So while pulling some wiring something shorted now I can't talk to the ecu, abs and possibly others. Also, Oil warning and "brakes" warning come on. Car starts and runs just not great. Thinking the Central electronics module is fried. replaced ecu (just cause it was easy) same problem.
Any help is appreciated.
Ignore all the bulb and door module warnings. Those are not connected. Not part of the problem.
Sunday,05,April,2020,17:23:30:29885
VCDS Version: 20.4.0.1 (x64) HEX-NET CB: 0.4508.4
VIN: WVWFV71K97W169218 License Plate: ORANGE CAR
Mileage: 146600km-91093mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 1C 22 25 44 46
VIN: WVWFV71K97W169218 Mileage: 146600km-91093miles
1C-Position Sensing -- Status: Not registered 0011
Address 01: Engine
Address 02: Auto Trans
Address 03: ABS Brakes
Part No: 1K0 820 047 GS
Component: Climatic PQ35 120 0606
VCID: 7BB60A383A91DD5E57-802E
7 Faults Found:
013 - Check DTC Memory
01296 - Sensor for Vent Temperature; Center (G191)
010 - Open or Short to Plus
00898 - Control Circuit A/C compressor
009 - Open or Short to Ground
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 AE HW: 3C0 937 049 AE
Component: Bordnetz-SG H52 2002
Revision: 00H52000 Serial number: 00000006577201
Coding: 11040801400A00005F00000032000000005000005F0001
Shop #: WSC 09113 444 54770
VCID: 6C9439644FFF4AE6CE-8038
Component: Wischer 181206 020 0501
Coding: 00038805
Shop #: WSC 09113
7 Faults Found:
02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
Fault Status: 01101001
Reset counter: 150
Mileage: 146609 km
Date: 2005.09.13
Time: 31:63:63
Voltage: 14.45 V
Fault Status: 01101010
Reset counter: 150
Mileage: 146609 km
Date: 2005.09.13
Time: 31:63:63
Voltage: 14.45 V
Reset counter: 150
Mileage: 146609 km
Date: 2005.09.13
Time: 31:63:63
Voltage: 14.45 V
Fault Status: 00100101
Reset counter: 190
Mileage: 146609 km
Date: 2005.09.13
Time: 31:63:63
Voltage: 14.45 V
Reset counter: 150
Mileage: 146609 km
Date: 2005.09.13
Time: 31:63:63
Voltage: 14.40 V
Reset counter: 150
Mileage: 146609 km
Date: 2005.09.13
Time: 31:63:63
Voltage: 14.45 V
Reset counter: 150
Mileage: 146609 km
Date: 2005.09.13
Time: 31:63:63
Voltage: 14.45 V
Address 15: Airbags
Part No SW: 1K0 953 549 AG HW: 1K0 953 549 AG
Component: J0527 036 0070
Coding: 0012122
Shop #: WSC 01279 785 00200
VCID: 77BE160806B9F93E33-8022
Component: E0221 002 0010
00002 - Transmission Control Unit
Part No SW: 1K6 920 973 A HW: 1K6 920 973 A
Component: KOMBIINSTRUMENT VDD 1610
Revision: V0003000 Serial number: VWZ7Z0G8013723
Coding: 0000207
Shop #: WSC 01286 386 08256
VCID: 312AE810A85DE70EBD-8064
7 Faults Found:
Fault Frequency: 9
Reset counter: 150
Fault Frequency: 14
Reset counter: 150
Mileage: 146578 km
Time: 17:00:43
Reset counter: 190
Fault Frequency: 9
Reset counter: 150
Fault Frequency: 9
Reset counter: 150
Reset counter: 150
Mileage: 146609 km
Time: 01:36:15
00438 - Fuel Supply Sensor 2 (G169)
Reset counter: 150
Mileage: 146609 km
Time: 00:24:35
Address 19: CAN Gateway Labels:. 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 K HW: 1K0 907 951
Component: J533__Gateway H04 0021
Revision: H04 02 Serial number: 110107F2001582
Coding: BF03030007000000
VCID: 2F2EEE68BE69F1FEAB-807A
01312 - Powertrain Data Bus
014 - Defective
Fault Status: 01101110
Reset counter: 150
Mileage: 146609 km
Time: 01:50:11
Mileage: 146609 km
Time: 01:50:11
Part No SW: 1K6 919 879 HW: 1K6 919 879
Component: Kompass 001 0003
Revision: 00001000 Serial number: 1225223T1RYX03
VCID: 7DB204202485D36E69-8028
Fault Frequency: 21
Reset counter: 150
Mileage: 146609 km
Time: 21:31:39
Address 22: AWD
Component: IMMO VDD 1610
01176 - Key
Mileage: 146609 km
Time: 17:27:38
00003 - Control Module
014 - Defective
Mileage: 146483 km
Time: 14:16:51
Address 44: Steering Assist
Part No SW: 1K0 959 433 CT HW: 1K0 959 433 CT
Component: KSG PQ35 RDK 052 0218
Revision: 00052000 Serial number: 00000000000000
Coding: 0000000000000000000000800001000188B820
Shop #: WSC 01287 785 00200
VCID: 044471C4476FA2A626-8050
6 Faults Found:
Fault Status: 01101101
Reset counter: 150
Fault Frequency: 20
Reset counter: 150
Mileage: 146561 km
Time: 02:06:39
Fault Frequency: 20
Reset counter: 150
Mileage: 146561 km
Time: 02:06:39
00625 - Vehicle Speed Signal
Reset counter: 150
Mileage: 146609 km
Time: 01:42:58
00830 - Convertible Top Control Module (J256)
Reset counter: 190
Reset counter: 150
Mileage: 146609 km
Time: 01:36:15
End----------(Elapsed Time: 00:43, VBatt start/end: 14.5V/14.5V)-----------
