2007 Passat 3C- USA, ABS & EPB Coding
Mills83
C?ID=136383
Hi I have a 2007 Passat Sedan 3C w-Auto Trans. The EPB control module was replaced with a used unit and needs coded. Unfortunately an auto scan was commenced prior to replacement and coding for ABS and EPB modules appear to be lost or at a default state.:banghead: Any help in obtaining the correct coding for the ABS and EPB modules would be very much appreciated.
AUTO SCAN WITH ORIGINAL EPB FITTED
Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: Release 19.6.1(x64) Data version: 20190529 DS308.0
Dealer/Shop Name:
Workshop Code: 000 00000 000000
Self-Diagnosis Log
Monday,16,March,2020,19:45:04:41049
VIN: WVWAK73C07P000904 License Plate:
Mileage: 223990km-139180mi Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 42 44 46 52 53 56 62 65 72
VIN: WVWAK73C07P000904 Mileage: 223990km-139180miles
53-Parking Brake -- Status: Malfunction 1010
72-Door, Rear Right -- Status: Cannot be reached 1100
Self-Diagnosis Log
Page 2
Address 01: Engine Labels:. 06F-907-115-AXX.clb
Part No SW: 3C0 907 115 S HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0020
Revision: --H14--- Serial number: VWZCZ000000000
Coding: 0404010A19070160
Shop #: WSC 24223 444 85562
VCID: 30651F90A3830ACF29-8064
005715 - Please check DTC Memory of ABS Controller
P1653 - 004 -
Mileage: 223996 km
Date: 2020.01.30
Time: 20:01:14
Temperature: 47.0°C
Temperature: 13.0°C
Absolute Pres.: 980.0 mbar
Voltage: 12.065 V
049448 - No Communications with Parking Brake Control Module
U0128 - 008 - - Intermittent
Mileage: 223997 km
Date: 2020.01.31
Time: 01:44:57
Temperature: 25.0°C
Temperature: 24.0°C
Voltage: 11.811 V
Readiness: 0110 0101
Self-Diagnosis Log
Page 3
Part No SW: 09G 927 750 HJ HW: 09G 927 750 FP
Component: AQ 250 6F 1068
Revision: 00H38000 Serial number:
Coding: 0000072
VCID: 00058F5053A35A4F99-8054
Self-Diagnosis Log
Page 4
Address 03: ABS Brakes Labels:. 3C0-614-095-C2.clb
Part No SW: 3C0 614 095 S HW: 3C0 614 095 S
Component: ESP 440 C2 H015 0004
Revision: H015 Serial number: 0667525099
Coding: 0010000
Shop #: WSC 00028 028 00001
VCID: 32611598AD8F38DF5F-8066
8 Faults Found:
Fault Frequency: 7
01542 - Yaw Rate Sensor (G202)
Reset counter: 22
Mileage: 223997 km
Date: 2020.01.31
Time: 01:42:31
Reset counter: 22
Mileage: 223997 km
Date: 2020.01.31
Time: 01:43:11
Reset counter: 22
Mileage: 223997 km
Date: 2020.01.31
Self-Diagnosis Log
Page 5
Time: 01:44:30
Reset counter: 22
Mileage: 223997 km
Date: 2020.01.31
Time: 01:44:30
Reset counter: 22
Mileage: 223997 km
Date: 2020.01.31
Time: 01:43:11
Reset counter: 22
Mileage: 223997 km
Date: 2020.01.31
Time: 01:44:30
00810 - Sensor 1/2 for Brake Pressure
Reset counter: 22
Mileage: 223997 km
Date: 2020.01.31
Time: 01:44:30
Self-Diagnosis Log
Page 6
Part No: 1K0 820 047 EC
Component: Climatic PQ35 090 0505
VCID: 69D3B2F440D9BB072E-803C
Self-Diagnosis Log
Page 7
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 Q HW: 3C0 937 049 Q
Component: Bordnetz-SG H46 1501
Revision: 00H46000 Serial number: 00000005590367
Coding: 14848F0340041A00470A00000F00000000285D435C0000
VCID: 3777248C46EDDDF768-8062
Subsystem 1 - Part No: 3C1 955 419 Labels: 1KX-955-119.CLB
Component: Wischer VW461 001 0101
Coding: 00063445
Shop #: WSC 00028
00061 - Footwell Lights
Reset counter: 23
Mileage: 223996 km
Date: 2020.01.24
Time: 14:50:00
Voltage: 11.95 V
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 23
