Emblem Reverse Camera View on RNS510
Wayne P
Australia
C?ID=325377
I have recently installed a Emblem Reversing Camera on my 2013 Beetle which is fitted with an RNS510 and it's working OK but Can I change the default screen from the Plan view illustration from the Optical Park System to the Camera as the default ? It would to have the Camera view each time I select reverse rather than having to select it each time. At the moment each time Reverse is selected I have to manually select the reverse camera and also when I select the camera view there are a few different views show, on the right of the screen shows a X to close the screen, a mute selection for the optical park warning sounds, Contrast settings adjustments and the fourth selection is to change back from Camera to the plan view optical sensor. Also generally on the left of the camera screen normally it show a plan view of the car but this doesn’t so can any of these selections be tweaked with VCDS ?
iichel
Netherlands, eastern part
C?ID=284912
You want to have a look at the PDC unit, login, go to adaptation and play a bit with the display parameter for reverse. You can choose PDC, camera or automatic. Not sure which one you need.
Wayne P
Australia
C?ID=325377
I am very new to all this so can you tell me how to login to the PDC ? is it thru the VCDS or on the RNS510 headhunt ? I haven't seen any way of getting in on the Headunit but maybe there is a way to boot into it, Thanks for your help
Wayne P
Australia
C?ID=325377
Thank you so much, that is so cool, you obviously know your way around VCDS
iichel
C?ID=284912
Wayne P
Australia
C?ID=325377
I like your Polo and I am thinking of getting one for my son this year
Once again thanks for your help
iichel
C?ID=284912
No problem, always happy to help!
The polo is a great car, but I'd recommend to go for a 6C, if you're considering one, rather than the 6R like I have. It's the facelifted version.
They are built a bit better than the 6R, mainly engine wise, and the new MQB platform will allow you to tweak your heart out. Plus, the new infotainment system is great.
Wayne P
Australia
C?ID=325377
Emblem Reverse Camera View on Discover Media
Hello, You helped me early in the year with Emblem Reverse Camera View on RNS510 which was a great help but now I have updated my Beetle with a Discover Media which works fine but once again I have an issue with how the Park Pilot displays. I have the Reverse camera working fine but the overlay for the Park Pilot doesn't show on the Left side but once I take it out of reverse the camera view disappears as it should and I get the full screen Park Pilot display so both systems are working but I can't get the overlay when the camera is in use, With the Park Pilot on screen on the Left side I get an icon for the Camera which is grey whereas the Icon at the bottom is white for turning send off which indicates to me the grey icon is not functioning to be able to select it
iichel
C?ID=284912
if you could show another autoscan, that would be good. but i don't know anything about the PQ discover media system.
Wayne P
Australia
C?ID=325377
Sunday,15,July,2018,10:20:28:62801
VCDS Version: 18.2.1.2 (x64)  HEX-NET CB: 0.4411.4
VIN: WVWZZZ16ZDM691696   License Plate:
Chassis Type: 16-VW32 (6R0)
Scan: 01 02 03 05 08 09 10 15 17 19 25 2B 37 44 55 56 77
VIN: WVWZZZ16ZDM691696   Mileage: 75820km-47112miles
Address 01: Engine (J623-CTHD)       Labels:. 03C-907-309-V1.clb
   Part No SW: 03C 906 026 AK    HW: 03C 907 309 Q
   Component: 1.4l R4 TSI   H02 3735
   Revision: LMH02---    Serial number: 00000000000000
   Coding: 00250012002400000000
   Shop #: WSC 00066 000 00071
   ASAM Dataset: EV_ECM14TSI01103C906026AK 001003
   ROD: EV_ECM14TSI01103C906026AK.rod
   VCID: 699A53F6888CB30C90-803C
Readiness: 1110 0101
   Part No SW: 0AM 300 058 P    HW: 0AM 927 769 D
   Component: GSG DSG AG7     431 3655
   Revision: 00043014    Serial number: CU501304176364
   VCID: 3E30D0AA6982E4B415-806A
   Part No SW: 5C0 907 379 C    HW: 5C0 907 379 C
   Component: ESP MK60EC1   H31 0156
   Revision: 00H31001
   Coding: E63B60F8212B00FB671106ED841F0080251800
   VCID: 2E10E0EA79E2143485-807A
   Component: VWKESSYPQ35GP 086 1101
   Revision: 00086000    Serial number: 0209997323
   Coding: 030C0C
   ASAM Dataset: EV_KESSYPQ35G A02715
   VCID: 3424F2829FCE3EE4F3-8060
   Part No SW: 5C0 907 044 Q    HW: 5C0 907 044 Q
   Component: Climatronic   H03 0304
   Revision: 00001K02
   Coding: 3010001002
   Shop #: WSC 00066 000 00075
   ROD: EV_ClimaAutoBasis_VW32.rod
