I tried to code the rear foglamps to work following form advice on changing Byte 18. This did not work. I cannot get the original coding back to remove the bulb error light on the dash. I'm looking for a member that can put the original coding back on the Passat CC with factory LED tail lights. The closest I've gotten is 0F with still leaves me with two LED Module DRL faults and no rear turn signals. I would greatly appreciate any advice on how to return it to factory.
Monday,08,February,2016,11:21:46:19968
VCDS Version: 15.7.3.0 (x64)
Data version: 20151216
VIN: WVWBN7AN2DE559507 License Plate: CDA 27271
Mileage: 25660km-15944mi Repair Order:
Chassis Type: AN (7N0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 2E 42 44 46 4F 52 53 55 56
62 65 72 77
VIN: WVWBN7AN2DE559507 Mileage: 25660km-15944miles
02-Auto Trans -- Status: Cannot be reached 1100
Address 01: Engine (CCT) Labels: 06J-906-026-CCT.clb
Part No SW: 06J 906 027 FE HW: 06J 907 309 B
Component: MED17.5.2 TFSI 2 06 3952
Revision: PAH04--- Serial number: VWZCZ000000000
Coding: 0404010A1C070160
Shop #: WSC 05314 000 00000
VCID: 73E5E41712FB28A67C-8026
049409 - No Communication with Transmission Control Module
U0101 - 000 -
Mileage: 25660 km
Date: 2016.02.08
Time: 11:03:45
Temperature: 47.0°C
Temperature: 28.0°C
Absolute Pres.: 980.0 mbar
Voltage: 11.938 V
Address 02: Auto Trans
Address 03: ABS Brakes Labels: 3AA-614-109.clb
Part No SW: 3AA 614 109 AP HW: 3AA 614 109 AP
Component: J104 C2 450M V46D 0030
Revision: --H07--- Serial number: 00000006725252
Coding: 0004495
Shop #: WSC 05311 000 00000
VCID: 7BF5CC373AAB60E624-802E
Reset counter: 109
Mileage: 25660 km
Date: 2016.02.08
Time: 11:03:46
Hex Value: 0x0000
Bin. Bits: 00000000 00000000
Voltage: 11.50 V
Bin. Bits: 00011111
Count: 217
Hex Value: 0x0000
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 3AA 907 044 AN HW: 3AA 907 044 AN
Component: Climatronic H03 0303
Revision: 00001K02
Coding: 0010001048
Shop #: WSC 00015 115 00000
VCID: 7CF7CF2BF7A567DE2D-8028
Address 09: Cent. Elect. (J519) Labels: 3AA-937-087.clb
Part No SW: 3AA 937 087 J HW: 3AA 937 087 J
Component: BCM PQ47 H++ 421 0465
Revision: BD421001
Coding: 0008000000000000008802819400A94C257D008840200D20C184402000C0
VCID: 41897EDFD8C7CA363E-8014
Subsystem 1 - Part No SW: 3C8 955 119 F HW: 3C8 955 119 F Labels: 1KX-955-119.CLB
Component: WWS464 080213 010 0604
Coding: 00B795
Subsystem 2 - Part No SW: 5Q0 955 547 HW: 5Q0 955 547 Labels: 5Q0-955-547.CLB
Component: RLFS 024 0042
Coding: 0228DD
Reset counter: 109
Mileage: 25660 km
Date: 2016.02.08
Time: 11:03:47
Voltage: 11.50 V
01516 - Terminal 30; Left
Fault Status: 00101011
Reset counter: 149
Mileage: 25660 km
Date: 2016.02.08
Time: 10:59:59
Term 15 Off
Voltage: 12.15 V
Fault Status: 00101010
Reset counter: 149
Mileage: 25660 km
Date: 2016.02.08
Time: 10:28:19
Voltage: 11.60 V
01800 - Light Switch (E1)
Reset counter: 149
Mileage: 25660 km
Date: 2016.02.08
Time: 10:29:20
Term 15 Off
Voltage: 12.10 V
02391 - Terminal 30 Reference
Reset counter: 149
Mileage: 25660 km
Date: 2016.02.08
Time: 10:59:59
Term 15 Off
Voltage: 12.15 V
Part No SW: 5N0 959 655 T HW: 5N0 959 655 T
Component: J234__713 VW10 HI 2118
Revision: 25018000 Serial number: 003LDP30JE2E
Coding: 0012595
VCID: 4E9355E3D999254EB3-801A
Subsystem 1 - Part No: 3C8 959 339 A
Subsystem 2 - Serial number: 0000000000CNEA
Subsystem 3 - Serial number: 0022.01.130000300000660015ÿ†63
Subsystem 4 - Serial number: 660015ÿ†6332MTS635470373 ÿ†63
Subsystem 5 - Serial number: 70373 ÿ†6342MTS626370353 ÿ†63
Subsystem 6 - Serial number: 70353 ÿ†6351HTS6TPFSQBKR ÿ†63
Subsystem 7 - Serial number: SQBKR ÿ†6361HTS6KQM7PBKJ ÿ†63
Subsystem 8 - Serial number: 7PBKJ ÿ†63727TS6GHDBPBKJ ÿ†63
Subsystem 9 - Serial number: BPBKJ ÿ†63827TS6J0J2RBKR ÿ
Subsystem 10 - Serial number: 2RBKR ÿ
Address 16: Steering wheel (J527) Labels: 3C0-953-569.clb
Part No SW: 3C5 953 501 BG HW: 5K0 953 569 T
Component: LENKS.MODUL 016 0140
Revision: FF010041 Serial number: 20130213300755
Coding: 098A270000
VCID: 6BD5FC7782CBF066B4-803E
Component: E221__MFL-TK6 H07 0022
Coding: E20000
0516 - Databus
Reset counter: 109