Mileage: 223996 km
Date: 2020.01.24
Time: 14:50:00
Voltage: 11.95 V
Self-Diagnosis Log
Page 8
Reset counter: 23
Mileage: 223996 km
Date: 2020.01.24
Time: 14:41:00
Voltage: 11.95 V
Self-Diagnosis Log
Page 9
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 K HW: 3C0 909 605 K
Component: 0N AIRBAG VW8R 029 2521
Revision: 10029000 Serial number: 003A3P8KLADR
Coding: 0012366
VCID: 2E5901E8B9B71C3F3B-807A
Subsystem 1 - Part No: 3C0 959 339 A
Component: BF-Gewichtsens. 006 0002
Subsystem 2 - Serial number: 0000000003AK0H
Subsystem 3 - Serial number: 0001.01.000000600000000000ÿ† 63
Subsystem 4 - Serial number: 000000ÿ† 6332MSME0E6243549ÿ† 63
Subsystem 5 - Serial number: 243549ÿ† 6342MSME0E72244FKÿ† 63
Subsystem 6 - Serial number: 2244FKÿ† 6351HTS6OLLAP7P2Fÿ† 63
Subsystem 7 - Serial number: AP7P2Fÿ† 6361HTS6OLLM06Q23ÿ† 63
Subsystem 8 - Serial number: M06Q23ÿ† 63727TS64IKMM462Eÿ† 63
Subsystem 9 - Serial number: MM462Eÿ† 63827TS63IKQSMV2Oÿ
Subsystem 10 - Serial number: QSMV2Oÿ
01578 - Airbag Deactivation Warning Lamp; Passenger Side (K145)
009 - Open or Short to Ground - Intermittent - MIL ON
Part No SW: 3C0 953 549 H HW: 3C0 953 549 H
Component: J0527 0015
Revision: 00005000 Serial number: 3C5953507R
Coding: 0002013
VCID: 31631A94A88903C726-8064
Self-Diagnosis Log
Page 10
Part No SW: 3C0 920 971 A HW: 3C0 920 971 A
Component: KOMBIINSTRUMENT VD1 1614
Revision: X0006000 Serial number: 00000000000000
Coding: 0007205
VCID: 234FE0DCE275A157A4-8076
Fault Frequency: 9
Reset counter: 63
Mileage: 223996 km
Date: 2020.01.24
Time: 16:45:41
Self-Diagnosis Log
Page 11
Address 19: CAN Gateway Labels:. 3C0-907-530-V1.clb
Part No SW: 3C0 907 530 C HW: 3C0 907 951 A
Component: Gateway 007 0040
Revision: 00007000 Serial number: 0700C065030515
Coding: 3FFD0E04D21002
VCID: 2143EAD4F869B347B6-8074
Reset counter: 22
Mileage: 223996 km
Date: 2020.01.30
Time: 19:40:37
Reset counter: 63
Mileage: 223997 km
Date: 2020.01.31
Time: 01:44:58
Part No SW: 3C0 919 965 HW: 3C0 919 965
Component: Kompass 005 0002
Revision: 00005000 Serial number: 1166279TQJ8K05
VCID: 6DDBC6E47431A72742-8038
Self-Diagnosis Log
Page 12
Part No SW: 3C0 959 433 AA HW: 3C0 959 433 AA
Component: IMMO 051 0383
Revision: 00051000 Serial number: VWZCZ000000000
Shop #: WSC 24223 444 105587
Component: ELV 029 0380
3C0905861J ELV 029 0380
Part No SW: 1K0 959 701 Q HW: 1K0 959 793 M
Component: J386 TUER-SG FT 1123
Revision: 31007001 Serial number: 00000061769102
Coding: 0001205
Shop #: WSC 43380 001 1048576
VCID: 3C7D3BA07FCBFEAF85-8068
01034 - Electric Window Thermal Protection Active; Driver
Fault Frequency: 73
Reset counter: 62
Mileage: 223996 km
Date: 2020.01.27
Time: 10:07:11
Self-Diagnosis Log
Page 13
Part No: 1K1 909 144 K
Component: EPS_ZFLS Kl.5 D06 1701
VCID: 336F109C529531D754-8066
00625 - Vehicle Speed Signal
Mileage: 3960 km
Temperature: 17.0°C
Voltage: 13.10 V
Voltage: 12.80 V
Component: KSG PQ46 RDK 051 0218
Coding: 13910F8001862E521004141FF08A0F0E085800
Shop #: WSC 00611 002 1048576
Self-Diagnosis Log
Page 14
Part No SW: 1K0 959 702 Q HW: 1K0 959 792 M
Component: J387 TUER-SG BT 1123
Revision: 11007001 Serial number: 00000028868923
Coding: 0001204
VCID: 3D7B36A464D1F7A7B2-8068
01035 - Electric Window Thermal Protection Active; Passenger
Fault Frequency: 72
Reset counter: 62
Mileage: 223996 km
Date: 2020.01.27
Time: 10:07:11
Self-Diagnosis Log
Page 15
