVALEOMQB.rod
VCID: 3F876EB9A6EBB0BA85-806A
Part No SW: 5G1 920 841 HW: 5G1 920 841
Component: KOMBI 243 4270
Coding: 0BB51A0A2180CF0502096A001000000000000000
VCID: 65CB9CD164F7CA6A2F-8030
Part No SW: 5Q0 907 530 S HW: 5Q0 907 530 L
Component: GW MQB Mid 211 2186
Revision: -------- Serial number: 28061410000015
Coding: 0101000800087300EF0000081C0F0000000105000000000000 0000000000
Shop #: WSC 00066 790 07027
ROD: EV_GatewConti_011.rod
VCID: 41836841D01FC64AF3-8014
Subsystem 2 - Part No SW: 5G0 959 442 P HW: 5G0 959 442 P
Component: E221__MFL-DC1 H14 0101
Serial number: 29140000966250074201
Coding: 29FFFF
Part No SW: 5Q0 959 393 B HW: 5Q0 959 393 B
Component: TSG FS 020 0025
Serial number: 280614060505BJ
Coding: 003003200000040000000000
VCID: 3E7913BDA1E1B9B28E-806A
Subsystem 1 - Part No SW: 5Q0 959 811 A HW: 5Q0 959 811 A
Serial number: 00000000000002898130
Coding: 011000
Part No SW: 5Q0 909 144 P HW: 5Q0 909 144 P
Component: EPS_MQB_ZFLS 122 1043
Coding: 0102
ROD: EV_SteerAssisMQB_010.rod
Part No SW: 5Q0 959 392 B HW: 5Q0 959 392 B
Component: TSG BFS 020 0025
Serial number: 23061406050330
VCID: 3D7B14B1ACE7A2AA97-8068
Subsystem 1 - Part No SW: 5Q0 959 812 A HW: 5Q0 959 812 A
Serial number: 00000000000002868483
Coding: 191000
Address 5F: Information Electr. (J794) Labels: 5G0-035-MIB-STD1.clb
Part No SW: 5G0 035 844 HW: 5G0 035 844
Component: MU-S-S-US 014 0645
Serial number: V7B00406142418
Coding: 02730000FF00000021220001001800001F0100040100010002
ROD: EV_MUStd4CPASE_VW37.rod
VCID: 64CD81D56FCDB36238-8030
Subsystem 1 - Part No SW: 5G0 919 605 H HW: 5G0 919 605 H
Component: ABT_Std_Plus H60 0030
Serial number: VWZ8Z9PS500AMD
B11CF 53 [009] - Deactivated
Reset counter: 87
Mileage: 57759 km
Date: 2016.11.20
Time: 20:53:29
Voltage terminal 30: 11.8 V
Address 75: Telematics (J949) Labels: 5QE-035-285.clb
Part No SW: 5QE 035 285 HW: 5QE 035 285
Component: OCULowMQBUS 006 0528
Shop #: WSC 00066 790 00208
ROD: EV_OCULowMQB.rod
VCID: 0201A74D95991D52AA-8056
End-------------------------(Elapsed Time: 03:23)--------------------------
Hmm..
Measuring Values:
Freeze-Frame:
The measured values seem really low. I wonder if VCDS is misplacing the decimal on that?
What procedure did you use? I'm thinking the one at the bottom of this page would be the correct one.
witchcraftz
Canada
Yes, I did the one at the bottom, really no choice as none of the others have the correct menu options.
Went for an oil change and then a 20 min drive at 90-120 km/h
The car feels slow to get to speed, and kind of sluggish, but maybe that is the normal acceleration because I'm used to my old tuned stage 3.5 MK4 TDI?
Values were very similar at then end as to what was there before the drive.
Soot Measured dropped to 0.37
Soot Calculated stayed at 60
Here is a short log I did going around the block right after.
