2012 8R Q5 OBD Mode 10 Permanent codes not shown
Shzeps
C?ID=11561
Hi, I used VCDS 19.6.2 with HEX-NET to set all readiness on this car. When it went for a smog (CA) it failed for permanent DTC P0300 and P0301 misfire. I went back with VCDS into the OBD function and mode 10 permanent DTC, no codes stored. I used a Autel OBD reader and now I can see the codes in permanent codes. Has anyone seen VCDS not showing the codes before? WA1LFAFP4BA103189 8RB56A CAEB NEV 4/11. Thanks for any help or info.
PetrolDave
Westbury, UK
C?ID=1423
Please post a VCDS Auto-Scan.
Shzeps
C?ID=11561
Auto-Scan
Here is the Auto-scan. Please let me know if and what I should log and send in.
Tuesday,08,October,2019,16:26:15:57829
VCDS Version: 19.6.2.0 (x64)  HEX-NET CB: 0.4513.4
VIN: WA1LFAFP4BA103189   License Plate:
Mileage: 234380km-145636mi   Repair Order:
Chassis Type: FP-AU48 (8T0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 36 42 46 52 53 55 56 5F 62
          6C 6D 72
VIN: WA1LFAFP4BA103189   Mileage: 234380km-145636miles
Address 01: Engine (0-----CAEB)       Labels:| 06H-907-115-CAB.clb
   Part No SW: 8R0 907 115 P    HW: 8K2 907 115 D
   Component: 2.0l R4/4V TF H19 0002
   Revision: E1H19---
   Coding: 0121010A290F0160
   Shop #: WSC 04091 002 1048576
   ASAM Dataset: EV_ECM20TFS0118R0907115P 001002
   ROD: EV_ECM20TFS0118K2907115AG.rod
   VCID: C1CA1F6D5068AF4768-8094
   Part No SW: 8R0 927 158 T    HW: 0BK 927 156 R
   Component: 0BK 20TFSIUSA H08 1003
   Revision: --H08---
   Coding: 000002
   ASAM Dataset: EV_TCMAL551211 002018
   VCID: CED034519136403FE5-809A
Address 03: ABS Brakes (J104)       Labels:. 8R0-907-379-V1.clb
   Part No SW: 8R0 907 379 H    HW: 8R0 907 379 H
   Component: ESP8 quattro  H06 0110
   Coding: 121D18
   Shop #: WSC 06334 000 00000
   VCID: C5C20B7D4C40836754-8090
   Part No SW: 8K0 907 064 CS    HW: 8K0 907 064 CS
   Component: BCM2 2.0      H05 0435
   Coding: 090500
   Shop #: WSC 06335 000 00000
   VCID: 8346D56502F47D573A-80D6
   Subsystem 1 - Part No SW: 8T0 959 754 A    HW: 8T0 959 754 A
   Component: FBSAUDIB8 IDG  H60 0072
   Serial number: 0511000016297007
   Serial number: 2311000059607009
   Part No SW: 8T1 820 043 AQ    HW: 8T1 820 043 AQ
   Component: KLIMA 3 ZONEN H08 0180
   Revision: C1000000    Serial number: 01050420110342
   Coding: 64112000
   VCID: 804CDA6913E2664F27-80D4
   Part No SW: 8K0 907 063 P    HW: 8K0 907 063 P
   Component: BCM1 1.0      H30 0392
   Revision: 10030001    Serial number: 00000000856069
   Coding: 26001091063CAF010000080300001D0D0F1C460802010161000000
   VCID: BC346E993F8AC2AF3B-80E8
   Subsystem 1 - Part No SW: 8R1 955 119 A    HW: 8R1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS416 110316  H11 0050
   Serial number: 90243014110314124248
   Coding: 01DD13
   Component: RLS  H04 0003
   Serial number: 11363154
   Coding: 024D25
   Component: E1 - LDS  H03 0031
   Serial number: 00000000002603111021
02258 - Door Opener Transmitter
                    Reset counter: 220
                    Mileage: 234384 km
                    Date: 2010.05.17
                    Time: 01:12:00
   Part No SW: 8K0 919 475 AA    HW: 8P0 919 475 N
   Component: PARKHILFE 8K  H01 0080
   Revision: 11001001    Serial number: 12501108802423
   Coding: 300105
   VCID: F8BCB2894B322E8F1F-80AC
Address 15: Airbags (J234)       Labels:* 8R0-959-655.clb
   Part No SW: 8R0 959 655 F    HW: 8R0 959 655 F
   Component: AirbagVW-AU10 H44 0610
   Serial number: 003GPD0N5032
   Coding: 303633313432303030304A55304C38523053
