2003 vw avh come in with multiple faults related to the t-body and customer got used one. with the new tbody i get code p3025--35-00 or 19481 angle sensor 1 for throttle drive 2 G 297 implausible. code doesn't show up right away and can take awhile to show up. The thing is this car doesn't have a g297??
when it came back after the used tbody was installed it had the following codes:
17579 angle sensor 2 for the throttle actuator g188 implausible
p1171-35-01
17972 throttle actuator j338
p1546 under voltage during basic settings
19481 angle sensor 1 for throttle drive 2 g297
p3025-35-10 implausible signal, intermittent
19391 idle control sys rpm
p0507-35-00 higher than expected
17551 load calculation cross check
p1143-35-00 upper limit exceeded
17553 mass air flow sensor g70
p1145-35-10 short to plus intermittent
after clearing and test driving the p3025 comes back first, the epc light comes on and the car goes into limp mode. Since its the one that comes back and doesn't seem to belong its what im focused on. Could it be the wrong tbody? another bad tbody or maybe im missing something else. I tried the wiggle test and checked the terminals at the tbody. Maf output looks OK. curios to see what people think. thanks in advance.
p1171-35-01
