2015 Golf 5F issue
hergy916
New Member
HC475947 (2nd hand?)
Dealership just replaced 5F module in a clients 2015 Golf TDi Sportwagen and now we can't code it for the needed correction. Car came stock with Fender audio package and a couple years ago we coded it to non Fender for full Audison upgrade before NavTv had a Most 150 adapter. We are using the clients HEX+CAN and have successfully tested two other vehicle with his HEX+CAN. The new 5F is causing two messages to appear - "no coding available for this ecu" and "appears to be an uninitialized control module". The other two cars did not do this. Car has been back to the dealership twice for two different mistakes on their part but still can't get this working. Any ideas? What info can I supply that may help with this issue?
hergy916
New Member
Tuesday,14,July,2020,15:39:03:17610
VCDS Version: 20.4.1.0 (x64)
VIN: 3VWCA7AUXFM518785   License Plate:
Mileage: 47342km-29416mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 15 16 17 19 2B 42 44 47 52 5F 75
VIN: 3VWCA7AUXFM518785   Mileage: 47342km-29416miles
Address 01: Engine (J623-CRUA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 997 022 N    HW: 04L 907 309
   Component: R4 2.0l TDI   X23 9459
   Revision: 85X23---
   Coding: 011D0012032410081000
   ASAM Dataset: EV_ECM20TDI01104L997022N 004002
   ROD: EV_ECM20TDI01104L997022N.rod
   VCID: 3B7EF7C4B2216A5E1E-806E
Readiness: 0 0 0 1 0
   Part No SW: 0D9 300 041 N    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H53 4512
   Revision: 05853104    Serial number: TFK01504010463
   Shop #: WSC 00066 790 00087
   ROD: EV_TCMDQ250021.rod
   VCID: 234E2FA42A91329E36-8076
   Part No SW: 3Q0 907 379 P    HW: 3Q0 907 379 C
   Component: ESC           H32 0385
   Revision: 00000000    Serial number: 51255000002645
   Coding: 04FA6AA124210974007E020881C82520562490004081A4B200630050C002
   Shop #: WSC 01383 790 50316
   VCID: 47969B34FEE93EBE8A-8012
   Revision: 00021000    Serial number: 0366778540
   Coding: 030C0C
   VCID: 3A70F2C0BD1B535605-806E
   Part No SW: 5GM 907 044 A    HW: 5GM 907 044 A
   Revision: 00001K01
   Coding: 02020124202100000005000012111400
   VCID: 42808A20D5CB1B965D-8016
   Part No SW: 5Q0 937 087 R    HW: 5Q0 937 087 R
   Component: BCM PQ37BOSCH 028 0145
   Revision: --------    Serial number: 86582104150011
   Coding: 00511846404182E969E44080401407001800000000000000000000000000
   Shop #: WSC 00066 790 00224
   ROD: EV_BCMBOSCH_014.rod
   VCID: 4A90A200EDFBC3D695-801E
043 0581
   Serial number:         150608093956
   Coding: 57575320202020313530343131
   Component: RLHS  037 0059
   Serial number: S4Y15M04D22H12M00S25
   Coding: 90A8DD
   Sun Roof:
   Subsystem 3 - Part No SW: 5G0 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS22.409  H03 0004
   Serial number: 0000FST000850JW00000
   Coding: 191800
   Roof Blind:
   Subsystem 4 - Part No SW: 5G0 959 591 A    HW: 8V3 959 591 A
H03 0004
   Serial number: 0000FST000850IV00000
   Coding: 4A33393420505332322E343039
   Serial number: 003GCR01STJ6
   Occupant Detection:
   Component: BF-Gewichtss.  H11 0021
   Serial number: IBH0000J150002U2B10V
   Coding: 303137
   Subsystem 2 - Part No SW: -----------    HW: 480 001 304 15
   Serial number: 35700000000E7890141G
   Subsystem 3 - Part No SW: -----------    HW: 480 002 005 15
   Serial number: 35800000000E5485941N
   Subsystem 4 - Part No SW: -----------    HW: 480 401 404 15
   Serial number: 35100029B1A878640391
   Subsystem 5 - Part No SW: -----------    HW: 480 401 404 15
   Serial number: 3520002AB1A8785473BB
   Subsystem 6 - Part No SW: -----------    HW: 480 401 404 15
