Audi Q5 Security Login Not Accepted Using Wifi Option
Ashraf6119
C?ID=174194
I had this vehicle in last week with Engine fault and did a quick scan using WiFi option and it would not accept login security code for adaptation and basic settings which is 27971 and 12233 tried few time but kept failing so thought of using USB cable and it did accept with out any problem so, I question is has any one come across this problem before.?
Below is the full scan using USB Cable option
Friday,03,January,2020,14:34:25:07075
VCDS Version: 19.6.2.0  HEX-NET CB: 0.4508.4
VIN: WAUZZZ8R3AA075935   License Plate:  Q5 2010
Mileage: 185670km-115369mi   Repair Order:
Chassis Type: 8R-AU48 (8T0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 42 46 52 53 55 56 5F 62 6D
          72
VIN: WAUZZZ8R3AA075935   Mileage: 185670km-115369miles
09-Cent. Elect. -- Status: Sporadic communication error 1000
Address 01: Engine (J623-CAHA)       Labels:| 03L-906-022-CAG.clb
   Part No SW: 03L 906 019 AS    HW: 03L 906 022 B
   Component: R4 2,0L EDC   H03 8476
   Revision: 11H03---
   Coding: 01210023240F2018
   Shop #: WSC 00557 210 92234
   ASAM Dataset: EV_ECM20TDI03L906019AS A01008
   ROD: EV_ECM20TDI03L906019AR.rod
   VCID: 7CB4ECAAF7F0C4AFFB-8028
4912 - Exhaust Gas Temperature Sensor 4 Bank 1
          P246E 00 [175] - Electrical Malfunction
                    Mileage: 185670 km
                    Date: 2020.01.02
                    Time: 18:52:49
                    Coolant temperature: 27 °C
                    Intake air temperature: 13 °C
                    Voltage terminal 30: 11.680 V
                    Crankshaft speed (RPM): 0.0 /min
                    Vehicle speed: 0.00 km/h
                    Vehicle voltage terminal 30: 11680 mV
                    Coolant temperature: 27.0 °C
                    Exhaust gas temp.bef.turbocharger: 109.0 °C
                    Exh t Sens TP Flt Us: 87.7 °C
                    Exhaust gas temperature before particulate filter: 1000.0 °C
5380 - Valve for Air Filter Bypass Flap (N275)
          P1016 00 [047] - Open Circuit
                    Mileage: 185670 km
                    Date: 2020.01.02
                    Time: 18:52:44
                    Accelerator position: 0.00 %
                    Ambient air pressure: 1007 hPa
                    Ambient temperature: 10.5 °C
                    Air mass: specified value: 796.0 mg/stroke
                    Intake air temperature: 13.2 °C
5258 - Exhaust Gas Temperature Sensor 4 Bank 1
                    Mileage: 185670 km
                    Date: 2020.01.02
                    Time: 18:52:44
                    Voltage terminal 30: 11.660 V
                    Vehicle voltage terminal 30: 11660 mV
                    Exhaust gas temp.bef.turbocharger: 111.2 °C
Readiness: 1 1 0 0 1
   Part No SW: 8R0 927 156 N    HW: 0B5 927 156 E
   Component: 0B5 20 TDIRdW H03 0002
   Revision: --H03---    Serial number: 0000000696
   Coding: 000001
   Shop #: WSC 06335 000 00000
   ASAM Dataset: EV_TCMDL501 A02044
   ROD: EV_TCMDL501.rod
   VCID: 46C04E42F9BC4E7FDD-8012
Address 03: ABS Brakes (J104)       Labels:. 8R0-907-379-V1.clb
   Part No SW: 8R0 907 379 M    HW: 8R0 907 379 M
   Component: ESP8 quattro  H06 0020
   Coding: 0D1D48
   VCID: 4AD87A72E5A4AA1F39-801E
01771 - Control Module for Headlight Range (J431)
                    Reset counter: 140
                    Mileage: 185670 km
                    Date: 2019.12.28
                    Time: 22:11:55
                    Hex Value: 0x0040
                    Hex Value: 0x0782
                    Hex Value: 0x001B
                    Hex Value: 0x1079
                    Hex Value: 0x00FF
   Part No SW: 8K0 907 064 DQ    HW: 8K0 907 064 DQ
   Component: BCM2 1.1      H02 0327
   Coding: 011500
   VCID: 024892529D14B25FB1-8056
   Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
   Serial number: 0510000003911001
   Serial number: 0210000006079010
                    Fault Status: 00101101
                    Reset counter: 140
                    Mileage: 185670 km
                    Date: 2019.12.29
                    Time: 14:06:05
