Coding MY16 Amundsen / MIB2 - VW/Skoda
BGB
Norway
C?ID=264865 (?) (NRRT)
Coding MY16 Amundsen / MIB2 - VW/Skoda - 1123601 - predictive route data
I've learned that there have been issues with coding in 5F on 2016 models where menues in unrelated controllers have disappeared. Read more here: http://forums.vwvortex.com/showthread.php?7325009-Coding-MY16-MIB2-cars
From VWVortex:
Posting this to find out if a problem being experienced on Skodas is being found on other VAG cars with the same system and maybe a warning to those looking at coding to tread very carefully indeed as the usual protections of autoscans and adaption maps before and after will not protect you with this problem.
This concerns the new 2016 Model Year cars 1-2 months old with the new MIB2 headunits (Amundsen and Columbus on Skoda, Discover and Discover Pro on VW)
Coding certain items (we now believe in 5f) will cause unrelated menus to disappear from the head unit. Coding done on an item is successful so it is not the wrong thing being coded.
The adaption maps being taken prior to any coding are not showing how the car actually is (judging by the menus functional on infotainment at the time) this mis-read map is being coded to the car when other items are coded resulting in corruptions in the controller.
Adaptions are being made that result in corruption of the head units and loss of menus that do not appear in VCDS log files so it is impossible to re-trace steps as you actually have not made those steps.
RossTech have not responded to queries about this from several people for over a month now so I would be very careful about using VCDS on a MY16 car with the high-end nav units until this is sorted.
Now I have not coded anything in 5F on my 2016 Skoda Octavia but I got this fault code:
Address A5: Frt Sens. Drv. Assist Labels: 5Q0-980-653.clb
Control Module Part Number: 5Q0 980 653 G HW: 5Q0 980 653
Component and/or Version: MQB_MFK H06 0060
Software Coding: 0101010001030308000400000100000101
Work Shop Code: WSC 73430 790 00000
ASAM Dataset: EV_MFKBoschAU370 001001 (SK37)
ROD: EV_MFKBoschAU370_AU37.rod
VCID: 3C7755FFB70376DE62-8068
B1630 02 [008] - Signal Failure
Reset counter: 125
Mileage: 512 km
Date: 2016.03.05
Time: 19:02:01
It seems that it has something to do with 5F issue - is there any information on 2016 models and VCDS?
That problem was fixed in version 15.7.3.
Dana
Western PA, USA
I'm not an exert in this area (I still drive a 2012 Tiggy / Mk6) but if tweaks were not made and that fault is stored I suspect the system failed in some way and needs to be further diagnosed. Please post the complete Auto-Scan if you'd like someone here to research this.
Reactions: BGB
BGB
Norway
Thank you Dana for your reply, I will post a complete scan as quickly as possible (At work for the moment).
BGB
Norway
Here is the complete scan, of course the fault code posted above did not appear for some reason:
VCDS Version: Release 15.7.4 (x64) Running on Windows 10 x64
Data version: 20160216
Monday,14,March,2016,23:08:33:26833
Chassis Type: NE (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 18 19 22 2B 36 42 44 52 55
          5F 69 6D A5
VIN: TMBLD9NE6G0158055   Mileage: 632km-392miles
Address 01: Engine (J623-CJSB)       Labels: 06K-907-425-V1.clb
   Part No SW: 8V0 906 264 H    HW: 06K 907 425 B
   Component: 1.8l R4 TFSI  H13 0003
   Revision: --H13---
   Coding: 349D001A2476010B1000
   Shop #: WSC 73430 031 00000
   ASAM Dataset: EV_ECM18TFS0208V0906264H 001005
   ROD: EV_ECM18TFS0208V0906264H_AU37.rod
   VCID: 4189240BD0E11B3631-8014