   Serial number: 3550002C119EFF5462DQ
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 401 404 15
   Serial number: 3560002C319EFF51D31M
   Part No SW: 5Q0 953 569 A    HW: 5Q0 953 569 A
   Revision: --------    Serial number: 20171128500852
   Coding: 0410
   Shop #: WSC 57940 002 1048576
   ASAM Dataset: EV_SMLSVALEOMQB 001016
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 3C7CF4D8B72F6D6617-8068
   Part No SW: 5G1 920 841     HW: 5G1 920 841
   Component: KOMBI         243 4270
   Coding: 0BA4121A2180CF0502086A001000000000000000
   VCID: 65CA71BC64250CAE98-8030
   Part No SW: 5Q0 907 530 AB    HW: 5Q0 907 530 L
   Component: GW MQB Mid    211 2203
   Revision: --------    Serial number: 06051510001314
   Coding: 0901000800087300EF0002081C0F00000001050000000000000000000000
   Shop #: WSC 00066 790 07030
   ROD: EV_GatewConti_011.rod
   VCID: 71E215ECA0EDD00EF4-8024
H16 0101
   Serial number: 29150000917720065186
   Power Converter DC AC:
   Subsystem 3 - Part No SW: 5Q0 907 155 A    HW: 5Q0 907 155 A
   Component: WECHSELRICHTE  H53 0041
   Serial number: 0071703
   Revision: 00000000    Serial number: 15000087278003
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 346CDCF89F7FA526DF-8060
   Serial number: 18051506050F7U
   Coding: 003A13200000040000000000
   VCID: 40848028DBC709864B-8014
   Serial number: 00000000000001280972
   Coding: 011000
   Component: EPS_MQB_ZFLS  126 1061
   Coding: 0102
   VCID: 438E8F24CAD1129E56-8016
Address 47: Sound System (J525)       Labels:| 5G0-035-456.clb
   Part No SW: 5G0 035 456     HW: 5G0 035 456
   Component: MIB_lite_amp  H40 0070
   Serial number: VWZ8Z1FC402SVN%
   Coding: 22000000AAAAAA0000
   ASAM Dataset: EV_AMPMst12C1ALPI 001007
   ROD: EV_AMPMst12C1ALPI.rod
   VCID: 63CE6FA46A11729E76-8036
8 Faults Found:
0532 - Rear Right Bass Speaker
          B1067 13 [143] - Open Circuit
                    Reset counter: 70
                    Mileage: 47342 km
                    Date: 2020.07.14
                    Time: 15:08:42
0537 - Rear Left Bass Speaker
          B1065 13 [143] - Open Circuit
                    Reset counter: 70
                    Mileage: 47342 km
                    Date: 2020.07.14
                    Time: 15:08:42
0565 - Loudspeaker 1 in Double-Subwoofer
          B130C 13 [143] - Open Circuit
                    Reset counter: 70
                    Mileage: 47342 km
                    Date: 2020.07.14
                    Time: 15:08:42
0560 - Front Right Treble Speaker
          B1064 13 [143] - Open Circuit
                    Reset counter: 70
                    Mileage: 47342 km
                    Date: 2020.07.14
                    Time: 15:08:42
0527 - Double Bass Speaker 1; Front Right
          B1346 13 [143] - Open Circuit
                    Reset counter: 70
                    Mileage: 47342 km
                    Date: 2020.07.14
                    Time: 15:08:42
0570 - Loudspeaker 2 in Double-Subwoofer
          B130D 13 [143] - Open Circuit
                    Reset counter: 70
                    Mileage: 47342 km
                    Date: 2020.07.14
                    Time: 15:08:42
0575 - Double Bass Speaker 1; Front Left
          B1345 13 [143] - Open Circuit
                    Reset counter: 70
                    Mileage: 47342 km
                    Date: 2020.07.14
                    Time: 15:08:42
0585 - Front Left Treble Speaker
          B1061 13 [143] - Open Circuit
                    Reset counter: 70
                    Mileage: 47342 km
                    Date: 2020.07.14
                    Time: 15:08:42
   Serial number: 220515060502D2