Address 53: Parking Brake Labels: 3C0-907-801-53.clb
Part No SW: 3C0 907 801 B HW: 3C0 907 801 B
Component: EPB VC8HC001 013 0001
Revision: 013
Coding: 0010000
Fault Status: 11101101
Fault Frequency: 122
Reset counter: 23
Mileage: 223992 km
Date: 2020.01.31
Time: 01:45:53
Voltage: 11.49 V
Count: 236
000 - - - MIL ON
Fault Status: 11100000
Reset counter: 23
Mileage: 223992 km
Date: 2020.01.31
Time: 01:45:53
Voltage: 11.49 V
Count: 170
02433 - Supply Voltage for Right Parking Brake Motor (V283)
011 - Open Circuit - MIL ON
Fault Status: 11111011
Reset counter: 22
Mileage: 223992 km
Date: 2020.01.24
Time: 15:10:19
Self-Diagnosis Log
Page 16
Voltage: 11.59 V
Count: 117
02432 - Supply Voltage for Left Parking Brake Motor (V282)
012 - Electrical Fault in Circuit - MIL ON
Fault Status: 11111100
Fault Frequency: 7
Reset counter: 17
Mileage: 223808 km
Date: 2020.01.13
Time: 22:14:48
Voltage: 12.84 V
Count: 86
Reset counter: 22
Mileage: 223992 km
Date: 2020.01.24
Time: 15:10:19
Voltage: 11.59 V
Count: 116
Address 56: Radio Labels: 1K0-035-161.lbl
Part No SW: 1K0 035 161 B HW: 1K0 035 161 B
Component: Radio DE2 014 0016
Revision: 00014000 Serial number: VWZ4Z7F6138104
Coding: 0040401
VCID: 1E39D128C9178CBF8B-804A
Self-Diagnosis Log
Page 17
Part No SW: 1K0 959 703 Q HW: 1K0 959 795 J
Component: J388 TUER-SG HL 1109
Revision: 12005001 Serial number: 00000000029359
Coding: 0001168
VCID: 3E7931A869D7ECBFAB-806A
01036 - Electric Window Thermal Protection Active; Rear Left
Fault Frequency: 20
Reset counter: 62
Mileage: 223996 km
Date: 2020.01.27
Time: 10:18:09
01813 - Supply Voltage for Door Controller; Rear Left (J388)
Fault Status: 00100001
Reset counter: 62
Mileage: 223996 km
Date: 2020.01.30
Time: 19:21:19
Component: RDK 0420
Coding: 0100101
Self-Diagnosis Log
Page 18
Address 72: Door, Rear Right Labels: None
Part No: No response
Component: Error LIN Slave 0
VCID: 2C5D0BE08FAB6E2F15-8078
End-------------------------(Elapsed Time: 02:09)--------------------------
AUTO SCAN WITH USED REPLACEMENT EPB MODULE FITTED
Dealer/Shop Name:
Self-Diagnosis Log
Monday,16,March,2020,19:49:52:41049
Self-Diagnosis Log
Page 2
P1653 - 004 -
Mileage: 223996 km
Date: 2020.01.30
Time: 20:01:14
Temperature: 47.0°C
Temperature: 13.0°C
Voltage: 12.065 V
Mileage: 223997 km
Date: 2020.01.31
Time: 01:44:57
Temperature: 25.0°C
Temperature: 24.0°C
Voltage: 11.811 V
Self-Diagnosis Log
Page 3
Coding: 0000072
Self-Diagnosis Log
Page 4
Coding: 0010000
6 Faults Found:
Reset counter: 22
Mileage: 223997 km
Date: 2020.01.31
Time: 01:50:55
Reset counter: 22
Mileage: 223997 km
Date: 2020.01.31
Time: 01:50:56
Reset counter: 22
Mileage: 223997 km
Date: 2020.01.31
Time: 01:50:56
Reset counter: 22
Self-Diagnosis Log
Page 5
Mileage: 223997 km
Date: 2020.01.31
Time: 01:50:56
Reset counter: 22
Mileage: 223997 km
Date: 2020.01.31
Time: 01:50:56
Reset counter: 22
Mileage: 223997 km
Date: 2020.01.31
Time: 01:50:56
Self-Diagnosis Log
Page 6
Coding: 00063445
Shop #: WSC 00028
Reset counter: 23
Mileage: 223997 km
Date: 2020.01.31
Time: 01:50:00
Voltage: 11.70 V
Reset counter: 23
Mileage: 223997 km
Date: 2020.01.31
Time: 01:52:00
Voltage: 11.65 V
Self-Diagnosis Log
Page 7
Reset counter: 23
Mileage: 223997 km
Date: 2020.01.31
Time: 01:50:00
Voltage: 11.70 V
Self-Diagnosis Log
Page 8
Coding: 0012366
Coding: 0002013
Self-Diagnosis Log
Page 9
Coding: 0007205
Reset counter: 23
Mileage: 223997 km
Date: 2020.01.31
