VW T6.1 Transporter ROD Files missing
corrado1441
C?ID=165274
Hello currently have latest version of ross-tech 19.6.2 running on a 2020 VW T6.1 Transporter. It says some ROD files are missing. I have downloaded the latest beta files that VCDS can find but still no luck.
Wednesday,19,February,2020,12:36:52:53429
VCDS Version: 19.6.2.0 (x64)  HEX-NET CB: 0.4513.4
Dealer/Shop Name: Bespoke Services
VIN: WV1ZZZ7HZLX007504   License Plate:
Mileage: 138   Repair Order:
Chassis Type: 7H-VN75 (3Q0)
Scan: 01 03 08 09 10 13 15 17 19 44 5F 65 75
65-Tire Pressure -- Status: Cannot be reached 0100
Address 01: Engine (J623-CXHA)       Labels: None
   Part No SW: 04L 906 056 RS    HW: 04L 907 445 M
   Component: R4 2.0l TDI   H01 9705
   Revision: 23301001
   Coding: 001940144344050900000000000000000000000000000000
   Shop #: WSC 00035 377 00146
   ASAM Dataset: EV_ECM20TDI03004L906056RS 004007
   ROD: EV_ECM20TDI03004L906056LE.rod
   VCID: 0F6E4E04D68DD9372E-805A
Readiness: N/A
   Part No SW: 7LB 614 517 A    HW: 7LB 614 517
   Component: ESC_base      H01 0700
   Serial number: 08508555191030
   Coding: 305524524847EE8C0C5924A4126A7706392320B8
   Shop #: WSC 00035 377 00127
   ASAM Dataset: EV_Brake1ESP90iBOSCHVN46X 002010
   ROD: EV_Brake1ESP90iBOSCHVN46X.rod
   VCID: 3E30C3C0A1A700BF95-806A
Address 08: Auto HVAC (J301)       Labels: None
   Part No SW: 7LA 907 426     HW: 7LA 907 426
   Component: AC Manuell    H01 0502
   Coding: A03110000810000001000800504001050000000000010000800000000000
   ASAM Dataset: EV_AirCondiBHTCT6PA 001004
   ROD: N/A
   VCID: 55E27C6C34D1E3E7A4-8000
No ASAM data for: "EV_AirCondiBHTCT6PA" (VN75)
   Part No SW: 2Q5 937 090     HW: 2Q5 937 090
   Component: BCM T6PA Std+ H10 0935
   Serial number: 01101931600981
   Shop #: WSC 00035 377 00145
   ASAM Dataset: EV_BCMA0 205001
   ROD: EV_BCMA0_204.rod
   VCID: 74A421E8DF6B9AEFB3-8020
   Subsystem 1 - Part No SW: 5Q0 955 559 B    HW: 5Q0 955 559 B  Labels: 5Q0-955-547.CLB
   Component: RLS  050 0105
   Serial number: S5Y19M10D11H17M22S55
   Coding: 02B8EE
   Drivers Door Control Module:
   Subsystem 2 - Part No SW: 7L1 959 405 B    HW: 7L1 959 163 B
   Component: FHSG_DRV  001 0002
   Serial number: 00000000000035228373
   Coding: 1F0007
   Subsystem 3 - Part No SW: 7L1 959 406 B    HW: 7L1 959 164 B
   Component: FHSG_PSG  001 0002
   Serial number: 00000000000035230695
   Coding: 050007
   Serial number: 000000000ZY193003SEC
   Serial number: 00000000000031899304
   Part No SW: 5QA 919 294 G    HW: 5QA 919 294
   Component: PDC 8 Kanal   H08 0061
   Serial number: 000150058419315
   Coding: 0471151801
   ASAM Dataset: EV_EPHVA18AU3700000 009046
   ROD: EV_EPHVA18AU3700000_003.rod
   VCID: 50EC8D780B3386CF77-8004
Address 13: Auto Dist. Reg (J428)       Labels:. 2Q0-907-572.clb
   Part No SW: 2Q0 907 572 R    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H03 0372
   Coding: 2A00600241FF8748949C815560508700000000000000000004
   ASAM Dataset: EV_ACCMRRCONTIVW376 003016
   VCID: 43C6B234CA456D57FA-8016
   Part No SW: 2Q0 959 655 AD    HW: 2Q0 959 655 AD
   Component: VW22Airbag    013 0506
   Revision: --------
   Coding: 8800C00000000000400000CF008C40000065
   ASAM Dataset: EV_AirbaVW22BPAVW27X 001022
   ROD: EV_AirbaVW22BPAVW27X.rod
   VCID: 7F4EFEC4E62DC9B7DE-802A
Address 17: Instruments (J285)       Labels: None
   Part No SW: 7LA 920 941     HW: 7LA 920 941
   Component: KOMBI         204 6750
