Audi Q7 (V8 TDI) DPF measuring blocks
R8440667
England
C?ID=382469
Good morning gentlemen.
Im brand new to vcds so please go easy on me!!
I have just bought Hex v2 in order to look at my 2007 4.2tdi Q7 dpf situation. I have a dpf warning on the cluster display which wont clear from driving. Don't seem to have any fault codes associated with this. Im hoping that I can carry out a forced regeneration in order to try and clear it (two dpfs fitted!) if one is indeed blocked or otherwise diagnose the fault.
My current problems are: From my understanding I cant look at the "advanced measuring blocks" function (greyed out) as my engine control module is an older format and as such I need to look at my dpf parameters via the "measuring blocks" function. I have tried many groups that I have found to be applicable from searching online. Problem is I cant seem to get any data from any group here. What am I doing wrong??
I have a glow plug fault code. Could this be stopping the car from automatically cleaning the dpf, and thus caused the problem??
Any help would be massively appreciated.
Regards Ben.
Sunday,24,November,2019,09:00:19:21534
VIN: WAUZZZ4L97D103181   License Plate: OE07NKL
Mileage: 304480km-189195mi   Repair Order:
Chassis Type: 4L (4L0)
Scan: 01 02 03 05 06 07 08 09 0E 0F 11 31 15 16 17 18 19 1E 34 36
          37 3C 42 46 47 4F 52 56 57 61 62 67 69 6C 6D 6F 72 76 77
VIN: WAUZZZ4L97D103181   Mileage: 304480km-189195miles
   Part No SW: 4L0 910 409     HW: 4E1 907 409 B
   Component: 4.2L V8TDI  G000AGMª0020
   Revision: --H04---    Serial number:
   Coding: 0011779
   Shop #: WSC 31414 790 00001
   VCID: 678BBC8E436895DF68D-8032
005661 - Glowplug for Cylinder 4 (Q13)
               P161D - 001 - Open Circuit
                    Fault Status: 01100001
                    Mileage: 304358 km
                    Date: 2019.11.19
                    Time: 09:40:00
                    RPM: 1008 /min
                    Torque: 147.8 Nm
                    Duty Cycle: 0.4 %
                    Voltage: 13.60 V
                    Duty Cycle: 27.6 %
                    Temperature: 6.3°C
   Part No SW: 09D 927 750 FE    HW: 09D 927 750 FE
   Component: AL 750 6A           1050
   Revision: 00H64000    Serial number:
   Coding: 0000504
   VCID: 76B5E1CA14C27C57E3B-8022
   Part No SW: 4L0 910 517 B    HW: 4L0 614 517 D
   Component: ESP ALLRAD MK25E1   0010
   Revision: 00H30001
   Coding: 0103585
   VCID: 290FFAB695FC63AFBE9-807C
                    Reset counter: 120
                    Mileage: 304484 km
                    Date: 2019.11.23
                    Time: 15:35:37
                    Count: 64
                    Count: 8261
                    Count: 128
                    Count: 42752
   Component: FBSAUDIC6 ELV   H31 0220
   Revision: 31050601    Serial number: 10601100732192
   Coding: 0000151
   Shop #: WSC 00694 210 84841
   VCID: 6393A89EB750F9FFB45-8036
   Subsystem 1 - Part No: 4F0 910 131 G
   Component: FBSAUDIC6 KSG   H27 0080
   Subsystem 3 - Part No: 4F0 910 220 K
   Component: FBSAUDIC6 IDG   H01 0040
00191 - Passenger's Door Handle Touch Sensor (G416)
                    Fault Status: 01111011
                    Reset counter: 118
                    Mileage: 304470 km
                    Date: 2019.11.22
                    Time: 11:46:02
00192 - Rear Left Door Handle Touch Sensor (G417)
                    Reset counter: 118
                    Mileage: 304470 km
                    Date: 2019.11.22
                    Time: 11:46:02
                    Reset counter: 118
                    Mileage: 304470 km
                    Date: 2019.11.22
                    Time: 11:46:02
   Part No SW: 4F0 910 760     HW: 4L0 959 760
   Component: Sitzmemory BFS  H01 0100
   Revision: 00000000    Serial number: 00000000896401
   Coding: 0078944
   VCID: 619FA296AD4CEBEFA69-8034
