Needle sweep HELP!
circiu emil
C?ID=318370
hi
i was tried to coding Audi a8 2009 to activate the needle sweep, but I don't have long coding on this.
there is any way to coding that in a decimal way.?
you can see the URL
thanks
file:///C:/Users/katy%20emi/Downloads/20180214_162939.webp
file:///C:/Users/katy%20emi/Downloads/20180214_164048.webp
PetrolDave
Westbury, UK
C?ID=1423
you can see the URL
Those URLs are to files on your LOCAL hard drive - so nobody else will be able to access them!!!
What you need to post is a full Auto-Scan - copy the .txt file that VCDS saves and post it inline between CODE tags.
rlarsen
Copenhagen, Denmark
C?ID=78998
Which coding has you tried with ??
drennie599
Northern Ireland
C?ID=109519
hi
you can see the URL
thanks
Not supported on that model.
Gremling
Norway, Nordland
C?ID=319714
Hi, just out of curiosity. What have you tried?
have you tried this?
Enabling Needle Sweep:
[17 - Instruments]
[Coding - 07] -> Long Coding Helper -> Select Byte 1
In Bit 0 - Check box for "Gauge Test/Needle Sweep active"
Would be nice if you can tell if this did the trick.
Also remember taking notes/screenshoots of any before and after changes
Regards
Gremling
daniel.b
Europe
C?ID=318819
OR
Instruments ----> Adaptation
Select "indicator_celebration" from the drop down list
Select "Active" from the lower drop down list
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
I would say this model will be in Adaptation like mention above .
