Exchanging SW and HW Parts?
bdlcalvin
C?ID=277300
The phone control module on my 2012 Bentley Continental GT apparently failed and needs to be replaced. When I pulled the VAGCOM fault codes this is what I got:
Address 77: Telephone (J412) Labels: 3C8-035-730-A.clb
Part No SW: 3D0 035 730 A HW: 3W3 035 730 A
Component: Telefon 010 0422
Revision: -------- Serial number: 35909603107760
Coding: 020002010100010000000000
Shop #: WSC 00083 790 00191
ASAM Dataset: EV_UHVPremiPhaet A01002
ROD: EV_UHVPremiPhaet.rod
VCID: 1A3BA7EF1DA6D79664-804E
U1400 00 [008] - -
Reset counter: 61
Mileage: 44257 km
Date: 2017.08.09
Time: 10:42:09
What's the difference between the SW (software?) part number and the HW (hardware?) part number? When I looked up the SW part I got a control module from a latest generation Phaeton costing about $900, but when I went to Bentley they wanted $4700 for what I'm guessing is the HW part. Does anyone have any idea if the SW part and the HW part would be interchangeable? I know Volkswagen/Audi/Bentley share a lot of parts and I'd rather not pay $4700 for something that should cost no more than $900...
Thanks in advance!
The hardware part number represents what the module is physically made of. The software part number is indicative of what software is installed on that hardware.
My guess is a Phaeton module would probably work.
My question is: Have you eliminated all potential external causes for the "Insufficient Voltage" fault?
bdlcalvin
C?ID=277300
I think I've eliminated all the potential external causes for "Insufficient Voltage" other than physically checking the connectors on the module. I've tried it hooked up to a known good battery as well as on a charger and still no luck. Moreover I haven't seen the fault come up again.
Thanks for the input on the part. I'm trying to decide if the possibility of saving $3700 is worth the risk of potentially having to pay an extra $1500 for the extra part and labor if it doesn't work.
I would definitely check the connectors on the module, as well as the voltage supply lines to it, and the relevant grounds.
If the fault codes hasn't come back, what other problems/symptoms does this module exhibit that leads you to think it needs to be replaced?
bdlcalvin
C?ID=277300
Just ran another test and the fault is back, so it's back in the picture. Also some new low voltage related faults came up suggesting to me that it is a battery or connectors issue. I'm really beginning to doubt the Bentley dealership's diagnosis of failed part, especially considering the other electronic anomalies that seem to be coming up.
Here's the whole test I just took:
Tuesday,03,October,2017,19:34:00:14702
VCDS Version: 17.8.0.1 (x64)
VIN: SCBFR7ZA8CC070727   License Plate:
Mileage: 48060km-29863mi   Repair Order: BENTLEY20171003
Chassis Type: ZA-BY62 (6N0)
Scan: 01 02 03 05 06 07 08 09 11 31 13 15 16 17 19 23 2E 34 36 37
          38 46 47 53 56 65 68 6C 71 76 77
VIN: SCBFR7ZA8CC070727   Mileage: 48060km-29863miles
68-Wiper Electr. -- Status: OK 0000
71-Battery Charger -- Status: Malfunction 0010
Address 01: Engine (   )       Labels: None
   Part No SW: 07C 906 018 JS    HW: 07C 906 018 JP
   Component: BY - 6.0 L -TT  A  ª8331
   Revision: --H06---    Serial number: VWX3Z0K7932276
   Coding: 0001170
   Shop #: WSC 00083 790 00217
   VCID: 7F0D767B2DC412BEF3-5140
8 Faults Found:
001348 - Sensor 1 for Exhaust Temp Bank 1 (G235)
               P0544 - 002 - Circuit Malfunction
                    Fault Status: 01100010
                    Fault Frequency: 9
                    Mileage: 42222 km
                    Date: 2016.07.01
                    Time: 08:24:49
                    Raw, Form. N/A: 000 000 023