   VCID: 3F8683D4A639767E32-806A
   Serial number: 00000000000001291285
   Coding: 091000
   Part No SW: 5G0 035 880 A    HW: 5G0 035 880 A
   Component: MU-S-NS-US    015 0655
   Serial number: V7B02708190037
   Coding: 027302020000000021220002001800001F0100340100010546
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 254A31BC24A5CCAE58-8070
   Subsystem 1 - Part No SW: 5G0 919 605 K    HW: 5G0 919 605 K
   Component: ABT_Std_Nav  H60 0030
   Serial number: VWZ8Z9RS600NK0
   Subsystem 2 - Part No SW: 5G0 919 866 S    HW: -----------
   Component:  NAR 2015  --- 0022
   Component: OCULowMQBUS   007 0564
   Coding: 02730202C2823A017F1E06000000
   Shop #: WSC 00066 790 00322
   ROD: EV_OCULowMQB.rod
End-------------------------(Elapsed Time: 04:13)--------------------------
OK, what exactly are you trying to change in that 5F module?
Based on the scan, the car still has a stock amplifier, but no speakers connected to it?
In the data I found, there's nothing explicit for Fender, but the type of sound system is in Byte 11, with possible values 00-03. It's currently set to 02, which is an external amp (presumably Fender?). Try 01 instead..
As for the "Uninitialized Module" warning, see the very bottom of the Coding page in the software manual:
https://www.ross-tech.com/vcds/tour/recode_screen.php
hergy916
New Member
What you are saying is what we are trying to do. By changing from 02 to 01 the internal amp in the 5F will turn on therefore making it possible to add external amplifiers without the MOST 150 adapter. This is how we used to do it. The problem is that when I go to open the long coding helper I get the "no coding available" error now which didn't happen with the original 5F module. Dealership says it isn't due to anything they have done but I didn't have this problem with the original 5F.
The factory amp is roughly installed just for testing purposes. It ultimately needs to come back out.
PetrolDave
Westbury, UK
C?ID=1423
If you look at the Auto-Scan you will see that for the 5F it shows that there are no labels available for the new 5F - hence why you get that message "no coding available".
All that means is that no coding can be automatically suggested for you, however that does NOT stop you manually changing the coding as Uwe has suggested by changing the hex bytes yourself.
NEtech
C?ID=56995
I think if you change Byte 11, Byte 04.. should also be changed.
Like this:
02730202FF00000021220001001800001F0100340100010546
hergy916
New Member
Like this:
This is exactly what we need to do but when I try to manually enter this code I get the "uninitialized module" error and I have stopped at that point since I have never encountered this error before and was not sure how to reverse it if I choose one of the options in the error message screen.
hergy916
New Member
Interesting. I had not noticed that. We don't do a lot of this kind of work so I'm not real familiar with all the details.
hergy916
New Member
I read that part but was not sure what would happen if I choose the wrong option and wasn't sure how to correct it if I do.
It will either accept it or reject it. WSC, Importer, and Equipment number have no effect on a module's function, they only track who made changes.
hergy916
New Member
That's good to know. Like I mentioned, we don't do a lot of this kind of work so I'm just not that familiar with it and don't wan't to create an even bigger issue. I will give this a try and let you know what happens.
hergy916
New Member
Looks like that worked! Thanks so much for all your help everyone! This has been a slow stressful process getting this figured out.
