- Joined
- May 14, 2019
- Messages
- 4
- Reaction score
- 0
- Location
- Bosnia and Herzegovina
- VCDS Serial number
- C?ID=359910
Can you help me with this one? I need code for ABS its wrong coded now?Can anybody get me orginal code?
Saturday,25,January,2020,12:08:40:04368
VCDS Version: 19.6.2.0 (x64) HEX-V2 CB: 0.4508.4
VIN: WVGZZZ1TZCW049832 License Plate:
Chassis Type: 1T-VW36 (7N0)
Scan: 01 03 08 09 10 15 16 17 18 19 25 42 44 46 4F 52 55 56 61 62
69 72
VIN: WVGZZZ1TZCW049832 Mileage: 140820km-87501miles
69-Trailer -- Status: Cannot be reached 1100
Address 01: Engine (J623-CAYC) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 PH HW: 03L 907 425 C
Component: R4 1.6l TDI H43 9978
Revision: --H43--- Serial number: 00000000000000
Coding: 00194036032401080000
Shop #: WSC 01324 020 00200
ASAM Dataset: EV_ECM16TDI02103L906023PH 003011
ROD: EV_ECM16TDI02103L997557T.rod
VCID: 7BA3F53A436471DF9C5-802E
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Coding: 333B401621260603CC1302E7841B6080350000
VCID: 7BA3F53A43E471DF9C5-802E
03366 - Vacuum Sensor
Reset counter: 131
Mileage: 140829 km
Date: 2014.06.17
Time: 20:47:07
Count: 3
Count: 2
Count: 20992
Count: 213
Count: 43776
Count: 65028
Count: 11
03842 - RPM Sensor Rear Right: Incorrect Signal
Reset counter: 131
Mileage: 140829 km
Date: 2014.06.17
Time: 20:47:08
Count: 3
Count: 2
Count: 20992
Count: 87
Count: 43776
Count: 65028
Count: 11
03841 - RPM Sensor Rear Left: Incorrect Signal
Reset counter: 131
Mileage: 140829 km
Date: 2014.06.17
Time: 20:47:08
Count: 7
Count: 2
Count: 20992
Count: 71
Count: 43776
Count: 65028
Count: 146
Reset counter: 131
Mileage: 140829 km
Date: 2014.06.17
Time: 20:47:07
Count: 3
Count: 2
Count: 20992
Count: 8192
Count: 43776
Count: 65028
Count: 11
Part No SW: 5K0 907 044 ES HW: 5K0 907 044 ES
Component: Climatronic H18 1112
Revision: 00001004
Coding: 0000004003
VCID: 005982D62A821207C97-8054
Part No SW: 5K0 937 087 M HW: 5K0 937 087 M
Component: BCM PQ35 H 011 0048
Revision: BE011001
Coding: 40180A3B80251AE0400800C0540011E44B559008626DA520E480C7000049
VCID: 3FDB412A177CADFFF0D-806A
Subsystem 1 - Part No: 1T1 955 119 A Labels: 1KX-955-119.CLB
Component: Wischer 05101 26 0512
Coding: 009795
Component: RLS 011011 05 54 0403
Coding: 0230ED
01517 - Control Module for Trailer/Towing Sensor (J345)
Reset counter: 131
Mileage: 140829 km
Date: 2014.06.17
Time: 05:35:18
Voltage: 14.75 V
02092 - Enabling Heated Seat
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 131
Mileage: 140829 km
Date: 2014.06.17
Time: 05:35:14
Voltage: 14.50 V
Address 10: Park/Steer Assist (J446) Labels:. 3C8-919-475.clb
Part No SW: 5K0 919 475 C HW: 5K0 919 475
Component: PARKHILFE 8K H07 0008
Revision: -------- Serial number: 12931004503123
Coding: 100001
Shop #: WSC 00028 028 00001
VCID: 3635240E38466CB723B-8062
Address 15: Airbags Labels: 1T0-909-605.lbl
Part No SW: 1T0 909 605 E HW: 1T0 909 605 E
Component: 02 AIRBAG VW8 022 0100
Revision: 02022000 Serial number: 003K4D04JT5B
Coding: 0012338
VCID: 372B290A334C95BF38D-8062
Subsystem 1 - Serial number: 6332QSME37601C60A
Subsystem 2 - Serial number: 6342QSME76661876N
Subsystem 3 - Serial number: 6352QSME005F2F52L
Subsystem 4 - Serial number: 6362QSME48630E62L
00589 - Airbag Igniter 1; Passenger Side (N131)
Part No SW: 5K0 953 501 BH HW: 5K0 953 569 L
Revision: FF010040 Serial number: 20111012301791