   Coding: 27A40A802480260001886A050401000000600000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009069
   ROD: N/A
   VCID: 7DB204CCEC21DBA7CC-8028
No ASAM data for: "EV_DashBoardVDDMQBAB" (VN75)
16777014 - ROD - Unknown Error Code
          - 00 [009]
                    Reset counter: 7
                    Mileage: 222 km
                    Date: 2020.02.19
                    Time: 12:32:00
16776989 - ROD - Unknown Error Code
          - 00 [009]
                    Reset counter: 7
                    Mileage: 222 km
                    Date: 2020.02.19
                    Time: 12:31:57
   Part No SW: 3Q0 907 530 AC    HW: 3Q0 907 530 C
   Component: GW MQB High   521 5388
   Serial number: 18111911600665
   Coding: 030100344F05730400000018000F00010001070000000000000000000000
   ASAM Dataset: EV_GatewNF 013026
   ROD: EV_GatewNF.rod
   VCID: 70AC2DF8AB73A6CF57-8024
   Component: 4-01-09-01-04
   Subsystem 2 - Part No SW: 3G0 959 442 F    HW: 3G0 959 442 F
   Component: E221__MFL-PR6  H06 0110
   Serial number: PR6-0440066319191939
   Coding: 2C1D00
   Subsystem 3 - Part No SW: 7E0 915 181 N    HW: 7E0 915 181 N
   Component: J367-BDMConti  H03 1052
   Serial number: 773433010019110600A5
131595 - Tire Pressure Monitoring Module
          U0127 00 [009] - No Communications
          [Timeout Knoten 0x0B / 65 - Steuergerät für Reifendrucküberwachung]
                    Reset counter: 7
                    Mileage: 222 km
                    Date: 2020.02.19
                    Time: 12:31:58
                    Supply voltage: Terminal 30: 11.7 V
                    Terminal 15: On
Address 44: Steering Assist (J500)       Labels: None
   Part No SW: 7LA 909 144 F    HW: 7LA 909 144 D
   Component: EPS_MQB_ZFLS  751 7150
   Coding: 0106
   ASAM Dataset: EV_SteerAssisMNB 002012
   ROD: N/A
   VCID: 45C2AC2CC4715367D4-8010
No ASAM data for: "EV_SteerAssisMNB" (VN75)
   Part No SW: 3G5 035 820     HW: 3G5 035 820
   Component: MU-O-ND-EU    H12 0156
   Serial number: VWZAZ2W1188315
   Coding: 64600008000020000000000000000000000000000000000000
   ASAM Dataset: EV_MUOIMQB 001001
   ROD: N/A
   VCID: 618A58BC70991F47C8-8034
No ASAM data for: "EV_MUOIMQB" (VN75)
7175 - ROD - Unknown Error Code
          - 00 [009]
                    Reset counter: 40
                    Mileage: 222 km
                    Date: 2020.02.19
                    Time: 12:32:00
Address 65: Tire Pressure
Address 75: Telematics (J949)       Labels: None
   Part No SW: 5WA 035 284     HW: 5WA 035 284
   Component: OCUGen3High   H20 0083
   Serial number: 0000000908VIMU9
   Coding: 06462000196898209005460160000607
   ASAM Dataset: EV_OCUGen3High 002115
   ROD: N/A
   VCID: 034672348AC5AD57BA-8056
No ASAM data for: "EV_OCUGen3High" (VN75)
7170 - ROD - Unknown Error Code
          - 00 [008]
                    Reset counter: 40
                    Mileage: 222 km
                    Date: 2020.02.19
                    Time: 12:32:01
End----(Elapsed Time: 01:14, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
I am confident these will be covered when a public version 20.x Beta is released. :)
pauli-und-greta
Switzerland
C?ID=395147
Hi all
I wanted to code the N279 of my Multivan T6.1 to heat also the cooling circuit of the engine - unfortunately I have the same issue with 19.6.2
I attach also the autoscan:
Samstag,21,März,2020,15:35:49:61222
VCDS -- Windows-basierter VAG/VAS-Emulator läuft auf Windows 10 x64
VCDS Version: AIB 19.6.2.1  HEX-V2 CB: 0.4508.4