CSV file link
Monday21November201613:26:37:38412-VCID:2649DBDD59710172E6-8072VCDS Version: Release 16.8.3 (x64)Data version: 20161010 DS267.0
04L 906 021 DADVMBR4 2.0L EDC H23 8278
G092F0G093F0G094F0G303F0G320F0G321F0G537F0G539F0G557F0G560F0G000F0G000F0
MarkerTIMELoc. IDE00434TIMELoc. IDE00435TIMELoc. IDE00436TIMELoc. IDE04092TIMELoc. IDE04652TIMELoc. IDE04653TIMELoc. IDE07716TIMELoc. IDE07718TIMELoc. IDE07744TIMELoc. IDE07747
STAMPParticle filter: soot mass calculatedSTAMPParticle filter: soot mass measuredSTAMPParticle filter: kilometers since last regenerationSTAMPDiesel particle filter bank 1STAMPExhaust gas jet volume in particle filterSTAMPSimulated particle filter surface temperatureSTAMPParticle filt.inlet temp.sens.1 bank 1: raw valueSTAMPParticle filter outlet temp.sens.1 bank 1: raw valueSTAMPParticle filter: air pressure sensor 1 bank 1: raw valueSTAMPParticle filter: differential pressure sensor 1 bank 1: offset
g g m kPa m³/h °C °C °C hPa hPa
1.05601.260.371.482203511.650.10/---/---1.8800.01147.80.191070.485.40.6310.853
3.13603.340.373.542203513.690.10/---/---3.902.1147.82.291072.4985.42.6912.93
5.2605.410.375.632203515.80.10/---/---5.9904.13147.74.351074.5485.34.7614.983
7.27607.480.377.692203517.850.40/---/---8.0562.86.19147.86.4106.96.6385.36.8517.063
9.36609.550.379.762203519.931.50/---/---10.13458.26125.38.481078.6986.78.9159.123
11.426011.630.3711.8522035111.991.30/---/---12.2142.510.35128.410.55108.110.7694.310.981411.23
13.486013.70.3713.9222035114.081.30/---/---14.2944.512.41131.112.63109.512.8599.913.051313.263
15.556015.760.3715.9822035116.141.50/---/---16.3845.914.49133.214.711114.9110515.131415.353
17.676017.880.3718.1122035118.251.50/---/---18.4648.616.6134.716.81112.317.02109.317.231517.453
19.716019.920.3720.1322035120.31.50/---/---20.547.818.67136.218.88113.819.1113.319.31519.513
21.786021.990.3722.222035122.361.50/---/---22.5848.320.71137.220.9211521.13116.921.361521.563
23.876024.080.3724.2822035124.431.50/---/---24.6548.222.78138.322.99116.123.2120.423.421523.643
25.956026.170.3726.3822035126.561.50/---/---26.7448.424.8813925.11117.125.31123.625.521525.733
28.16028.310.3728.5222035128.671.50/---/---28.8848.726.95139.627.1711827.39126.427.641527.873
30.176030.380.3730.6122035130.751.50/---/---30.9650.129.1140.129.31118.729.53128.929.741529.953
32.246032.450.3732.6722035132.831.50/---/---33.0450.131.17140.331.38119.231.613131.811532.033
34.316034.530.3734.7422035134.891.50/---/---35.1351.233.24140.533.45119.833.67132.933.881534.113
36.396036.630.3736.8522035136.981.50/---/---37.250.535.35140.435.56120.135.77134.635.981536.183
38.536038.740.3738.9422035139.111.50/---/---39.3350.337.42140.237.64120.437.88135.938.11538.313
40.636040.850.3741.0622035141.221.50/---/---41.4349.739.53140.139.74120.739.94137.240.171540.393
42.76042.910.3743.1222035143.31.50/---/---43.494941.64139.741.88120.942.1138.242.291542.493
44.796044.990.3745.222035145.361.50/---/---45.5949.843.7139.443.92121.244.1313944.381544.613
46.856047.030.3747.2322035147.391.50/---/---47.6248.645.7813945.98121.446.19139.846.391546.633
48.886049.120.3749.3522035149.481.50/---/---49.695047.85138.648.03121.748.24140.548.461548.673
50.966051.170.3751.3822035151.571.50/---/---51.7848.449.89138.250.13121.950.36141.150.531550.743
53.086053.270.3753.4922035153.651.50/---/---53.8748.751.99137.752.21122.252.42141.652.631552.863
55.136055.370.3755.6122035155.731.50/---/---55.9448.854.1137.354.28122.454.4914254.711554.923
57.216057.430.3757.6322035157.821.50/---/---58.0347.656.14136.856.37122.756.6142.456.781556.993
59.356059.530.3759.7422035159.911.50/---/---60.1248.658.25136.358.46122.958.67142.758.881559.123
