Hi all,
This is my first post, so please be gentle with me
I've recently embarked upon a little project on my Superb Combi, namely a highline reversing camera.
I've 'modified' the tailgate to accommodate the new parking camera/boot release unit with great success, installed the camera controller in a suitable void behind the boot trim near the offside wheel arch as well as run the cable from the boot to the RNS-510 (Columbus) unit. I've connected up the 12v, ground and CAN Hi & Lo connections as you'd expect.
Now, I have registered the controller in the CAN gateway (6C - backup cam), and I can see its 'vitals' through the measuring blocks, the controller recognises the steering angle data, the reversing signal etc but that is where my luck runs out.
There's very little info online about retrofitting a camera to this particular car so I have had to play it all by ear, as it were.
These are the parts I have fitted so far:
Camera unit: 5N0 627 566
Camera control module: 5N0 907 441A
The main problem I am having is not being able to change the coding on the camera controller AT ALL. It point blank refuses to accept ANY coding changes, I've tried altering the WSC/Importer figures to eliminates the 'zero number' issue but I still get error 31: out of range.
I am wondering if I need to get a 3C Passat camera controller to replace the 5N Tiguan unit if it won't play nice with my car, or even change the CAN gateway.
I have attached a full scan of my car as it currently stands, I'm not too concerned with the calibration error at the moment as I will look into that another day, All I want to go is get the damned thing working to start with!
I've always overcome any issues with my 'tinkering' in the past, but I've hit a real brick wall on this one. Any help would be greatly appreciated
Chassis Type: 3T (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 36 37 42 44 46 52 55 56 61 62
6C 72 77
VIN: TMBKF73T8E9015256 Mileage: 49360km-30670miles
Address 01: Engine (J623-CFGB) Labels: 03L-906-018-CFF.clb
Part No SW: 03L 906 018 RR HW: 03L 906 018 MH
Component: R4 2,0L EDC H28 5266
Revision: 41H28--- Serial number:
Coding: 00190012042501080000
Shop #: WSC 33361 790 00999
ASAM Dataset: EV_ECM20TDI01103L906018RR 003003
ROD: EV_ECM20TDI01103L906018RR.rod
VCID: 0B1E10E3A2DF58790A9-805E
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
Component: ESP MK60EC1 H31 0152
Revision: 00H31001
Coding: 863D6016092300FF610D06E9901F0092340000
VCID: 7DFA4E3BE46B66C904D-8028
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 3T0 907 044 CJ HW: 3T0 907 044 CJ
Component: Climatronic H19 0607
Revision: 00001008
Coding: 0018000003
ROD: EV_ClimaAutoBasis_SK12.rod
VCID: 7CFC433FF7716FC1333-8029
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 1K0 937 087 AN HW: 1K0 937 087 AN
Component: BCM PQ35 H+ 112 0771
Revision: AF112771
Coding: 48010AB8E86BF1C0400800C0310089EC4BF800E0732187208089E7040041
Subsystem 1 - Part No: 3T2 955 119 B
Component: Wischer 30061 26 0700
Coding: 00D7B7
Component: RLS 080713 05 54 0403
Coding: 062BED
Subsystem 3 - Part No: 7N0 951 171 A
Component: DWA-Sensor 00 002 0206
Address 10: Park/Steer Assist (J446) Labels: 5J0-919-475.clb
Part No SW: 5J0 919 475 B HW: 5J0 919 475 A
Component: PARKHILFE 4K H11 0010
Revision: --H11--- Serial number: 32961318501575
Coding: 108002
Shop #: WSC 33361 790 00085
ASAM Dataset: EV_EPHVA14SKxxx0000 002001
ROD: EV_EPHVA14SKxxx0000_SK46.rod
VCID: 346CAB1F9FA16781BB3-8061
Part No SW: 3T0 959 655 D HW: 3T0 959 655 D
Component: J234__LDM VW10 HI 2118
Revision: 24019000 Serial number: 003LEPCYXU66
Coding: 0017485
VCID: 4280FDC71D15D93139F-8017