Datenstand: 20200302 DS308.0
www.vcds.de
Fahrzeug-Ident.-Nr.: WV2ZZZ7HZLH048100   KFZ-Kennzeichen:
Kilometerstand: 90   Reparaturauftrag:
Fahrzeugtyp: 7H-VN75 (3Q0)
Scan: 01 02 03 08 09 10 13 14 15 17 18 19 22 3C 44 55 5F 69 6D 75
          A5 D6 D7
01-Motorelektronik -- Status: i.O. 0000
02-Getriebe -- Status: i.O. 0000
03-Bremsenelektronik -- Status: i.O. 0000
08-Klima-/Heizungsel. -- Status: i.O. 0000
09-Zentralelektrik -- Status: i.O. 0000
10-Einparkhilfe 2 -- Status: i.O. 0000
13-Distanzregelung -- Status: i.O. 0000
14-Raddämpfung -- Status: i.O. 0000
15-Airbag -- Status: i.O. 0000
17-Schalttafeleinsatz -- Status: Fehler 0010
18-Standheizung -- Status: i.O. 0000
19-Diagnoseinterface -- Status: i.O. 0000
22-Allrad -- Status: i.O. 0000
3C-Spurwechsel -- Status: i.O. 0000
44-Lenkhilfe -- Status: i.O. 0000
55-Leuchtweitenreg. -- Status: i.O. 0000
5F-Informationselek. I -- Status: i.O. 0000
69-Anhänger -- Status: i.O. 0000
6D-Heckklappe -- Status: i.O. 0000
75-Telematik -- Status: Fehler 0010
A5-Front-/Vorfeldkamera -- Status: i.O. 0000
D6-Lichtsteuerung links 2 -- Status: i.O. 0000
D7-Lichtsteuerung rechts 2 -- Status: i.O. 0000
Adresse 01: Motorelektronik (J623-CXFA)       Labeldatei: Keine
   Teilenummer SW: 04L 906 056 QJ    HW: 04L 907 445 M
   Bauteil: R4 2.0l TDI   H01 9696
   Revision: 23301001
   Codierung: 0025401C4366050800000000000000000000000000000000
   Betriebsnr.: WSC 00012 790 00025
   ASAM Datensatz: EV_ECM20TDI03004L906056QJ 004004
   ROD: EV_ECM20TDI03004L906056QF.rod
   VCID: 0556687465AFD44FFA0-8050
Readiness: Nicht Verfügbar
Adresse 02: Getriebe (J743)       Labeldatei: DRV\0BH-927-711.clb
   Teilenummer SW: 0BT 300 012 E    HW: 0GC 927 711 H
   Bauteil: GSG DQ500     H06 3105
   Revision: 00H06V11
   Codierung: 0014
   Betriebsnr.: WSC 00000 000 00000
   ASAM Datensatz: EV_TCMDQ500021 001001
   ROD: EV_TCMDQ500021_VW36.rod
   VCID: 313EECA481A7A8EF768-8064
Adresse 03: Bremsenelektronik (J104)       Labeldatei: Keine
   Teilenummer SW: 7LA 614 517 A    HW: 7LA 614 517
   Bauteil: ESC_high      H01 0700
   Seriennummer: 08512742200124
   Codierung: 10554452C84BE68D085522A413666766383720B8
   ASAM Datensatz: EV_Brake1ESP90iBOSCHVN46X 002010
   VCID: 3D26C0944DFF5C8FE20-8068
Adresse 08: Klima-/Heizungsel. (J255)       Labeldatei: Keine
   Teilenummer SW: 7LA 907 040 A    HW: 7LA 907 040 A
   Bauteil: Climatronic   H01 0502
   Codierung: 0030100008101100010009005040010500000000000B1101A08000000000
   ASAM Datensatz: EV_AirCondiBHTCT6PA 001004
   ROD: n.v.
   VCID: 392ED48459D760AFCE8-806C
   Subsystem 1 - Teilenummer SW: 7LA 907 049 D    HW: 7LA 907 049 D
   Bauteil: E857  H02 0301
   Seriennummer: 00005066064509121312
   Subsystem 2 - Teilenummer SW: 7LA 907 049 F    HW: 7LA 907 049 F
   Seriennummer: 00002160120140459602
   Codierung: 000000
Keine ASAM Daten verfügbar: "EV_AirCondiBHTCT6PA" (VN75)
Adresse 09: Zentralelektrik (J519)       Labeldatei: Keine
   Teilenummer SW: 2Q5 937 090     HW: 2Q5 937 090
   Bauteil: BCM T6PA Std+ H10 0935
   Seriennummer: 01102003700124
   Betriebsnr.: WSC 00012 790 00067
   ASAM Datensatz: EV_BCMA0 205001
   VCID: 74B025B03E35DDC7DDE-8020
   Sensor für Regen- und Lichterkennung:
   Subsystem 1 - Teilenummer SW: 5Q0 955 559 B    HW: 5Q0 955 559 B  Labeldatei: DRV\5Q0-955-547.CLB
   Bauteil: RLS  050 0105
   Seriennummer: S4Y20M01D03H12M21S31
   Codierung: 02B8EE
   Türsteuergerät Fahrerseite:
   Subsystem 2 - Teilenummer SW: 7L2 959 405 B    HW: 7L2 959 163 B
   Bauteil: FHSG_DRV  001 0002
   Seriennummer: 00000000000037989366
   Codierung: 130007
   Türsteuergerät Beifahrerseite:
   Subsystem 3 - Teilenummer SW: 7L2 959 406 B    HW: 7L2 959 164 B
   Bauteil: FHSG_PSG  001 0002
   Seriennummer: 00000000000038015494
   Codierung: 090007
Adresse 10: Einparkhilfe 2 (J791)       Labeldatei:| DRV\5Q0-919-298.clb
   Teilenummer SW: 5QA 919 298 H    HW: 5QA 919 298 A
   Bauteil: PLA 3.0 12K   H08 0061
   Seriennummer: 000150057220032
   Codierung: 0279167851
   ASAM Datensatz: EV_EPHVA2CAU3700000 009048
   ROD: EV_EPHVA2CAU3700000.rod
   VCID: 55F67834D58FA4CFCA0-8000
Adresse 13: Distanzregelung (J428)       Labeldatei:. 2Q0-907-572.clb
   Teilenummer SW: 2Q0 907 572 R    HW: 2Q0 907 572 B
   Bauteil: ACCCONTIMQB   H03 0372
   Codierung: 3204678B49FF8748949C815580508700000000000000000004
   ASAM Datensatz: EV_ACCMRRCONTIVW376 003016
   VCID: 43D2B66C2B1B2A7F944-8016
Adresse 14: Raddämpfung (J250)       Labeldatei: 5Q0-907-376.clb
   Teilenummer SW: 5Q0 907 376 C    HW: 5Q0 907 376 A
   Bauteil: DAEMPFUNGS-SG H17 0130
   Seriennummer: 03012041350574
   ASAM Datensatz: EV_DRCONTITEMIC 001019
   ROD: n.v.
Keine ASAM Daten verfügbar: "EV_DRCONTITEMIC" (VN75)
Adresse 15: Airbag (J234)       Labeldatei:* Keine
   Teilenummer SW: 2Q0 959 655 AE    HW: 2Q0 959 655 AE
   Bauteil: VW22Airbag    015 0506
   Revision: --------
   Codierung: 88CFC00000000000800000CF000C40000065
   ASAM Datensatz: EV_AirbaVW22BPAVW27X 001022
   VCID: 005879607A8DF167C96-8054
   Crashsensor für Seitenairbag Fahrerseite:
   Subsystem 1 - Teilenummer SW: -----------    HW: 442 062 801 20
   Bauteil: SideSensor_Df  1E2 0887
   Seriennummer: 3577Y519933C68C4F2DT
   Codierung: 2D2D2D
   Crashsensor für Seitenairbag Beifahrerseite:
   Subsystem 2 - Teilenummer SW: -----------    HW: 442 062 801 20
   Bauteil: SideSensor_Pf  1E2 0887
   Seriennummer: 3587Y51A53398AA124DC
   Codierung: 2D2D2D
   Crashsensor für Seitenairbag hinten Fahrerseite:
   Subsystem 3 - Teilenummer SW: -----------    HW: 442 0D2 401 20
   Bauteil: SideSensor_Dr  30F 1108
   Seriennummer: 351CF11C733144D1E48Q
   Codierung: 2D2D2D
   Crashsensor für Seitenairbag hinten Beifahrerseite:
   Subsystem 4 - Teilenummer SW: -----------    HW: 442 0D2 401 20
   Bauteil: SideSensor_Pr  30F 1108
   Seriennummer: 352CF11C733144D2555H
   Codierung: 2D2D2D
Adresse 17: Schalttafeleinsatz (J285)       Labeldatei: Keine
   Teilenummer SW: 7LA 920 320     HW: 7LA 920 320
   Bauteil: KOMBI         503 4193
   Codierung: 04A408087D8C00080188620B1001000800601E02
   ASAM Datensatz: EV_DashBoardVDDMQBA0 001042
   ROD: n.v.
Keine ASAM Daten verfügbar: "EV_DashBoardVDDMQBA0" (VN75)
1 Fehler gefunden:
16711681 - ROD - Unbekannter Fehlercode
          - 00 [008]
          Sporadisch - bestätigt - geprüft seit letzter Löschung
             Umgebungsbedingungen:
                    Fehlerstatus: 00000001
                    Fehlerpriorität: 4
                    Fehlerhäufigkeit: 10
                    Verlernzähler: 44
                    Kilometerstand: 85 km
                    Datum: 2020.03.21
                    Zeit: 14:57:22
Adresse 18: Standheizung (J364)       Labeldatei: Keine
   Teilenummer SW: 5WA 963 272 A    HW: 5WA 963 272 A
   Bauteil: STH-VW37x     006 0010
   Seriennummer: 000000000000002
   Codierung: 3543222054121512DCE519
   ASAM Datensatz: EV_AuxilHeateWOSVW38X 001009
   ROD: n.v.
