Programming new battery for 2011 Audi A4
PinoySaMI
MI
C?ID=220597
I need help programming my new battery for my Audi A4. I saw the link below in Audizine. It has 3 options. I tried the option 2: 19 CAN gateway and plugged in new battery PN, Manufacturer Code and SN but when I hit TEST the old battery info still shows up. I tried it 3x but to no success.
I bought my replacement battery from the dealer.
http://wiki.ross-tech.com/wiki/index...ry_Replacement
Thanks in advance.
PetrolDave
Westbury, UK
C?ID=1423
Got an Auto-Scan of your A4 which you can post here?
PinoySaMI
MI
C?ID=220597
i do not know how to post the auto scan using a wireless hexnet.
I don't know what intermediate software the above passed though, but without line breaks, it's completely illegible.
PinoySaMI
MI
C?ID=220597
Finished
VIN: WAUBFAFL8BN035774
Scan: 01 02 03 05 08 09 15 16 17 19 2E 42 46 47 52 53 56 62 72 77
03-ABS Brakes -- Status: Malfunction 16010
05-Acc/Start Auth. -- Status: Malfunction 16010
08-Auto HVAC -- Status: Malfunction 16010
09-Cent. Elect. -- Status: OK 16000
16-Steering wheel -- Status: OK 16000
17-Instruments -- Status: Malfunction 16010
19-CAN Gateway -- Status: OK 16000
42-Door Elect, Driver -- Status: OK 16000
46-Central Conv. -- Status: OK 16000
52-Door Elect, Pass. -- Status: OK 16000
53-Parking Brake -- Status: Malfunction 16010
62-Door, Rear Left -- Status: OK 16000
72-Door, Rear Right -- Status: OK 16000
Address 01: Engine  (CAEB
 0----)	Labels: 06H-907-115-CAB.clb
	Part No SW: 8K2 907 115 AG	HW: 8K2 907 115 D
	Component: 2.0l R4/4V TF H19 0002
	Revision: E1H19---
	Coding: 0104010A290F0160
	Shop #: WSC 59023 001 1048576
	ASAM Dataset: EV_ECM20TFS0118K2907115AG 001002
	ROD: EV_ECM20TFS0118K2907115AG.rod
	VCID: 74AB4FD34721A7D7369AAA-8021
0018 - Bank 1: Camshaft A (Intake)
	P0012 00 [040] - Advance Setpoint not Reached (Over-Retarded)
		Fault Status: 00010010
		Fault Frequency: 40
		Reset Counter: 1
		Mileage: 197375 km
		Time: 00:00:00
	P0012 00 [096] - Advance Setpoint not Reached (Over-Retarded)
		Fault Priority: 15
		Fault Frequency: 96
		Reset Counter: 1
		Mileage: 66303 km
		Time: 00:00:00
0015 - SAE - Reserved by Document ISO 15031-6
	P000F 00 [096] - 2005
		Fault Status: 00001111
		Fault Priority: 15
		Fault Frequency: 0
		Reset Counter: 96
		Mileage: 131330 km
		Time: 00:00:00
		Fault Priority: 9
		Fault Frequency: 0
		Reset Counter: 96
		Mileage: 131330 km
		Time: 00:00:00
		Fault Frequency: 0
		Reset Counter: 96
		Mileage: 131330 km
		Time: 00:00:00
Address 02: Auto Trans  (J217)	Labels: 8K-02.lbl
	Part No SW: 8K0 927 158 K	HW: 0BK 927 156 N
	Component: 0BK 20TFSIUSA H08 0010
	Revision: --H08---
	Coding: 001112
	Shop #: WSC 02145 785 00200
	ASAM Dataset: EV_TCMAL551211 001013
	ROD: EV_TCMAL551211_AU48.rod
	VCID: 3E3FADFB39ED3D87107EF8-806B
No fault codes found.
