2016 MY16 Passat TDI 140 Highline Diesel (Australian Model) faults
free2beee
Australia
C?ID=394496
Hi everyone:),
I posted a similar post in the new user forum to introduce myself but have decided maybe it should have been posted in here. (Admin can you let me know? Thanks)
I have fault codes across 5 modules all with the 0010 code. I wonder if anyone can let me know if coding needs to change or something else. By way of context, I upgraded the car with PLA3.0 from Kufatec which had their own coding dongle, I am not sure if that coded other modules or just the Parking/Steering section as it is showing no faults.
Saturday,28,March,2020,15:39:37:41391
VIN: WVWZZZ3CZGExxxxxx   License Plate: xxxxxxx
Mileage: 83672km-51991mi   Repair Order:
Chassis Type: 3C-VW48 (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 3C 42 44 52 5F 6C A5
          CF
VIN: WVWZZZ3CZGE1xxxxxx   Mileage: 83672km-51991miles
Address 01: Engine (J623-DFCA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 FN    HW: 04L 907 309 M
   Component: R4 2,0L EDC   H23 1195
   Revision: B4H23---
   Coding: 011D0012046505083000
   Shop #: WSC 05311 115 00318
   ASAM Dataset: EV_ECM20TDI01104L906026FN 002001
   ROD: EV_ECM20TDI01104L906026FN_002_VW48.rod
   VCID: 7BA3F1D0736F7A2F9C7-802E
   Part No SW: 0D9 300 041 J    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H53 4906
   Revision: 06253104    Serial number: TFK01510270727
   Shop #: WSC 05311 115 00089
   ROD: EV_TCMDQ250021.rod
   VCID: 1F1BE5408737C60FD0F-804A
   Revision: 00000000    Serial number: 63185000000703
   Coding: 0EEC928F34230B6E077A060041C64970492CD0E0608292F51862F03AC2A9
   Shop #: WSC 17873 123 50804
   VCID: 7AADF4D47C554327871-802E
8307 - Databus
          [FCAN: PLA_Status_PLA_ESP signal is invalid]
                    Fault Frequency: 19
                    Reset counter: 36
                    Mileage: 83408 km
                    Date: 2020.02.27
                    Time: 11:34:33
16401 - Tire Pressure Warning
          C102D 00 [009] - -
                    Reset counter: 245
                    Mileage: 83547 km
                    Date: 2020.03.12
                    Time: 05:59:19
   Part No SW: 3Q0 959 435 C    HW: 3Q0 959 435 C
   Component: VWKESSYMQB    036 0710
   Revision: 00036000    Serial number: 0385786377
   Coding: 0F00100F03
   Shop #: WSC 04174 123 61029
   ASAM Dataset: EV_KessyHellaMQBAB 004032
   VCID: 3A2D34D43CD58327C71-806E
   Part No SW: 5G0 907 044 BG    HW: 5G0 907 044 BG
   Component: Climatronic   H04 1202
   Revision: 00001K10
   Coding: 1112010430210000111550401210180A
   ASAM Dataset: EV_ACClimaBHBVW37X 005137
   ROD: EV_ACClimaBHBVW37X_005_VW37.rod
   VCID: 6D87CF883D1BE49F123-8038
   Geber f¸r K‰ltemitteldruck/K‰ltemitteltemperatur:
263682 - Exterior Air Quality/Humidity Sensor
          B137A 31 [008] - No Signal
                    Reset counter: 36
                    Mileage: 83651 km
                    Date: 2020.03.24
                    Time: 15:20:21
                    Voltage terminal 30: 14.5 V
                    Outside air temperature: 23.5 ∞C
                    System run time-Engine running time: 255 s
                    System run time-Terminal 15 on: 255 s
   Part No SW: 5Q0 937 086 AJ    HW: 5Q0 937 086 AJ
   Revision: --------    Serial number: 86581111151510
   Coding: 03011B46C2C102FF07A04094B11007281880000000000000000000000000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 025D8C3414850BE7DF1-8056
   Subsystem 1 - Part No SW: 3G2 955 119 A    HW: 3G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    150801  043 0607
   Serial number:         150930150330
   Component: RLHS  037 0059
   Serial number: S4Y15M11D19H15M36S17
   Coding: 90A8DD
   Light switch:
   Subsystem 3 - Part No SW: 3G0 941 633     HW: 3G0 941 633