Address 07: Control Head        Labels: 4L0-910-7xx-07-H.clb
   Part No SW: 4L0 910 731 D    HW: 4E0 035 729 A
   Component: Interfacebox    H43 3450
   Revision: 00000000    Serial number: 387DS077547013
   Coding: 0002002
   Subsystem 2 - Serial number: 00000001836152
   Subsystem 3 - Serial number: 0106.05.110000000100010535ÿ
   Subsystem 4 - Serial number: 010535ÿ
                    Reset counter: 153
                    Mileage: 304437 km
                    Date: 2019.11.21
                    Time: 08:58:37
                    Bin. Bits: 00000000
                    Bin. Bits:  0000000
                    Bin. Bits:      001
   Part No SW: 4L0 910 043     HW: 4L0 820 043 E
   Revision: 00---012    Serial number: 00000000110632
   Coding: 0001048
02508 - Temperature Sensor for Refrigerant (G454)
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 118
                    Mileage: 304470 km
                    Date: 2019.11.22
                    Time: 11:41:05
                    Reset counter: 160
                    Mileage: 304479 km
                    Date: 2019.11.22
                    Time: 15:23:03
                    Temperature: 90.0°C
                    Temperature: 20.0°C
                    Temperature: -55.0°C
                    RPM: 1600 /min
                    Absolute Pres.: 1.0 bar
                    Current: 0.000 A
                    Temperature: 14.0°C
   Part No SW: 4F0 910 279 J    HW: 4F0 907 279 A
   Coding: 0111101
   VCID: 303917D2B6261267797-8064
   Subsystem 1 - Part No: 4L2 910 113   Labels: 1KX-955-119.CLB
   Component: Wischer AU716   H08 0080
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
   Part No SW: 4L0 910 110 A    HW: 4L0 035 110
   Component: MP3-Changer     H43 0350
   Revision: 00043000    Serial number: AUZ5ZBG1055173
   VCID: 1D67DE66D1B48F0FC21-8048
Address 0F: Digital Radio        Labels: None
   Part No SW: 4E0 910 563 C    HW: 4E0 035 563
   Component: DAB-Tuner       H41 0830
   Revision: 00000001    Serial number: KE1276V7100915
   VCID: 2411EB82F2DEBEC78DF-8070
Address 11: Engine II        Labels: Redir Fail!
   Component: 4.2L V8TDI  G000AGSª0020
   Coding: 0011779
   Shop #: WSC 95147 753 45725
   Part No SW: 4L0 910 655 B    HW: 4L0 959 655
   Component: 31 AIRBAG AUDI8RH39 0120
   Revision: 06H39000    Serial number: 0037GD09BZPX
   Coding: 0013105
   VCID: 2C0103A29A0E768745F-8078
   Subsystem 1 - Serial number: 6332QSME216B1D01A
   Subsystem 2 - Serial number: 6342QSME28563119B
   Subsystem 3 - Serial number: 6352QSME2856264FP
   Subsystem 4 - Serial number: 6362QSME245A783FW
   Subsystem 5 - Serial number: 63734SME20647837
   Subsystem 6 - Serial number: 63834SME224B533B0
   Revision: 00H08000    Serial number: 90054071020272
   Coding: 0112142
   VCID: 6695B18A44628CD753B-8032
Address 17: Instruments        Labels: 4L0-910-xxx-17.lbl
   Part No SW: 4F0 910 930 C    HW: 4L0 920 980 G
   Component: KOMBIINSTR. M73 H18 0170
   Revision: 00400000    Serial number: 5HJ14AH47
   Coding: 2593448
   Shop #: WSC 00011 888 96745
   VCID: 2313E89EF7D0B9FFF45-8076
Address 18: Aux. Heat        Labels: 4L0-910-105.lbl
   Part No SW: 4L0 910 105     HW: 4L0 815 071 D
   Component: Heizgeraet      H08 0080
   Revision: 0000000C    Serial number: 00000009014264
   VCID: 6099A792A646E2E7A97-8034
   Part No SW: 4L0 910 468     HW: 4L0 907 468 A
   Component: J533__Gateway   H06 0040
   Revision: 00H06000    Serial number: 0800D0732781C5
   Coding: F7DBFFDF747E02
   Shop #: WSC 00385 210 90017
   VCID: 6C81C3A25A8EB68705F-8038
Address 1E: Media Player 2 (R192)       Labels:. 4E0-035-785.lbl
   Part No SW: 4E0 035 785     HW: 4E0 035 785
   Component: SG ext.Player H09 0170
   Revision: 00000000
   VCID: 6597B686B56487CF5A1-8030
Address 34: Level Control        Labels: 4L0-910-553.lbl
   Part No SW: 4L0 910 553 C    HW: 4L0 907 553
