Injector: Cylinder 3 - Circuit Malfunction
UWSCSI
Norway
C?ID=134408
Hello...
So, my VW Caddy with a 1.6 TiD engine is not doing well. Engine is running rough and has poor acceleration/lack of power.
Connected my VAG-COM and it is pointing out injector no 3.
I have disconnected the plug and inspected and rinsed, but no progress.
Is it anything else I should do and check before I changed the injector?
Friday,24,January,2020,15:36:56:19306
VCDS Version: 19.6.1.0
VIN: WV1ZZZ2KZFX007889   License Plate:
Chassis Type: 2K-VN35 (7N0)
Scan: 01 03 08 09 10 15 16 17 18 19 25 42 44 46 52 56 61 69 77
VIN: WV1ZZZ2KZFX007889   Mileage: 41710km-25917miles
Address 01: Engine (J623-CAYE)       Labels:. 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 TD    HW: 03L 907 425 C
   Component: R4 1.6l TDI   H43 9979
   Revision: --H43---    Serial number: 00000000000000
   Coding: 00114034032401080000
   Shop #: WSC 35110 790 50316
   ASAM Dataset: EV_ECM16TDI02103L906023TD 003003
   ROD: EV_ECM16TDI02103L997557R.rod
   VCID: 7BFF08E5F2AE0A97CC-802E
9839 - Injector: Cylinder 3 (N32)
          P0203 00 [237] - Circuit Malfunction
                    Mileage: 41709 km
                    Date: 2020.01.24
                    Time: 15:02:00
                    Engine speed: 1232.75 /min
                    Normed load value: 15.7 %
                    Coolant temperature: 66 蚓
                    Intake air temperature: 17 蚓
                    Voltage terminal 30: 14.682 V
                    Incorrect information on selected Piezo power level-LF_STATE_PPS_SPI[0]: 0
                    Injector valve 2: capacity-CAPA_INJ_MAIN[1]: 32.1019 湩
                    Voltage load of main injection cylinder 2-CHR_INJ_MAIN[1]: 1434.6 渙s
                    Measured energy of main injection cylinder 2-EGY_INJ_MAIN[1]: 3.614 mJ
                    Supply voltage of analog output 1-VCC_1: 4.98 V
                    Supply voltage of analog output 2-VCC_2: 5.00 V
                    Injection valve 2: voltage-V_INJ_MAIN[1]: 5.04 V
9835 - Injector: Cylinder 3 (N32)
          P0203 00 [167] - Circuit Malfunction
                    Mileage: 41713 km
                    Date: 2020.01.24
                    Time: 15:31:25
                    Engine speed: 801.75 /min
                    Normed load value: 23.9 %
                    Coolant temperature: 69 蚓
                    Intake air temperature: 13 蚓
                    Voltage terminal 30: 11.746 V
                    Injector valve 2: capacity-CAPA_INJ_MAIN[1]: 0.0353 湩
                    Voltage load of main injection cylinder 2-CHR_INJ_MAIN[1]: 8.0 渙s
                    Measured energy of main injection cylinder 2-EGY_INJ_MAIN[1]: 0.893 mJ
                    Injection valve 2: voltage-V_INJ_MAIN[1]: 225.21 V
Readiness: 1 1 0 0 0
   Part No SW: 1K0 907 379 BM    HW: 1K0 907 379 BM
   Component: ESP MK60EC1   H46 0164
   Revision: 00H46001
   Coding: 423C200D09220301421304EC9022C051A1000020
   Shop #: WSC 35110 377 08192
   VCID: 7EF901F1E9BC1FBFEB-802A
   Part No SW: 7N0 907 426 CC    HW: 7N0 907 426 CC
   Component: AC Manuell    H20 0606
   Revision: 00001002
   Coding: 0010004003
   VCID: 77F714D5CE862EF7A8-8022
9672723 - Heated Seat; Front Left
          B1398 13 [009] - Open Circuit
                    Reset counter: 137
                    Mileage: 41411 km
                    Date: 2020.01.18
                    Time: 11:40:48
   Part No SW: 5K0 937 085 AA    HW: 5K0 937 085 AA
   Component: BCM PQ35 B+   122 0174
   Revision: BB122001
   Coding: 611A0A3A80251A6D088800829000006403017288424FAD60648087000041
   VCID: 72E125C1ADE44BDF9F-8026
   Subsystem 1 - Part No: 1T1 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer 16051  26  0512
   Coding: 009795
Address 10: Park/Steer Assist (J446)       Labels:| 1Q0-919-475.clb
   Part No SW: 2K0 919 475     HW: 1Q0 919 475
   Component: PARKHILFE 4K  H03 0004
   Revision: --------    Serial number: 32901412802666
   Coding: 118001
   ASAM Dataset: EV_EPHVA14VN3370000 001006
   ROD: EV_EPHVA14VN3370000.rod
   VCID: 70E52FC9ABE879CF69-8024
   Part No SW: 7E0 959 655 B    HW: 7E0 959 655 B
   Component: VW10Airbag029 H07 0013
   Revision: --------    Serial number: 003HL00R10D$
   Coding: 000000000000000000000000000000003239
   VCID: 356BDEDD940A1CE77A-8060