   Serial number: 15 06 2015  10000699
   Serial number: 000000000ZY1527208K0
   Component: Sirene, DWA  005 0312
   Serial number: 00000000000033891458
534549 - Databus
                    Reset counter: 23
                    Mileage: 83408 km
                    Date: 2020.02.27
                    Time: 11:33:16
540693 - Databus
                    Reset counter: 238
                    Mileage: 83408 km
                    Date: 2020.02.27
                    Time: 11:33:16
204546 - Remote key 2
                    Reset counter: 238
                    Mileage: 83411 km
                    Date: 2020.02.27
                    Time: 11:48:52
   Part No SW: 5QA 919 298 C    HW: 5QA 919 298 A
   Serial number: 000308417618339
   Coding: 0371167851
   ROD: EV_EPHVA2CAU3700000.rod
   VCID: 50F9767C8A692977195-8004
   Component: ACC BOSCH MQB H04 0192
   Coding: 320467D251FFC428949C804D
   Shop #: WSC 00015 115 00001
   ASAM Dataset: EV_ACCBOSCHVW48X 001008
   ROD: EV_ACCBOSCHVW48X.rod
   VCID: 34311AEC1EB175571DD-8060
1538 - Sensor for Automatic Distance Control
          [FAULT_SENSOR_BLIND]
                    Reset counter: 29
                    Mileage: 83497 km
                    Date: 2020.03.06
                    Time: 15:21:06
                    Control Module temperature: 42 ∞C
                    Voltage terminal 15: 12.8 V
                    Velocity_vehicle_reference: 28.51 m/s
                    Longitudinal_acceleration_vehicle_reference: 0.06 m/s≤
                    Status_ACC_System: ACC_activ_controlled
1542 - Sensor for Automatic Distance Control
          [FAULT_SYSTEM_BLIND]
                    Reset counter: 29
                    Mileage: 83498 km
                    Date: 2020.03.06
                    Time: 15:21:32
                    Control Module temperature: 41 ∞C
                    Voltage terminal 15: 13.0 V
                    Velocity_vehicle_reference: 29.54 m/s
                    Longitudinal_acceleration_vehicle_reference: 0.34 m/s≤
                    Status_ACC_System: ACC_Override
   Part No SW: 3Q0 959 655 BB    HW: 3Q0 959 655 BB
   Component: Airbag VW20   013 0195
   Revision: --------    Serial number: 003STPPAKVGF
   Coding: 98FCC0C0000000005C540000008800000065
   Shop #: WSC 05314 000 00001
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 7F5B05C06777660FB0F-802A
   Subsystem 1 - Part No SW: -----------    HW: 454 000 111 15
   Serial number: 3576U00000065689971G
   Subsystem 2 - Part No SW: -----------    HW: 454 000 111 15
   Serial number: 3586U000000ED489971V
   Subsystem 3 - Part No SW: -----------    HW: 454 800 211 15
   Serial number: 3516R5962C5080000003
   Subsystem 4 - Part No SW: -----------    HW: 454 802 410 15
   Serial number: 3526R6E93BC08000000K
   Subsystem 5 - Part No SW: -----------    HW: 454 801 610 15
   Serial number: 3556V18CCC108000000I
   Part No SW: 3Q0 953 521 B    HW: 5Q0 953 569 A
   Revision: FF033033    Serial number: 20151021400459
   Coding: 0810
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 2F3B1580F797568F60F-807A
   Part No SW: 3G0 920 751 A    HW: 3G0 920 751 A
   Component: KOMBI         301 6421
   Coding: 27A401186798000801887B0B1000000000000000
   VCID: 2313E9B0AB5FE2EFF47-8076
          U1014 00 [009] - -
                    Fault Frequency: 34
                    Reset counter: 251
                    Mileage: 83408 km
                    Date: 2020.02.27
                    Time: 11:31:28
16776980 - Databus
          [PLA_Status_01 keine Kommunikation]
                    Reset counter: 238
                    Mileage: 83408 km
                    Date: 2020.02.27
                    Time: 11:31:29
   Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2246
   Revision: --------    Serial number: 09111510800334