   Component: LUFTFDR.-CDC    H03 7660
   Revision: --H03001    Serial number: 15.1528-0096.2
   Coding: 0015520
   VCID: 2A0D05BA90FA68B7B73-807E
                    Reset counter: 158
                    Error Code: 13
01577 - Turn-Off due to Over-Temp
                    Fault Status: 00100001
                    Reset counter: 160
                    Mileage: 304473 km
                    Date: 2019.11.22
                    Time: 14:52:28
                    Error Code: 68
   Component: Sitzmemory FS   H01 0100
   Coding: 0074858
   Part No SW: 4E0 910 887 T    HW: 4E0 919 887 M
   Component: MNS ECE         H49 1030
   Revision: 00000000    Serial number: 399D$077571393
   Shop #: WSC 00385 210 71556
   VCID: 3E2539EA7C72F417FBB-806A
02927 - DVD Read Error
                    Reset counter: 160
                    Mileage: 304470 km
                    Date: 2019.11.22
                    Time: 14:06:29
                    Hex Value: 0x5DD7
                    Hex Value: 0xEBA0
                    Hex Value: 0x0401
                    Hex Value: 0x0000
   Part No SW: 4L0 910 566 B    HW: 4L0 907 566 A
   Component: J0769_SWA_MasterH07 0070
   Revision: 00H07000    Serial number: 6PZ 009 014-00
   Coding: 0011101
   VCID: 2D070EA6A1147F8F521-8078
   Subsystem 1 - Part No: 4L0 910 568 B
   Component: J0770_SWA_Slave_H06 0070
   Subsystem 2 - Serial number: 6PZ 009 014-20
   Subsystem 3 - Serial number: 3F18.12.0600H0600000010121ÿ
   Subsystem 4 - Serial number: 010121ÿ
Address 42: Door Elect, Driver        Labels: 4L0-910-793-42.lbl
   Part No SW: 4L0 910 793 B    HW: 4L0 959 793 B
   Component: TSG FA          H12 0150
   Revision: 00-00000
   Coding: 0019163
   VCID: 2F3B14AEAB180D9F60D-807A
   Part No SW: 4L0 910 289 F    HW: 4L0 907 289 C
   Component: Komfortgeraet   H07 0040
   Revision: 0040 ---    Serial number: 01038117300000
   Coding: 7610619
   VCID: 333318DE4730297F045-8066
03073 - Rear Lid Closed Sensor 1
                    Reset counter: 120
                    Mileage: 300688 km
                    Date: 2019.08.22
                    Time: 12:59:56
Address 47: Sound System        Labels: 4L0-910-223-BO.lbl
   Part No SW: 4L0 910 223 G    HW: 4L0 035 223 D
   Component: DSP-High AU716  H03 0150
   Revision: PROD_01     Serial number: 00000000027137
   Coding: 0000023
   VCID: 2809FFB28EF65AA7A17-807C
   Part No SW: 4F0 910 280     HW: 4F0 907 280 E
   Revision:             Serial number: 00000000044557
   Coding: 0011101
   VCID: 5EE5996A9C32D4179BB-800A
Address 52: Door Elect, Pass.        Labels: 4L0-910-793-52.lbl
   Part No SW: 4L0 910 793 B    HW: 4L0 959 792 B
   Component: TSG BF          H12 0150
   Revision: 00-00000
   Coding: 0019163
   Part No SW: 4E0 910 541 Q    HW: 4E0 035 541 S
   Revision: 00000000    Serial number: 388D4077617969
   VCID: 2E0509AAAC1204976BB-807A
Address 57: TV Tuner
   Part No SW: 4L0 910 181     HW: 4L0 915 181
   Component: J0644 BEM       H12 0530
   Revision: --------    Serial number: 00000000020235
   VCID: 6491AB82B25EFEC74DF-8030
   Subsystem 1 - Part No: 4E0 915 105 A
   Component: von VA0  205VA03B78
   Coding: 344530393135313035412056413032303556413033423738
   Shop #: WSC 00011 888 06946
                    Mileage: 304470 km
                    Date: 2019.11.22
                    Time: 11:41:00
                    Reset counter: 158
                    Mileage: 304470 km
                    Date: 2019.11.22
                    Time: 11:41:00
Address 62: Door, Rear Left        Labels: 4L0-910-795.lbl
   Part No SW: 4L0 910 795 B    HW: 4L0 959 795 B
   Coding: 0018442
   VCID: 313F12D6BD2C1B6F769-8064
   Part No SW: 4E0 910 754 S    HW: 4E0 035 753 A
   Component: SDS 3502 UK     H45 0630
   Revision: 00000000    Serial number: 00000703300389
   Shop #: WSC 12336 024 394758
   VCID: 363521CA54423C5723B-8062
No Faults Found
