Deep down the byte 18 rabbit hole after installing OEM US LED tails on 12 GLI...
zedo
C?ID=215712
I have a 2012 Jetta GLI non nav halogens. I installed a set of US-spec (from hybrid I guess?) LED tails and I'm having a worse and worse time trying to code them, with now non-lighting coding errors coming up.
First of all I was getting rear fog warning light after install. This set does not have rear fog nor is the car wired for it as far as I know. I don't care about rear fog - would be nice but not worth effort, though I do have auto headlight switch with rear fog capability. The car has no additional modifications beyond what I just mentioned.
Anyway, now I'm getting a bunch of errors in autoscan beyond just those related to the lighting setup, not to mention that none of the byte 18 variations (including those done w/out long code) have fixed the issue. Car was at dealer today for DSG flush and I asked them to reset to factory via their system that connects to Germany. My coding changes were indeed reset (and it fixed a weird issue I had with trunk) but the LED DRLs won't come on at all still and there are still warnings for about every possible exterior light upon startup. This was not the case when I first started on this. I also had previously followed some instructions on letting BCM reset and try recoding to original settings but that didn't work either. Dealer reset also did not resolve DRLs or autoscan ABS/TPS monitoring error plus several other autoscan errors. There are no dash lights or anything beyond lights out bulb. The LED tails work except that the dimming parameters seem to be off as the turn signals are extremely bright while brakes and night lamps extra dim.
I have no idea WTF is going on at this point so any suggestions are tremendously appreciated! As per the norm, a seemingly semi-simple mod has gone way over my head !
Here is my latest, post-dealer VCDS autoscan:
Thursday,23,April,2015,18:11:01:48450
VCDS Version: 14.10.2.0
Data version: 20150311
VIN: 3VW4A7AJ3CM048038 License Plate:
Mileage: 83190km-51691mi Repair Order:
Chassis Type: AJ (7N0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 2E 42 44 46 47 4F 52 56 62
72 77
VIN: 3VW4A7AJ3CM048038 Mileage: 83190km-51691miles
Address 01: Engine (CBF) Labels: 06J-907-115-CBF.clb
Part No SW: 06J 906 027 K HW: 06J 907 309 B
Component: MED17.5.2 TFSI 2 03 2908
Revision: PAH04--- Serial number:
Coding: 040301081C070160
Shop #: WSC 09417 444 100808
VCID: 334BF61652882AB9A3D-8066
Address 02: Auto Trans Labels: 02E-927-770.lbl
Part No SW: 02E 300 057 B HW: 02E 927 770 AL
Component: GSG DSG AG6 511 2730
Revision: 05351113 Serial number: 00001103201160
VCID: 181121BA2B2EE9E1B6F-804D
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Coding: A14B600C49260002850B06E792210041A70800
VCID: 7BDB1E36FA5822F93BD-802E
Reset counter: 81
Mileage: 83195 km
Date: 2015.04.23
Time: 00:04:55
Count: 2
Count: 12
Count: 29184
Count: 16390
Count: 49664
Count: 254
Address 08: Auto HVAC
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 5K0 937 086 L HW: 5K0 937 086 L
Component: BCM PQ35 M 011 0048
Revision: BJ011001
Coding: 2F200A1A902F06C400080080000005640100008840808D625C 8000000040
Shop #: WSC 64979 001 1048576
VCID: 3D5FD02EA4CCECC9459-8068
Fault Status: 00101010
Reset counter: 80
Mileage: 83195 km
Date: 2015.04.23
Time: 13:38:57
Voltage: 12.55 V
02897 - Supply Voltage for LED Module for DRL and Parking Light; Right