   Coding: 030300345F087300FB0002581C0F00010001070000000000000000000000
   ROD: EV_GatewConti_013.rod
   VCID: 79AFEBD87953483F8EB-802C
   Serial number: 29150002186110075451
   Coding: 2CFFFF
   Serial number: 1488858203
   Analog clock:
   Component: Analoguhr  209 2002
   Serial number: 15000154107005
   Coding: 0800000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71BFD3F82123007F36B-8024
Address 3C: Lane Change (J769)       Labels:| 3Q0-907-566.clb
   Part No SW: 3Q0 907 566 B    HW: 3Q0 907 566
   Component: MRR1Rear      H16 0230
   Revision: --------
   Coding: 44C002
   ASAM Dataset: EV_RearRadarS1BoschVW48X 001002
   VCID: 372B2DE00FC79E4F38F-8062
   Serial number: 220815BHM11588
   Coding: 00351A208001020000000000
   VCID: 43D349304B1FC2EF947-8016
   Subsystem 1 - Part No SW: 5Q4 959 811 E    HW: 5Q4 959 811 E  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000002557486
   Coding: 0D0000
   Component: EPS_MQB_ZFLS  125 1063
   Coding: 9303
   VCID: 44D14A2C4E11C5D7ADD-8010
   Serial number: 011015BIU19426
   Coding: 003510208001020000000000
   VCID: 42DD4C345405CBE79F1-8016
   Subsystem 1 - Part No SW: 5Q4 959 812 E    HW: 5Q4 959 812 E  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000002560819
   Coding: 050000
   Part No SW: 3G0 035 045 G    HW: 3G0 035 045
   Component: MU-H-N-RW     H50 0343
   Serial number: A688J0FB000689
   Coding: 02840108FF00000051510001000828001F0204C601200102DF
   VCID: 221DECB4B445EBE7FF1-8076
   Component: ABT_High  H62 0031
   Serial number: VWZ8Z9RU30423C
   Subsystem 2 - Part No SW: V03 959 806 FQ    HW: -----------
   Component: ROW 2019/2020  --- 0079
   Component: Gracenote2  --- 4008
   Part No SW: 5Q0 980 556     HW: 5Q0 980 556
   Component: RVC Compact   H07 0100
   Coding: 0184010162002017000040
   Shop #: WSC 05311 000 00197
   ROD: EV_CamSysRVRVCPANAMQBAB_005_VW48.rod
   VCID: 77ABEDE04F475E4FF8F-8022
   Part No SW: 3Q0 980 654 C    HW: 3Q0 980 654
   Component: MQB_B_MFK     H04 0023
   Serial number: 12111511K20116
   Coding: 000408010000010100022346C050410084000E000020
Address CF: Lane Chge Asst 2 (J770)       Labels:. 3Q0-907-566.clb
   Part No SW: 3Q0 907 590 B    HW: 3Q0 907 590
   Revision: --------
   Coding: 44C002
   ASAM Dataset: EV_RearRadarS2BoschVW48X 001002
End----------(Elapsed Time: 02:07, VBatt start/end: 12.0V/12.0V)-----------
PetrolDave
Westbury, UK
C?ID=1423
                    Reset counter: 29
                    Mileage: 83497 km
                    Date: 2020.03.06
                    Time: 15:21:06
                    Reset counter: 29
                    Mileage: 83498 km
                    Date: 2020.03.06
                    Time: 15:21:32
The problem with ACC is likely caused by this fault code. Did you have to move/remove the front fender/bumper when you did the PLA retrofit?
In addition, I would inspect the ACC sensor to see if it doesn't have an accumulation of dirt or road grime on it.
free2beee
Australia
C?ID=394496
Hello, yes we had to remove both front and back fender/bumpers to punch the holes for the PLA retrofit. Does this mean a recalibration is necessary or something else?
free2beee
Australia
C?ID=394496
Thanks for closing the other similar post and in answer to your question, I will inspect the sensor for any obstructions.
PetrolDave
Westbury, UK
C?ID=1423
It means either:
- the radar has been moved out of alignment while fitting/removing the bumper; or
- as Uwe suggests when refitting the bumper the radar has been slightly obscured; or
- the radar needs recalibrating.
free2beee
Australia
C?ID=394496
It means either:
Thanks very much for your help on this. I will look further into it. The issue happens only for a short time and then starts working again, it does not happen every time I drive the car with ACC engaged.
