2007 Audi Q7 Code Help
atmclick
C?ID=318804
Hey guys, so I replaced the battery, and coded it correctly.
These are the issues that remain.
Any ideas?
6C-Back-up Cam. -- Status: Cannot be reached 1100
6D-Trunk Elect. -- Status: Malfunction 1010
Address 01: Engine        Labels:. 079-907-560-BAR.clb
   Part No SW: 4L0 910 560 C    HW: 4L0 907 560 A
   Component: 4.2l V8/4V          0060
   Revision: --H16---    Serial number:
   Coding: 01210009190F0160
   Shop #: WSC 02101 444 59425
   VCID: A81CA4671B78D50662-80FD
005241 - Brake Boost Vacuum System
               P1479 - 008 - Mechanical Failure
                    Mileage: 182782 km
                    Date: 2017.10.08
                    Time: 18:13:07
                    RPM: 2258 /min
                    Load: 72.9 %
                    Speed: 47.0 km/h
                    Temperature: 94.0°C
                    Temperature: 21.0°C
                    Absolute Pres.: 980.0 mbar
                    Voltage: 14.224 V
002129 - Park/Neutral Switch Input Circuit
               P0851 - 004 - Short to Ground - Intermittent
                    Mileage: 182784 km
                    Date: 2017.11.15
                    Time: 20:16:44
                    Temperature: 1.0°C
                    Temperature: 4.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 8.382 V
009523 - Ignition Switch; Run/Start Position Circuit
               P2533 - 002 - Open or Short to Ground - Intermittent
                    Mileage: 182784 km
                    Temperature: 11.0°C
                    Temperature: 12.0°C
                    Voltage: 10.160 V
                    Temperature: -40.0°C
                    Absolute Pres.: 0.0 mbar
                    Voltage: 0.000 V
Readiness: 0010 1100
   Part No SW: 09D 927 750 BR    HW: 09D 927 750 BR
   Component: AL 750 6A           0915
   Revision: 00H52000    Serial number:
   Coding: 0000504
   Shop #: WSC 31414 790 00001
   VCID: FF4E5F3BAE76B2BE73-80AB
Address 03: ABS Brakes        Labels:. 4L0-910-517-V1.clb
   Part No SW: 4L0 910 517 E    HW: 4L0 614 517 E
   Component: ESP ALLRAD MK25E1   0140
   Revision: 00H45001
   Coding: 0017457
   VCID: AC1458770F80F92686-80F9
            000 -  -  - Intermittent
                    Reset counter: 136
                    Mileage: 182784 km
                    Date: 2017.12.17
                    Time: 13:55:54
                    Count: 128
                    Count: 13569
                    Count: 297
                    Count: 53248
                    Reset counter: 95
                    Mileage: 182784 km
                    Date: 2017.12.17
                    Time: 13:55:57
                    Count: 128
                    Count: 13569
                    Count: 107
                    Count: 53248
   Component: FBSAUDIC6 ELV   H31 0210
   Revision: 27120501    Serial number: 10601000413678
   Coding: 0000143
   VCID: E386F34B22DE765E77-80B7
   Subsystem 1 - Part No: 4F0 910 131 L
   Component: FBSAUDIC6 KSG   H27 0080
   Subsystem 3 - Part No: 4F0 910 220 G
   Component: FBSAUDIC6 IDG   H45 0060
00191 - Passenger's Door Handle Touch Sensor (G416)
            007 - Short to Ground
                    Fault Status: 01110111
                    Reset counter: 95
                    Mileage: 182782 km
                    Date: 2005.09.20
                    Time: 12:31:38
01176 - Key
                    Reset counter: 135
                    Mileage: 182782 km
                    Date: 2005.09.20
                    Time: 12:36:44
Address 07: Control Head        Labels: 4L0-910-7xx-07-H.clb
