2019 KAROQ - Fault Code
Charcoal75
North Yorkshire, UK
C?ID=376403
A scan on my new Karoq is showing Status OK on all modules except for the following.
I would like to know what is the likely cause of this fault and if I should be doing anything to sort it.
Part No SW: 565 920 950 B HW: 565 920 950 B
Component: KOMBI 312 2700
Coding: 27A50C0E678C260001887A031001000080000000
Shop #: WSC 00033 790 00188
ASAM Dataset: EV_DashBoardVDDMQBAB 009068
VCID: 1B63D71B43266CBF3C5-804E
16776982 - Databus
[SWA_01 keine Kommunikation]
Reset counter: 95
Mileage: 3179 km
Date: 2019.10.16
Time: 10:47:41
siLc
Tallinn, Estonia
C?ID=330192
Still, a full autoscan should be posted. This snippet of info says there's a problem with communicating with the blind spot monitoring but we don't know whether the vehicle in question even has it (because of no full autoscan) to even start suggesting anything.
Charcoal75
North Yorkshire, UK
C?ID=376403
Thank you for your response.
I don't have blind spot monitoring and sorry but I only have the following copy of the full scan:
Wednesday,16,October,2019,10:51:35:15046
VIN: TMBKP7NU0K5046720   License Plate: NC19SVV
Mileage: 3179km-1975mi   Repair Order:
Chassis Type: NU-SK37 (3Q0)
Scan: 01 02 03 08 09 10 13 15 17 19 42 44 52 5F 6D A5
VIN: TMBKP7NU0K5046720   Mileage: 3179km-1975miles
Address 01: Engine (J623-DKRF)       Labels: None
   Part No SW: 04C 906 025 BK    HW: 04C 907 309 BB
   Component: R3 1.0l TFS   H20 6503
   Revision: D7H20000
   Coding: 0125003223641D082000
   ASAM Dataset: EV_ECM10TFS01104C906025BK 002001
   ROD: EV_ECM10TFS01104C906025BK_AU37.rod
   VCID: 6A8DC2DFDCFC4537773-803E
   Part No SW: 0CW 300 043     HW: 0AM 927 769 E
   Component: GSG DQ200G2_M H05 1603
   Revision: 00005008    Serial number: CU501906148498
   ROD: EV_TCMDQ200021_VW31.rod
   VCID: 74B1DCA78E3883C7DDF-8020
   Part No SW: 5Q0 614 517 ES    HW: 5Q0 614 517 BP
   Component: ESC           H35 0190
   Revision: 00000000    Serial number: 61639000000636
   Coding: 1F078AA120242472477E060262C325F8510424E26046A4733821F078D2024A0B00000C6212120B095A35351919323200
   Shop #: WSC 00033 790 00119
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 038007
   ROD: EV_Brake1UDSContiMK100IPB_038.rod
   VCID: 0655966FE8A48157F3B-8052
   Part No SW: 565 907 044 BL    HW: 565 907 044 BL
   Component: Climatronic   H04 2002
   Revision: 00001K00
   Coding: 06110004000110011105000800101022
   Shop #: WSC 33361 790 00189
   ASAM Dataset: EV_ACClimaBHBVW37X 006147
   VCID: 6695B6EFC8E4615753B-8032
   Subsystem 3 - Part No SW: 5Q0 907 659 C    HW: 5Q0 907 659 C
   Component: G238 _AQS  H30 0119
   Serial number: 98688514
   Part No SW: 5Q0 937 084 DB    HW: 5Q0 937 084 CE
   Component: BCM MQBAB M   H38 0273
   Serial number: 01001914500091
   ASAM Dataset: EV_BCMMQB 019001
   ROD: EV_BCMBOSCH_019_VW37.rod
   VCID: 7BA3F79BA366CCBF9C5-802E
   Subsystem 1 - Part No SW: 5Q0 955 547 B    HW: 5Q0 955 547 B  Labels: 5Q0-955-547.CLB
   Component: RLHS  052 0107
   Serial number: S6Y19M06D13H19M28S09
   Coding: 00186E