   Part No SW: 8T2 820 043 AE    HW: 8T2 820 043 AE
   Component: KLIMA 1 ZONE  H08 0171
   Revision: B1000000    Serial number: 01200120100128
   Coding: 34150000
   VCID: 75A2F98EDCDA95E784-8020
   Part No SW: 8K0 907 063 P    HW: 8K0 907 063 P
   Component: BCM1 1.0      H25 0380
   Revision: 10025001    Serial number: 00000000445709
   Coding: 260050914034AF010001000300001D0D001D470800010101000000
   VCID: 3C342CAABF7004AFBB-8068
   Subsystem 1 - Part No SW: 8R2 955 119 A    HW: 8R2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS416 100117  H10 0041
   Serial number: 90243015100114084929
   Coding: 01DD13
   Component: RLS  H04 0003
   Serial number: 10757673
   Coding: 024D25
   Subsystem 3 - Part No SW: 8K0 941 531 AL    HW: 8K0 941 531 AL
   Component: E1 - LDS  H08 0090
   Serial number: 00000000002001100222
   Part No SW: 8K0 919 475 R    HW: 8K0 919 475 A
   Component: PARKHILFE 8K  H06 0070
   Revision: 11001001    Serial number: 50941002800421
   Coding: 100108
   VCID: 48DC407AFBA8580F2F-801C
                    Reset counter: 140
                    Mileage: 185670 km
                    Date: 2019.12.29
                    Time: 14:06:05
                    Temperature: 77.0°C
Address 15: Airbags (J234)       Labels:* 8R0-959-655.clb
   Part No SW: 8R0 959 655 C    HW: 8R0 959 655 C
   Component: AirbagVW-AU10 H39 0560
   Serial number: 003FQD06CLV+
   Coding: 30433331313030303030554A305238523053
   ROD: EV_AirbaAU10SMEAU416.rod
   VCID: 44C4544ACF807C6FC3-8010
   Serial number: 6334MSME4F530A4FT
   Serial number: 6344MSME4E451465H
   Serial number: 6352QSME2F4D2B1AZ
   Serial number: 6362QSME2F4D4F24.
   Serial number: 63732SME3A4E4330/
   Serial number: 63832SME364E1532
   Component: Lenks.Modul   H05 0005
   Revision: --------    Serial number: 90372RE500009
   Coding: 000033
   Shop #: WSC 06335 123 12345
   VCID: 44C4544AC7807C6FC3-8010
   Component: E221 - MFL  H02 0010
Address 17: Instruments (J285)       Labels:. 8R0-920-xxx-17.clb
   Part No SW: 8R0 920 980 L    HW: 8R0 920 980 L
   Component: KOMBIINSTR.   H11 0255
   Revision: 00000000    Serial number: CJM322K1A
   Coding: 2F0622000B002600010000
   VCID: 42C85252DD94725FF1-8016
   Part No SW: 8T0 907 468 T    HW: 8T0 907 468 K
   Component: GW-BEM 4CAN-M H09 0105
   Revision: EB800053    Serial number: 5300E101198109
   Coding: 00C303
   VCID: 52E862120DF4E2DF41-8006
   Subsystem 1 - Part No SW: 8R0 915 181     HW: 8R0 915 181
   Component: J367-BDM  H07 0107
   Serial number: 00000000004140906356
                    Fault Frequency: 68
                    Reset counter: 140
                    Mileage: 178180 km
                    Date: 2019.06.12
                    Time: 10:58:43
                    Bin. Bits:    10111
                    Voltage: 11.00 V
                    Count: 6
00384 - Optical Databus
                    Fault Status: 00101011
                    Reset counter: 126
                    Mileage: 185172 km
                    Date: 2019.12.16
                    Time: 12:44:30
                    Bin. Bits:    10000
                    Voltage: 12.30 V
                    Count: 19
                    Bin. Bits:    11000
                    Reset counter: 140
                    Mileage: 185670 km
                    Date: 2019.12.29
                    Time: 14:06:05
                    Bin. Bits:    00011
                    Voltage: 9.90 V
                    Count: 6
                    Bin. Bits:    10000
                    Time: 0.90 s
   Part No SW: 8K0 959 793 J    HW: 8K0 959 793 E
   Component: TSG FA        H11 0306
   Revision:             Serial number: 0000102724389
   Coding: 011002204001440004
   VCID: 47DE4346F6B6577726-8012
                    Reset counter: 140
                    Mileage: 185670 km
                    Date: 2019.12.28
                    Time: 15:39:03
   Revision: 00002001    Serial number: 0126084553
   Coding: 013B0622203930000420053280000000
                    Reset counter: 140
                    Mileage: 185670 km
                    Date: 2019.12.29
                    Time: 14:06:05
   Part No SW: 8K0 959 792 J    HW: 8K0 959 792 E