   VCID: 312AFB9660DC0BCC98-8064
   Part No SW: 6R0 937 088 F    HW: 6R0 937 088
   Component: BCM PQ25 Re4  H50 0353
   Revision: BU050001    Serial number: 04571154131400
   Coding: 6CB8697B0801080009A809916E0B86C5F8C2670F60851841B2A004010000
   VCID: 41CAAB56D87C9B4C68-8014
   Component: RLS 240413 05  54  0403
   Coding: 02300A
   Subsystem 2 - Part No SW: 6R0 959 802 BB    HW: 6R0 959 802 BB  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  002 1060
   Serial number: KU0KU022041300012790
   Coding: 0DBC34
   Subsystem 3 - Part No SW: 6R0 959 801 AS    HW: 6R0 959 801 AS  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  002 1060
   Serial number: KU0KU019031300017318
   Coding: 0DBC34
   Subsystem 4 - Part No SW: 5C5 959 591     HW: 5K0 959 591
   Component: J245 PS71.023  H10 0007
   Serial number:     WRH000928D2
   Coding: 381000
   Subsystem 5 - Part No SW: 5C0 959 442 C    HW: 5C0 959 442 C
   Component: E221__MFL-YVJ  H02 0103
   Serial number: 00000000000000695710
   Coding: E20000
Address 10: Park/Steer Assist (J446)       Labels:| 1Q0-919-475.clb
   Part No SW: 5C5 919 475 A    HW: 7E0 919 475 A
   Component: PARKHILFE 8K  H10 0007
   Revision: --------    Serial number: 83481315700035
   Coding: 308101
   Shop #: WSC 00066 123 00126
   ASAM Dataset: EV_EPHVA18VW3240000 001004
   ROD: EV_EPHVA18VW3240000.rod
   Part No SW: 5C0 959 655 C    HW: 5C0 959 655 C
   Serial number: 003G6M0A31CU
   Coding: 0000424A
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 3228F49A65DA30D4E1-8066
   Serial number: 3572MSME1F40727AZZZ$
   Serial number: 3582MSME5F762178ZZZ2
   Part No SW: 5C5 920 870 B    HW: 5C5 920 870 B
   Component: KOMBI         H24 0103
   Revision: X0024005    Serial number:
   Coding: 150B01
   Shop #: WSC 00066 000 00124
   ASAM Dataset: EV_KombiUDSMM9RM10 A04712
   ROD: EV_KombiUDSMM9RM10_A04_VW32.rod
   VCID: 291A13F6480C730C50-807C
Address 19: CAN Gateway (J533)       Labels:. 6R0-907-530-V2.clb
   Part No SW: 6R0 907 530 F    HW: 1K0 907 951
   Component: J533  Gateway H39 0042
   Revision:   H39       Serial number: 15051303301893
   Coding: 254081
   Shop #: WSC 00066 123 12345
   VCID: 3620C88A81B22CF4CD-8062
   Part No SW: 5K0 953 234     HW: 5C5 920 870 B
   Component: IMMO          H24 0103
   Coding: 000007
   Shop #: WSC 00066 000 00126
   ASAM Dataset: EV_ImmoUDSMM9RM10 A01702
   ROD: EV_ImmoUDSMM9RM10_VW12.rod
   VCID: 6A982CFA8D8AB81499-803E
Address 2B: Steer. Col. Lock (J764)       Labels:| 5K0-905-861.clb
   Revision: 00000000    Serial number: 13000070503002
   Coding: 4900000000000000
   Shop #: WSC 00066 790 50316
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 302CFE926BD602C497-8064
Address 37: Navigation
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 70     3305
   Revision: 00H22000
   VCID: 373EC58E46B8D5FCD6-8062
Address 55: Headlight Range (J431)       Labels:. 6R0-907-357.clb
   Part No SW: 6R0 907 357     HW: 6R0 907 357
   Component: LWR-ECU       H02 0070
   Coding: 0312000001000000
   ASAM Dataset: EV_HeadlRegulVWLWRPt 001004
   ROD: EV_HeadlRegulVWLWRPt_VW32.rod
   VCID: 77BE058ECE3815FC16-8022
Address 56: Radio
   Part No SW: 7P6 035 730 K    HW: 7P6 035 730 K
   Revision: 1B001001    Serial number: 00007664668436
   Coding: 0A01000000010101
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002.rod
   VCID: 3A38DCBABDAAC89429-806E
9455635 - Telephone Microphone
          B1048 13 [009] - Open Circuit
                    Reset counter: 184
                    Mileage: 75828 km
                    Date: 2018.07.14
                    Time: 10:54:01
9457427 - Left audio channel for speech/telephone
          B104F 13 [009] - Short to GND
                    Reset counter: 184
                    Mileage: 75828 km
                    Date: 2018.07.14
                    Time: 10:54:01
9457171 - Right audio channel for speech/telephone
          B104E 13 [009] - Short to GND
                    Reset counter: 184
                    Mileage: 75828 km
                    Date: 2018.07.14
                    Time: 10:54:01
End----------(Elapsed Time: 01:21, VBatt start/end: 14.5V/14.5V)-----------
Wayne P
Australia
C?ID=325377
Hi, I am new to auto scans so it didn't quite come out the way they normally do but anyway you will notice that Radio and Navigation say they cannot be reached and that's because I have changed to the Discover Media and I did try to remove them from the installation list but that didn't work out so easier to just leave them their for the moment and I access module 5F via the Go To function on VCDS because I can't add it to the installation list because it doesn't show on the installation list so I can't add it so it won't show in the Auto scan