   Part No SW: 5K0 953 521 DQ    HW: 5K0 953 569 AH
   Revision: FF010042    Serial number: 20140522200806
   Coding: 1082160000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 7EF901F1E1BC1FBFEB-802A
   Component: E221__MFL-TAS  H31 0037
   Coding: 820000
   Part No SW: 2K0 920 876 F    HW: 2K0 920 876 F
   Component: KOMBI         H03 0905
   Coding: 180A00
   VCID: 336FE0C59A7E02D754-8066
Address 18: Aux. Heat        Labels: 1K0-815-007.clb
   Part No: 7N0 963 272 E
   Component: Standheizer     044 4941
   Revision: 00044000    Serial number: 09028239000000
   Coding: 0031032
   Shop #: WSC 35110 377 00182
   VCID: 3777D4D54606EEF768-8062
   Part No SW: 7N0 907 530 AQ    HW: 7N0 907 530 AL
   Component: J533  Gateway H58 1653
   Revision:   H58       Serial number: 190514F1002926
   Coding: 357400
   VCID: 7F07FCF5EEB616B7E0-802A
   Component: IMMO          H03 0905
   VCID: 6AD13DA18D34831F27-803E
   Part No SW: 1T0 959 701 T    HW: 1T0 959 701 T
   Component: Tuer-SG         009 2109
   Coding: 0132144
   VCID: 4895A7293BF8910F11-801C
01706 - Switch for Mirror-Adjust (E43)
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 140    3501
   Revision: 00H22000
   VCID: 3973D2ED7012F8879E-806C
   Part No SW: 1T0 959 702 R    HW: 1T0 959 702 R
   Coding: 0132144
   VCID: 4797A41536E69E7718-8012
   Part No SW: 3C8 035 195 H    HW: 3C8 035 195 H
   Component: Radio RCD510  006 0246
   Revision: 00000001    Serial number: VWZ1Z3P0295214
   Coding: 05000200020013
   VCID: 2D5BF6BD745A542702-8078
02877 - Digital Radio Antenna (R183)
                    Fault Status: 00100111
                    Reset counter: 185
                    Mileage: 41354 km
                    Date: 2014.06.09
                    Time: 13:47:56
   Part No SW: 7N0 907 534     HW: 7N0 907 530 AL
   Component: Batt.regelung H58 1653
   Coding: 330F1859
   VCID: 71E32ACDA8E270C766-8024
   Component: J367-BDM  H07 0180
   Serial number: 31135H57431491229011
   Part No SW: 1K0 907 383 G    HW: 1K0 907 383 G
   Component: Anhaenger     H10 0110
   Revision: 3B001001    Serial number: 00008200432976
   Coding: 010D000101000000
   VCID: 3163EACD686230C726-8064
   Part No SW: 7P6 035 730 M    HW: 7P6 035 730 M
   Component: TELEFON       H16 4217
   Revision: 1B001001    Serial number: 00007666270359
   Coding: 0A01010000010110
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002.rod
   VCID: 3C7DCBF9B720CDAF85-8068
End-------------------------(Elapsed Time: 03:12)--------------------------
Did you check wiring with load light from ECU to injector plug using WD and RTFB?
UWSCSI
Norway
C?ID=134408
Thanks for the tip... The circuit tester with bulb shows me that the ECU is firing the injector.
Jonesy
Ireland
C?ID=236509
I've seen Injectors on these give lots of bother.
If you've had the VW emmision update done, in the last 2yrs, VW will replace injectors under warranty.... (In Ireland anyway)
UWSCSI
Norway
C?ID=134408
Thanks for your reply. Do you know why they replace them under warranty? (I need some good points so I can argue my case with my VW dealer).
Jonesy
Ireland
C?ID=236509
I'm guessing it's their way of accepting liability. I don't know what they say officially but they do replace them once it's within 2yrs of software update being done 👍
NZDubNurd
New Zealand
C?ID=230482
1.6 TDI injector failure is very common. Ask Uncle Google.
The replacements are apparently updated and are more reliable (S suffix?)... but remember you may still have 3 other originals.
Dont get "rebuit" ones, as its usually the non-replacable driver coil that fails.
golfi_vend
Tartu, Estonia
C?ID=195131
Lucky You, who You get it replaced Under warranty.
There is TPI that states that injectors are not included in "Trust building measures".
UWSCSI
Norway
C?ID=134408
Hi guys... I went to the VW dealer and addressed the problem. They acknowledged the fault and replaced 2 injectors free of charge...
The car is from 2014 and the VW emmision update was performed February 2018...
The VW dealership stated that it had nothing to do with the VW emmision update, but more to the fact that there has been a lot of problems with these injectors.
Anyway, I am happy that the VW dealership actually took responsibility and fixed the problem free of charge this time.
Thanks for all the help.
Best regards from Norway.
