AUDI A3 8V BLUETOOTH ACTIVATION
ib97
Croatia
C?ID=375363
Hello all,
tried to activate bluetooth for audio streaming on a3 8v but I wasn't successful.
It showed bluetooth actiated and other possible bits and controller accepted changes and nothing happened in the car.
Here is the auto-scan.
So if anyone can help, thank you in advance.
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 55 5F
VIN: WAUZZZ8V1Dxxxxxxx   Mileage: 117589km-73066miles
Address 01: Engine (J623-CMBA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 016 J    HW: 04E 907 309 A
   Component: R4 1.4l TFS   H13 9017
   Revision: WAH13---
   Coding: 02190032232401082000
   Shop #: WSC 35667 003 1048576
   ASAM Dataset: EV_ECM14TFS01104E906016J 002014
   ROD: EV_ECM14TFS01104E906016DE_AU37.rod
   VCID: 290E069BC977C63FBE9-807C
   Part No SW: 5Q0 907 379 AC    HW: 5Q0 907 379 D
   Component: ESC           H75 0437
   Coding: 10F16AA220212A6C017C060401CC290856045480608094F20239000805
   Shop #: WSC 18559 000 1048576
   ROD: EV_Brake1UDSContiMK100IPB_008_VW37.rod
   VCID: 7DA602CB6D7F8A9FA21-8028
   Part No SW: 8V0 820 043     HW: 8V0 820 043
   Component: AC Automat    H11 0031
   Revision: 20017000    Serial number: 00000000010586
   Coding: 00000004000000001000000000001000
   Shop #: WSC 06314 790 00021
   ASAM Dataset: EV_AirCondiFrontVaAU37X 008016
   VCID: 6FBA28833713E80F20D-803A
   Serial number: 34180B46000000000001
329988 - Motor for Defroster Flap
          B1090 71 [008] - Actuator stuck
                    Reset counter: 167
                    Mileage: 116788 km
                    Date: 2019.09.28
                    Time: 16:17:25
                    Voltage terminal 30: 13.9 V
                    Interior temperature: 29.2 °C
                    Outside air temperature: 17.5 °C
                    Defroster flap: specified value: 45
                    Defroster flap: actual value: 0
                    Defroster flap: actual value: 0.0 %
   Part No SW: 5Q0 937 084 Q    HW: 5Q0 937 084 Q
   Component: BCM MQBAB H   H14 0106
   Serial number: 00011225601025
   Coding: 04000A42C28120DD03044000001C0708000C000000000000000000000000
   ROD: EV_BCMBOSCH_010.rod
   VCID: 46D4AD2778290947B3B-8012
   Subsystem 1 - Part No SW: 8V1 955 119 A    HW: 8V1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 120801  041 0580
   Serial number:         120815083728
   Coding: 0A47F7
   Light switch:
   Subsystem 2 - Part No SW: 8V0 941 531 J    HW: 8V0 941 531 J
   Serial number: 21 07 2012  00000518
   Subsystem 3 - Part No SW: 8U0 955 559     HW: 8U0 955 559
   Serial number: 20167398
204546 - Remote key 2
                    Reset counter: 101
                    Mileage: 114984 km
                    Date: 2019.09.10
                    Time: 16:45:10
   Part No SW: 5Q0 919 283 A    HW: 5Q0 919 283
   Component: PARKHILFE 4K  009 0026
   Revision: --------    Serial number: 60831225102774
   Coding: 0000040001
   ASAM Dataset: EV_EPHVA14AU3700000 002015
   VCID: 372AD0E30FC360CF38D-8062
   Part No SW: 5Q0 959 655 L    HW: 5Q0 959 655 L
   Component: AirbagVW20    009 0349
   Serial number: 003GER007YY6
   Coding: 98CCC000000000005C540000004800000065
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 49CEA61B6937E63F5E9-801C
   Subsystem 1 - Part No SW: -----------    HW: 480 001 209 12
   Serial number: 35767000000C839DEB0C
   Subsystem 2 - Part No SW: -----------    HW: 480 001 209 12
   Serial number: 35867000000F7305DB0/
   Subsystem 3 - Part No SW: -----------    HW: 480 402 708 12
   Serial number: 35165029B0CAF171910C
   Subsystem 4 - Part No SW: -----------    HW: 480 402 708 12
   Serial number: 3526502A50C61721F095
   Subsystem 5 - Part No SW: -----------    HW: 480 401 408 12
   Serial number: 3556502A50C61722513.