   Subsystem 2 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Serial number: 000000000ZY190500K5T
   Subsystem 3 - Part No SW: 5QD 951 605     HW: 5QD 951 605
   Serial number: 00002856223982262701
   Steering Column Switch:
   Subsystem 4 - Part No SW: 5Q1 953 521 AD    HW: 5Q1 953 569 A
   Component: Lenks.Modul  H13 0170
   Serial number: 0100300520190C103357
   Serial number: 000308418319147
   Coding: 0471151851
   VCID: 4CC16447B648BB0765F-8018
   Part No SW: 2Q0 907 572 Q    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H03 0342
   Coding: 3205674150FF8728749C814530408700000000000000000000
   ASAM Dataset: EV_ACCMRRCONTIVW376 003015
   ROD: EV_ACCMRRCONTIVW376_003_VW37.rod
   VCID: 42DD4A7F840C7D779F3-8016
   Part No SW: 3Q0 959 655 CM    HW: 3Q0 959 655 CM
   Component: Airbag VW21   006 0720
   Revision: --------    Serial number: 003Z2PB4WP6E
   Coding: 98CCC0C0000000005C5400CF008800000065
   ROD: EV_AirbaVW21TS6VW48X.rod
   VCID: 0B43A75BF3C6FC3FAC5-805E
   Subsystem 1 - Part No SW: -----------    HW: 454 002 905 19
   Serial number: 357000000001773C5B3L
   Subsystem 2 - Part No SW: -----------    HW: 454 000 106 19
   Serial number: 35800000000074750C3B
   Subsystem 3 - Part No SW: -----------    HW: 454 802 605 19
   Serial number: 35100256AE618000000I
   Subsystem 4 - Part No SW: -----------    HW: 454 802 505 19
   Serial number: 35200E929DF18000000
   Subsystem 5 - Part No SW: -----------    HW: 454 800 705 19
   Serial number: 35500862E0418000000D
16776982 - Databus
                    Reset counter: 95
                    Mileage: 3179 km
                    Date: 2019.10.16
                    Time: 10:47:41
   Part No SW: 3Q0 907 530 AA    HW: 3Q0 907 530 C
   Component: GW MQB High   521 5366
   Serial number: 18061910522132
   Coding: 030100047F085700EB0002581C0F00010001070000000000000000000000
   Shop #: WSC 00033 790 00141
   ROD: EV_GatewNF.rod
   VCID: 6E85CECFE014A9172BB-803A
   Component: 0-00-02-00-04
   Subsystem 2 - Part No SW: 3V0 919 719 F    HW: 3V0 919 719 F
   Component: E221__MFL-PR6  H03 0170
   Serial number: 000000000C2430100619
   Component: J367-BDMConti  H03 1051
   Serial number: 758860030019060417FA
   Part No SW: 5Q4 959 593 F    HW: 5Q4 959 593 F
   Component: TSG FS        006 0246
   Serial number: 0000378152033
   Coding: 00110820D001020000001100
   VCID: 48C95857A2305727417-801C
   Subsystem 1 - Part No SW: 5Q0 959 408 A    HW: 5Q0 959 164
   Component: FOND_FHSG_DRV  007 0010
   Serial number: 00000000000031047395
   Coding: 1D0200
   Part No SW: 5Q0 909 144 AB    HW: 5Q0 909 144 AA
   Component: EPS_MQB_ZFLS  130 1082
   Coding: 11170000
   ROD: EV_SteerAssisMQB_015.rod
   Part No SW: 5Q4 959 592 F    HW: 5Q4 959 592 F
   Component: TSG BFS       006 0246
   Serial number: 0000377805353
   Coding: 00110020D401020000001100
   ROD: EV_DCU2PasseSideMAXHCONT_SK37.rod
   VCID: 47CB5B6BAF2E585F48D-8012
   Subsystem 1 - Part No SW: 5Q0 959 407 A    HW: 5Q0 959 163
   Component: FOND_FHSG_PSG  007 0010
   Serial number: 00000000000031047329
   Coding: 050200
Address 5F: Information Electr. (J794)       Labels:| 3V0-035-MIB-STD2.clb
