Hello All,
Newbie here. I have a bout of throwing some rich codes. (posted below) and wanted to see if you experts could help out. FYI, I have the 3.0L engine with about 28,500 miles on it. The check engine came on about a 3 weeks ago. I looked at the codes, and checked on this site for possible issues. I started the diagnosis process on the air side. I cleaned the MAF and erased the codes. After about 200 of city/hwy miles, the CEL came back with same results. I wanted to add. I changed the fuel filter about 5000 miles ago. All plugs with correct gap and coil packs were changed about 2000 miles ago). Air filter was changed less than 5000 miles ago. I haven't checked anything yet on the fuel side, i.e. pressure, leaks, etc. (I also included a full scan result after the fuel trim report) Thanks everyone. I'm looking forward to hearing from you. Have a great day.
*I cleaned the MAF
*checked the power and ground connections from the car to the MAF plug, (all good)
*ran logs on the fuel trims, each time CEL came on, the negative values were just about the same, (posted one below)
*I ran 4 redline tests to check the numbers on the MAF. I didn't take logs, but in 2nd gear at about 6400rpm's, the MAF #'s were 98g/s and 102g/s the first day, 124g/s and 108g/s on second day. that is a far cry from the 80% of max HP (220 x .80=176).
*did a smoke test to check for vacuum leaks, found a hose just past the MAF, that had leak from original crimp clamp. Replaced that and after retest, no leaks anywhere.
Log:
*I cleaned the MAF
Log:
Address 01: Engine (8E1 909 559 B)
13:53:34 Group 032: Lambda Control (Mixture Adaptation)
1.5 % Adaptation (Idle) Bank 1 Sensor 1
-17.2 % Adaptation (Partial) Bank 1 Sensor 1
0.8 % Adaptation (Idle) Bank 2 Sensor 1
-14.1 % Adaptation (Partial) Bank 2 Sensor 1
13:53:34 Group 033: Lambda Control
-2.3 % Lambda Control Bank 1 Sensor 1
1.540 V Sensor Voltage Bank 1 Sensor 1
-1.6 % Lambda Control Bank 2 Sensor 1
1.540 V Sensor Voltage Bank 2 Sensor 1
13:53:34 Group 002: General
800 /min Engine Speed (G28)
18.8 % Engine Load
2.87 ms Injection Timing
4.92 g/s Mass Air Flow (G70)
Address 01: Engine Labels: 06C-909-559-ASN.lbl
Part No SW: 8E1 909 559 B HW: 8E0 909 059 A
Component: 3.0L V6/5V G 0030
Revision: 00000000 Serial number: AUZ6Z0D0285717
Coding: 0013754
Shop #: WSC 00672 785 00200
VCID: 3537DC2D09563F9F7D3-5160
17535 - Fuel Trim; Bank 1 (Mult)
P1127 - 002 - System too Rich - Intermittent
16556 - Fuel Trim; Bank 1
P0172 - 002 - System Too Rich - Intermittent
Address 02: Auto Trans Labels: 01V-927-156.lbl
Part No: 8E0 927 156 AB
Component: AG5 01V 3.0l5VT USA 0404
Coding: 0001002
VCID: 6E8533412C804C477C9-5160
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517 A
Component: ABS/ESP allrad 4529
Coding: 04497
Shop #: WSC 00672
VCID: 26150B61C1F04407C49-51A8
Part No: 8E0 820 043 AD
Component: A4 Klimaautomat 1424
Coding: 00100
Shop #: WSC 00672
VCID: 63935275F242F12FE37-513C
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 F
Component: int. Lastmodul USA 0517
Coding: 01013
Shop #: WSC 00672
VCID: 3537DC2D0C563F9F7D3-4AE0
02104 - Light Detection Sensor (G399)
29-10 - Short to Ground - Intermittent
Address 15: Airbags Labels: 8H0-959-655-84.lbl
Part No: 8H0 959 655 D
Component: Airbag 8.4EC 0015
Coding: 0010105
VCID: 3B23CA152F72E9EF8B7-5160
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 N
Component: Lenksáulenmodul 0611
Coding: 02041
Shop #: WSC 00672
VCID: 3E25C3013960FCC7AC9-4AE0
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8H0 920 950 H
Component: KOMBI+WEGFAHRS. RB4 D22
Coding: 01401
Shop #: WSC 09401
VCID: 313FE83DF83E13BF21B-5160
WAUDT48H35K005891 AUZ6Z0D0285717
Address 26: Auto Roof Labels: 8H0-959-255.lbl
Part No: 8H0 959 255
Component: VSG B6 CABRIO 6386
VCID: 73B3223547A261AF937-5160
Part No: 8H0 959 760
Component: Sitzmemory EE H06 0010
Coding: 00002
Shop #: WSC 00065
VCID: 74B12129479C66978AD-4B1E
Address 46: Central Conv. Labels:. 8E0-959-433-MAX.clb
Part No: 8H0 959 433 E
Component: Komfortgerát T7B 3320
Coding: 11788
Shop #: WSC 00672
VCID: 3635DB2111503487749-4AE0
Subsystem 1 - Part No: 8H1959801B
Component: Tõrsteuer.FS BRM 3020
Subsystem 2 - Part No: 8H1959802B
Component: Tõrsteuer.BF BRM 3020
Subsystem 3 - Part No: 8H0959801A
Component: Tõrsteuer.HL BRM 0002
Subsystem 4 - Part No: 8H0959802A
Component: Tõrsteuer.HR BRM 0002
Address 55: Headlight Range Labels: 4Z7-907-357.lbl
Part No: 4Z7 907 357
Component: dynamische LWR D09
Coding: 00070
Shop #: WSC 00672
VCID: 045171E9173C5617BAD-4B1E
Address 63: Entry Assist,D Labels: None
Part No: 8H0 959 760 A
Component: EasyEntry F M H13 0010
Coding: 00006
Shop #: WSC 00065
VCID: 3537DC2D0C663F9F7D3-4B1E
Address 73: Entry Assist, P Labels: None
Component: EasyEntry BF H13 0010
Coding: 00005
Shop #: WSC 00065
End----------(Elapsed Time: 05:30, VBatt start/end: 12.5V/12.6V)-----------
