First attempts with 2019 GTI Rabbit Edition, US model - some settings inop
w124_karl
NC, USA
C?ID=387342
Hello there - brand new user here! My cable arrived yesterday and I very excitedly started off with a full scan. That's at the end of this post.
I've already gotten the Steering Assist --> Driving Profile Switchover setting changed successfully to "Direct: controlled over threshold value" to try and make the throttle response a bit more even, like described in this video. Haven't gone for a drive yet, but the setting did take. Progress!
There are some things I'd like to change on the car, and I'm having trouble with a couple of them.
1. Disabling the NAR headlight restrictions. Following this video, I went to Controller 55 to try it. I got a "No response from controller" popup:
noResponseFromController by krshultz, on Flickr
2. Disabling the "Starting vibration reduction." I've found the setting, but I get ERROR: Channel not available. There are two similar-looking channels, both of which do the same thing. I found a thread here which talks about ot being able to find the settings, but I've found them. They just won't change.
Annotation 2019-11-20 123607 by krshultz, on Flickr
Annotation 2019-11-20 123718 by krshultz, on Flickr
Has anyone run across a way to make these work on a facelift car?
Might also need help with ESC and ASR disablement, but I think I've found a lead on post 70 of this thread on vwvortex.
Really cool software, I can tell it's going to be quite a time sink for me to go out there and play with stuff :)
Wednesday,20,November,2019,11:05:00:21032
VIN: 3VW5T7AU9KM004410   License Plate: FKL-5555
Mileage: 24013km-14920mi   Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 03 05 08 09 13 15 17 19 29 2B 32 39 3C 42 44 4B 52 5F A9
          D6 D7
VIN: 3VW5T7AU9KM004410   Mileage: 24013km-14920miles
29-Left Light -- Status: Malfunction 0010
39-Right Light -- Status: Malfunction 0010
Address 01: Engine (J623-DKFA)       Labels: None
   Part No SW: 5G0 906 259 Q    HW: 06K 907 425 J
   Revision: --H13---
   Coding: 091900122424002F1000
   Shop #: WSC 00066 790 00392
   ASAM Dataset: EV_ECM20TFS0205G0906259Q 001003
   ROD: EV_ECM20TFS0205G0906259Q.rod
   VCID: 3C213361D6EE8567D5F-8068
Address 03: ABS Brakes (J104)       Labels:* 5Q0-907-379-ESP-V1.clb
   Part No SW: 5Q0 614 517 DC    HW: 5Q0 614 517 AB
   Component: ESC           H25 0324
   Revision: 00000000    Serial number: 62428000000446
   Coding: 01FA6BA154200970407B020160C36880D62A90024006163610435051C089430B00000012121212B835351919323200
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 037009
   ROD: EV_Brake1UDSContiMK100ESP_037_VW37.rod
   VCID: 75B7E645B544142FEA1-8020
   Part No SW: 3Q0 959 435 L    HW: 3Q0 959 435 L
   Component: VWKESSYMQB    037 1204
   Revision: 00037000    Serial number: 0487265627
   Coding: 132C0C0623
   VCID: 43D3489DAB10FA9F945-8016
   Part No SW: 5GM 907 426 G    HW: 5GM 907 426 G
   Component: AC Manuell    H03 2001
   Revision: 00001K05
   Coding: 00020004200110000000000000000006
   ASAM Dataset: EV_ACManueBHBVW37X 004134
   ROD: EV_ACManueBHBVW37X_004.rod
   VCID: 4CC163A1864E35E765F-8018
   Part No SW: 5Q0 937 087 BA    HW: 5Q0 937 087 BA
   Component: BCM PQ37BOSCH 036 0265
   Revision: --------    Serial number: C86416091802W2
   Shop #: WSC 00066 790 00223
   ASAM Dataset: EV_BodyContrModul1UDSBosc 019001
   ROD: EV_BCMBOSCH_019_VW37.rod
   VCID: 7BA3F07D9360425F9C5-802E
   Subsystem 1 - Part No SW: 5G1 955 119 A    HW: 5G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    180708  043 0551
   Serial number: 97022066180810134746
   Subsystem 2 - Part No SW: 5Q0 955 559 B    HW: 5Q0 955 559 B  Labels: 5Q0-955-547.CLB
   Component: RLS  050 0105
   Serial number: SBY18M08D08H15M30S43
   Coding: 00A8DD
   Steering Column Switch:
   Subsystem 3 - Part No SW: 5Q1 953 521 M    HW: 5Q1 953 569
   Component: Lenks.Modul  H03 0170
   Serial number: 0300141020180C200262
204546 - Remote key 2
                    Reset counter: 155
                    Mileage: 21396 km
                    Date: 2019.10.10
                    Time: 13:00:14
   Part No SW: 5Q0 907 572 P    HW: 3QF 907 572 A
   Component: ACC BOSCH MQB H11 0682
   Coding: 2D00008101FFC728949C810500401600000000000000000004
   ASAM Dataset: EV_ACCBOSCHVW416 002008
   VCID: 44D14B81AE1EFDA7ADF-8010
   Serial number: 003GCR0ACXG0
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 47CB5C8D9F28D6BF48D-8012
   Occupant Detection:
   Serial number: IBH00000000000AC7BKK
   Coding: 30305A
   Subsystem 2 - Part No SW: -----------    HW: 480 002 807 18
   Serial number: 357000000000D1382335
   Subsystem 3 - Part No SW: -----------    HW: 480 002 907 18
   Serial number: 3580000000097448233D
   Subsystem 4 - Part No SW: -----------    HW: 480 400 507 18
   Component: SideSensor_Dr  004 6149
   Serial number: 35100011A2B6D2F4241
   Subsystem 5 - Part No SW: -----------    HW: 480 400 507 18
   Component: SideSensor_Pr  004 6149
   Serial number: 3520001102B6FB45A673
   Subsystem 6 - Part No SW: -----------    HW: 480 400 509 18
   Component: FrontSensor_D  003 6149
   Serial number: 3550001B12BB7285440.