   ROD: EV_AirbaAU10SMEAU416.rod
   VCID: C7DE01757E4C9177A6-8092
   Subsystem 1 - Part No SW: 8R0 959 339 A    HW: 8R0 959 339 A
   Serial number: 5810000R1100002YKH
   Serial number: 6334MSME5C7311136
   Serial number: 6344MSME5D561911F
   Serial number: 6352QSME6E092876T
   Serial number: 6362QSME30061E74D
   Serial number: 63732SME2306536C-
   Serial number: 63832SME75050156T
   Component: Lenks.Modul   H17 0014
   Revision: --------    Serial number: 90372KCS001GF
   Coding: 000017
   VCID: BD32639D2490CBA70C-80E8
   Component: E221 - MFL  H02 0010
Address 17: Instruments (J285)       Labels:. 8R0-920-xxx-17.clb
   Part No SW: 8R0 920 981 G    HW: 8R0 920 981 G
   Component: KOMBIINSTR.   H20 0258
   Revision: 00000000    Serial number: EK037KN3C
   Coding: 8B1622000300D705020000
   VCID: BE3064912996D0BF15-80EA
   Part No SW: 8T0 907 468 AD    HW: 8T0 907 468 K
   Component: GW-BEM 4CAN-M H09 0117
   Revision: EC000056    Serial number: 5600E113160587
   Coding: 00C303
   Subsystem 1 - Part No SW: 8R0 915 181     HW: 8R0 915 181
   Component: J367-BDM  H07 0140
   Serial number: 00000000005650113037
                    Fault Frequency: 27
                    Reset counter: 7
                    Mileage: 234385 km
                    Date: 2010.06.26
                    Time: 04:28:00
                    Bin. Bits:    10000
                    Voltage: 11.90 V
                    Count: 11
   Part No SW: 8R0 959 760 D    HW: 8R0 959 760 B
   Component: MEM-FS        H07 0075
   Revision: AA000000    Serial number: 00001002377646
   Coding: 00581300000000000000
   VCID: C2C810615D6EB45F71-8096
   Part No SW: 8K0 959 793 M    HW: 8K0 959 793 M
   Component: TSG FA        H12 0357
   Revision:             Serial number: 0000005714723
   Coding: 011D03205E00440004
   VCID: CAD83841655E6C1FB9-809E
   Revision: 00002001    Serial number: 0145907325
   Coding: 0126023A20FA749484B0053200000000
   Component: GTO BF  H01 0070
   Serial number: 00000000000000378581
   Subsystem 4 - Part No SW: 8R0 959 591 A    HW: 8R0 959 591
   Part No SW: 8K0 959 792 M    HW: 8K0 959 792 M
   Component: TSG BF        H12 0357
   Revision:             Serial number: 0000113571727
   VCID: C9DA074D60586707B0-809C
   Revision: 00000003    Serial number: 00000000908285
   VCID: B42446B917DA0AEFF3-80E0
   Part No: 8K0 907 357 D
   Coding: 0000006
   VCID: B6207CB1C1A618FFCD-80E2
   Part No SW: 4G0 035 082     HW: 4G0 035 082
   Component: Radio U SIRIU H51 0052
   Revision: AB001007    Serial number: 471DR0B7570222
   Coding: 020007020100000001
   VCID: DDF2C31DC4D0EBA76C-8088
   Part No SW: 8T1 035 664 C    HW: 8T1 035 664 B
   Component: H-BN-NA       H51 0116
   Revision: --------    Serial number: 490D 0B7612973
   Coding: 010200060005A1EF41000B0E000000030000
   VCID: B83C72890BB2EE8FDF-80EC
   Subsystem 1 - Part No: 8R0 060 884 P
   Component: NAR 2010  0407
   Subsystem 2 - Part No SW: 8F0 919 604     HW: 8F0 919 604
   Component: DU7 High  H43 0084
   Serial number: 9466CV0B0552662
   Subsystem 3 - Part No SW: 8T0 919 609 F    HW: 8T0 919 609 F
   Component: E0380 Bedient  H08 0100
   Serial number: 00000000790361
   Component: CD-Database  1886
   Part No SW: 8K0 959 795 F    HW: 8K0 959 795 F
   Component: TSG HL        H11 0357
   Revision:             Serial number: 0000114666133
   Coding: 010C03204000240004
   Part No SW: 8R0 907 441 A    HW: 4L0 907 441 B
   Revision: --H05---    Serial number: 525PA8-J12A0KI
   Coding: 1020010