Coding: 1182140000
VCID: 71BFD71211280B8F369-8024
Subsystem 1 - Part No SW: 5K0 959 542 C HW: 5K0 959 542 C Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H31 0037
Coding: 820000
Part No SW: 1T0 920 885 A HW: 1T0 920 885 A
Component: KOMBI H04 0407
Coding: 181F00
VCID: 3635240E38C66CB723B-8062
Address 18: Aux. Heat Labels: 1K0-815-071.clb
Part No: 7N0 963 271 C
Component: Zuheizer 051 2730
Revision: 00051000 Serial number: 09022126000000
Coding: 0000031
VCID: 34311E06223A7EA71DF-8060
01415 - Recirculating Pump (V55)
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 131
Mileage: 140828 km
Date: 2014.06.17
Time: 04:06:25
Locked
Temperature: 53.0°C
Temperature: 57.0°C
Voltage: 12.29 V
02251 - Heater Unit Locked
Reset counter: 131
Mileage: 140828 km
Date: 2014.06.17
Time: 04:43:34
Part No SW: 7N0 907 530 K HW: 1K0 907 951
Component: J533 Gateway H40 1620
Revision: H40 Serial number: 051011F1001374
Coding: 358002
VCID: 38292A3632529AC7317-806C
Reset counter: 131
Mileage: 140829 km
Date: 2014.06.17
Time: 05:35:21
Component: IMMO H04 0407
VCID: 6A8DC07E3CFEF857773-803E
Part No SW: 1T0 959 701 T HW: 1T0 959 701 T
Component: Tuer-SG 009 2121
Coding: 0131253
VCID: 48C95AF64EB2EA47417-801C
Part No SW: 5N1 909 144 L HW: 5N1 909 148 G
Component: J500__APA-BS KL.311 0802
Revision: 1AH03729 Serial number: 00102350178901
Coding: 0000258
Shop #: WSC 05311 000 00000
VCID: 3B23353A0F64B1DFDC5-806E
Part No SW: 7N0 907 532 HW: 1K0 907 951
Component: EZE_2 H40 1620
Coding: 050B0500
VCID: 6FBBD16A079C1D7F20D-803A
Subsystem 1 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J245EE20SKB13 H02 0220
Subsystem 2 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J394EE20SKB13 H02 0220
Part No SW: 1T0 959 702 R HW: 1T0 959 702 R
Coding: 0131253
VCID: 47CB59CA43ACE53F48D-8012
Address 55: Headlight Range (J745) Labels:. 5M0-907-357-V3.clb
Part No SW: 5M0 907 357 E HW: 7L6 907 357 C
Component: AFS-ECU H04 0105
Coding: 038200000F000200
ASAM Dataset: EV_HeadlRegulVWAFSPt 002014
ROD: EV_HeadlRegulVWAFSPt_VW32.rod
Subsystem 1 - Part No: 1T0 941 329 A Labels: 3D0-941-329.CLB
Subsystem 2 - Part No: 1T0 941 329 A Labels: 3D0-941-329.CLB
5256213 - Front Left Ride-Height Sensor
C1034 15 [137] - Open or Short to Plus
Fault Frequency: 10
Reset counter: 131
Mileage: 140829 km
Date: 2020.01.25
Time: 05:35:17
13705985 - Databus
U1123 00 [137] - Received Error Message
[Fehlerwert im Signal BR3_Rad_kmh_HL]
Fault Frequency: 13
Reset counter: 131
Mileage: 140829 km
Date: 2020.01.25
Time: 05:35:57
13705987 - Databus
[Fehlerwert im Signal BR3_Rad_kmh_HR]
Fault Frequency: 13
Reset counter: 131
Mileage: 140829 km
Date: 2020.01.25
Time: 05:35:57
Part No SW: 1K0 035 186 AN HW: 1K0 035 186 AN
Component: Radio RCD310 031 0075
Revision: 01000001 Serial number: VWZ1Z2L3184397
Coding: 05000400040009
VCID: 72BDD81E14AE3097CF3-8026
Part No SW: 7N0 907 534 HW: 1K0 907 951
Component: Batt.regelung H40 1620
Coding: 030B185A
VCID: 71BFD71211A80B8F369-8024
Component: J367-BDM H07 0180
Serial number: 00000000008900711146
Part No SW: 5K0 959 703 A HW: 5K0 959 703 A
Component: Tuer-SG 007 2104
Coding: 0131216
Shop #: WSC 01324 020 1012552
VCID: 323D181ED82E70970F3-8066
Address 69: Trailer
Part No SW: 5K0 959 704 A HW: 5K0 959 704 A
Coding: 0131216
VCID: 33331D1A2734799F045-8066
End----------(Elapsed Time: 01:27, VBatt start/end: 12.1V/12.1V)-----------