   Part No SW: 8V0 953 521 B    HW: 5Q0 953 549 A
   Revision: --------    Serial number: 1409120003005Y
   Coding: A408
   ROD: EV_SMLSKLOMQB_009_VW37.rod
   VCID: 392ED6DB39D776BFCE9-806C
   Part No SW: 8V0 920 870     HW: 8V0 920 870
   Component: KOMBI         H23 0490
   Coding: 07A401002A80000801008800000000
   VCID: 78A813DF425DAFB7F17-802C
   Part No SW: 5Q0 907 530 J    HW: 5Q0 907 530 F
   Component: GW MQB High   122 1126
   Revision: --------    Serial number: 0000086952
   Coding: 030100F42B08640000000200000B00000001000000000000000000000000
   ASAM Dataset: EV_GatewLear 008010
   ROD: EV_GatewLear_008.rod
   VCID: 3828D3DF02DD6FB7317-806C
   Subsystem 2 - Part No SW: 8U0 951 528     HW: 8U0 951 528
   Serial number: 04 09 2012  C1046869
   Serial number: 6495868101
   Part No SW: 5Q0 959 393 A    HW: 5Q0 959 393
   Component: TSG FS        H12 0006
   Serial number: 25081200010399
   Coding: 001C0E204000040100001002
   VCID: 3D26C2CB2DFF4A9FE21-8068
   Part No SW: 5Q0 909 144 L    HW: 5Q0 909 144 K
   Coding: 01
   ROD: EV_SteerAssisMQB_008.rod
   Part No SW: 5Q0 959 392 A    HW: 5Q0 959 392
   Component: TSG BFS       H12 0006
   Serial number: 15081200010469
   Coding: 001C06204000040100001002
   VCID: 3C20CFCF36E54397D5F-8068
   Component: LWR-ECU       005 0070
   Coding: 0198000001000000
   VCID: 75B61AEB554FD2DFEA1-8020
Address 5F: Information Electr. (J794)       Labels:| 8V0-035-MIB-ENT1.clb
   Part No SW: 8V0 035 889 A    HW: 8V0 035 889
   Component: MU-E--ER      150 0107
   Revision: --------    Serial number: 000031092909000
   Coding: 01730000FF00000010110001000A0000000001040100010000
   ASAM Dataset: EV_MUEnt4CCONT 004052
   ROD: EV_MUEnt4CCONT.rod
   VCID: 40D8BB3F5A0D2777897-8014
   Subsystem 1 - Part No SW: 8V0 919 603 A    HW: 8V0 919 603 A
   Component: DU Std  H47 0013
   Serial number: AUZ8Z9C08008FU
   Multimedia Operating Unit:
   Subsystem 2 - Part No SW: 8V0 919 614 M    HW: 8V0 919 614 M
   Serial number: ALJAL119081600020131
          B201A 00 [009] - -
                    Fault Frequency: 246
                    Reset counter: 151
                    Mileage: 109623 km
                    Date: 2019.06.07
                    Time: 09:04:56
                    Voltage terminal 30: 12.1 V
DV52
C?ID=194404
hmm.......... here's a more readable version of the code-string on the hex5F module from your auto scan:
Name
Byte	Hex	Binary
0	01	00000001
1	73	01110011
2	00	00000000
3	00	00000000
4	FF	11111111
5	00	00000000
6	00	00000000
7	00	00000000
8	10	00010000
9	11	00010001
10	00	00000000
11	01	00000001
12	00	00000000
13	0A	00001010
14	00	00000000
15	00	00000000
16	00	00000000
17	00	00000000
18	01	00000001
19	04	00000100
20	01	00000001
21	00	00000000
22	01	00000001
23	00	00000000
24	00	00000000
I've highlighted Byte 16 which (if the same as 8V1 035 041) is where the software switches for Bluetooth are - see below (slightly different module in the screenshot):
S0 - what precisely did you mean when you said " bluetooth activated and other possible bits and controller accepted changes"?
PS: please tell us about the SVM error - what has happened to the hex5F module in the past?
Somnus
SLC, USA
C?ID=215931
I wonder, is Bluetooth a SWaP item on that generation A3?
ib97
Croatia
C?ID=375363
So, I checked all the bits 0-3 and I have put bit 4-5 on visibility ON, but nothing happens. Also, I know there is no navigation and telephone connectivity in the car, if that means something.
It's my friend's car and I really don't know. He bought it used.
siLc
Tallinn, Estonia
C?ID=330192
The basic MMI radio on an early A3 8V has BT as an option, so I'd guess the BT hardware is there but its disabled and can be activated at the dealer for a sum of money.