   Part No SW: 5Q0 035 874 C    HW: 5Q0 035 874 C
   Component: MU-S-ND-ER    H41 0475
   Serial number: SKZAZ2W0449640
   Coding: 03230601FF00000001111201008808002F0208D6012005008F
   ROD: EV_MUStd4CTSAT_VW41.rod
   VCID: 34311CA7CEB8C3C71DF-8060
   Subsystem 1 - Part No SW: 565 919 605 B    HW: 565 919 605 B
   Component: ABT_Std-2_Nav  H52 8130
   Serial number: SKZ6ZHW1700975
   Subsystem 2 - Part No SW: 5L0 051 236 BA    HW: -----------
   Component: ECE AS 19/20  --- 1115
   Part No SW: 5Q0 959 107 S    HW: 5Q0 959 107 J
   Component: HDSG-Modul    H13 0271
   Revision: --------    Serial number: A2-C737-6291-8
   Coding: 1800
   Part No SW: 3QD 980 654 A    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H12 1611
   Serial number: 15051941K12390
   Coding: 0203070800000401000213448140A90090000E00000000
   ASAM Dataset: EV_MFKBoschMQBB 002041
   ROD: EV_MFKBoschMQBB_002_VW37.rod
   VCID: 49CF5D53B93AAE2F5E9-801C
End----------(Elapsed Time: 01:32, VBatt start/end: 12.2V/12.2V)-----------
Mike@Gendan
Swansea, UK
C?ID=57030
Try deselectng "Use Aggressive Mode" in the Auto-Scan options.
You may find a communications fault like that doesn't appear in "standard" mode
Since it is "Confirmed - Tested Since Memory Clear" and the Gateway also shows "Malfunction", I think it will still show.
I'm going to suggest it's either a coding fault or possibly a software bug in the cluster.
@Charcoal75 -- have you made any coding or adaptation changes to this car?
Charcoal75
North Yorkshire, UK
C?ID=376403
I have added 'Lane Assist' which is working OK in conjunction with the factory fitted ACC.
The coding / adaptations I made are:
[17-Instruments]
[Recode-07] lung coding
[Byte 04] [Bit 6] Spurhal assistant: yes
[Byte 11] [Bit 1] Spurhalt assistant: BAP Strecke yes
[A5 front camera]
[Byte 16] [Bit 7] HC, 0
[44 Steering Assist]
[Security Access-16]
Enter the access code: 19249
[Byte 03] [Bit 0] Spurhalt assistant, Verbaut
[5F-Information Electr.]
[Adjust-10]
Search for "HCA" ENG122229-ENG117740 Car Function List BAP Gen2 LDW HCA 0x19 -> active
Search for "Departure" ENG122227-ENG117506 Car Functions Adaptations Gen2 Menu display Lane Departure Warning -> active
Search for "Departure" ENG122227-ENG117508 Car Functions Adaptations Gen2 Menu display Lane Departure Warning over threshold high -> active
I also took the precaution to save RAW-HEX files of the Controller Channel Maps prior to making these changes.
DV52
C?ID=194404
^^^.............. and do the records in the CodingLog.CSV and AdpLog.CSV files in the C:\Ross-Tech\VCDS\Debug directory confirm that those amendments and no other changes were made?
Charcoal75
North Yorkshire, UK
C?ID=376403
I will check and report back........
Have now checked and the Coding and Adpt logs and show only the changes that I made.
I tried clearing the fault code but it will not clear and remains .......
16776982 - Databus
Reset counter: 95
Mileage: 3179 km
Date: 2019.10.16
Time: 10:47:41
Help please, I am new to VCDS and do not yet know how to identify what might be causing the fault code to persist.