Fault Status: 01101010
Reset counter: 40
Mileage: 83195 km
Date: 2015.04.23
Time: 13:38:59
Voltage: 12.50 V
Address 15: Airbags
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 1K5 953 521 AK HW: 5K0 953 569 B
Revision: FF010040 Serial number: 20110614300276
Coding: 089A140000
Shop #: WSC 00066 000 00187
ROD: EV_SMLSNGVOLWS.rod
VCID: 76CD0F02C97A7F91443-8023
Subsystem 1 - Part No SW: 5K0 959 542 HW: 5K0 959 542 Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H06 0010
Coding: 830000
Part No SW: 5C6 920 971 B HW: 5C6 920 971 B
Component: KOMBI H04 0617
Coding: 271E01
Shop #: WSC 00066 000 00118
VCID: 2C79ED6A47B67541E27-8079
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 K HW: 1K0 907 951
Component: J533 Gateway H40 1620
Revision: H40 Serial number: 06091101290627
Coding: 351002
VCID: 3851C13A8BEEC9E196F-806D
Part No SW: 561 919 965 HW: 561 919 965
Component: Kompass 001 0001
Revision: 00001000 Serial number: 1829227R046005
VCID: 63EB4656A2E8FA3913D-8036
Component: IMMO H04 0617
VCID: 6AF52B728DC2AB71D0B-803F
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Revision: A1001003 Serial number: 7660408300
VCID: 2977147E40446069191-807C
Address 42: Door Elect, Driver (J386) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 561 959 701 HW: 3C0 959 793 B
Component: TUER-SG FT 002 0515
Revision: 13110009 Serial number: 0003310845
Coding: 0004B5
Shop #: WSC 01383 790 50316
ROD: EV_TSGFPQ35BRFVW46X.rod
VCID: 5B9B7EB65298C2F95BD-800E
Slave Driver:
Subsystem 1 - Part No SW: 3C0 959 703 C HW: 3C0 959 795 D Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 006 1508
Serial number: 00000005996724
Coding: 000490
B11EC 54 [008] - Missing Calibration / Basic Setting
Reset counter: 80
131584 - Motor for Rear Window Regulator
B11EE 54 [008] - Missing Calibration / Basic Setting
Reset counter: 80
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 70 3201
Revision: 00H20000
VCID: 3449F50A57862D81BA7-8061
Address 47: Sound System
Address 4F: Centr. Electr. II (J520) Labels: 1K0-907-532.clb
Part No SW: 7N0 907 532 HW: 1K0 907 951
Component: EZE_2 H40 1620
Coding: 01030100
VCID: 6FC33A66BE204E59875-803A
Subsystem 1 - Part No SW: 5K0 959 591 HW: 5K0 959 591
Component: J245 PS41.019 H08 0006
Coding: 180000
Address 52: Door Elect, Pass.
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1K0 035 180 AD HW: 1K0 035 180 AD
Component: Radio Prem-8 H04 0018
Revision: -----17S Serial number: VWZ4Z7L3192332
Coding: 0102000001
VCID: 62E543527DF2F33118B-8037
Reset counter: 40
Mileage: 77651 km
Date: 2014.05.28
Time: 11:36:20
Address 77: Telephone
End-------------------------(Elapsed Time: 02:08)--------------------------
golfi_vend
Tartu, Estonia
C?ID=195131
First...What options have you tried for byte 18?
I have many tables for that byte...
All of them found from www , haven't tried out any of them myself as i don't have such car.
===LED TAIL LIGHTS===
04; ROW; halogen(GTI); DRLs=LED(+Parking Lights); Tail Lights=LED; Rear Fog-Yes
15; ROW; halogen(GTI); DRLs=Incandescent; Tail Lights=LED; Rear Fog-Yes
41; ROW; Xenon; DRLs=No (LED Parking Lights); Tail Lights=LED; Rear Fog-Yes
44; ROW; Xenon DRLs=No; Tail Lights=LED; Rear Fog-Yes
22; ROW/Japan;halogen; DRLs=No; Tail Lights=LED; Rear Fog-Yes
3F; Ska; Xenon; DRLs=perm Low Beams; Tail Lights=LED; Rear Fog-Yes
43; Ska; halogen; DRLs=perm Low Beams; Tail Lights=LED; Rear Fog-Yes