   Part No SW: 4L0 910 732 R    HW: 4E0 035 729 A
   Component: Interfacebox    H43 4610
   Revision: 00000000    Serial number: 331GL087527015
   Coding: 0002003
   Shop #: WSC 02116 444 04990
   VCID: B83C7427CBD84586F2-80ED
   Subsystem 2 - Serial number: 00000001836152
   Subsystem 3 - Serial number: 0106.05.110000000100010535ÿ
   Subsystem 4 - Serial number: 010535ÿ
   Part No SW: 4L0 910 043     HW: 4L0 820 043 F
   Component: KLIMABETAETIGUNGH05 0040
   Revision: 00---008    Serial number: 00000000028362
   Coding: 0524328
   VCID: E18AF94338C2644E65-80B5
   Part No SW: 4F0 910 279 F    HW: 4F0 907 279 A
   Component: ILM Fahrer      H15 0180
   Coding: 0114123
   Component: Wischer AU716   H11 0030
   Coding: 00064792
   Shop #: WSC 31414
   Component: REGENLICHTSENSORH12 0090
   Coding: 00150059
   Shop #: WSC 31414
   Part No SW: 4L0 910 111 A    HW: 4L0 035 111
   Component: CD-Changer      H41 0100
   Revision: 00000000    Serial number: AUZ5ZBF3005251
   VCID: 9E7082BF493C1BB618-80CB
Address 0F: Digital Radio        Labels: 4E0-910-593-SIR.lbl
   Part No SW: 4E0 910 593 D    HW: 4E0 035 593
   Component: SDAR SIRIUS     H04 0670
   Revision: 00000000    Serial number: AUZ4Z7F5021286
                    Reset counter: 95
                    Mileage: 182784 km
                    Date: 2017.12.17
                    Time: 13:55:56
   Component: 73 AIRBAG AUDI8RH37 0210
   Revision: 02H37000    Serial number: 0038QD021Y89
   Coding: 0014131
   VCID: AB165B6B0A8EFE1E8F-80FF
   Subsystem 1 - Part No: 4L0 910 339
   Component: BF-Gewichtsens. H02 0020
   Subsystem 2 - Serial number: 6332QSME0E330965F
   Subsystem 3 - Serial number: 6342QSME0E06107FJ
   Subsystem 4 - Serial number: 6352QSME0E023807B
   Subsystem 5 - Serial number: 6362QSME0E102773C
   Subsystem 6 - Serial number: 63734SME0C591B1FC
   Subsystem 7 - Serial number: 63834SME0C5A0A051
   Part No SW: 4F0 910 549 A    HW: 4F0 953 549 C
   Revision: 00H02000    Serial number: 90026061120004
   Coding: 0012242
   VCID: A71EA75B1666DA7E6B-80F3
   Component: E0221           H07 0090
Address 17: Instruments        Labels: 4L0-910-xxx-17.lbl
   Part No SW: 4F0 910 930 C    HW: 4L0 920 980 H
   Component: KOMBIINSTR. M73 H16 0070
   Revision: 00400000    Serial number: 53K55WV46
   Coding: 2641263
   Shop #: WSC 60635 000 1048576
   VCID: A306B34B625E365E37-80F7
   Part No SW: 4L0 910 468     HW: 4L0 907 468 A
   Component: J533__Gateway   H06 0040
   Revision: 00H06000    Serial number: 0800D06421805B
   Coding: F5D7FE77347A02
   VCID: EC949877CF003926C6-80B9
                    Reset counter: 95
                    Mileage: 182784 km
                    Date: 2017.12.17
                    Time: 13:56:00
                    Reset counter: 95
                    Mileage: 182784 km
                    Date: 2017.12.17
                    Time: 13:56:55
00317 - Rear Lid Control Module (J605)
                    Reset counter: 135
                    Mileage: 182782 km
                    Date: 2005.09.20
                    Time: 12:12:47
   Part No SW: 4F0 910 760     HW: 4L0 959 760
   Component: Sitzmemory FS   H01 0100
   Revision: 00000000    Serial number: 00000000896401
   Coding: 0082954
   Part No SW: 4E0 910 887 N    HW: 4E0 919 887 C
   Component: MNS US          H45 0740
   Revision: 00000000    Serial number: 306DG067501255
                    Fault Frequency: 10
                    Reset counter: 133
                    Fault Frequency: 10
                    Reset counter: 133
                    Mileage: 182784 km
                    Date: 2017.11.26