Address 69: Trailer        Labels: 4E0-910-383.lbl
   Part No SW: 4E0 910 383 C    HW: 4E0 907 383 C
   Component: ANHAENGERELEKTR 004 0060
   Part No SW: 4L0 910 441 A    HW: 4L0 907 441 A
   Component: J772__Rearview      0050
   Revision: --H12---    Serial number: 525PA8-J7342AL
   Coding: 1031001
   Part No SW: 4L0 910 945     HW: 4L0 827 851 B
   Component: ValeoHeckdeckel H21 0280
   Revision: --H21001    Serial number: E5030000B
   Shop #: WSC 98765 666 38354
   Subsystem 3 - Serial number: RD19.04.07--H21001001B0258ÿ
   Subsystem 4 - Serial number: 1B0258ÿ
   Revision: AAH05061    Serial number: 002658822-----
   Coding: 0003587
   VCID: 2615F18A84E24CD793B-8072
   Component: J_245_EE15_SKB09H10 0180
   Component: J_394_EE15_SKB09H10 0180
   Component: J_392_EE15_SKB09H10 0180
Address 72: Door, Rear Right        Labels: 4L0-910-795.lbl
   Part No SW: 4L0 910 795 B    HW: 4L0 959 794 B
   Coding: 0018442
   Part No SW: 4F0 910 283 G    HW: 4F0 919 283 G
   Component: Parkhilfe 8-Kan H12 0060
   Revision: 00H12000    Serial number: 06330710004718
   Coding: 0231146
   Part No SW: 4E0 910 336 M    HW: 4E0 862 335
   Component: Handyvorb2      H16 1130
   Revision: 00000000    Serial number: 00000007652521
   Coding: 0010900
End----------(Elapsed Time: 02:43, VBatt start/end: 13.9V/13.9V)-----------
Documentation for those V8 TDIs is rather rare. The fact that fact that VCDS shows "Redir Fail!" usually indicates that a label file exists in some language, but I'm not able to locate it at the moment.
One thing I notice is that both your ECUs have software version 0020 and there is an 0040 available for them.
Also at over 300,000 km, the DPFs are likely due for a manual cleaning or even replacement.
R8440667
England
C?ID=382469
Jolly decent of you to respond to my thread Uwe. Interesting that you say data files for the v8 TDI are difficult to get hold of. Is that to say i wont be able to look at any engine control parameters other than generic fault codes?? or will i be able to somehow get vcds to work with my v8 tdi engine control system at some stage??
Regarding the software update that you think might be available. Can this be done via vcds or are we talking main dealer??
Regarding the dpf manual cleaning, If you think its the right thing to do, i will pull them both off the car and soak them in a bucket of industrial oven cleaner for a couple of days! does this sound like something that might work?? (really wish i could use vcds to see which, if either, was blocked- thats one of the reasons i bought it in the first place!)
I am very grateful that you are prepared to give up/share your precious time and expertise to help. Top Man👍🏻
Regards, Ben.
Please stand by a bit until we've got our staff back in the office during the week. You can definitely see everything there is to see with standard measuring blocks, the only problem is that I don't know where to tell you to look.
R8440667
England
C?ID=382469
Understood sir. I don’t mean to be impatient. Very appreciative of any advice that you can throw my way. Have a great evening...
Did you know manual chemical cleaning or with block plate to pressure wash in reverse & with removal of oxygen sensors is also possible of the DPF's in the car too?
Check out Wurth and Lubro-moly products.
R8440667
England
C?ID=382469
Really appreciate the input Jack. frustrating that i cant currently look at the dpf parameters with vcds. However, Im determined to have a go at “deep cleaning” both filters if i cant get any diagnostics info. dont know what else to do really. I will look at your suggestions (they sound good) and formulate a plan. I am prepared to just remove them both and soak them in a bucket of something harsh. Regardless of manhours involved. But do you really think that there is a better option?? just want to give the process the best chance really.