   Component: TSG BF        H11 0306
   Revision:             Serial number: 0000102706764
   VCID: 46C04E42F1BC4E7FDD-8012
                    Reset counter: 140
                    Mileage: 185670 km
                    Date: 2019.12.30
                    Time: 12:22:35
   Revision: 00000003    Serial number: 10000000418095
   VCID: 3424048A9720CCEF73-8060
Address 55: Headlight Range        Labels: 8T0-907-357.clb
   Part No SW: 8H0 907 357 A    HW: 8H0 907 357
   Coding: 0000021
   Shop #: WSC 06334 000 00000
   VCID: 302C089AA338F0CF17-8064
   Component: AFS-Modul links H07 0004
   Component: AFS-Modul rechtsH07 0004
   Part No SW: 4F0 035 056 B    HW: 4F0 035 056
   Component: Radio U STD   H45 0020
   Revision: AB001007    Serial number: 342AY0A7753368
   Coding: 010003020100000001
   VCID: 1F0EFB260EA67FB7BE-804A
   Part No SW: 8T2 035 666 E    HW: 8T2 035 666 E
   Component: H-BN-EU       H47 0047
   Revision: --------    Serial number: 475A00A7543877
   Coding: 010101060105A1ED01000B1E000000010000
   VCID: 3D3221AEA46A0DA78C-8068
   Subsystem 1 - Part No: 8R0 060 884 J
   Component: EUR 2010  1005
   Subsystem 2 - Part No SW: 4F0 919 604     HW: 4F0 919 604
   Component: DU7 High  H43 0306
   Serial number: 9356AP0A1174165
   Subsystem 3 - Part No SW: 8T0 919 609 F    HW: 8T0 919 609 F
   Component: E0380 Bedient  H08 0100
   Serial number: 00000000450921
   Subsystem 4 - Part No: 8R0 906 961 A
   Component:   CD-Database  1293
   Part No SW: 8K0 959 795 C    HW: 8K0 959 795 C
   Component: TSG HL        H10 0306
   Revision:             Serial number: 0000102731574
   Coding: 010002204001240004
                    Reset counter: 140
                    Mileage: 185670 km
                    Date: 2019.12.30
                    Time: 12:22:35
   Part No SW: 8R0 827 851 B    HW: 8R0 827 851 B
   Component: J605  Master  H27 0300
   Revision: --------    Serial number: 8R0827851B
   VCID: 3B362FB6BA7E0397B2-806E
   Subsystem 1 - Part No SW: 8R0 827 852 B    HW: 8R0 827 852 B
   Component: J756  Slave  H27 0300
   Serial number: 8R0827852B
   Component: TSG HR        H10 0306
   Revision:             Serial number: 0000102731577
                    Reset counter: 140
                    Mileage: 185670 km
                    Date: 2019.12.28
                    Time: 15:39:03
End----------(Elapsed Time: 01:41, VBatt start/end: 13.4V/13.6V)-----------
Ashraf6119
C?ID=174194
Seriously guys NO one to reply or any feedback to this post, has NO one come a cross this kind of problem using this new interface with WiFi option.......?
I have not seen such a thing, no.
Is there any possibility that you there was lock-time on the module (from entering incorrect ones) that happened to expire while you were making the switch from WiFi to USB?
When a UDS module refuses Security Access, the first thing to do is check:
IDE00323 -- Security Access: Number of invalid keys
If the value there is not zero, then you should wait until it is (with the ignition ON and a battery charger connected).
Ashraf6119
C?ID=174194
Thanks for the reply. NO there was NO lock time nor I did input wrong code there are only 2 security codes in drop bar 12233 and 27971 both did not accept while interface was in WiFi option as soon as I connected the USB Cable it did accept without even recycling the ignition key........
I will try this again when I get another vehicle and see if its still doing the same or not and report back...
Treborg
C?ID=194107
I note the "12 V" level is at 11.0 V, which seems too low. Was the engine on?
I'm getting the 03041 code on my 2013 Q5 Hybrid, particularly when I scan with the engine off for a while (like overnight). I'm starting to wonder if the vehicle 12 V battery is dying. Low battery voltage with the engine off could cause a lot of weird problems - this happens on Priuses when their 12 V battery starts to die. On a Prius, if the 12 V battery dies, the whole vehicle is dead.
Same is true of most hybrids. There's a 12V circuit that needs to be energized in order to close the contactor for the hybrid battery.
But we are straying way off-topic from the OP's questions here.