   Part No SW: 0D9 300 012 F    HW: 02E 927 770 AQ
   Component: DQ250-6A MQB  H53 4904
   Revision: 06253104    Serial number: TFK01511201275
   Shop #: WSC 73430 031 00063
   ROD: EV_TCMDQ250021_AU37.rod
   VCID: 1939AC6B18F163F699-804C
   Revision: 00000000    Serial number: 63365000000381
   Coding: 1C076A913425A9740077070541C82938562C9500E08294FC16415070E009
   ROD: EV_Brake1UDSContiMK100IPB_SK37.rod
   VCID: 7AFB93E7FDB788EE30-802E
   Revision: 00021000    Serial number: 0387876734
   Coding: 030C0C
   Shop #: WSC 73430 790 00000
   ROD: EV_KessyHellaMQBAB_AU37.rod
   VCID: 3A7B53E7BD3748EE70-806E
   Part No SW: 5E0 907 044 AA    HW: 5E0 907 044 AA
   Component: Climatronic   H04 1002
   Revision: 00001K07
   Coding: 02010004004101011005004100101000
   ROD: EV_ACClimaBHBVW37X_SK37.rod
   VCID: 64C7CD9F6F336E1EFA-8030
   Part No SW: 5Q0 937 086 AK    HW: 5Q0 937 086 AK
   Revision: --------    Serial number: 86580812151430
   Coding: 0C031B76C24722FB4FE44004001C17280C00000000000000000000000000
   ROD: EV_BCMBOSCH_AU37.rod
   VCID: 0305EE038A7DC92663-8056
   Slave 1:
   Subsystem 1 - Part No SW: 5E1 955 119     HW: 5E1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS371 151115  041 0570
   Serial number:         151124190742
   Coding: 065DDD
   Slave 2:
   Component: RLHS  037 0059
   Serial number: S4Y15M12D12H12M20S32
   Coding: 00885D
Address 10: Park/Steer Assist (J446)       Labels: 5Q0-919-294.clb
   Revision: --------    Serial number: 39391534302056
   Coding: 0071151151
   Shop #: WSC 73430 790 00063
   ROD: EV_EPHVA18AU3700000_SK37.rod
   VCID: 43852E03CAFD092623-8016
Address 13: Auto Dist. Reg (J428)       Labels: 5Q0-907-572.clb
   Part No SW: 5Q0 907 572 F    HW: 5Q0 907 572 F
   Component: ACC Bosch MQB H05 0400
   Serial number: 26111503211971
   Coding: 000C1E00FE0339
   ASAM Dataset: EV_ACCMRRBoschVW372 001016
   ROD: EV_ACCMRRBoschVW372_AU37.rod
   Part No SW: 3Q0 959 655 AQ    HW: 3Q0 959 655 AQ
   Component: Airbag VW20   013 0200
   Revision: --------    Serial number: 003SNPNGKT1$
   Coding: 98FCC000000000005C5400CC000800000065
   ROD: EV_AirbaVW20TS6VW48X_SK37.rod
   VCID: 0D11C83BDC398F5605-8058
   Seat belt tensioner; left:
   Component: BeltPretRevFL  H36 0350
   Serial number: 34169593B11121550576
   Coding: 333135
   Seat belt tensioner; right:
   Component: BeltPretRevFR  H36 0350
   Serial number: 34169592B10121590481
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 454 000 312 15
   Serial number: 3576U00000009B89B71L
   Subsystem 4 - Part No SW: -----------    HW: 454 000 212 15
   Serial number: 3586U0000008199DA71O
   Subsystem 5 - Part No SW: -----------    HW: 454 802 611 15
   Serial number: 3516R4C884A09000000B
   Subsystem 6 - Part No SW: -----------    HW: 454 802 511 15
   Serial number: 3526RBF56F808000000P
   Subsystem 7 - Part No SW: -----------    HW: 454 801 410 15
   Serial number: 3556VD53BD108000000I
   Part No SW: 5Q0 953 507 JB    HW: 5Q0 953 549 E
   Component: Lenks. Modul  003 0120
   Revision: --------    Serial number: 01121504401142
   Coding: 6410
   ASAM Dataset: EV_SMLSKLOMQB 020001
   ROD: EV_SMLSKLOMQB_SK37.rod
   VCID: 7F0D62F3E695ADC607-802A
   Part No SW: 5E0 920 758 B    HW: 5E0 920 758 B
   Component: KOMBI         324 6422
   Coding: 07A50819ED840008018C6A031000000000000000
   Shop #: WSC 73430 031 12345
   VCID: 2B5566A3426DE166FB-807E
Address 18: Aux. Heat (J364)       Labels: 5Q0-963-272.clb
   Part No SW: 5Q0 963 272 F    HW: 5Q0 963 272 F
   Component: STH-MQB       007 0072
   Coding: 9309
   ASAM Dataset: EV_AuxilParkiHeateWOS 002018