   VCID: 4BC29E4C034BE23F6C4-801E
Keine ASAM Daten verfügbar: "EV_AuxilHeateWOSVW38X" (VN75)
Adresse 19: Diagnoseinterface (J533)       Labeldatei:| DRV\3Q0-907-530-V1.clb
   Teilenummer SW: 3Q0 907 530 AC    HW: 3Q0 907 530 C
   Bauteil: GW MQB High   521 5388
   Seriennummer: 25012010520609
   Codierung: 030100344F05730499100218900F00010001070000000000000000000000
   ASAM Datensatz: EV_GatewNF 013026
   ROD: EV_GatewNF.rod
   VCID: 70B829A04A2DE1E7396-8024
   Generator:
   Bauteil: 4-00-11-01-04
   Steuergerät für Multifunktionslenkrad:
   Subsystem 2 - Teilenummer SW: 3G0 959 442 F    HW: 3G0 959 442 F
   Bauteil: E221__MFL-PR6  H06 0110
   Seriennummer: PR6-0440036028200972
   Codierung: 2C1D00
   Steuergerät für Batterieüberwachung:
   Subsystem 3 - Teilenummer SW: 7E0 915 181 L    HW: 7E0 915 181 L
   Bauteil: J367-BDMConti  H03 1051
   Seriennummer: 77197200001912070507
Adresse 22: Allrad (J492)       Labeldatei:* DRV\0CQ-907-554.clb
   Teilenummer SW: 0CQ 907 554 L    HW: 0CQ 525 130 C
   Bauteil: Haldex4Motion H56 7822
   Seriennummer: HA1-00011.12.19
   Codierung: 0001
   ASAM Datensatz: EV_AllWheelContrHA1VW37X 004013
   VCID: 4EC49758F059D7170BA-801A
Adresse 3C: Spurwechsel (J1086)       Labeldatei:* Keine
   Teilenummer SW: 2Q0 907 686 B    HW: 2Q0 907 686 B
   Bauteil: HRE3_Kl15_Mst H06 0150
   Seriennummer: 00000536744459
   Codierung: 52954640
   ASAM Datensatz: EV_HREntryHellaGen3Kl15 002001
   ROD: EV_HREntryHellaGen3Kl15.rod
Adresse 44: Lenkhilfe (J500)       Labeldatei:. DRV\2N0-909-143.clb
   Teilenummer SW: 7LA 909 144 F    HW: 7LA 909 144 D
   Bauteil: EPS_MQB_ZFLS  751 7150
   Codierung: 9306
   ASAM Datensatz: EV_SteerAssisMNB 002012
   ROD: n.v.
   VCID: 45D6A874252F144FBA0-8010
Keine ASAM Daten verfügbar: "EV_SteerAssisMNB" (VN75)
Adresse 55: Leuchtweitenreg. (J745)       Labeldatei:. DRV\7P6-907-357.clb
   Teilenummer SW: 7P6 907 357 E    HW: 7P6 907 357 A
   Bauteil: AFS-ECU       H07 0080
   Revision: --------    Seriennummer: --------------
   Codierung: 0C82020009210003
   Betriebsnr.: WSC 00012 790 00156
   ASAM Datensatz: EV_HeadlRegulAFSMQBMAX 001001
   ROD: n.v.
   VCID: 41DEBC643107386F868-8014
Keine ASAM Daten verfügbar: "EV_HeadlRegulAFSMQBMAX" (VN75)
Adresse 5F: Informationselek. I (J794)       Labeldatei: Umleit. fehlgeschl.!
   Teilenummer SW: 3G5 035 816     HW: 3G5 035 816
   Bauteil: MU-O-ND-EU    H12 0156
   Seriennummer: VWZAZ2X0532799
   Codierung: 64600000000020000000000000000000000000000000000000
   ASAM Datensatz: EV_MUOIMQB 001001
   ROD: n.v.
   VCID: 66944FF878E93F5753A-8032
Keine ASAM Daten verfügbar: "EV_MUOIMQB" (VN75)
Adresse 69: Anhänger (J345)       Labeldatei: Keine
   Teilenummer SW: 5H0 907 383     HW: 5H0 907 383
   Bauteil: Anhaenger     H09 0040
   Seriennummer: 000000000005412
   Codierung: 0100000202001300
   ASAM Datensatz: EV_TrailFunctGener3Hella 001009
   ROD: n.v.
   VCID: 6B823ECC630B023F0C4-803E
Keine ASAM Daten verfügbar: "EV_TrailFunctGener3Hella" (VN75)
Adresse 6D: Heckklappe (J605)       Labeldatei:* Keine
   Teilenummer SW: 7LA 959 107     HW: 4M0 959 107 C
   Bauteil: HDSG-Modul    H14 0672
   Revision: --------    Seriennummer: A2-C769-9790-2
   Codierung: 4100
   ASAM Datensatz: EV_DeckLidCONTIVN46T 001017
   ROD: EV_DeckLidCONTIVN46T.rod
   VCID: 0352766C6B9BEA7FD44-8056
Adresse 75: Telematik (J949)       Labeldatei: Keine
   Teilenummer SW: 5WA 035 284     HW: 5WA 035 284
   Bauteil: OCUGen3High   H20 0088
   Seriennummer: 0000000911VISM5
   Codierung: 06462000196898209005460160500607
   ASAM Datensatz: EV_OCUGen3High 002115
   ROD: n.v.
