Incorrect label information for 4G9 920 980 B
nugentp
C?ID=6386
Connected VCDS with a C7 Allroad today (MY2013) - I discovered that the instrument module (4G9 920 980 B) is not properly configured in the label file (as it takes a redirect from another 4H0 controller if my reading of the label files is correct).
The Coding Byte in question is 09 - this determines the car model designation displayed in centre of instrument cluster when the ignition is turned on or off. I stepped through values 00-09 and can report these findings.
00 – A6
01 – A7
02 – S6
03 – S7
04 – RS6
05 – RS7
06 – A6 allroad
07 – A6 hybrid
08 – A6
09 – A7
I wasn't brave enough to go beyond 09 unless something unexpected happened.
Not sure if this is the correct place to ask about support for new controller modules.
I also noted that the coding group for fuel tank configuration in Byte 02 might be wrong.
Bits 0-2 were set to 00 which is supposedly for an A8/S8 (4H) machine
I have changed them to 03 which is what a 4GH machine needs according to coding guidance but I now have my doubts on this one due to differences notes above.
Full scan included here with only a couple of silly faults that have since been cleared - the car is otherwise happy & healthy but I noticed a few places where it was seemingly coded with mixture of LHD and RHD values across different modules. All of the modules are factory fitted - no retrofits - so I dunno if there are other coding anomalies or if VCDS label files are not 100% perfect on these 4G controllers.
It is a genuine C7 4GH allroad - RHD UK model.
I also note that the CAN gateway (Address 19) - 4G5 907 468 A - has no coding guidance at all in VCDS and that the Engine ECU - 4G0 907 311 E - is referencing a generic 059 label file. There are a few other controllers without any label information.
Saturday,05,January,2019,14:19:06:30756
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86(Parallels)
VCDS Version 18.9.0.4  HEX-NET CB: 0.4437.4
VIN: WAUZZZ4G9DNxxxxxx   License Plate: xxxxxxxx
Mileage: 142401km-88483mi   Repair Order:
Chassis Type: 4G-AU57 (4G5)
Scan: 01 02 03 05 08 09 10 15 16 17 19 28 34 3B 42 44 46 47 52 53
          5F 62 72
VIN: WAUZZZ4G9DNxxxxxx   Mileage: 142401km-88483miles
Address 01: Engine (J623-CLAA)       Labels:. 059-907-401-V2.clb
   Part No SW: 4G0 907 311 E    HW: 4G0 907 401
   Component: 3.0TDI EDC17  H37 0001
   Revision: 53H37---
   Coding: 32254012052609020000
   ASAM Dataset: EV_ECM30TDI0114G0907311E 001001
   ROD: EV_ECM30TDI0114G0907311E.rod
   VCID: 2502F5382499226288-8071
18660 - Start interruption due to insufficient engine speed
          P151D 00 [032] - -
   Part No SW: 4G0 927 156 S    HW: 0B5 927 156 F
   Component: 0B5 30 TDIRdW H10 0004
   Revision: --H10---    Serial number: 0000000481
   Coding: 000001
   ASAM Dataset: EV_TCMDL501 A02196
   ROD: EV_TCMDL501.rod
   VCID: 3C34305CB71383AAC7-8069
   Coding: 27A6C705E465E3A0CB00
   VCID: 36202274893F59FA31-8063
0604 - Tire Pressure Warning
          C102D 00 [008] -  -
                    Fault Frequency: 26
                    Reset counter: 81
                    Mileage: 140860 km
                    Date: 2018.12.04
                    Time: 16:16:51
                    VzRef: 34
                    Bit Info 1: 00
                    Bit Info 2: 40
                    Bit Info 3: 26
                    Bit Info 4: 1F
                    F-Path: 01
                    F-Type: 28
                    Uz: BB
   Part No SW: 4H0 907 064 FG    HW: 4H0 907 064 BG
   Component: BCM2 2.0      H31 0560
   Coding: 01B93006000000000000
   Shop #: WSC 53484 001 1048576
   VCID: 73A6DB60D2CD0CD2D6-8027
   Serial number: 2312000068673013
   Part No SW: 4G0 820 043 K    HW: 4G0 820 043 K
   Component: KLIMA 4 ZONEN H12 0064
   Serial number: 17041200040582
   Coding: 3622007820
   VCID: 271EFF305E953072BA-8073
   Part No SW: 4H0 907 063 BP    HW: 4H0 907 063
   Component: BCM1 2.0      H12 0111
   Revision: 11012002    Serial number: 00000001287572
   Coding: 690000108034A7E00905008300005F5FCF9DC70827080101000008402000
   VCID: 77BEEF70C6B560F2EA-8023
   Component: WWS57X 120309  H35 0080
   Serial number:         120317110929
   Coding: 0045F7
   Component: RLS  H04 0003
   Serial number: 20139503