Time: 01:50:56
Self-Diagnosis Log
Page 10
Coding: 0001205
Self-Diagnosis Log
Page 11
Coding: 0001204
Self-Diagnosis Log
Page 12
Part No SW: 3C0 907 801 E HW: 3C0 907 801 E
Component: EPB VC8HC003 013 0003
Revision: 013
Coding: 0010000
VCID: 244DE3C0E77BA66FDD-8070
000 - - - MIL ON
Reset counter: 22
Mileage: 223992 km
Date: 2020.01.30
Time: 19:41:48
Voltage: 11.18 V
Count: 170
000 - - - MIL ON
Reset counter: 22
Mileage: 223992 km
Date: 2020.01.30
Time: 19:41:48
Voltage: 11.18 V
Count: 171
Reset counter: 22
Mileage: 223992 km
Date: 2020.01.30
Time: 19:55:27
Self-Diagnosis Log
Page 13
Voltage: 12.84 V
Count: 86
02443 - Control Head
Fault Status: 00111000
Reset counter: 62
Voltage: 9.42 V
Count: 46
Reset counter: 23
Mileage: 223480 km
Date: 2018.08.06
Time: 00:05:00
Voltage: 11.39 V
Count: 236
Coding: 0040401
Self-Diagnosis Log
Page 14
Coding: 0001168
Component: RDK 0420
Coding: 0100101
End-------------------------(Elapsed Time: 02:05
Admin Note: Please do not use the [Print] function in VCDS to post data here. Please post the native text that VCDS produces; it is much more legible on a forum. The native text of all scans is saved in the Scans sub-folder.
Mills83
C?ID=136383
Understood and noted for the future thanks:)
Mills83
C?ID=136383
Mills83
C?ID=136383
Car is fixed!
Auto Scan after Coding and Basic Settings applied
Tuesday,24,March,2020,16:17:56:41049
VCDS Version: 19.6.2.2
Mileage: 224020km-139199mi   Repair Order: RVA6
VIN: WVWAK73C07P000904   Mileage: 224020km-139199miles
   VCID: 30651F90A3830ACF15-8064
   Coding: 0000072
   VCID: 00058F5053A35A4FA5-8054
   Coding: 0013755
   VCID: 32611598AD8F38DF63-8066
   VCID: 69D3B2F440D9BB0712-803C
   VCID: 3777248C46EDDDF754-8062
   Coding: 00063445
   Shop #: WSC 00028
                    Reset counter: 24
                    Mileage: 224028 km
                    Date: 2020.02.07
                    Time: 00:18:00
                    Voltage: 11.75 V
                    Reset counter: 24
                    Mileage: 224028 km
                    Date: 2020.02.07
                    Time: 00:18:00
                    Voltage: 11.80 V
   Coding: 0012366
   VCID: 2E5901E8B9B71C3F07-807A
   Subsystem 3 - Serial number: 0001.01.000000600000000000ÿ†63
   Subsystem 4 - Serial number: 000000ÿ†6332MSME0E6243549ÿ†63
   Subsystem 5 - Serial number: 243549ÿ†6342MSME0E72244FKÿ†63
   Subsystem 6 - Serial number: 2244FKÿ†6351HTS6OLLAP7P2Fÿ†63
   Subsystem 7 - Serial number: AP7P2Fÿ†6361HTS6OLLM06Q23ÿ†63
   Subsystem 8 - Serial number: M06Q23ÿ†63727TS64IKMM462Eÿ†63
   Subsystem 9 - Serial number: MM462Eÿ†63827TS63IKQSMV2Oÿ
   Coding: 0002013
   VCID: 31631A94A88903C71A-8064
   Coding: 0007205
   VCID: 234FE0DCE275A15798-8076
   VCID: 2143EAD4F869B3478A-8074
                    Reset counter: 24
                    Mileage: 224028 km
                    Date: 2020.02.07
                    Time: 00:18:29
   VCID: 6DDBC6E47431A7277E-8038
   Coding: 0001205
   VCID: 3C7D3BA07FCBFEAFB9-8068
   VCID: 336F109C529531D768-8066
   Coding: 0001204
   VCID: 3D7B36A464D1F7A78E-8068
   Revision:   013
   Coding: 0000013
   VCID: 244DE3C0E77BA66FE1-8070
   Coding: 0040401
   VCID: 1E39D128C9178CBFB7-804A
   Coding: 0001168
   VCID: 3E7931A869D7ECBF97-806A
   Component:    RDK              0420
   Coding: 0100101
   VCID: 2C5D0BE08FAB6E2F29-8078
End-------------------------(Elapsed Time: 01:59)--------------------------