Subsystem 1 - Serial number: 6332MTS680791713
Subsystem 2 - Serial number: 6342MTS669541713
Subsystem 3 - Serial number: 6351HTS6QIDB4CKR
Subsystem 4 - Serial number: 6361HTS603KF2CKJ
Subsystem 5 - Serial number: 63727TS685V95CKR
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 521 BN HW: 5K0 953 569 E
Component: LENKS.MODUL 016 0140
Revision: FF010042 Serial number: 20130708300033
Coding: 1082140000
ROD: EV_SMLSNGVOLWS.rod
VCID: 79F25A2BF8435AE9285-802C
Subsystem 1 - Part No SW: 5E0 919 719 F HW: 5E0 919 719 F
Component: E221__MFL-PR6 H04 0120
Coding: 820000
Part No SW: 3T2 920 941 M HW: 3T2 920 941 M
Component: KOMBI H06 0811
Coding: 711E01
ROD: EV_Kombi_UDS_VDD_RM09_SK25.rod
VCID: 3F86F433A6E7B4D9561-806A
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 AL HW: 7N0 907 530 AL
Component: J533 Gateway H58 1642
Revision: H58 Serial number: 200613F1002149
Coding: 352303
Shop #: WSC 03246 166 13427
VCID: 7AF04527F54551F121F-802F
Mileage: 49364 km
Date: 2014.11.19
Time: 11:46:30
Component: IMMO H06 0811
VCID: 6AD075678DE5E171D1F-803F
Address 36: Seat Mem. Drvr (J810) Labels: 3C0-959-760.lbl
Part No SW: 3C8 959 760 E HW: 3C8 959 760 E
Component: Sitzmemory H05 3001
Revision: 00H05000
Coding: 00003B
Shop #: WSC 12336 024 394758
VCID: 37769C1386D78C999E1-8062
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 3T0 035 686 C HW: 3T0 035 686 C
Component: RNS-MID H10 5269
Revision: AB001001 Serial number: SKZ6Z7N5210009
Coding: 04000402000400A11000
VCID: 3668911781DD7591857-8063
Subsystem 1 - Part No: 3T0 051 859 Q
Component: EU West V10 8048
Reset counter: 55
Mileage: 49360 km
Address 42: Door Elect, Driver (J386) Labels: 8X0-959-793.clb
Part No SW: 8X0 959 793 H HW: 8X0 959 793 H
Component: TSG FA H10 0415
Coding: 011D0220DE01001000
VCID: 52A0CD870D7549B189F-8007
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 195 3501
Revision: 00H22000
VCID: 39729A2B70C39AE9685-806C
Address 52: Door Elect, Pass. (J387) Labels: 8X0-959-792.clb
Part No SW: 8X0 959 792 H HW: 8X0 959 792 H
Component: TSG BF H10 0415
VCID: 51A2C28B087332A9B05-8004
Address 55: Headlight Range (J745) Labels: 5M0-907-357-V3.clb
Part No SW: 5M0 907 357 F HW: 7L6 907 357 C
Component: AFS-ECU H04 0111
Coding: 01C600003F000000
ROD: EV_HeadlRegulVWAFSPt.rod
VCID: 37769C138ED78C999E1-8062
Subsystem 1 - Part No SW: 8U0 941 329 HW: 8U0 941 329
Component: LeiMo links H01 0003
Coding: 8E0000
Subsystem 2 - Part No SW: 8U0 941 329 HW: 8U0 941 329
Component: LeiMo rechts H01 0003
Coding: 8E0000
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
Reset counter: 55
Mileage: 49360 km
Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb
Part No SW: 7N0 907 534 HW: 7N0 907 530 AL
Component: Batt.regelung H58 1642
Coding: 030F185A
VCID: 71E2620BA83312A9905-8024
Component: J367-BDM H07 0180
Part No SW: 8X0 959 795 D HW: 8X0 959 795 D
Component: TSG HL H07 0415
Coding: 010C00200001001000
VCID: 50A4C78F03793BA1BFB-8005
Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
Part No SW: 5N0 907 441 A HW: 5N0 907 441 A
Component: J772__Rearview 0030
Revision: 00H13000 Serial number: 525PA8-J399331
Coding: 8388607
Shop #: WSC 98765 666 38384
VCID: 2D5ABE7BB48B3649F4D-8078
Reset counter: 15
03006 - Back-up Camera System not calibrated
Reset counter: 15
Component: TSG HR H07 0415
Address 77: Telephone (J412) Labels: 3C8-035-730-A.clb
Part No SW: 3C8 035 730 D HW: 3C8 035 730 D
Component: Telefon 022 0946
Revision: -------- Serial number: 35502105026606
Coding: 020000000100010000000001
ASAM Dataset: EV_UHVPremi 002708
ROD: EV_UHVPremi_SE36.rod
VCID: 244C5B5F2F41F7012B3-8071
End-------------------------(Elapsed Time: 03:42)--------------------------