   ROD: EV_AuxilParkiHeateWOS_AU37.rod
   VCID: 39794CEBB83143F679-806C
   Subsystem 1 - Part No SW: 5Q0 963 513 A    HW: 5Q0 963 513 A
   Component: R149 T91-LIN  003 0301
   Serial number: 00000000000001279532
   Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1243
   Revision: --------    Serial number: 0004208070
   Coding: 030100347F085900EB00225E1E0F00010001050000000000000000000000
   Shop #: WSC 73430 790 12345
   ROD: EV_GatewLear.rod
   VCID: 79F98CEBF8B183F639-802C
   Subsystem 2 - Part No SW: 3V0 919 719 A    HW: 3V0 919 719 A
   Component: E221__MFL-PR6  H02 0150
   Serial number: 000000000D2684251115
   Subsystem 3 - Part No SW: 5Q0 915 181 H    HW: 5Q0 915 181 H
   Component: J367-BDMConti  H02 1011
   Serial number: 74185704001512120263
Address 22: AWD (J492)       Labels: 0CQ-907-554.clb
   Serial number: HA1-00007.11.15
   Coding: 0001
   ROD: EV_AllWheelContrHA1VW37X_AU21.rod
   VCID: 4A9B0327EDD7D86EE0-801E
   Revision: 00000000    Serial number: 15000254787001
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB_AU37.rod
   VCID: 34677DDF9F53BE9EAA-8060
Address 36: Seat Mem. Drvr (J810)       Labels: None
   Part No SW: 5Q0 959 760 A    HW: 5Q0 959 760 A
   Component: Sitzmemory    H06 0009
   Serial number: Y0006OKA14066
   Coding: 001000000000010001A081808080000000008181000000D4
   ASAM Dataset: EV_SeatMemorDriveSide 001015
   ROD: EV_SeatMemorDriveSide_SK37.rod
   VCID: 3B7556E3B20D71E66B-806E
   Serial number: 0000178756556
   Coding: 00110920DE00048000001100
   ROD: EV_DCUDriveSideEWMAXCONT_SK37.rod
   VCID: 479D3A13FEC52506FF-8012
   Subsystem 1 - Part No SW: 5Q0 959 811 A    HW: 5Q0 959 811 A
   Serial number: 00000000000008291766
   Coding: 010200
   Component: EPS_MQB_ZFLS  126 1063
   Coding: 9103
   ROD: EV_SteerAssisMQB.rod
   VCID: 44872D1FCFF30E1E1A-8010
   Serial number: 0000178905610
   Coding: 00110120DE00048000001100
   ROD: EV_DCUPasseSideEWMAXCONT_SK37.rod
   VCID: 46833717F9CF3C0E04-8012
   Subsystem 1 - Part No SW: 5Q0 959 812 A    HW: 5Q0 959 812 A
   Serial number: 00000000000008277538
   Coding: 190200
   Coding: 03EA00003F010000
   ROD: EV_HeadlRegulVWAFS_SE26.rod
   VCID: 408F210FDBEB123E3E-8014
   Coding: 3E0000
   Coding: 3E0000
Address 5F: Information Electr. (J794)       Labels: 3V0-035-MIB-HGH2.clb
   Part No SW: 3V0 035 020 B    HW: 3V0 035 020
   Component: MU-H-ND-EU    H50 0318
   Serial number: A676K0FB005175
   Coding: 037342010000000011111202008800002F0002F401208100BE
   VCID: 2541909B2489D7162D-8070
   Media Player Position 1:
   Radio Tuner - Digital:
   Subsystem 2 - Part No SW: 5E0 919 606     HW: 5E0 919 606
   Component: ABT_High  H61 0031
   Serial number: SKZ8Z9RW800SU7
   Engine Control Module 2:
   Subsystem 3 - Part No SW: -----------    HW: -----------
   Component: -------------  --- ----
   Seat Adjustment Driver Side:
   Subsystem 4 - Part No SW: V03 959 801 JK    HW: -----------
   Component: ECE 2016  --- 0134
   Air Conditioning Compressor:
   Diesel Pump Control Unit:
   Door Electronics Driver Side:
   Subsystem 7 - Part No SW: -----------    HW: -----------
   Brake Assistance:
   Subsystem 8 - Part No SW: -----------    HW: -----------
   Interior Monitoring:
   Subsystem 9 - Part No SW: -----------    HW: -----------
   Sound System:
   Door Electronics Rear Left:
   Subsystem 12 - Part No SW: -----------    HW: -----------
   Subsystem 13 - Part No SW: -----------    HW: -----------
   Subsystem 14 - Part No SW: V03 959 800 EG    HW: -----------
   Component: Gracenote2  --- 1012
Address 69: Trailer (J345)       Labels: 5Q0-907-383.clb