Address 03: ABS Brakes  (J104)	Labels: 8K0-907-379.clb
	Part No SW: 8K0 907 379 BJ	HW: 8K0 907 379 BJ
	Component: ESP8 quattro  H04 0060
	Revision: --------
	Coding: 1D0D10
	Shop #: WSC 02391 823 56573
	VCID: 8247990B8D950167B406CC-80D7
02214 - Tire Pressure Warning
	000 -  -  - Intermittent
		Reset Counter: 160
		Mileage: 161634 km
		Date: 2019.03.09
		Time: 20:42:46
		Hex Value: 0x6F00
		Hex Value: 0x4006
		Hex Value: 0x1237
		Hex Value: 0x1DB4
		Hex Value: 0x00FF
		Fault Status: 00101101
		Reset Counter: 192
		Mileage: 162608 km
		Date: 2019.03.27
		Time: 19:43:34
		Hex Value: 0x0000
		Hex Value: 0x0082
		Hex Value: 0x0032
		Hex Value: 0x027A
		Hex Value: 0x00FF
Address 05: Acc/Start Auth.  (J393)	Labels: 8K0-907-064-05.clb
	Part No SW: 8K0 907 064 CF	HW: 8K0 907 064 CF
	Component: BCM2 2.0      H05 0434
	Coding: 090100
	Shop #: WSC 02399 823 56573
	VCID: 76AF75DB515DADC7088E40-8023
	Subsystem 1 - 	Part No SW: 8T0-959-754-A
	Component: FBSAUDIB8 IDGH50 0071
	Subsystem 2 - 	Part No SW: 8K0-905-852-D
	Component: J764 ELV MLB H37 0042
02812 - Supply Voltage (Terminal 30) for Electronic Steering Column Lock
		Reset Counter: 191
		Mileage: 162608 km
		Date: 2019.03.27
		Time: 19:44:04
		Reset Counter: 192
		Mileage: 162629 km
		Date: 2019.03.28
		Time: 17:58:55
Address 08: Auto HVAC  (J255)	Labels: None
	Part No SW: 8T1 820 043 AN	HW: 8T1 820 043 AN
	Component: KLIMA 1 ZONE  H08 0180
	Revision: A1000000
	Coding: 64002000
	VCID: 7DBD6AF7746BFE9F49F437-8028
01271 - Positioning Motor for Temperature Flap (V68)
	001 - Upper Limit Exceeded
		Fault Status: 01100001
		Reset Counter: 27
		Mileage: 156456 km
		Date: 2018.10.18
		Time: 18:59:07
		Voltage: 13.00 V
		Temperature: 22.0°C
		Temperature: 12.0°C
		Count: 11189
		Count: 11672
		Bin. Bits: 01000000
		Bin. Bits: 00000111
		Time: 6.00 s
		Reset Counter: 192
		Mileage: 162628 km
		Date: 2010.01.22
		Time: 00:08:47
Address 09: Cent. Elect.  (J519)	Labels: 8K0-907-063.clb
	Part No SW: 8K0 907 063 P	HW: 8K0 907 063 P
	Component: BCM1 1.0      H30 0392
	Revision: 10030001
	Coding: 690000B1063C00010000080300007F5F0F14520802000021000000
	VCID: 3C3BA7F32FF137973E4AC2-8069
	Subsystem 1 - 	Part No SW: 8K1-955-119-A	Labels: 1Kx-955-119.clb
	Component: WWS 261110   H06 0070
	Coding: 00FD11
	Subsystem 2 - 	Part No SW: 8K0-941-531-AK	Labels: 8K-09-02.lbl
	Component: E1 - LDS     H08 0090
	Subsystem 3 - 	Part No SW: 8K0-907-410-C
	Component: HOMELINK     H01 0010
Address 15: Airbags  (J234)	Labels: 8K0-959-655.clb
	Part No SW: 8K0 959 655 K	HW: 8K0 959 655 K
	Component: AirbagVW-AU10 H41 0610
	Coding: 303837354230303030304A55304C384B3053
	ROD: EV_AirbaECUVWAUDI010_AU48.rod
	VCID: 45CDC2175C3B6E5F51A4AF-8010
	Subsystem 1 - 	Part No SW: 8K0-959-339-C
	Component: BF-Gewichtss.H02 0040
	Serial Number: 5810000R1000002361��
	Subsystem 2 - 	Serial Number: 6334MSME5A122467A1��
	Subsystem 3 - 	Serial Number: 6344MSME58614C7CT1��
	Subsystem 4 - 	Serial Number: 6352QSME066B4B2CT1��
	Subsystem 5 - 	Serial Number: 6362QSME726A5206G1��
	Subsystem 6 - 	Serial Number: 63732SME376E423831��
	Subsystem 7 - 	Serial Number: 63832SME326E2300U1��
53505 - Component Protection