                    RPM: 678 /min
                    Load: 13.3 %
                    Temperature: 90.0°C
                    Temperature: 69.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 11.811 V
006436 - Controller Pin Coding
               P1924 - 008 - Implausible Signal - Intermittent
                    Raw, Form. N/A: 000 000 000
                    Temperature: 90.0°C
                    Temperature: 72.0°C
                    Voltage: 12.065 V
005715 - Please check DTC Memory of ABS Controller
               P1653 - 004 -  - Intermittent
                    Mileage: 47886 km
                    Date: 2017.09.28
                    Time: 00:00:45
                    RPM: 907 /min
                    Load: 14.9 %
                    Temperature: 90.0°C
                    Temperature: 69.0°C
                    Voltage: 11.811 V
005717 - Please check DTC Memory of Auto. Distance Controller
               P1655 - 004 -  - Intermittent
                    Mileage: 47886 km
                    Date: 2017.09.28
                    Time: 00:00:45
                    RPM: 907 /min
                    Load: 15.3 %
                    Temperature: 90.0°C
                    Temperature: 69.0°C
                    Voltage: 11.811 V
005703 - Check Coding of ECUs on Powertrain Data Bus
               P1647 - 008 -  - Intermittent
                    RPM: 1291 /min
                    Load: 17.6 %
                    Temperature: 90.0°C
                    Temperature: 71.0°C
                    Voltage: 11.811 V
049493 - No Communication with Instrument Cluster
               U0155 - 008 -  - Intermittent
                    RPM: 1291 /min
                    Load: 16.9 %
                    Temperature: 90.0°C
                    Temperature: 71.0°C
                    Voltage: 11.811 V
049412 - No Communication with Cruise Control Module
               U0104 - 008 -  - Intermittent
                    RPM: 1109 /min
                    Load: 16.1 %
                    Temperature: 90.0°C
                    Temperature: 69.0°C
                    Voltage: 11.811 V
049508 - No Communications with HVAC Control Module (J301)
               U0164 - 008 -  - Intermittent
                    RPM: 1109 /min
                    Load: 16.1 %
                    Temperature: 90.0°C
                    Temperature: 69.0°C
                    Voltage: 11.811 V
   Part No SW: 09E 927 760 BB    HW: GS1 9.1 1.7
   Component: ZC6C1435  6L W12TT  1435
   Revision: --H05---    Serial number:        0013424
   Coding: 0000111
   VCID: 71E9A0436B9074CE75-515E
               U0155 - 000 -  - Intermittent
                    Mileage: 47886 km
Address 03: ABS Brakes        Labels: None
   Part No SW: 3W0 614 517 M    HW: 3W0 614 517 M
   Component: ESP 8.1 4WD     H01 0750
   Coding: 0002516
   Shop #: WSC 00083 790 00209
   VCID: 3F8D367B6A44D2BEB3-806A
            000 -  -  - Intermittent
                    Reset counter: 34
                    Hex Value: 0x0000
                    Hex Value: 0x4282
                    Hex Value: 0x0023
                    Hex Value: 0x0190
                    Hex Value: 0x0000
   Part No SW: 3D0 909 137 G    HW: 3D0 909 137 G
   Component: A1 Kessy            6850
   Revision: 00H23072    Serial number: VWX3Z0K7932276
   Coding: 0405741
   VCID: 2B55722B8E3C5E1E0F-807E
   Part No SW: 3W3 959 760     HW: 3W3 959 760
   Component: MEM-BFS       H03 0171
   Revision: AA000000    Serial number: 00001002276390
   Coding: C01A1B2485A70000090001010101000000212727000000
   Shop #: WSC 00083 790 00242
   VCID: 0109F0839C30644E85-8054
Address 07: Control Head        Labels: 3D0-907-048.clb
   Part No SW: 3D0 907 048     HW: 3D0 907 048