61.386061.620.3761.8522035161.981.50/---/---62.1947.560.36135.960.53123.160.7414360.961561.173
63.466063.670.3763.8822035164.071.40/---/---64.2847.862.39135.562.62123.362.86143.363.031563.243
65.66065.780.3765.9922035166.161.40/---/---66.3746.664.4913564.71123.464.92143.465.131565.373
67.636067.870.3768.122035168.241.50/---/---68.4469.766.6134.666.78123.666.99143.667.211467.423
69.716069.920.3770.1322035170.322.00/---/---70.5374.468.64133.968.87123.769.1143.869.291869.53
71.846072.040.3772.2522035272.412.00/---/---72.6272.970.74133.370.96123.971.17144.171.382071.613
73.896074.120.3774.3522035474.482.00/---/---74.6972.672.85132.873.03124.173.24144.373.462073.683
75.946076.150.3776.3722035676.552.00/---/---76.7471.774.89132.475.12124.275.35144.675.532075.743
78.046078.250.3778.4622035878.631.90/---/---78.8560.276.9613277.18124.477.39144.877.622077.863
80.126080.350.3780.5322035880.691.80/---/---80.898979.04131.979.25124.579.4614579.681779.893
82.186082.40.3782.6222036182.83.60/---/---82.99148.181.12131.181.35124.781.5414581.752881.963
84.296084.50.3884.7122036984.881.80/---/---85.15683.21130.483.43125.383.64145.383.863184.093
86.376086.610.3886.7922037686.951.70/---/---87.167085.2913185.51125.985.72145.485.931786.153
88.486088.690.3888.922038389.072.70/---/---89.27103.687.38130.587.62126.387.85145.488.042588.263
90.546090.760.3890.9822039391.142.80/---/---91.37108.589.47130.189.68127.289.89145.290.122790.363
92.646092.870.3993.122040493.242.20/---/---93.4468.191.61129.991.79128.792.01145.192.222892.433
94.756094.960.3995.1822041395.352.80/---/---95.55107.993.64129.993.88130.194.1214594.362794.543
96.856097.040.3997.2622042597.433.70/---/---97.63128.895.76129.795.9813296.19144.696.43096.633
98.96099.130.3999.3522043899.493.60/---/---99.69143.797.85129.898.04134.698.26144.298.483498.693
100.9860101.190.4101.4220453101.573.60/---/---101.77133.399.9130100.12137.5100.35143.9100.5438100.763
103.0460103.260.4103.48220468103.643.40/---/---103.87127.6101.98130.4102.19140.7102.4143.4102.6235102.853
105.1560105.380.41105.6220482105.743.20/---/---105.94118.9104.1130.9104.29143.8104.51142.8104.7332104.943
107.2360107.440.41107.65220495107.822.90/---/---108.02105.1106.15131.5106.38146.8106.61142106.7931107.013
109.2960109.510.42109.73220504109.892.30/---/---110.1371108.22131.9108.43149.3108.65141.4108.8727109.113
111.460111.620.42111.84220512111.991.70/---/---112.1957.1110.35132.5110.54151.2110.76140.5110.9818111.193
113.4860113.70.42113.91220519114.072.70/---/---114.27109.4112.4132.6112.62152.1112.86139.9113.0420113.263
115.5560115.760.42115.98220529116.144.40/---/---116.37153.7114.47132.9114.68152.9114.9139.2115.1335115.363
117.6560117.880.42118.1220543118.243.70/---/---118.44182.1116.59134116.79153.3117.01138.5117.2339117.443
119.7360119.950.42120.16220560120.337.50/---/---120.54297.5118.65135.3118.88153.2119.1138.4119.358119.513
121.8560122.040.42122.26220582122.4310.10/---/---122.63360.8120.76137.4120.98153.7121.2138.5121.4290121.633
123.960124.130.43124.36220607124.510.00/---/---124.71251.9122.86140.2123.05157.4123.26138.8123.48107123.693
125.9860126.190.44126.4220635126.583.90/---/---126.79151.3124.91143.1125.12163.1125.35139.5125.5652125.773
128.160128.310.45128.52220660128.673.80/---/---128.88138.7127.01144.4127.23167.2127.44139.6127.6539127.883
130.1560130.370.45130.6220682130.743.30/---/---130.96117.6129.11145.4129.3170129.51139.5129.7336129.943
132.2360132.450.45132.66220702132.822.70/---/---133.0495.2131.17146.3131.38171.7131.61139.1131.8130132.023
134.3160134.520.46134.73220718134.92.20/---/---135.1275.6133.24147133.44172133.65138.7133.8824134.13