   Part No SW: 5Q0 907 383 J    HW: 5Q0 907 383 B
   Component: Anhaenger     H21 0203
   Revision: 8C001003    Serial number: 0388656291
   Coding: 0100000202000000
   ROD: EV_TrailFunctGener2Hella_AU37.rod
   VCID: 3E735FF7A11F64CE4C-806A
Address 6D: Trunk Elect. (----)       Labels: 7N0-959-107.clb
   Part No SW: 5E0 959 107 A    HW: 5E0 959 107
   Component: HDSG-Modul    H01 0746
   Revision: 42001001    Serial number: 317501780
   Coding: 1233074003
   ASAM Dataset: EV_HDSGSk462 301136
   ROD: EV_HDSGSk462_SK37.rod
   VCID: 2A5B63A74D97F86E00-807E
Address A5: Frt Sens. Drv. Assist (R242)       Labels: 5Q0-980-653.clb
   Part No SW: 5Q0 980 653 G    HW: 5Q0 980 653
   Component: MQB_MFK       H06 0060
   Serial number: 10000466941
End-------------------------(Elapsed Time: 05:54)--------------------------
Really hope some experts can come with some input.
BGB
Norway
Anyone want to take a look please? Pretty please... :p
NEtech
C?ID=56995
This DTC has been in different Autoscans.
It could be an DTC for information (Fault Priority: 6).
So if 1123601 (B1630) is shown, like the above Autoscan, please observe when it comes up.
I could be it becomes, active when the Camera in your window is covered by dirt or snow/ice.
BGB
Norway
Thank you very much for your reply.
This may be, I do have lane assist, city safety and acc and I do know that when we have had much snow and dirt during the winter the sensors and camera in the front window may get covered up. I even at one point got a warning while driving saying "low visibility" in a snow storm.
The main issue here is that nothing is related to the problem with MIB2 and Amundsen during VCDS pre 15.7.3 release.
BGB
Norway
After 16 days at the dealership they concluded that the fault code most likely comes from when the sensor is dirty / covered and the message "low visibility acc" appears. As for the long 16 days wait they sorted out a couple of other things as well.
BGB
Norway
So I still get the 1123601 - predictive route data and I now know that it has nothing to do with the visibility of the ACC, also there are now two fault codes where it used to be only one. Would really appreciate if someone could shed some light on this issue.
Could it have something to do with the traffic sign recognition? When I cleared the DTCs a beep and a message saying something about the TSR came up in the display.
Todays auto-scan:
Sunday,29,May,2016,13:55:18:26833
VCDS Version: 15.7.4.1 (x64)
VIN: TMBLD9NE6G0158055   License Plate: IDAG
Mileage: 1436km-892mi   Repair Order:
          5F 69 6D A5
VIN: TMBLD9NE6G0158055   Mileage: 1436km-892miles
   Revision: --H13---
   Coding: 030C0C
   Revision: 00001K07
   Slave 1:
   Coding: 065DDD
   Slave 2:
   Coding: 00885D
   Coding: 0071151151
   Coding: 333135
   Coding: 333135
   Coding: 6410
   Coding: 9309
   Coding: 0001
   Coding: 010200
   Coding: 9103
   Coding: 190200
65608 - Lamp for Ambient Speaker Illumination
          B13C8 01 [008] - Electrical Failure
                    Reset counter: 172
                    Mileage: 1001 km
                    Date: 2016.04.26
                    Time: 23:07:21
   Coding: 3E0000
   Coding: 3E0000
   Brake Assistance:
   Sound System:
   Coding: 1233074003
1123600 - predictive route data
                    Reset counter: 203
                    Mileage: 1405 km
                    Date: 2016.05.28
                    Time: 12:14:32
                    Reset counter: 203
                    Mileage: 1227 km
                    Date: 2016.05.28
                    Time: 08:47:30