   Component: J127 KBT vorn       0100
   Revision: ABH06001    Serial number: VWZ6Z7L0304053
   VCID: 63C5DA0BA66CD65EF7-8036
   Part No: 3W0 907 040 G
   Component: Climatronic BY614   2015
   Coding: 0000111
   Shop #: WSC 54078 000 1048576
   VCID: 35615453587818EE69-8060
00020 - Motor for Blocking Flap; Defrost and Body Vents; Right (V199)
00022 - Motor for Warm-Air Flap; Center Console Rear Right (V201)
Address 09: Cent. Elect.        Labels:. 3D0-937-049-V2.clb
   Part No SW: 3D0 937 049 P    HW: 3D0 937 049 P
   Component: J519                7600
   Revision: -4006---    Serial number: --------------
   Coding: 40820000AB2A11800500030000000000
   VCID: 377D5E5B4274EAFE7B-8062
Address 11: Engine II        Labels: None
   Coding: 0001170
   VCID: 7F0D767B2DC412BEF3-515E
Address 13: Auto Dist. Reg        Labels: None
   Part No SW: 3W0 907 567 A    HW: 3W0 907 567 A
   Component: AC201  NAR BY614   00871
   Revision: 00031000    Serial number: 00000000088774
   Coding: 0020614
   Shop #: WSC 00083 790 00200
   VCID: 3D714C736048C0AEA1-8068
                    Count: 55
                    Count: 79
Address 15: Airbags        Labels: None
   Part No SW: 3W3 959 655     HW: 3W3 959 655
   Component: 07 Airbag 9.43  H04 0050
   Revision: 93H04005    Serial number: 003FV0000K5V
   Coding: 0012343
   VCID: 0407F99743227166AE-8050
   Subsystem 1 - Part No: 3W7 959 339 B
   Component: BF-Gewichtsens. H02 0003
   Subsystem 2 - Serial number: 00MUG
   Subsystem 3 - Serial number: 6332DRB40CE59091
   Subsystem 4 - Serial number: 6342DRB40CE5149D
   Subsystem 5 - Serial number: 63528RB405E8B5DD
   Subsystem 6 - Serial number: 63628RB405E8BE4E
   Subsystem 7 - Serial number: 63747RB406014E6C
   Subsystem 8 - Serial number: 63847RB406014E52
   Part No: 7L6 953 549 K
   Component: J527                3601
   Coding: 0000042
   VCID: 479D2E9B32949A7E0B-8012
Address 17: Instruments        Labels: 3Wx-920-xxx-17.lbl
   Part No SW: 3W0 920 851 C    HW: 3W0 920 851 C
   Component: J285 KOMBI-INST.    3013
   Revision: KPH10V14
   Coding: 0034214
   Shop #: WSC 35931 001 1048576
   VCID: 3663535F417E13F660-8062
                    Fault Status: 00101101
                    Fault Frequency: 10
                    Reset counter: 139
                    Mileage: 44243 km
                    Date: 2017.06.06
                    Time: 08:27:43
Address 19: CAN Gateway        Labels:. 6N0-909-901-7L.clb
   Part No SW: 6N0 909 901     HW: 3W0 920 851 C
   Component: J533  GW-K-CAN TP20 3013
   Coding: DFFBFFAEEB054700
   VCID: 70EFA547639A7DC67A-8024
Address 23: Brake Booster        Labels: None
   Part No: 3W0 907 563 B
   Component: BREMSBOOSTER    007 0430
   Revision: 00007000    Serial number: 00000000018634
   VCID: 3A7B476F7166F79684-806E
   Part No SW: 5N0 035 342 D    HW: 5N0 035 342 D
   Component: SG EXT.PLAYER H13 0150
   Revision: A1001003    Serial number: 7669383574
   Coding: 030000
   Shop #: WSC 00083 790 00197
   VCID: 285F8D275BCA7506E2-807C
Address 34: Level Control        Labels: 3Wx-907-553-34.clb
   Part No: 3W0 907 553 H
   Component: LUFTFDR.-CDC- 3C3V0 7505
   Coding: 0005511
   Shop #: WSC 44617 001 1048576
   Component: MEM-FS        H03 0171
   Revision: AA000000    Serial number: 00001002276304
   Coding: C01A1B2485A70000090001010101010000212727000000
   Shop #: WSC 00083 790 00243
Address 37: Navigation (J0506)       Labels: None
   Part No SW: 3W0 035 017 C    HW: 3W0 035 017 C
   Component: RNS-MID       H06 0360
   Revision: AB001001    Serial number: VWZ6Z7L0304053
   Coding: 060700020000002600
   Shop #: WSC 03246 104 183778
   VCID: 2D517C337428502E11-8078
00862 - Antenna for GPS Navigation (R50/R52)
                    Fault Status: 00100111