136.3860136.610.46136.81220731136.961.70/---/---137.1859.2135.36147.4135.55171.7135.76138.3135.9619136.163
138.4560138.660.46138.88220743139.061.70/---/---139.2460.9137.38147.8137.6170.7137.8137.8138.0117138.233
140.5160140.710.46140.92220750141.071.80/---/---141.2963.8139.45148139.66169.3139.88137.5140.117140.33
142.5660142.780.46142.99220754143.141.70/---/---143.3852.3141.49148.2141.7167.8141.91137.1142.1318142.353
144.6760144.880.46145.11220754145.251.50/---/---145.4650143.61148.5143.81165.9144.02136.8144.2315144.453
146.7360146.950.46147.17220754147.321.50/---/---147.5450.3145.67148.6145.88163.7146.1136.6146.3115146.523
148.8160149.020.46149.23220754149.394.20/---/---149.63219.3147.74148.9147.95161.6148.16136.6148.3818148.63
150.9260151.130.46151.36220762151.499.70/---/---151.71375.4149.86149.1150.06159150.27137.3150.4864150.73
152.9960153.20.46153.42220777153.577.70/---/---153.79240.7151.92150.5152.13155.8152.35140152.56117152.783
155.0660155.270.47155.48220797155.649.40/---/---155.88349153.99151.8154.2154.4154.42142.8154.6375154.863
157.1460157.370.47157.59220821157.7111.10/---/---157.93396.4156.1152.1156.29156.7156.49145.2156.7107156.923
159.260159.420.48159.63220848159.86.30/---/---159.99224.2158.13153158.36162.3158.55148158.7792158.993
161.3160161.530.48161.74220878161.897.20/---/---162.13265.3160.2154.2160.42167.9160.64149.7160.8865161.13
163.3960163.630.48163.852209111646.60/---/---164.21192.9162.35155.6162.54173.4162.74151.4162.9578163.173
165.560165.720.49165.92220945166.083.70/---/---166.29188.1164.42157.9164.63179.7164.87153165.0842165.283
167.660167.790.49167.98220977168.145.50/---/---168.36192.1166.49158.9166.7183.7166.92153.3167.1353167.383
169.6360169.880.5170.1221004170.234.20/---/---170.44147.8168.58160.7168.77187.8168.98153.9169.1949169.413
171.7360171.940.5172.15221027172.323.60/---/---172.53148.4170.66162.3170.89190.3171.12154.2171.3540171.533
173.8360174.020.5174.24221051174.45.00/---/---174.63202.4172.74163.5172.95190.9173.17154.2173.3941173.613
175.8860176.120.5176.35221078176.486.50/---/---176.69251.9174.85165.2175.03190.7175.24155.1175.4557175.663
177.9560178.160.5178.38221109178.578.00/---/---178.78292.9176.89167.9177.12189.2177.35157.1177.5372177.753
180.160180.280.5180.49221144180.659.10/---/---180.87325178.99170.6179.2188.2179.41159.3179.6386179.873
182.1260182.360.5182.54221181182.79.80/---/---182.91347.3181.1173.2181.28190.8181.48161.8181.6995181.893
184.1760184.380.51184.62221218184.810.50/---/---184.99368.1183.12175.7183.35195.2183.53164.3183.74101183.963
186.2860186.490.51186.71221258186.8711.10/---/---187.11383.3185.21178.6185.42200.5185.63167185.87108186.13
188.3760188.60.51188.79221300188.9511.40/---/---189.16393.2187.29181.9187.5205.4187.71169.8187.92113188.133
190.4660190.670.51190.88221343191.0712.00/---/---191.28416.5189.38185.5189.62208.9189.85173190.03117190.243
192.660192.790.51193221387193.1612.40/---/---193.38424.7191.49189.4191.71210.9191.92176192.13122192.373
194.6860194.890.51195.11221432195.2912.70/---/---195.47435193.62192.8193.85211.8194.03179.4194.24125194.463
196.7160196.920.52197.13221476197.328.70/---/---197.53264.1195.67195.9195.88212.2196.1182.2196.29120196.53
198.8560199.030.52199.24221522199.416.70/---/---199.62234.3197.74197.9197.96212.2198.17184.5198.3874198.623
200.8860201.120.52201.36221556201.496.20/---/---201.69220.2199.86199200.04211.1200.25185.4200.4664200.673
202.9660203.180.53203.39221587203.574.90/---/---203.77199.2201.89199.5202.12208.7202.36186202.5457202.753
205.160205.290.52205.5221609205.666.40/---/---205.87212.6203.99199.7204.21204.3204.42186.4204.6375204.873
207.1460207.370.53207.6221627207.735.40/---/---207.94194.4206.1200206.29198.3206.51187.5206.7257206.933