Keine ASAM Daten verfügbar: "EV_OCUGen3High" (VN75)
2 Fehlercodes gefunden:
1190912 - ROD - Unbekannter Fehlercode
          - 00 [008]
                    Fehlerpriorität: 4
                    Verlernzähler: 40
                    Datum: 2020.03.21
                    Zeit: 14:57:23
0081 - ROD - Unbekannter Fehlercode
          - 00 [008]
                    Fehlerpriorität: 6
                    Fehlerhäufigkeit: 11
                    Verlernzähler: 40
                    Kilometerstand: 13 km
                    Datum: 2020.03.16
                    Zeit: 15:57:54
Adresse A5: Front-/Vorfeldkamera (R242)       Labeldatei:* Keine
   Teilenummer SW: 2Q0 980 653     HW: 2Q0 980 653
   Bauteil: MQB MFK 3.0   H11 1029
   Seriennummer: E33417011200010
   Codierung: 000108882178C020409F00001030000006010000000000000000000000000000
   ASAM Datensatz: EV_MFK3ValeoMQB 005035
   ROD: EV_MFK3ValeoMQB_004.rod
   VCID: 72BC23A84421D3F7CF2-8026
Adresse D6: Lichtsteuerung links 2 (A31)       Labeldatei: 7PP-941-572.clb
   Teilenummer SW: 992 941 571 AA    HW: 992 941 571 A
   Bauteil: LED1L         H08 9002
   ASAM Datensatz: EV_LLPGen3LKEBODPO68X 001003
   ROD: EV_LLPGen3LKEBODPO68X.rod
   VCID: 619E5CE491C7586FA68-8034
Adresse D7: Lichtsteuerung rechts 2 (A27)       Labeldatei: 7PP-941-572.clb
   Bauteil: LED1R         H08 9002
   ASAM Datensatz: EV_LLPGen3RKEBODPO68X 001003
Ende--(Dauer: 01:23, Batt.-Spannung Start/Ende: 11.9V/11.9V. VIgn 11.9V)---
Looking forwart to the 20.x beta :)
Cheers
P&G
PetrolDave
Westbury, UK
C?ID=1423
It would be better if you make sure you install the English version of VCDS (it can be installed alongside your German version) and use that when posting here - most of us don't speak German!
hadez16
C?ID=289891
Try the newest 20.4 Release :)
@Uwe
are there any detailed release notes?
nirvananils
C?ID=289109
Changelog would be nice. Maybe it´s possible @Uwe ?
pauli-und-greta
Switzerland
C?ID=395147
I finally had some time to use VCDS 20.4 for a new autoscan in English ;-).
I'm still looking for some support how to change N279 to engine preheat instead of heating only the drivers cabin.
Code of the Auxiliary Heater.
Address 18: Aux. Heat (J364)       Labels:* None
   Part No SW: 5WA 963 272 A    HW: 5WA 963 272 A
   Component: STH-VW37x     006 0010
   Serial number: 000000000000002
   Coding: 3543222054121512DCE519
   ASAM Dataset: EV_AuxilHeateWOSVW38X 001009
   ROD: EV_AuxilHeateWOSVW38X_VW27.rod
   VCID: 4BC29E4C034BE233F60-801E
I also prepared some screenshots of the diffent pages/settings of the Auxiliary Heater - unfortunately I didn´t save them properly.
I'll add the to this post asap, but maybe the solution is quite obvious to an expert.
Thank you for your help!