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 400 509 18
   Component: FrontSensor_P  003 6149
   Serial number: 3560001B12BB7282E277
   Part No SW: 5G1 920 856 D    HW: 5G1 920 856 D
   Component: KOMBI         351 2500
   Coding: 0BAD0912A988CF0502882A095000000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009065
   VCID: 2F3B142D17986EFF60D-807A
16777020 - Function Restricted due to Interrupted Communications
          U1110 00 [008] - -
          [BAP_TEL_0x28 keine Kommunikation]
                    Reset counter: 58
                    Mileage: 147 km
                    Date: 2019.01.10
                    Time: 11:58:12
   Part No SW: 3Q0 907 530 Q    HW: 3Q0 907 530 C
   Component: GW MQB High   518 5344
   Serial number: 03101800841102
   Coding: 0101000830085900FB00002B080F00000001070000000000000000000000
   Shop #: WSC 00066 790 07027
   ROD: EV_GatewNF.rod
   VCID: 3D273E65CDF48C6FE21-8068
   Component: 1-00-0d-00-04
   Subsystem 2 - Part No SW: 5G0 959 442 AD    HW: 5G0 959 442 AD  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H11 0052
   Serial number: 29180002188240058385
   Coding: 28FFFF
   Part No SW: 8V0 907 399 D    HW: 8V0 907 399 D
   Component: LCM_MLBevoH08 0014
0033 - Supply voltage
          [Supply voltage - lower limit exceeded]
                    Reset counter: 55
                    Mileage: 23180 km
                    Date: 2019.11.07
                    Time: 07:30:24
   Part No SW: 2Q0 905 861 A    HW: 2Q0 905 861 A
   Component: ELV-MQBB      H07 0021
   Serial number: 18000260106014
   ROD: EV_ELVMarqMQBA0_VW37.rod
   VCID: 313F125501AC780F769-8064
Address 32: Differential Locks (J492)       Labels:* 0CQ-907-554.clb
   Part No SW: 0CQ 907 554 P    HW: 0CQ 907 554 P
   Component: Quersperre    H52 8043
   Serial number: HA1-00020.06.18
   Coding: 0001
   ASAM Dataset: EV_LockElectHA1VW37X 001007
   ROD: EV_LockElectHA1VW37X.rod
   VCID: 52FD7DD9646A63172F3-8006
                    Reset counter: 59
                    Mileage: 23300 km
                    Date: 2019.11.08
                    Time: 16:08:47
   Component: HRE_Master    H12 0081
   Serial number: 0493589269
   Coding: 01011103
   ROD: EV_HREntryHella_VW37.rod
   Lane Change Assistant 2:
   Component: HRE_Slave  H12 0081
   Serial number: 0492969902
   Coding: 010111
   Part No SW: 5Q4 959 593 M    HW: 5Q4 959 593 F
   Component: TSG FS        006 0247
   Serial number: 42038828700313
   Coding: 003E13200000040000000000
   VCID: 4FFB74AD77580EFF00D-801A
   Subsystem 1 - Part No SW: 5Q4 959 811 F    HW: 5Q4 959 811 F  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG DRV  010 0004
   Serial number: 00000000000000911465
   Coding: 011000
   Part No SW: 5QN 909 144 A    HW: 5QN 909 144 A
   Component: EPS_MQB_ZFLS  507 5081
   Coding: 810A0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 50F977D16A661107197-8004
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V2.clb
   Part No SW: 3Q0 907 338 C    HW: 3Q0 907 338 C
   Component: FCM MQB Low   002 0342
   Serial number: 26091800840252
   Coding: 000000050900210A01110F00030000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 002004
   ROD: EV_MultiModulContiVW48X_002_VW37.rod
   VCID: 35372645F5C4542F2A1-8060
   Part No SW: 5Q4 959 592 M    HW: 5Q4 959 592 F
   Component: TSG BFS       006 0247
   Serial number: 46038828501482
   VCID: 4EC569A9705207F70BB-801A
   Subsystem 1 - Part No SW: 5Q4 959 812 F    HW: 5Q4 959 812 F  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG PSG  010 0004
   Serial number: 00000000000000899655
   Coding: 091000
Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-ENT2.clb
   Part No SW: 5G6 035 868     HW: 5G6 035 868
   Component: MU-E--ER      695 8742
   Serial number: 30081800011554
   Coding: 02730000BE00000041220001001000009F0003D40000010000
   ASAM Dataset: EV_MUEnt4CGen2LGE 001041
   ROD: EV_MUEnt4CGen2LGE_VW37.rod
   VCID: 70B9D751CA263107397-8024
   Part No SW: 5G0 907 159 G    HW: 4H0 907 159 A