209.2160209.430.53209.65221645209.826.10/---/---210.02285.6208.14199.8208.36191.9208.59188.2208.79552093
211.2960211.510.52211.72221664211.8810.00/---/---212.1371.6210.23198.8210.44186210.65189.1210.8785211.113
213.3760213.60.52213.79221687213.9511.60/---/---214.16404.5212.29197212.5180.9212.71190.8212.93112213.153
215.4360215.650.52215.87221713216.0512.60/---/---216.24439214.38194.3214.6178.4214.79192.2215120215.213
217.560217.710.53217.93221740218.18.70/---/---218.3256.5216.44191.5216.65181.8216.87193.1217.1126217.293
219.660219.790.53220.01221766220.186.60/---/---220.38236.6218.51190.2218.72186.9218.93193.3219.1471219.373
221.6560221.880.53222.1221788222.247.60/---/---222.44272.6220.61189.5220.79190.6221192.9221.2166221.433
223.7260223.930.53224.15221808224.336.60/---/---224.54232.2222.65189.2222.88192.6223.11192.2223.376223.513
225.8560226.040.53226.26221828226.435.60/---/---226.63191.6224.76189.5224.97192.7225.18191.9225.464225.633
227.960228.120.54228.36221842228.494.00/---/---228.69124.8226.85189.8227.04191.1227.26191.5227.4849227.693
229.9760230.180.54230.4221852230.572.00/---/---230.7763.6228.9190.1229.12188.2229.36190.9229.5429229.763
232.0460232.260.54232.48221858232.641.90/---/---232.8770.4230.98190231.19184.8231.4190.3231.6218231.853
234.1560234.380.54234.6221860234.741.70/---/---234.9452.5233.1189.7233.29182233.51189.6233.7219233.933
236.2260236.430.54236.65221860236.831.60/---/---237.0454.4235.15189.6235.37179.4235.6189235.7916236.013
238.360238.510.54238.72221860238.881.50/---/---239.1166.4237.26189.2237.47176.9237.68188.4237.8815238.113
240.3860240.610.54240.8221860240.962.00/---/---241.1683.2239.3188.9239.51174.6239.73187.8239.9419240.143
242.4460242.650.54242.88221863243.062.10/---/---243.2480.4241.38188.6241.61172.1241.8187.5242.0122242.233
244.5160244.730.54244.94221865245.12.10/---/---245.380.9243.44188.2243.65169.5243.88187.3244.1121244.33
246.660246.80.54247.01221868247.182.10/---/---247.3880.6245.51187.9245.73166.9245.94187.1246.1521246.383
248.6560248.880.54249.09221870249.242.40/---/---249.44106.8247.61187.5247.8164.7248.01187248.2321248.443
250.7360250.940.54251.15221876251.326.90/---/---251.52342.1249.65186.8249.88162.6250.11186.8250.335250.513
252.8160253.020.54253.23221887253.394.70/---/---253.62145.4251.73185.1251.94161252.15187.1252.3886252.63
254.9160255.130.54255.35221903255.494.80/---/---255.71204.9253.86183.9254.05161.6254.26187.5254.4840254.73
256.9860257.190.54257.4221920257.588.50/---/---257.79277255.91182.5256.13163256.36187.4256.5563256.763
259.0660259.270.54259.48221941259.647.60/---/---259.87284.3257.99180.5258.2166.7258.41187.5258.6375258.853
261.1560261.380.54261.6221964261.759.80/---/---261.96340.8260.1179.2260.31171.7260.52187.4260.7398260.943
263.2760263.480.54263.69221989263.8412.20/---/---264.06424.9262.17178.5262.39177.6262.63187262.86114263.063
265.3560265.560.54265.77222016265.927.70/---/---266.13298.1264.27178.8264.48183.3264.7186.4264.92109265.133
267.3860267.610.55267.81222041267.9610.10/---/---268.18352266.35179.7266.55187.7266.76185.8266.96101267.163
269.4960269.70.55269.92222067270.079.80/---/---270.29371.4268.39181.2268.63190.5268.85185.1269.06101269.283
271.5660271.770.56271.98222094272.145.40/---/---272.38236.4270.49182.9270.7191.7270.92184.7271.1368271.353
273.6760273.890.56274.13222123274.325.60/---/---274.49203.9272.6183.7272.81191.8273.02184.2273.2365273.453
275.7860275.990.56276.2222151276.365.10/---/---276.58170.8274.7184.8274.92191.6275.13184.3275.3653275.563
277.8660278.060.56278.27222177278.437.50/---/---278.64395.7276.78185.4276.99191.3277.2184.2277.4246277.633