Here's the full scan:
Saturday,11,April,2020,12:49:06:61222
VIN: WV2ZZZ7HZLH048100   License Plate:
Mileage: 391km-242mi   Repair Order:
Chassis Type: 7H-VN46 (3Q0)
          A5 D6 D7
VIN: WV2ZZZ7HZLH048100   Mileage: 391km-242miles
Address 01: Engine (J623-CXFA)       Labels: None
   Part No SW: 04L 906 056 QJ    HW: 04L 907 445 M
   Component: R4 2.0l TDI   H01 9696
   Revision: 23301001
   Coding: 0025401C4366050800000000000000000000000000000000
   Shop #: WSC 00012 790 00025
   ASAM Dataset: EV_ECM20TDI03004L906056QJ 004004
   ROD: EV_ECM20TDI03004L906056QE.rod
   VCID: 0556687465AFD443604-8050
Readiness: N/A
   Part No SW: 0BT 300 012 E    HW: 0GC 927 711 H
   Component: GSG DQ500     H06 3105
   Revision: 00H06V11
   ROD: EV_TCMDQ500021_VN46.rod
   VCID: 313EECA481A7A8E3ECC-8064
   Part No SW: 7LA 614 517 A    HW: 7LA 614 517
   Component: ESC_high      H01 0700
   Serial number: 08512742200124
   Coding: 10554452C84BE68D085522A413666766383720B8
   ROD: EV_Brake1ESP90iBOSCHVN46X_002.rod
   VCID: 3D26C0944DFF5C83784-8068
Address 08: Auto HVAC (J255)       Labels:* None
   Part No SW: 7LA 907 040 A    HW: 7LA 907 040 A
   Component: Climatronic   H01 0502
   Coding: 0030100008101100010009005040010500000000000B1101A08000000000
   ROD: EV_AirCondiBHTCT6PA.rod
   VCID: 392ED48459D760A354C-806C
   Operating and display unit 1 for air conditioning:
   Subsystem 1 - Part No SW: 7LA 907 049 D    HW: 7LA 907 049 D
   Component: E857  H02 0301
   Serial number: 00005066064509121312
   Subsystem 2 - Part No SW: 7LA 907 049 F    HW: 7LA 907 049 F
   Serial number: 00002160120140459602
   Serial number: 01102003700124
   Shop #: WSC 00012 790 00067
   ROD: EV_BCMA0_205.rod
   VCID: 74B025B03E35DDCB47A-8020
   Serial number: S4Y20M01D03H12M21S31
   Coding: 02B8EE
   Subsystem 2 - Part No SW: 7L2 959 405 B    HW: 7L2 959 163 B
   Serial number: 00000000000037989366
   Coding: 130007
   Subsystem 3 - Part No SW: 7L2 959 406 B    HW: 7L2 959 164 B
   Serial number: 00000000000038015494
   Coding: 090007
   Part No SW: 5QA 919 298 H    HW: 5QA 919 298 A
   Component: PLA 3.0 12K   H08 0061
   Serial number: 000150057220032
   Coding: 0279167851
   ASAM Dataset: EV_EPHVA2CAU3700000 009048
   ROD: EV_EPHVA2CAU3700000_VW27.rod
   VCID: 55F67834D58FA4C3504-8000
   Coding: 3204678B49FF8748949C815580508700000000000000000004
   ROD: EV_ACCMRRCONTIVW376_003_VW27.rod
   VCID: 43D2B66C2B1B2A730E0-8016
   Part No SW: 5Q0 907 376 C    HW: 5Q0 907 376 A
   Component: DAEMPFUNGS-SG H17 0130
   Serial number: 03012041350574
   ROD: EV_DRCONTITEMIC_VW27.rod
   Part No SW: 2Q0 959 655 AE    HW: 2Q0 959 655 AE
   Component: VW22Airbag    015 0506
   Revision: --------
   Coding: 88CFC00000000000800000CF000C40000065
   ROD: EV_AirbaVW22BPAVW27X_VW27.rod
   VCID: 005879607A8DF16B532-8054
   Subsystem 1 - Part No SW: -----------    HW: 442 062 801 20
   Serial number: 3577Y519933C68C4F2DT
   Subsystem 2 - Part No SW: -----------    HW: 442 062 801 20
   Serial number: 3587Y51A53398AA124DC
   Subsystem 3 - Part No SW: -----------    HW: 442 0D2 401 20
   Component: SideSensor_Dr  30F 1108
   Serial number: 351CF11C733144D1E48Q
   Subsystem 4 - Part No SW: -----------    HW: 442 0D2 401 20
   Component: SideSensor_Pr  30F 1108
   Serial number: 352CF11C733144D2555H
Address 17: Instruments (J285)       Labels:* None-SRI3
   Part No SW: 7LA 920 320     HW: 7LA 920 320
   Component: KOMBI         503 4193
   Coding: 04A408087D8C00080188620B1001000800601E02
   ASAM Dataset: EV_DashBoardVDDMQBA0 001042
   ROD: EV_DashBoardVDDMQBA0_VW27.rod
16777018 - Function Restricted due to Interrupted Communications
          U1110 00 [008] - -
          [BAP_Audio_0x31 keine Kommunikation]
                    Reset counter: 53
                    Mileage: 264 km
                    Date: 2020.04.01
                    Time: 18:50:19
16711681 - Ethernet Databus
          U11C4 00 [008] - No Communications
                    Fault Frequency: 79
                    Reset counter: 56
                    Mileage: 85 km