	U1101 00 [008] - Active
		Reset Counter: 1
		Mileage: 66303 km
		Time: 00:00:00
53265 - Supply voltage
		Fault Status: 00010001
		Reset Counter: 1
		Mileage: 131776 km
		Time: 00:00:00
37044 - Seat Occupied Recognition
	B10B4 00 [008] - Function Restriction due to Undervoltage
		Fault Status: 10110100
		Reset Counter: 1
		Mileage: 131776 km
		Time: 00:00:00
Address 16: Steering wheel  (J527)	Labels: 8K0-953-568.clb
	Part No SW: 8K0 953 568 F	HW: 8K0 953 568 F
	Component: Lenks.Modul   H17 0014
	Revision: --------
	Coding: 000014
	VCID: 3D3DAAF734EB3E9F0974F7-8068
	Subsystem 1 - 	Component: E221 - MFL   H02 0010
Address 17: Instruments  (J285)	Labels: 8T0-920-xxx-17.clb
	Part No SW: 8K0 920 950 H	HW: 8K0 920 950 H
	Component: KOMBIINSTR.   H20 0258
	Revision: 00200000
	Coding: 8B1209000300D705020000
	VCID: 342B8FD307A1FFD7F61A6A-8061
00532 - Supply Voltage B+
		Reset Counter: 192
		Mileage: 162629 km
		Date: 2019.03.28
		Time: 07:29:04
Address 19: CAN Gateway  (J533)	Labels: 8T0-907-468.clb
	Part No SW: 8T0 907 468 AB	HW: 8T0 907 468 H
	Component: GW-BEM 5CAN   H06 0117
	Revision: GB800053
	Coding: 00C303
	VCID: 8145960788931A7FAD1CDB-80D4
	Subsystem 1 - 	Part No SW: 8K0-915-181-E
	Component: J367-BDM     H07 0170
Address 2E: Media Player 3  (R199)	Labels: 8T0-035-785.clb
	Part No SW: 8T0 035 785 A	HW: 8T0 035 785
	Component: SG ext.Player H08 0290
	Revision: 00000000
	Coding: 020302
	VCID: 3935BEE720C302BF252C23-806C
Address 42: Door Elect, Driver  (J386)	Labels: 8K0-959-793.clb
	Part No SW: 8T0 959 793 M	HW: 8T0 959 793 D
	Component: TSG FA        H08 1401
	Revision: --------
	Coding: 011C03204000410001
	VCID: 53E9EC4FA26FD8EFCF50C1-8006
Address 46: Central Conv.  (J393)	Labels: 8K0-907-064-46.clb
	Coding: 0106023A00FA400480B0013200000000
	Subsystem 1 - 	Part No SW: 8K0-959-719
	Component: GTO BF       H06 0050
	Subsystem 2 - 	Part No SW: 1K0-951-605-C
	Component: LIN BACKUP HOH05 1501
	Subsystem 3 - 	Part No SW: 8K0-959-591-A
	Component: J245 PS039   H07 0041
Address 47: Sound System  (J525)	Labels: 8T0-035-223-ASC.clb
	Part No SW: 8T0 035 223 AH	HW: 8T0 035 223
	Component: DSP STD       H07 0230
	Revision: S2300000
	Coding: 0203010102
	VCID: 74AB4FD34721BFD7369AAA-8021
Address 52: Door Elect, Pass.  (J387)	Labels: 8K0-959-792.clb
	Part No SW: 8T0 959 792 M	HW: 8T0 959 792 D
	Component: TSG BF        H08 1401
	Revision: --------
	VCID: 52E7E94B9D75D1E7C426DC-8007
Address 53: Parking Brake  (J540)	Labels: 8K0-907-801.clb
	Part No SW: 8K0 907 801 H	HW: 8K0 907 801 H
	Revision: 00000003
		Reset Counter: 192
		Voltage: 0.00 V
		Count: 77
		Hex Value: 0x4060
		Hex Value: 0x0082
		Hex Value: 0x4040
		Reset Counter: 192
		Mileage: 162629 km
		Date: 2019.03.28
		Time: 07:37:09
		Voltage: 10.90 V
		Count: 80
		Hex Value: 0x02E3
		Hex Value: 0x0001
		Hex Value: 0x1010
Address 56: Radio  (J503)	Labels: 8Tx-035-1xx-56.clb
	Part No SW: 8T1 035 186 R	HW: 8T1 035 186 R
	Component: Con3 Sirius   H06 0351
	Revision: 00000009
	Coding: 04020002010185004119070800
	VCID: 46CFC51B613D7D4758AE50-8013
		Reset Counter: 107
		Mileage: 120582 km
		Date: 2016.12.08
		Time: 17:18:41