279.9560280.170.56280.38222203280.5510.00/---/---280.74380.1278.88185.9279.11191.5279.31183.7279.52105279.733
282.0360282.240.56282.45222230282.6111.60/---/---282.83397.7280.95186.8281.17192.9281.38184.1281.6113281.813
284.1360284.360.56284.56222257284.719.40/---/---284.93349.9283.03187.9283.23194.3283.45184.5283.67101283.893
286.1760286.390.56286.63222282286.8110.10/---/---286.99348.2285.13188.6285.35195.1285.54185285.74105285.953
288.2360288.450.56288.67222308288.8310.40/---/---289.04384.7287.21189.4287.42195.1287.63185.4287.8596288.033
290.3660290.560.56290.78222334290.948.50/---/---291.15251.1289.24189.9289.45194.5289.67185.9289.89110290.123
292.4260292.630.57292.87222358293.056.40/---/---293.24262.8291.38190.5291.6193.3291.79186.4291.9970292.213
294.5360294.740.57294.95222379295.117.10/---/---295.33238.6293.45190.6293.66191.4293.89186.4294.1279294.353
296.6360296.850.57297.03222398297.195.40/---/---297.39177.9295.52190.7295.74188.8295.95186.5296.1663296.393
298.6660298.890.58299.12222410299.32.50/---/---299.4866.3297.62190.4297.85185.3298.03186.5298.2441298.453
300.7460300.960.58301.17222416301.333.60/---/---301.53143.7299.69190.3299.9181.7300.12186.3300.3529300.533
302.8560303.040.57303.26222427303.414.70/---/---303.62208.6301.74189.7301.96178.7302.17185.8302.3939302.623
304.8860305.120.57305.35222444305.489.00/---/---305.69354.4303.85189304.03175.6304.24186.2304.4566304.663
306.9560307.170.57307.38222466307.579.10/---/---307.78221.2305.89187.7306.12172.8306.35187.1306.53106306.743
309.160309.280.57309.49222493309.666.10/---/---309.87241.7307.99186.1308.21174.8308.42187.6308.6359308.873
311.1360311.370.57311.6222523311.737.60/---/---311.94285.8310.1185.1310.28179.1310.49187.7310.7168310.923
313.2160313.420.57313.63222556313.828.90/---/---314.03318.7312.14184.4312.37185.6312.61187.8312.7883312.993
315.3560315.530.58315.74222592315.918.40/---/---316.12294.4314.24184.5314.46194.6314.67187.9314.8883315.123
317.3960317.620.58317.86222628317.988.40/---/---318.19299.5316.35185.6316.53204.6316.74187.9316.9683317.183
319.4660319.680.58319.89222663320.078.30/---/---320.29288.1318.39187.6318.62213.2318.85187.8319.0485319.253
321.660321.780.58321.99222700322.148.20/---/---322.37294.2320.5190.5320.71218.2320.92188321.1381321.373
323.6360323.870.58324.1222736324.247.10/---/---324.44242.9322.6193.7322.79219.6323188.4323.2179323.423
325.7160325.930.58326.14222770326.326.10/---/---326.54216.8324.64196.3324.87218.9325.1188.6325.2966325.53
327.8560328.040.58328.25222800328.415.00/---/---328.62180.7326.75198.2326.96215.6327.18188.8327.3956327.623
329.8960330.120.58330.35222824330.483.90/---/---330.69138.5328.85199.5329.03210.4329.24188.7329.4644329.683
331.9660332.180.58332.39222842332.582.90/---/---332.79105.3330.89200.2331.12204.2331.35188.6331.5434331.753
334.1160334.290.58334.51222859334.673.30/---/---334.88142.8333.01200.5333.22198.2333.43188.5333.6428333.883
336.1360336.350.57336.54222880336.710.40/---/---336.91398.2335.1200.2335.29193.6335.51188.3335.7267335.923
338.1860338.40.57338.62222903338.812.60/---/---338.99440.9337.12199.7337.36188.4337.54190337.75117337.963
340.2660340.470.58340.68222931340.856.80/---/---341.05250339.19197.9339.4184.4339.62192.1339.8694340.043
342.2960342.510.58342.72222961342.887.00/---/---343.1232.4341.25196.7341.46185.4341.66193.1341.8873342.13
344.3760344.60.58344.79222992344.966.10/---/---345.16213.1343.29195.6343.51188.6343.72193.9343.9365344.153
346.4460346.650.58346.87223021347.045.20/---/---347.24179.3345.37194.8345.6192.7345.79194.1346.0157346.233
348.5160348.730.58348.94223045349.093.80/---/---349.3113.7347.44194.3347.64196.4347.86194348.0846348.293