   VCID: B42446B9D7DA0AEFF3-80E0
   Part No SW: 8R0 827 851 B    HW: 8R0 827 851 B
   Component: J605  Master  H51 0330
   Revision: --------    Serial number: 8R0827851B
   VCID: BB366D853A84C59732-80EE
   Subsystem 1 - Part No SW: 8R0 827 852 B    HW: 8R0 827 852 B
   Component: J756  Slave  H51 0330
   Serial number: 8R0827852B
   Component: TSG HR        H11 0357
   Revision:             Serial number: 0000114666130
End----------(Elapsed Time: 01:51, VBatt start/end: 13.6V/13.7V)-----------
Tuesday,08,October,2019,16:27:00:57829
Mode 10: Permanent Fault Codes
__________________________________________
Tuesday,08,October,2019,16:27:33:57829
Mode 03: Emission related fault codes
Mode 07: Pending emission related fault codes
Address 7E8: No fault code found.
Address 7E9: No fault code found.
Tuesday,08,October,2019,16:28:00:57829
Tuesday,08,October,2019,16:29:08:57829
Mode 9 : Calibration Identification
Type 02 - VIN : WA1LFAFP4BA103189 (Address E8)
Type 04 - Calibration ID : 8R0907115P Q0002 (Address E8)
Type 04 - Calibration ID : 8R0158T 100322   (Address E9)
Type 06 - Calibration Verification Number : 35256D79 (Address E8)
Type 06 - Calibration Verification Number : 4954B6B1 (Address E9)
Type 08 - In-use performance tracking :
    OBD Monitoring Conditions Encountered count : 1896
    Ignition cycle count : 6538
    Conditions completion count / Specified conditions encountered count
         Catalyst monitor bank 1 : 3322 / 1881
         Catalyst monitor bank 2 : 0 / 0
         O2 Sensor monitor bank 1 : 2430 / 1896
         O2 Sensor monitor bank 2 : 0 / 0
         EGR-VVT monitor : 4808 / 1896
         AIR monitor : 0 / 0
         EVAP monitor : 48 / 247
         Secondary O2 Sensor monitor bank 1 : 2829 / 1881
         Secondary O2 Sensor monitor bank 2 : 0 / 0
Type 0A - Controller Name : ECM-EngineControl (Address E8)
Type 0A - Controller Name : TCM-TransmisCtrl (Address E9)
Tuesday,08,October,2019,16:29:30:57829
Mode 01 - PID 01 : Readiness  --  Address 7E8
Number of DTCs stored: 0  --  MIL Status: MIL OFF
Misfire monitoring:  Passed
Fuel System:  Passed
Comprehensive Components:  Passed
Catalyst monitoring:  Passed
Heated catalyst monitoring: Not installed.
Evaporative system monitoring:  Passed
Secondary air system monitoring: Not installed.
A/C system refrigerant monitoring: Not installed.
Oxygen sensor monitoring:  Passed
Oxygen sensor heater monitoring:  Passed
Exhaust Gas Recirculation:  Passed
This makes little sense to me, with no faults showing in native VAG mode, none in any of the three generic OBD modes, and OBD Readiness explicitly claiming "Number of DTCs stored: 0".
Is there any history of misfire codes in this car?
Shzeps
C?ID=11561
I am sure it did have misfires at some point. This is a shop car and has been sitting around for a while.
Here is a pic of the codes.
Shzeps
C?ID=11561
Uwe would it help to log anything and send it. I would be glad to help further development.
Well, what would be most interesting is a log of what those other tools are doing when they pull those codes. If you were local, I'd say bring the car by so we can have a look at it with some other tools we have, but I think your distance to us precludes that.
Let me ask this in a straightforward manner: Is is this ECU tuned?
Shzeps
C?ID=11561
No everything is stock. I will keep an eye out for another car with a PD DTC and then see if it is detected by VCDS and report back.
Andy
Sector 7G
HC424490
Thanks for the details, this is helping us to look into this.