                    Time: 22:08:35
                    Bin. Bits:     1100
                    Reset counter: 105
                    Mileage: 182066 km
                    Date: 2017.08.03
                    Time: 16:31:47
   Part No SW: 4L0 910 566 A    HW: 4L0 907 566 A
   Component: J0769_SWA_MasterH06 0060
   Revision: 00H06000    Serial number: 6PZ 009 014-00
   Subsystem 1 - Part No: 4L0 910 568 A
   Component: J0770_SWA_Slave_H05 0060
   Subsystem 2 - Serial number: 6PZ 009 014-20
   Subsystem 3 - Serial number: 3F20.04.0600H0500000010027ÿ
   Subsystem 4 - Serial number: 010027ÿ
Address 42: Door Elect, Driver        Labels: 4L0-910-793-42.lbl
   Part No SW: 4L0 910 793 B    HW: 4L0 959 793 B
   Component: TSG FA          H12 0130
   Revision: 00-00000
   Coding: 0051915
   VCID: AF2E4F7B3E96823EA3-80FB
   Part No SW: 4L0 910 289 D    HW: 4L0 907 289 A
   Component: Komfortgeraet   H05 0020
   Revision: 0020 ---    Serial number: 01012824010000
   Coding: 7632925
   VCID: B12A490328A294CEB5-80E5
01134 - Alarm Horn (H12)
                    Reset counter: 96
                    Mileage: 168065 km
                    Date: 2016.12.23
                    Time: 03:07:39
                    Reset counter: 135
                    Mileage: 182782 km
                    Date: 2005.09.20
                    Time: 12:12:46
Address 47: Sound System
   Part No SW: 4F0 910 280     HW: 4F0 907 280 B
   Revision:             Serial number: 00000000024455
   Coding: 0012001
   VCID: DEF0C2BF09BC5BB658-808B
Address 52: Door Elect, Pass.        Labels: 4L0-910-793-52.lbl
   Part No SW: 4L0 910 793 B    HW: 4L0 959 792 B
   Component: TSG BF          H12 0130
   Revision: 00-00000
   Coding: 0051915
   Part No SW: 4F0 910 357 E    HW: 4F0 907 357 E
   Component: AFS 1           H01 0010
   Coding: 0000021
   Part No SW: 4E0 910 541 T    HW: 4E0 035 541 L
   Revision: 00000000    Serial number: 388D%067522979
   Part No SW: 4L0 910 181     HW: 4L0 915 181
   Component: J0644 BEM       H12 0530
   Revision: --------    Serial number: 00000000013194
   Shop #: WSC 03106 444 84416
   VCID: E484F05727D071668E-80B1
   Subsystem 1 - Part No: 000 915 105 DL
   Component: von VA0  37040551FP
   Coding: 303030393135313035444C56413033373034303535314650
   Shop #: WSC 13918 002 104857
                    Fault Frequency: 7
                    Date: 2005.09.20
                    Time: 12:03:10
Address 62: Door, Rear Left        Labels: 4L0-910-795.lbl
   Part No SW: 4L0 910 795 B    HW: 4L0 959 795 B
   Coding: 0051722
   Revision: 00050100    Serial number: 00000900021699
   Coding: 0062424
   VCID: A208B64F7D443F563C-80F7
            013 - Check DTC Memory - Intermittent - MIL ON
                    Fault Status: 10101101
                    Reset counter: 134
                    Mileage: 182784 km
                    Date: 2017.11.26
                    Time: 22:08:35
                    (no units): 0.0
                    Voltage: 14.20 V
                    (no units): 36.0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
02214 - Tire Pressure Warning
                    Reset counter: 0
                    Mileage: 182783 km
                    Date: 2005.09.20
                    Time: 12:55:26
                    (no units): 5.0
                    Temperature: 6.0°C
                    Error Code: 1
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
   Component: SDS 3501 US     H45 0630
   Revision: 00000000    Serial number: 00000602150466
   Shop #: WSC 12336 024 394758
   VCID: B4244017D7B0A1E6DE-80E1
Address 6C: Back-up Cam.