   Coding: 02512B
   Subsystem 3 - Part No SW: 4G0 941 531     HW: 4G0 941 531
   Component: E1 - LDS  H07 0044
   Serial number: 04 04 2012  00000812
   Serial number: E9A80326000000000001
                    Fault Status: 00101100
                    Reset counter: 107
                    Mileage: 142018 km
                    Date: 2018.12.24
                    Time: 20:28:00
03674 - Indicator Lamp for Start-Stop Operation
                    Reset counter: 111
                    Mileage: 141445 km
                    Date: 2018.12.15
                    Time: 16:14:00
   Part No SW: 4H0 919 475 Q    HW: 4H0 919 475 C
   Component: PARKHILFE ACC H07 0060
   Revision: 11001001    Serial number: 55901208901402
   Coding: 08030C
   ASAM Dataset: EV_EPHVA18AU57X0000 004005
   VCID: 40CC44ACDBFBE74A9B-8015
   Revision: --------    Serial number: 003JG0084EL%
   Coding: 30323436313330303537554A305234473053
   Serial number: 3575HRB405V1BEPSCHPX
   Serial number: 3585HRB404V1BBH2C88D
   Serial number: 3515JRB400E4UHGCIHF3
   Serial number: 3525JRB401E4UHGC9P0W
   Serial number: 3554VRB405D18E5G118X
   Serial number: 3564VRB400M4UHPKL0FU
   Revision: 00000000    Serial number: 20120417000975
   Coding: 000035
   VCID: 302C146C635B77CA6B-8065
   Component: E221 - MFL  H08 0009
   Part No SW: 4G9 920 980 B    HW: 4G9 920 980 B
   Component: TDieGb    Nv  H78 0416
   Revision: 28131177    Serial number: 658190312596036
   Coding: 33A6200813012600010600
   ASAM Dataset: EV_RBD4K 004045
   ROD: EV_RBD4K.rod
   VCID: 32281E64655745DA1D-8067
   Part No SW: 4G5 907 468 A    HW: 4G5 907 468
   Component: J533--Gateway H10 0028
   Revision: --------    Serial number: 00000000486550
   Coding: 00CD077D00
   ASAM Dataset: EV_GatewPkoUDS 001013
   VCID: 33261B609A4D4CD216-8067
   Component: J367-BDM  H07 0141
   Serial number: 00000000003790922824
   Voltage stabilizer:
   Serial number: 09011200000000000165
   Part No SW: 4G0 919 158 C    HW: 4G0 919 158 C
   Component: KLIMA FOND    H07 0064
   Serial number: 19041200040530
   Coding: 02
   VCID: 2F2E17107665683272-807B
   Part No SW: 4G0 907 553 F    HW: 4G0 907 553 F
   Component: LUFE-DAEMPFER H18 0782
   Coding: 008000
   ROD: EV_AirSuspe_VW51.rod
   VCID: 2E100A14716F613A79-807B
   Component: SARA 6D       H01 0051
   Revision: --------    Serial number: EJ1BPA8200198M
   ASAM Dataset: EV_SARA2 004010
   ROD: EV_SARA2_004.rod
   Part No SW: 4G8 959 793 G    HW: 4G8 959 793 G
   Component: TSG FA        H03 0505
   Coding: 011F16004001620002080002
   VCID: 44C448BCC7E3FB6ABF-8011
   Component: RCEPS         H35 0010
   Revision: 00001000    Serial number: 0027470277
   Coding: 101000010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod
   Revision: 00002001    Serial number: 0174000735
   Coding: 013F062220B9040083200904000104000000000000000000000000000000
   Revision: CJ007001    Serial number: 00000000043861
   Coding: 030000
   VCID: 1D72DDD804C9EAA2D0-8049
   Part No SW: 4G8 959 792 G    HW: 4G8 959 792 G
   Component: TSG BF        H03 0505
   VCID: 43C64BA0C2EDFC5286-8017
   Revision: --------    Serial number: 00000000319415
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2A1806044D870D1AA5-807F
   Part No SW: 4G0 035 193 E    HW: 4G0 035 193 D
   Component: RMC Cnct Nav  H52 0775
   Coding: 0101050001E15B67082B060301020100000000
   VCID: 2502F5382C99226288-8071
   Subsystem 1 - Part No: 8X0 919 884 D
   Component: P13-50-11.06  0002
   Subsystem 2 - Part No SW: 4G0 919 603     HW: 4G0 919 603
   Component: DU6 Basic  H42 0084
   Serial number: 9464CT0C2521366
   Subsystem 3 - Part No SW: 4G2 919 610 B    HW: 4G2 919 610 B
   Serial number: 90349LDC0017V
   Part No SW: 4G8 959 795 G    HW: 4G8 959 795 G
   Component: TSG HL        H03 0505
   Coding: 010F14004001620002080002
   VCID: 46C052B4F1DFC97AA1-8013
   Component: TSG HR        H03 0505
End----------(Elapsed Time: 01:44, VBatt start/end: 13.5V/14.4V)-----------
nugentp
C?ID=6386
I have sent all the unknown module controller maps to support by email.
One odd thing - or maybe I overlooked something - the CAN Gateway controller (Address 19) is classified as unknown, but an AutoScan in Debug=2 did not produce PLA or PLB files for the CAN Gateway.