		Fault Frequency: 102
		Reset Counter: 194
		Mileage: 140996 km
		Date: 2018.01.28
		Time: 12:59:12
		Bin. Bits: 00000000
		Bin. Bits: 00000000
		Bin. Bits: 00000000
		Bin. Bits: 00000000
		Bin. Bits: 00000000
		Bin. Bits: 10000000
		Bin. Bits: 00000000
		Bin. Bits: 00000000
Address 62: Door, Rear Left  (J388)	Labels: 8K0-959-795.clb
	Part No SW: 8T0 959 795 N	HW: 8T0 959 795 B
	Component: TSG HL        H06 1401
	Revision: --------
	Coding: 010C03204000210001
	VCID: 56EF155BB19DCDC7284EE0-8003
PinoySaMI
MI
C?ID=220597
Sorry. I didn’t know it will like that. Anyway, I replaced it with a much better copy.
OK, it should be Adaptation Channel 4 in 19-CAN Gateway as described here.
What value is in Adaptation Channel 4 now?
What's the part number, vendor code, and serial number of the battery you're installing?
PinoySaMI
MI
C?ID=220597
I am using a wireless hex net.
This is under Chassis: 19 Adaptation: Cloud. Ch 5. battery info/replacement:
Stored value: 8K0915105D. MLA 101124OA1T
New Battery: 000915105DH EMC 38071000O5.
Under Driveline there is 61. battery regulation also. I am not sure which route to take.
000915105DH is an 80Ah battery that should be a direct, 1:1 replacement for 8K0915105D. Try changing just one digit in the existing serial number.
Your car does not have a separate module at address 61.
PinoySaMI
MI
C?ID=220597
Just the SN # and not the PN#?
Yes, if the battery's specifications are the same (and it appears they are), then just changing a single digit in the serial number will tell the car that you've installed a new battery.
PinoySaMI
MI
C?ID=220597
I did change just one digit of the serial #. From original stored value “8K0915105D. MLA 101124OA1T”, I changed the serial# to 101125OA1T or 101124OA2T but neither changes work. The previous value still came up when I hit TEST.
One thing I took note is that after the first change in the serial #, when I exit and went back to try again...the stored value block is empty.
Just to clarify. The step I took were;
Select
Common
19-CAN Gateway
Function
Cloud function
Adaptation-10
Battery Information/Replacement-4
OK, we've been able confirm that there's something in VCDS-Mobile that's not working quite correctly with this.
If you want an immediate fix, beg/borrow/steal a PC, install VCDS, and use that; it will work. If you're unable or unwilling to do that, I'm confident we'll get a fix for VCDS-Mobile implemented in the foreseeable future.
PinoySaMI
MI
C?ID=220597
I have a Mac laptop. Is VCDS already compatible with Mac?
PinoySaMI
MI
C?ID=220597
So I'll just use my VCDS mobile and wired it to a Windows laptop with VCDS?
Your HEX-NET can be user with the full (Windows) version of VCDS via USB or via WiFi.
Shaun
Ok this should be fixed now in VCDS-Cloud. Feel free to try this again with VCDS-Mobile, if you haven't already done it with the PC software.
PinoySaMI
MI
C?ID=220597
Had the battery information changed using a windows based VCDS. Thank you.
PinoySaMI
MI
C?ID=220597
I didn’t see this post right away, I already changed the battery information using a windows based VCDS but will try it with my wireless hex-net.