350.660350.790.59351.01223059351.172.20/---/---351.3868.7349.51194.1349.72198.2349.93193.7350.1527350.373
352.6560352.870.59353.09223066353.244.30/---/---353.44177.3351.6194.1351.79198.6352.01193.3352.2224352.433
354.7360354.940.59355.15223077355.325.10/---/---355.52230353.65193.6353.88198.5354.09192.9354.2947354.513
356.79603570.58357.21223094357.369.30/---/---357.58353.8355.73193.9355.94197.6356.15193.3356.3775356.593
358.8860359.10.59359.29223116359.465.50/---/---359.66186.4357.79194.5358.01195.8358.23194.3358.4486358.653
360.9460361.150.59361.38223142361.556.20/---/---361.74243359.87195.3360.11195.2360.29194.9360.5154360.733
363.0160363.220.59363.43223172363.67.10/---/---363.8230.9361.94195.4362.15196.5362.37195.3362.5971362.793
365.160365.290.59365.51223202365.685.90/---/---365.88193.6364.01195.8364.23200.3364.44195.8364.6565364.883
367.1560367.380.59367.61223233367.755.00/---/---367.96179.5366.11196.3366.3205.8366.51196366.7352366.943
369.2360369.450.59369.66223261369.835.20/---/---370.04178.1368.16196.8368.38211.2368.59195.9368.7952369.013
371.3460371.540.6371.74223285371.893.90/---/---372.13128.2370.26197.6370.48216370.7195.8370.9147371.133
373.460373.630.59373.86223303373.995.00/---/---374.21175.4372.35198.3372.55218.7372.76195.5372.9850373.193
375.4860375.690.6375.9223316376.083.00/---/---376.2972.9374.42199.3374.63219.4374.85195.2375.0544375.263
377.6160377.810.6378.02223323378.182.20/---/---378.3883.8376.51200.3376.73218376.95195.1377.1622377.383
379.6560379.870.6380.11223328380.253.30/---/---380.46127.8378.61200.5378.81215.5379.02194.7379.2332379.443
381.7360381.950.6382.16223337382.323.80/---/---382.54145.5380.66200.9380.87212.5381.1194.4381.337381.513
383.8160384.020.59384.23223351384.44.10/---/---384.62178.1382.74201.7382.95208.4383.16194.8383.3841383.613
385.9260386.130.59386.36223366386.494.50/---/---386.71154.9384.85202.2385.06203.7385.28195.2385.4945385.73
387.9960388.20.59388.42223377388.573.50/---/---388.79179.9386.92202.9387.13198.9387.35195.8387.5639387.783
390.0560390.260.59390.48223386390.644.10/---/---390.87135.9388.99202.8389.2195.5389.42195.9389.6345389.853
392.1760392.380.59392.6223393392.753.60/---/---392.96129.4391.1202.7391.31192.9391.53196391.7436391.953
394.2360394.450.59394.67223400394.823.30/---/---395.04125.6393.17202.3393.38191.4393.6196.1393.8134394.023
396.3160396.530.59396.74223407396.893.90/---/---397.13158.7395.24201.7395.45190.4395.67196.2395.8835396.113
398.4260398.640.59398.88223415399.054.40/---/---399.24179.9397.36201.3397.56189.5397.77196.5397.9843398.23
400.5360400.740.59400.95223424401.115.90/---/---401.34230.6399.45200.6399.67188.6399.88197400.151400.313
402.660402.810.58403.03223434403.186.10/---/---403.4221.4401.53199.8401.74187.5401.95197.8402.1763402.383
404.6760404.890.58405.12223444405.296.10/---/---405.48222.7403.62198.9403.83186.3404.03198.6404.2461404.453
406.7860406.990.58407.2223455407.366.10/---/---407.59224.4405.7198405.92185.5406.13199.1406.3561406.563
408.8860409.10.58409.31223465409.475.90/---/---409.68215.2407.78197.2407.99184.6408.2199.5408.4261408.633
410.9660411.170.58411.39223476411.576.20/---/---411.79240.6409.89196.3410.11183.6410.33199.9410.5358410.753
413.0960413.270.58413.48223486413.646.20/---/---413.88222.6412195.5412.22182.7412.42200.1412.6366412.863
415.1560415.380.58415.6223497415.7311.00/---/---415.95313.7414.11194.7414.3181.4414.53200.2414.7465414.943
417.2460417.460.58417.67223511417.838.60/---/---418.04297.3416.16193.4416.37180.2416.6200.3416.890417.033
419.2960419.50.59419.7223523419.869.40/---/---420.08334418.24192.4418.45179.3418.66200.2418.8786419.113
421.3760421.60.59421.78223536421.949.60/---/---422.14314.6420.27191.3420.49178.9420.71199.6420.9396421.133