Very grateful to you guys for helping me out...
Manual removal clean is always best but most labor intense.
This is why I been coming up with beat the flat rate clock ideas & since my beginning of automotive time?
I like to block turbo ports and EGR & reverse PSI into a reclamation tank & out the forward OXS sensors, filter it with strainer etc. then dispose of properly?
OK, in ECU #2 at address 11:
MVB #102: Exhaust gas cleaning Bank 1
Field 1: EGT after Pre-cat
Field 2: EGT before DPF
Field 3: Pressure Difference across DPF
Field 4: Differential Pressure Sensor Offset
MVB #103: Exhaust gas cleaning Bank 2
MVB #105: Particulate filter Bank 1
Field 1: Oil Ash Volume
Field 2: Soot Mass Calculated
Field 3: Soot Mass Actual/Measured
Field 4: Distance since last regen
MVB #106: Particulate filter Bank 2
Show us what you have there. :-)
R8440667
England
C?ID=382469
HI. I'm really pleased that you have acquired this information Uwe- Awsome work. I will plug into the car first thing In the morning. Hopefully I can look at these parameters on ECU module #2. Fingers crossed. I will report back asap, hopefully with this data for you chaps to cast your eyes over. Be great if I can find out whats going on in there!
Cheers Guys.
R8440667
England
C?ID=382469
Good morning Gents.
Im pleased to report that I have been able to access the measuring blocks for my dpf parameters in engine module #2 (as advised by Uwe yesterday) Results below:
Tuesday,26,November,2019,11:01:58:21534
VIN:    License Plate: OE07NKL
Mileage: 189306   Repair Order:
                Address 11: Engine II  (4L0 910 409 )
11:01:38 Group 102         (EXHAUST GAS CLEANING BANK 1)
  899.0°C  Temperature     (Egt after pre cat)
  121.8°C  Temperature     (EGT BEFORE DPF)
  0 mbar  Pressure         (pressure difference accross dpf)
  0 mbar  Pressure         (differential pressure sensor offset)
11:01:38 Group 103         (EXHAUST GAS CLEANING BANK 2)
  899.0°C  Temperature
  121.8°C  Temperature
  0 mbar  Pressure
  0 mbar  Pressure
11:01:38 Group 003
  693 /min  RPM                   (*****idle)
  276.1 mg/str  Mass Air / Rev.
  487.6 mg/str  Mass Air / Rev.
  464.1 mg/str  Mass Air / Rev.
11:02:41 Group 105          (PARTICULATE FILTER BANK 1)
  0.20  (no units)          (oil ash volume)
  37.0  (no units)          (soot mass calculated
  6.5  (no units)           (soot mass actual/measured
  1340 km  Mileage          (distance since last regen)
11:02:41 Group 106          (PARTICULATE FILTER BANK 2)
  0.20  (no units)
  35.5  (no units)
  11.5  (no units)
  1340 km  Mileage
11:02:41 Group 003
  672 /min  RPM                  (******IDLE)
  282.0 mg/str  Mass Air / Rev.
  270.3 mg/str  Mass Air / Rev.
  293.8 mg/str  Mass Air / Rev.
11:03:27 Group 102                  (**** AS ABOVE
  899.0°C  Temperature
  121.8°C  Temperature
  29 mbar  Pressure
  0 mbar  Pressure
11:03:27 Group 103
  899.0°C  Temperature
  127.6°C  Temperature
  29 mbar  Pressure
  0 mbar  Pressure
11:03:27 Group 003
  2331 /min  RPM                    (******* 2300RPM)
  640.4 mg/str  Mass Air / Rev.
  564.0 mg/str  Mass Air / Rev.
  475.9 mg/str  Mass Air / Rev.
11:04:53 Group 105                     (****** AS ABOVE
  0.20  (no units)
  37.0  (no units)
  7.0  (no units)
  1340 km  Mileage
11:04:53 Group 106
  0.20  (no units)
  35.5  (no units)
  11.5  (no units)
  1340 km  Mileage
11:04:53 Group 003
  2394 /min  RPM                       (***** 2300RPM)
  522.9 mg/str  Mass Air / Rev.
  605.1 mg/str  Mass Air / Rev.