Mileage: 25660 km
Date: 2016.02.08
Time: 11:03:47
Address 17: Instruments (J285) Labels: 3C8-920-xxx-17.clb
Part No SW: 3C8 920 971 B HW: 3C8 920 971 B
Component: KOMBI H05 0705
Coding: 240F00
Shop #: WSC 05314 115 00000
VCID: 2C573F6B4745375EFD-8078
12648704 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Reset counter: 109
Mileage: 25660 km
Date: 2016.02.08
Time: 11:03:47
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 AJ HW: 7N0 907 530 AJ
Component: J533 Gateway H51 1634
Revision: H51 Serial number: 150213F2000373
Coding: 469006
VCID: 78FFD33BCB9D4BFE49-802C
Reset counter: 109
Mileage: 25660 km
Date: 2016.02.08
Time: 11:03:46
Part No SW: 3C8 919 965 HW: 3C8 919 965
Component: Kompass 001 0001
Revision: 00001000 Serial number: 1614128R3D6203
VCID: 75E1DA0F1C8F369652-8020
Part No SW: 3AA 959 433 C HW: 3AA 959 433 C
Component: IMMO 042 0404
Revision: 00042000 Serial number: VWZCZ000000000
VCID: 3979163F701792F676-806C
Component: ELV 029 0380
3C0905861J ELV 029 0380
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
Component: SG EXT.PLAYER H19 0550
Revision: A1001003 Serial number: 7664331387
Coding: 010100
VCID: 2A5B397345B1296E0F-807E
Address 42: Door Elect, Driver (J386) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 3C8 959 701 HW: 3C0 959 793 C
Component: TUER-SG FT 002 0555
Revision: 12110009 Serial number: 0006553890
Coding: 0004B7
Shop #: WSC 05311 115 00000
ROD: EV_TSGFPQ35BRFVW46X.rod
VCID: 6DD1F26FBCDFFE56AA-8038
Slave Driver:
Subsystem 1 - Part No SW: 3C8 959 703 D HW: 3C8 959 795 Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 004 0501
Serial number: 00000003365030
Coding: 010490
Part No SW: 5N1 909 144 P HW: 5N1 909 148 J
Component: J500__APA-BS KL.302 1202
Revision: 1BH04737 Serial number: 00130420064301
Coding: 0000258
VCID: 3F8D78276E33BCC648-806A
Address 46: Central Conv. Labels: 3C0-959-433-46.clb
Component: KSG PQ47 ELV 042 0638
Coding: 1B910F8001862E521204141FF08A0F0E105800
Address 4F: Centr. Electr. II (J520) Labels: 1K0-907-532.clb
Part No SW: 7N0 907 532 HW: 7N0 907 530 AJ
Component: EZE_2 H51 1634
Coding: 00000008
VCID: 6FEDE867BED30C4698-803A
Subsystem 1 - Part No SW: 3C8 919 204 A HW: 3C8 919 204 A
Component: Analoguhr 005 0004
Address 52: Door Elect, Pass. (J387) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 3C8 959 702 HW: 3C0 959 792 C
Component: TUER-SG BT 002 0555
Revision: 14110009 Serial number: 0006551697
Coding: 0004B6
ROD: EV_TSGBPQ35BRFVW46X.rod
VCID: 6ED3F563B1D9054E93-803A
Slave Passenger:
Subsystem 1 - Part No SW: 3C8 959 704 D HW: 3C8 959 794 Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 004 0501
Serial number: 00000003332147
Coding: 010490
Part No SW: 3AA 907 801 H HW: 3AA 907 801 H
Component: J540 EPB4 VW-86594 0010
Revision: H19 Serial number: 00000000780311
Coding: 0022156
VCID: 36631D0341097D8E9B-8062
Reset counter: 109
Mileage: 25660 km
Date: 2016.02.08
Time: 11:03:46
Voltage: 11.70 V
Count: 73
Hex Value: 0x1270
Hex Value: 0x0001
Hex Value: 0x0101
Address 55: Headlight Range (J431) Labels: 6R0-907-357.clb
Part No SW: 6R0 907 357 B HW: 6R0 907 357 A
Component: LWR-ECU 005 0030
Coding: 070A000101000000
ASAM Dataset: EV_HeadlRegulVWLWRCC 002004
ROD: EV_HeadlRegulVWLWRCC.rod
VCID: 3979163FB81792F676-806C
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1K0 035 180 AF HW: 1K0 035 180 AF
Component: Radio Prem-8 H05 0008
Revision: -----09S Serial number: VWZ4Z7N1106296
Coding: 0100040004000F
VCID: 64C7974B6715BF1EF5-8030
Reset counter: 217
Mileage: 21490 km
Date: 2015.10.26
Time: 16:45:03
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 3AA 907 273 D HW: 3AA 907 273 D
Component: RDKBERU30 H09 0010
Serial number: 10000000197388
ASAM Dataset: EV_RDKBERU30 003012
ROD: EV_RDKBERU30_VW36.rod
VCID: 35611A0F940F769692-8060
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 K HW: 7P6 035 730 K
Component: TELEFON H15 3200
Revision: 1B001001 Serial number: 00007664175400
Coding: 0A10040000010110
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA.rod
VCID: 3A7B0933BD1199EE7F-806E
End-------------------------(Elapsed Time: 03:14)--------------------------