   Part No SW: 4L0 910 945     HW: 4L0 827 851 A
   Component: ValeoHeckdeckel H20 0280
   Revision: --H20001    Serial number: E5030000B
   Shop #: WSC 98765 666 38354
   Subsystem 3 - Serial number: RD29.04.06--H20001001A0092ÿ
   Subsystem 4 - Serial number: 1A0092ÿ
                    Reset counter: 133
                    Mileage: 182784 km
                    Date: 2017.11.26
                    Time: 21:50:38
   Component: ILM HINTEN 2    H05 0040
   Revision: AAH05044    Serial number: 001565502-----
   Coding: 0003843
   Shop #: WSC 02132 444 57211
   VCID: A600AA5F116CC37650-80F3
   Component: J_245_EE14_SKB09H10 0160
   Component: J_394_EE14_SKB09H10 0160
   Component: J_392_EE14_SKB09H10 0160
00927 - Terminal 30 (Right)
                    Fault Status: 00101100
                    Reset counter: 135
                    Mileage: 182782 km
                    Date: 2005.09.20
                    Time: 12:15:29
Address 72: Door, Rear Right        Labels: 4L0-910-795.lbl
   Part No SW: 4L0 910 795 B    HW: 4L0 959 794 B
   Coding: 0051722
02123 - Door Warning Light / Entry Light
                    Reset counter: 135
                    Mileage: 182784 km
                    Date: 2017.12.17
                    Time: 13:55:55
   Part No SW: 4F0 910 283 D    HW: 4F0 919 283 D
   Component: Parkhilfe 4-Kan H09 0030
   Revision: 00H09000    Serial number: 11720606103961
   Coding: 0021246
   VCID: A502AD536C6AC86E59-80F1
01543 - Parking Aid Warning Chime (H15)
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 95
                    Mileage: 182784 km
                    Date: 2017.12.17
                    Time: 13:55:55
   Part No SW: 4F0 910 336 C    HW: 4E0 862 335
   Component: Handyvorb2      H00 0600
   Coding: 0000000
                    Time Indication: 15
End----------(Elapsed Time: 02:49, VBatt start/end: 14.8V/14.9V)-----------
Dana
Western PA, USA
Ref to the previous condition and scans: http://forums.ross-tech.com/showthread.php?12541-Fault-Code-Issues-(-Audi-Q7-4-2
Does the battery still run flat -or- is everything OK now with the new one installed and coded? Does this vehicle start and run?
Comments:
The fact that the 00166 - Access/Start Authorization Switch (E415) - Defective DTC hasn't returned is great but P2533/009523 - Ignition Switch; Run/Start Position Circuit is still stored. Make sure you cleared 01-Engine codes so we don't send you chasing old problems.
Most of the Intermittent DTCs should clear but the lack of back-up cam and amplifier communication may be related to the previous water leaks. If the MMI system is non functional or you don't have sound from the speakers you may want to poke around in the back looking for water damaged modules and wiring. That may even lead you back to a battery drain if that concern is still present.
Engine-wise you may be able to diagnose the brake DTC with the key on, engine off using Basic Settings 008. That only works with an electric pump however. If that 4.2L has a mechanical vacuum pump the diagnosis won't be possible using a scan tool command.