1F; NAR; halogen; DRLs=Incandescent; Tail lights=LED; Rear Fog=No
21; NAR; halogen; DRLs=LED(+Parking Lights); Tail lights=LED; Rear Fog=No
===INCANDESCENT TAIL LIGHTS w/ REAR FOG===
02; ROW; halogen; DRLs=Incandescent; Tail lights=Incandescent; Rear Fog=Yes
3C; ROW; Xenon; DRLs=perm Low Beams; Tail lights=Incandescent; Rear Fog=Yes
40; ROW; halogen; DRLs=No; Tail lights=Incandescent; Rear Fog=Yes
42; Ska; Xenon; DRLs=LED(+Parking Lights); Tail lights=Incandescent; Rear Fog=Yes
Hex;Primary Vehicle;Secondary Vehicle;Lighting;Region;Details
05;VW Jetta (VW351); ;Halogen;RoW;TFL_0
4A;VW Jetta (VW351); ;Xenon;RoW;PO_LED
4B;VW Jetta (VW351); ;Xenon;RoW;TFL _LED
7E;Audi Q3 (AU316);VW Jetta (VW351);Halogen/Xenon;Südk.;TFL_0
7F;Audi Q3 (AU316);VW Jetta (VW351);Halogen/Xenon;Südk.;TFL_S
86;VW Jetta (VW351); ;Halogen/Xenon;RoW/Ska;TFL_0_Ska
8C;VW Jetta (VW361); ;Halogen/Xenon;RoW;TFL_1
TFL_0: TFL mit NSL u. RFL (daytime running lights and rear fog light, reversing light)
TFL_1: mit TFL TFL-Outputs (daytime running lights with daytime running light outputs)
TFL_S: TFL Skandinavien Abblendlicht m (daytime running lights via Scandinavia low beam lights)
TFL_LED: LED-Modul mit und Doppelfunktion PO TFL (LED module with dual function parking lights and daytime running lights)
TFL_0_S: Sonderlösung Skand., Vorhalt (special Scandinavia derivative solution)
PO_LED: LED-Modul, nur für PO genutzt (led module used only for parking lights)
zedo
C?ID=215712
Thanks for the quick response. I tried so many combos from the various lists I found and suggestions on forums. 21 seems like it should be the correct code but again it doesn't seem to work :-/ thus my confusion. I almost feel like whatever new code I put in isn't being accepted at all actually. I did follow one post the forum about resetting by coding to default number (looks like 21 should be it in my case), getting out, locking car, waiting 2 mins for BCM to "fall asleep" and then recoding once more to 00. That didn't do anything either...
zedo
C?ID=215712
Also, here is my autoscan from prior to changing anything regarding lighting and prior to dealer reset. With this coding I had enabled a few things like windows down via key. Trying to code back to this exact setup did not return things to normal. As a note, the error in this autoscan regarding the left brake light is correct - there was some problem with the assembly in that lamp where it would cut out sometimes and trigger bulb out warning. This is one of the reasons I replaced with this LED set.
Saturday,18,April,2015,20:52:39:48450
VIN: 3VW4A7AJ3CM048038 License Plate: ZEDO
Mileage: 83150km-51667mi Repair Order:
72 77
VIN: 3VW4A7AJ3CM048038 Mileage: 83150km-51667miles
Revision: 00H31001
Revision: BJ011001
Coding: 2F230A3A902F06C400080080250085640720008841808D62DC 8000000040
Shop #: WSC 00066 123 12345
00984 - Left Tail Light (M4)
Fault Frequency: 67
Reset counter: 72
Mileage: 77059 km
Date: 2014.05.04
Time: 20:46:49
Voltage: 14.10 V
Part No SW: 5C0 959 655 E HW: 5C0 959 655 E
Component: AirbagVW10G 013 0807
Serial number: 003GTM01SU44
Coding: 00003937
ASAM Dataset: EV_AirbaVW10SMEVW360 A01020
VCID: 3449F50A9F862D81BA7-8061
Subsystem 1 - Part No SW: 5C6 959 339 HW: 5C6 959 339
Component: BF-Gewichtss. H10 0027
Serial number: 6940000Y1100007C8F0B
Coding: 303245
Component: S.Sens.Fahr.V H01 ----
Serial number: 3572MSME192B1262ZZZR
Component: S.Sens.Beif.V H01 ----
Serial number: 3582MSME772C7161ZZZ.