  517.0 mg/str  Mass Air / Rev.
The first set of numbers are from the car sitting with engine at idle. The second set of numbers is with the car sitting with engine rpm at around 2300rpm.
Im no expert but these figures all look reasonable to me. Also Both banks seem to be very similar. (i.e. not just one blocked dpf.)
One thing that does look odd to me is the EGT after pre-cat readings. Are they high? Both sensors seem to be stuck at 899 degrees and don't move as if the had failed to max or something?? Just to satisfy my curiosity on this I have just left the car for an hour so its cold and plugged vcds in again. Without starting the engine (static) both EGT after pre-cat sensor readings are still maxed out at 899 degrees.
I checked and there are no still no fault codes in engine module #1 0r #2. (other than cyl 4 glow plug) The car still has a permanent DPF warning on the instrument cluster which wont clear from driving.
Any input/advice much appreciated.
Regards, Ben.
NEtech
C?ID=56995
Normally yes, I would fix it.
Normally not installed.
Have you checked car user manual, it is described what to do, drive vehicle with conditions for regeneration.
That should be possible if no sensor signals (eg glow plug) are faulty.
I would make Controller Map files with diff. condition, idle, etc.
[Applications]
[Controller Channel Map]
- Controller Address = 01
- Login or security code: Leave blank
- Function: Measuring values
- Output: CSV file
[Go]
AIB Wolfgang
Hello Ben
11:03:27 Group 103
899.0°C Temperature Exhaust gas temperature after precatalyst bank 2
Idling: 90 ... 270 ° C
At full load: 490 ... 830 ° C Temperature too high sensor or wiring faulty
127.6°C Temperature Exhaust gas temperature before particle filter bank 2
Idling: 70 ... 250 ° C
29 mbar Pressure Differential pressure particle filter bank 2
0 ... 950 mbar
0 mbar Pressure Offset differential pressure particle filter bank 2
11:03:27 Group 103
Since both banks read the same, I'm inclined to think Niels is correct, that these sensors don't exist in this application...?
R8440667
England
C?ID=382469
Many thanks for giving me some more input on my situation gents. I need to find out if these sensors are indeed fitted to my vehicle and check them out. I have looked at elsawin for a removal procedure and it seems to show that they are fitted on the v8 tdi, in the engine bay, one in each turbocharger body. I need to have a look myself. I will also replace the bad glowplug.
Regarding the handbook procedure for dpf cleaning during driving. I have indeed tried this a few times. Best I could do was get it to go off for 5 mins before returning. I suspect that this feat is probably a red herring!
Do my dpf pressures and soot/ash readings seem normal to you guys? or getting blocked?
What kind of differential pressures are you seeing at idle?
The fact that both pressure sensors have an offset value of 0 seems a bit questionable, but isn't totally implausible either.
R8440667
England
C?ID=382469
The differential pressures across both dpf's are reading zero at idle.
When I read the sensor data with the engine sitting at 2300rpm (no load) I was getting differential readings of 29mbar across each dpf.
Thanks again.
Ben.
I find that strange. There should be some pressure differential across them at idle. Maybe just a few mbar, but not zero.
How long have you owned this vehicle? Is there any chance that the ECUs have been tinkered with and the DPFs have been gutted?
R8440667
England
C?ID=382469
I have owned the car for three years. Its been passing statutory mot tests on emissions every year no problem.
ive been under the car a few times since ive had it and never noticed any new welding seams on the dpfs.
I havent noticed it smoking badly either. But nonetheless this is a very interesting avenue to explore. I Wouldnt be surprised if they have been messed with- Would explain some things. I am Planning on cleaning them out soon but this will be somewhat of a non-event if they are hollow!
I will get underneath asap and do some investigation. Annoyingly i have got a lift but its lying on the floor in a shed due to me moving house recently and loosing my big garage (i really miss that garage. Sob Sob!)
Also I have read that those dpf pressure sensors are a weakness specifically on the 4.2tdi for some reason. And i believe that the gearbox has to be lowered to gain access. Dont think I can do that without a lift.
Thanks for helping me out.
Ben.
R8440667
England
C?ID=382469
...Sorry to go on gents but Another thing that i have found very strange is the fact that i have a permanent dpf warning on the dash display but no dpf fault codes stored in the engine control modules.
This could possibly be explained by someone having fiddled with the ECU coding... I wonder???