                    Reset counter: 139
                    Mileage: 44242 km
                    Date: 2017.06.01
                    Time: 12:59:39
Address 38: Roof Electronics        Labels: None
   Part No: 3W0 907 135 G
   Component: Dachmodul           0803
   Coding: 0006589
Address 46: Central Conv.        Labels: 3D0-959-933.lbl
   Part No: 3D0 959 933 M
   Component: GS HSG              8134
   Coding: 0000040
   VCID: 3A7B476F7666F79684-4B32
   Subsystem 1 - Part No: 3W8 959 701 K
   Component: Tuersteuergeraet FS 1107
   Subsystem 2 - Part No: 3W8 959 702 K
   Component: Tuersteuergeraet BF 1107
   Subsystem 3 - Part No: 3W8 959 703 F
   Component: Tuersteuergeraet HL 0705
   Subsystem 4 - Part No: 3W8 959 704 F
   Component: Tuersteuergeraet HR 0705
   Subsystem 5 - Part No: 3W0 909 610 G
   Component: 14 HDSG             1810
   Subsystem 6 - Part No: 7L0 907 719 A
   Component:    Neigungssensor   0020
00485 - Drivers Outside Door Handle Central Locking Button (E369)
00934 - Electric Window Motor; Rear Left (V26)
00935 - Electric Window Motor; Rear Right (V27)
Address 47: Sound System        Labels: None
   Part No: 3W8 035 466 A
   Component:   PREMIUM AMPLIFIER 4030
   Shop #: WSC 12336 024 394758
   VCID: 3B75426B7A5CCE9E9F-806E
Address 53: Parking Brake        Labels: 3W0-907-801.clb
   Part No SW: 3W0 907 801 F    HW: 3W0 907 801 F
   Component: EPB  BC7H0280   HC7 0280
   Coding: 0022413
   VCID: 397958637360FC8E8D-5140
Address 56: Radio (J0506)       Labels: None
                    Reset counter: 139
                    Mileage: 44242 km
                    Date: 2017.06.01
                    Time: 12:59:39
Address 65: Tire Pressure        Labels: None
   Part No SW: 3W7 907 273 A    HW: 3W7 907 273 A
   Component: J0502 RDK           0004
   Revision: 0004 004    Serial number: 00000700009620
   Coding: 0000E04185C863B8FD858500858500
   Shop #: WSC 00083 790 00205
   VCID: 3E734B7F6D4EDBB6B8-806A
Address 68: Wiper Electr.        Labels: 3Wx-955-023.clb
   Part No: 3W1 955 023 J
   Component: Wischermodul       ª0401
   Shop #: WSC 00000 725 65552
   Part No SW: 3W3 907 441 C    HW: 3W3 907 441 C
   Revision: 00H09000    Serial number: 525 PA8J110070
   Coding: 2020002
   VCID: 397958637060FC8E8D-806C
                    Reset counter: 135
                    Mileage: 47886 km
                    Date: 2017.09.28
                    Time: 00:00:44
                        Reverse OFF
                    Count: 3
Address 71: Battery Charger (J367)       Labels:* None
   Part No SW: 3W3 915 181     HW: 3W3 915 181
   Component: EMM Batt Man  H04 0400
   Coding: 2C0100
   Shop #: WSC 00083 790 00151
   ASAM Dataset: EV_BatteChargVaria1 001001
   ROD: EV_BatteChargVaria1_001.rod
   VCID: 76E3935FC9FE53F6A0-8022
13635840 - Supply voltage
                    Reset counter: 135
                    Mileage: 47886 km
                    Date: 2017.09.28
                    Time: 13:24:58
12604928 - Combination / Chassis CAN Bus (SAE Bus D)
          U0056 00 [008] - Performance
                    Reset counter: 135
16776977 - SAE - Reserved by Document ISO 15031-6
          P0000 00 [009] - 2005
                    Mileage: 7568 km
                    Date: 2012.02.22
                    Time: 09:22:25
   Part No SW: 3W0 919 283 E    HW: 3W0 919 283 E
   Component: J446  ST Parkhilfe  0100
   Revision: 11H01001    Serial number: 48631101100530
   Coding: 0300026
          U1400 00 [008] - -
                    Reset counter: 135
                    Mileage: 47958 km
                    Date: 2017.10.02
                    Time: 05:54:14
End-------------------------(Elapsed Time: 04:36)--------------------------