Wayne P
Australia
C?ID=325377
Wayne P
Australia
C?ID=325377
I have just been looking at the Introduction to your Polo and I am amazed how much time you put int modifying yours and I am working on a few projects for mine also like Blind spot monitor which I have installed but trying to get it running is challenging as I only had a Golf wiring diagram to start with and that didn't work so now I have the Beetle diagram and that is quite different so I have some wiring problems to solve
Viking
C?ID=151455
You'll need a newer CAN Gateway which supports Controller 5F I presume. Once you do this you should be able to select 5F in the installation list, and from that you should then be able to access the newer Media unit.
Wayne P
Australia
C?ID=325377
Hi and thank you, I tried another gateway and that just added to the problem having so many other options other than 5F and even when I deselected them from the gateway, I had so many modules that I couldn't code or recode correctly that I have given up on that Idea for a little while
I am not that familiar with all the gateway stuff but but everyone says on forums you need a 7N0 or later and I tried that but obviously there is a lot more to it then just getting the latest gateway. I can access 5F directly, just can't add it to the installation list because there is no box to tick for 5F, but I have coded 5F and it works quite well but I just don't get the park pilot overlay on the left side of the screen
siLc
Tallinn, Estonia
C?ID=330192
What gateway did you try for this?
http://forums.ross-tech.com/showthr...eetle-5C-soft-top-1-2-TSI-DSG-kessy-Xenon-NAV
Since the Beetle is based on the PQ25 electrics platform, perhaps 7N0 isn't the correct gateway? This reference scan from a newer car indicates you would need the following GW.
Address 19: CAN Gateway (J533)       Labels:. 7E0-909-901.clb
   Part No SW: 7E0 909 901     HW: 7E0 937 090
   Component: GW-K-CAN TP20 H81 0744
   Revision: B9081001
   Coding: 502007
   VCID: 688945E162713E87DA8-803D
Wayne P
Australia
C?ID=325377
Yeah so complicated, the 7E0 937 090 J533 can Gateway, which I have tried, and it does away with the 09: Cent. Elect. (J519) altogether and uses the Can gateway for both and my beetle has both J533 and J519, 2 separate units. so without rewiring the whole system I hoped to use the 7E0 937 090 and the 7N0 but so far that hasn't worked out. I haven't given up but it seems complicated at the moment, it would be nice to have one unit for all but VW seem to tweak each unit for each model and then give it a new part number, so just need to keep playing
iichel
C?ID=284912
I agree with the earlier mention of an incompatible can gateway.
You'll need to fit a bcm with integrated can gateway from the 7E0 family. That is what is currently also fitted in the latest beetle.
The process of removing the external can gateway fortunately is not very complicated.
You will have to run power train can, diagnostics can and instrument cluster can wires to the bcm. I would take them from the G85, obd connector and instrument cluster respectively. Then one last wire from the bcm to the old gateway connector for the Lin alternator.
After that it will be a matter of transferring the coding of the bcm, gateway, battery monitor (if present) and putting the right adaptation values in the modules. And don't forget to learn the remotes.
It may sound a bit complicated but it's very doable :-) and your discover media will work like a charm...
Wayne P
Australia
C?ID=325377
That's good news, when the can gateway I bought didn't do the trick, I bought the latest beetle 7E0, I had something similar in mind, I thought I would be able to run wires from the existing can gateway plug to the BCM but hadn't gotten that far yet.
OK so I get the idea and will work on that thanks
I tried the 7E0 by itself but didn't get far because I have keyless entry and the 7E0 can't recognise that yet and as soon as I went to put power on it couldn't find a key obviously
I will get there eventually, it sounds like you have been in the same situation
I ordered a socket last week to go from the can gateway to save hacking into the existing harness so i'll see how I go and keep you updated
Discover Media has been a great retrofit and with a few refinements I hope to get the Blind Spot Monitor working also, another reason I bought the 7E0 :)