   Serial number: 170506202639
   VCID: 323D1D5904AA43170F3-8066
   Part No SW: 7P5 941 572 A    HW: 7P5 941 572 A
   Component: LED1L         H06 0002
   ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
   ROD: EV_LEDMinMaxL_KEBODAVW481.rod
   VCID: 392F2A75D9DCB04FCE9-806C
   Component: LED1R         H06 0002
   ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
   ROD: EV_LEDMinMaxRKEBODVW481.rod
End----------(Elapsed Time: 01:27, VBatt start/end: 12.8V/12.8V)-----------
Somnus
SLC, USA
C?ID=215931
Welcome to the forum!
for the headlight tweak, your car does not have a (55 - Headlight Range) module. the functions of the Headlight Range controller are now handled by the (4B - Multifunc. Module)
Although I am unsure of which bits control the Region Restriction on the 4B module off the top of my head, It ishould be documented in the Long Coding Helper
w124_karl
NC, USA
C?ID=387342
Thanks! I have to admit that I'm having a hard time staying productive at work today, since the car is right through that door over there.
I think I had a light bulb moment thanks to your response - are the control modules shown in the "Installed" tab the only ones available on the car? That would make a lot of sense. It did seem strange at the time that 55 didn't show up there, but did show up elsewhere, like I had to go chase it down.
Dana
Western PA, USA
Yes, providing the vehicle isn't malfunctioning and the Installation list wasn't tampered with, the Installed tab contains all of the modules installed in the vehicle.
P.S. Make sure you create a factory-like condition backup in the event tweaks cause any issues. If you aren't familiar with maps, this should be helpful https://youtu.be/au4FR1FCrHU?list=PLwfzU5uvU-lLGh-SQDOxcS1cdBLYqJP7K
w124_karl
NC, USA
C?ID=387342
Thanks Dana for the confirmation. That'll help me avoid any more chasing of modules that don't exist on my 2019.
I took a two full backups, in both the default and Raw Hex file formats, zipped all the files up, and stashed them aside for later use. I'm taking screenshots as well, it's an easy way for me to see differences before/after.
Dana
Western PA, USA
quailallstar
Florida & the Nation's Capital
C?ID=53119
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
Welcome! Hope you're enjoying your new ride!
There's lots of fun stuff to tweak with VCDS, but be advised...
This one is purely hocus-pocus, some kind of urban legend that just refuses to die. The setting has nothing to do with throttle response and nobody has ever produced evidence it does.
DV52
C?ID=194404
Karl: If you will allow me use an Aussie horse-racing colloquialism - I'd bet London-to-a-brick (a "brick" is our slang for a £10 note) that your errant adaptation channel isn't listed in the admap for the hex03 module. If I'm correct, it means that your particular ABS module doesn't have this channel accessible.
Make an admap and test my hypothesis - please
Agree!! This is a "stuff-and-nonsence" tweak. If there is any improvement at all (and I very much doubt that there is), it's marginal at best!!
w124_karl
NC, USA
C?ID=387342
I’ve just now seen this. I should be able to post both of the requested files sometime tomorrow evening, US time.
You’re all right, BTW. I could sense little to no difference with that driving profile switchover tweak. Glad to hear it’s not my imagination that it didn’t do anything.
w124_karl
NC, USA
C?ID=387342
Don, you're correct. Here's a link to the admap for channel 03 in raw CSV form. This is factory default, before I made any changes at all.
Before I knew what I was doing, I just went straight in to 03 to look for stuff. At the time, I didn't know that the "Installed" tab in VCDS would stop me looking for things that weren't actually on the car.
w124_karl
NC, USA
C?ID=387342
That user would be me and yes, I would greatly appreciate it :)
Done. I've got blockmap, adpmap, and adphex forms of the same factory-default scan, so let me know if these don't work.