Serial number: 3516KSME291F5012ZZZO
Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3526KSME39265312ZZZL
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3556LSME09211712ZZZH
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Component: F.Sens.Beif H02 ----
Serial number: 3566LSME6F5A3212ZZZ$
Coding: 271E01
Coding: 351002
Revision: 00H20000
Part No SW: 3T0 035 456 B HW: 3T0 035 456 B
Component: KonzernAmp10K 0362
Revision: -------- Serial number: BP225319948226
VCID: 3041F91A6B9E11A1DEF-8065
Coding: 01030100
Coding: 180000
Address 52: Door Elect, Pass. (J387) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 561 959 702 HW: 3C0 959 792 B
Component: TUER-SG BT 002 0515
Revision: 15110009 Serial number: 0003299509
Coding: 0004B4
ROD: EV_TSGBPQ35BRFVW46X.rod
VCID: 5C997DAA5796C5C1527-8009
Slave Passenger:
Subsystem 1 - Part No SW: 3C0 959 704 B HW: 3C0 959 794 C Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 006 1508
Serial number: 00000006033705
Coding: 000490
Coding: 0102000001
Reset counter: 20
Mileage: 77651 km
Date: 2014.05.28
Time: 11:36:20
End-------------------------(Elapsed Time: 02:16)--------------------------
zedo
C?ID=215712
Just one final note. I also tried to enable/disable the DRLs per the manual and those procedures did not work either. The DRLs would not come on. Additionally, changing coding to enable/disable DRL via menus, or enabling other functions such as coming home on/off via menu, did not work. Setting fogs to operate at DRL did indeed work but turning that off again results in no DRLs at all. No new settings appear to take effect, unlike before when enabling/disabling such things was immediately visible on the MFI. :cry:
zedo
C?ID=215712
Just in case I hadn't screwed things up enough already, last night I tried a few more codes and finally one resulted in the car going crazy. Every single light/piece of electronics flickered, the DRLs came on flashing when hitting break pedal, etc etc and VCDS would no longer access module 9 so I couldn't even try to recode back to original. I hope I didn't brick the module :(
Any suggestions at all for this??? Seemed like it should have been relatively simple, as it was for some others with GLIs who did same. :confused: :(
Jef
HQ
As noted... so the J519 isn't talking... so lets try the following:
  • Operate power locks with door switch several times, leave in the unlock position when done
  • See about arming the alarm for 30 minutes
  • Disconnect battery cables and touch them together, 10 secs good, 10 minutes great. 10 years... dedication
  • Unplug J519 and leave overnight.
See if any of those tips helps get the J519 up and talking again.
Side foot note for everyone, while we don't know what all is going on here.... when doing something outside the normal scanning of a car, lets make sure a battery charger is hooked up. Low voltage can cause problems.
zedo
C?ID=215712
Tried all these stops, with the exception of holding the battery cables together for 10 years - started to get cold standing there after 14 hours so I gave up. Unfortunately nothing has worked. Autoscan freezes on module 9 and can't access it manually either still. ESP fault popped up after I disconnected battery but it's my understanding that it should hopefully reset after a few miles of driving (correct?). Here is the autoscan I just did (I had to click "done" when it got to module 9 since it just froze there):
Wednesday,29,April,2015,12:10:27:48450
VIN: 3VW4A7AJ3CM048038   License Plate: SCREWED
Mileage: 83210km-51704mi   Repair Order:
          72 77
VIN: 3VW4A7AJ3CM048038   Mileage: 83210km-51704miles
09-Cent. Elect. -- Status: Sporadic communication error 1000
46-Central Conv. -- Status: Sporadic communication error 1000
000604 - Fuel Pump Control Module
               P025C - 000 - Short to Ground - Intermittent
                    Temperature: -40.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 12.573 V
Readiness: 0110 0101
   Revision: 00H31001
                    Reset counter: 44
                    Mileage: 83219 km
                    Date: 2015.04.29
                    Time: 00:01:09
                    Count: 2
                    Count: 12
                    Count: 12800
                    Count: 16390
                    Count: 49664
                    Count: 65280
Address 09: Cent. Elect.        Labels: None
   VCID: 558F688EBCBC14896D9-8000
Address 15: Airbags
   Coding: 271E01
12664832 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 84
                    Mileage: 83215 km
                    Date: 2015.04.29
                    Time: 02:15:45
13631488 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 84
                    Mileage: 83215 km
                    Date: 2015.04.29
                    Time: 02:15:46
   Coding: 351002
   Shop #: WSC 00000 960 117126
                    Reset counter: 84
                    Mileage: 83215 km
                    Date: 2015.04.29
                    Time: 02:15:47
                    Reset counter: 84
                    Mileage: 83215 km
                    Date: 2015.04.29
                    Time: 02:15:47
                    Reset counter: 84
                    Mileage: 83219 km
                    Date: 2015.04.29
                    Time: 17:01:54
                    Reset counter: 84
                    Mileage: 83219 km
                    Date: 2015.04.29
                    Time: 17:01:53
   Revision: 00H20000
            000 -  -  - MIL ON
                    Fault Status: 11100000
                    Mileage: 83219 km
                    Date: 2015.04.29
                    Time: 00:00:58
                    Battery Volts: 12.6 V
                        PD
                    Temperature: 31.0°C
                    Count: 2
                    Steering Angle: 0.00°
                    Count: 1
                        SteerAng n.Init
Address 46: Central Conv.
   Coding: 01030100
   Coding: 180000
   Coding: 0102000001
                    Reset counter: 44
                    Mileage: 83215 km
                    Date: 2015.04.29
                    Time: 01:08:59
Address 62: Door, Rear Left
Address 72: Door, Rear Right
End-------------------------(Elapsed Time: 03:23)--------------------------
