001384 - Signal implausible
WSIXPO
Unverified
France
LP/IP
Hello everyone,
Well, I am a new kid on your forum and after many research I can not fix my problem.
I installed on my Audi TT MK2 1.8 2011 a cruise control following the procedure of "macgran73" very well done.
To this day, the regulator does not work (no LED) and I have this fault on my VAGCOM (sorry in french) :
1 Code défaut trouvé:
001384 - Commande de régulateur de vitesse (E45) Signal implausible
P0568 - 000 -
Capture:
Etat du défaut: 01100000
Priorité du défaut: 0
Fréquence du défaut: 1
Compteur de RAZ: 255
Kilométrage: 49582 km
Heure: 0
Date: 2018.12.26
Temps: 14:35:14
Capture:
Tr/min: 0 /min
Charge: 0.0 %
Vitesse: 0.0 km/h
Température: 12.0°C
Température: 14.0°C
Press. Absolue: 1000.0 mbar
Tension: 12.065 V
I thought about a wiring problem between the engine computer and the multifunction steering wheel computer, so I checked my wiring.
With the VGACOM, I launched a test on the engine ECU (capture 3 and 4) and I manage to move the value "Vehicle Speed" (60 km / h) and switches Position II
I noticed in Capture 4 and in Capture 3 that Switchs position 1 does not change?
I also test the method of holding the SET button for 5 seconds, but nothing either.
I looked at the default code 001384, but he talks about link problem, it seems, yet my connection is good since the engine computer receives the info.
Do you have an idea because here I confess that I'm stuck ...
FYI, my flying calculator is a:
Adresse 16: Volant multifonct. Labels: 8P0-953-549.lbl
No. pièce Log: 8P0 953 549 K Mat: 8P0 953 549 K
Pièce: J0527 H37 0070
Codage: 0002041
No. Atelier: WSC 01236 785 00200
VCID: 4683895C31409D745C-8012
Sous-système 1 - No. pièce: XXXXXXXXXXX
Pièce: E0221 H06 0030
Aucun code défaut trouvé.
Thank you for your return and Happy New Year 2019.