423.4160423.640.59423.87223550424.059.10/---/---424.23314.4422.38190.2422.61178.4422.78199422.9990423.23
425.4960425.70.59425.91223562426.079.10/---/---426.28326.3424.44189.2424.64177.8424.87198.2425.189425.283
427.5860427.770.59427.99223575428.169.00/---/---428.37315.5426.49188.1426.7177.1426.92197.2427.1392427.363
429.6360429.870.59430.1223588430.247.90/---/---430.46269.6428.61187.2428.78176.2428.99196.2429.289429.413
431.7460431.960.59432.17223600432.337.30/---/---432.53262.4430.67186.3430.88175.3431.13195.1431.3575431.533
433.8560434.030.6434.24223612434.46.90/---/---434.62236.3432.74185.4432.96174.4433.17193.9433.3872433.623
435.8760436.110.6436.28223623436.443.10/---/---436.6497.6434.85184.5435.04173.4435.25192.9435.4557435.663
437.9260438.130.61438.37223632438.562.50/---/---438.7487.3436.87184437.1172.4437.28191.9437.4928437.713
44060440.210.61440.42223641440.582.20/---/---440.7865.8438.95183.6439.16171.4439.37191.3439.6122439.793
442.1160442.280.61442.49223648442.661.90/---/---442.8663.7440.99183.3441.21170.6441.42190.7441.6320441.873
444.1360444.370.61444.6223654444.742.10/---/---444.9477.9443.09182.9443.28169.7443.49190443.7119443.923
446.2160446.430.61446.64223658446.822.50/---/---447.0388.4445.14182.6445.37168.9445.61189.5445.79224463
448.3560448.540.61448.75223662448.912.30/---/---449.1287.5447.24182.2447.46167.9447.68189447.8924448.123
450.3760450.60.61450.79223664450.952.20/---/---451.1677.8449.35181.8449.54167449.75188.4449.9523450.163
452.4360452.640.61452.87223665453.042.20/---/---453.2478.7451.37181.4451.61166.3451.78187.9451.9922452.213
454.5460454.750.61454.96223666455.122.30/---/---455.3584.2453.46181453.68165.5453.9187.5454.1222454.363
456.660456.780.61456.99223666457.141.90/---/---457.3756.4455.53180.6455.74164.8455.94187.1456.1423456.373
witchcraftz
Canada
After a two hour drive at 2500 RPM at 120 km/h
Measured Soot is 0
Calculated Soot is 60
During the drive I maxed out at 120 km/h on flat roads.
I had major power loss, couldn't go up hills at speed in any gear, in fact when it geared down and revved high, I seemed to loose more power.
On another hand, I did notice that there *seemed* to be an minor improvement in power after that 2 hour drive at slower speeds. Of course it might be me just imagining things as I've gotten used to the car.
This makes me think it's possibly not the DPF. However I am getting a constant Calculated Soot at 60.
So one of the sensors used to calculated the "Calculated Soot" must be reading wrong. I would expect it to fluctuate a bit? Or is it maybe maxed out at 60?
Can you possibly tell me which ones are used in the calculations?
NEtech
C?ID=56995
It could be problems with:
  • DPF pressure sensor(s)
  • Air mass
  • EGR systems
  • Temperature sensors
  • Lambda sensor
  • Fuel amount
Are there 2 sensors in exhaust manifold ?
witchcraftz
Canada
Yes there are 2 sensors.
witchcraftz
Canada
So I forgot to update this thread but I'd like to do so now.
I removed both DPF sensors, the Adblue sensor and did a test with a shop vac and a long hose against the DPF filter to see if it was clogged. It was most definitely not clogged. There was no resistance through the filter. So I confirmed my DPF was not plugged up but a sensor measurement was wonky.
I buttoned everything back up and did a lot of digging. Turns out that there is a software update because this is a problem.
I brought the car into the dealership and had the software update done. Drove for a bit andthe numbers kept slowly creeping down afterwards.
Within a short time the soot values were all back to acceptable range and a regen cycle happened. Haven't had problems since.