                    Date: 2020.03.21
                    Time: 14:57:22
   Serial number: 25012010520609
   Coding: 030100344F05730499100218900F00010001070000000000000000000000
   ROD: EV_GatewNF_VW27.rod
   VCID: 70B829A04A2DE1EBA32-8024
   Component: 4-00-11-01-04
   Serial number: PR6-0440036028200972
   Coding: 2C1D00
   Subsystem 3 - Part No SW: 7E0 915 181 L    HW: 7E0 915 181 L
   Component: J367-BDMConti  H03 1051
   Serial number: 77197200001912070507
   Part No SW: 0CQ 907 554 L    HW: 0CQ 525 130 C
   Component: Haldex4Motion H56 7822
   Serial number: HA1-00011.12.19
   Coding: 0001
   VCID: 4EC49758F059D71B91E-801A
Address 3C: Lane Change (J1086)       Labels:* None
   Part No SW: 2Q0 907 686 B    HW: 2Q0 907 686 B
   Component: HRE3_Kl15_Mst H06 0150
   Serial number: 00000536744459
   Coding: 52954640
   ASAM Dataset: EV_HREntryHellaGen3Kl15 002001
Address 44: Steering Assist (J500)       Labels:| 2N0-909-143.clb
   Coding: 9306
   ROD: EV_SteerAssisMNB_VN46.rod
   VCID: 45D6A874252F1443204-8010
   Part No SW: 7P6 907 357 E    HW: 7P6 907 357 A
   Coding: 0C82020009210003
   Shop #: WSC 00012 790 00156
   ASAM Dataset: EV_HeadlRegulAFSMQBMAX 001001
   ROD: EV_HeadlRegulAFSMQBMAX_VW27.rod
   VCID: 41DEBC64310738631CC-8014
Address 5F: Information Electr. (J794)       Labels:* Redir Fail!
   Part No SW: 3G5 035 816     HW: 3G5 035 816
   Serial number: VWZAZ2X0532799
   Coding: 64600000000020000000000000000000000000000000000000
   ROD: EV_MUOIMQB_SE27.rod
   VCID: 66944FF878E93F5BC9E-8032
Address 69: Trailer (J345)       Labels:* None
   Part No SW: 5H0 907 383     HW: 5H0 907 383
   Component: Anhaenger     H09 0040
   Serial number: 000000000005412
   Coding: 0100000202001300
   ASAM Dataset: EV_TrailFunctGener3Hella 001009
   ROD: EV_TrailFunctGener3Hella_VW27.rod
   VCID: 6B823ECC630B0233960-803E
Address 6D: Trunk Elect. (J605)       Labels:* None
   Part No SW: 7LA 959 107     HW: 4M0 959 107 C
   Component: HDSG-Modul    H14 0672
   Revision: --------    Serial number: A2-C769-9790-2
   Coding: 4100
   ASAM Dataset: EV_DeckLidCONTIVN46T 001017
   VCID: 0352766C6B9BEA734E0-8056
Address 75: Telematics (J949)       Labels:* None
   Component: OCUGen3High   H20 0088
   Serial number: 0000000911VISM5
   Coding: 06462000196898209005460160500607
   ROD: EV_OCUGen3High_002_AU27.rod
2566 - GPS Antenna
          B1054 13 [008] - Open Circuit
          [GPS-Antenna - Interruption]
                    Reset counter: 40
                    Time: 00:00:00
                    Voltage terminal 30: 12.7 V
1190912 - Ethernet Databus Branch 1
          U122C 00 [008] - No Communication
                    Fault Frequency: 81
                    Reset counter: 37
                    Mileage: 85 km
                    Date: 2020.03.21
                    Time: 14:57:23
                    Ethernet counter checksum error: branch 1: 0
                    Ethernet counter connection interruptions: branch 1: 1
0081 - Databus
          [Ethernet Databus missing message - Infotainment Unit]
                    Fault Frequency: 81
                    Reset counter: 37
                    Mileage: 13 km
                    Date: 2020.03.16
                    Time: 15:57:54
                    Voltage terminal 30: 12.4 V
Address A5: Frt Sens. Drv. Assist (R242)       Labels:* None
   Part No SW: 2Q0 980 653     HW: 2Q0 980 653
   Component: MQB MFK 3.0   H11 1029
   Serial number: E33417011200010
   Coding: 000108882178C020409F00001030000006010000000000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 005035
   ROD: EV_MFK3ValeoMQB_005_VW27.rod
   VCID: 72BC23A84421D3FB556-8026
   Part No SW: 992 941 571 AA    HW: 992 941 571 A
   Component: LED1L         H08 9002
   ASAM Dataset: EV_LLPGen3LKEBODPO68X 001003
   ROD: EV_LLPGen3LKEBODPO68X_SK25.rod
   VCID: 619E5CE491C758633CC-8034
   Component: LED1R         H08 9002
   ASAM Dataset: EV_LLPGen3RKEBODPO68X 001003
End----------(Elapsed Time: 01:24, VBatt start/end: 12.1V/12.1V)-----------
Thanks again!
P&G
