Friday,20,January,2017,11:23:26:10366
VCDS Version: 17.1.2.0 HEX-NET CB: 0.4334.4
Data version: 20170107 DS267.0
Workshop Code: 785 02313 000200
VIN: WAUZZZ4H7DN029728 License Plate: A8_4H_HYBRID_2NDCRASH
Mileage: 62923km-39098mi Repair Order:
Chassis Type: 4H (4H1)
Scan: 01 02 03 05 06 08 09 0E 10 15 16 17 19 20 28 30 34 36 3B 3C
40 42 44 46 47 48 51 52 53 56 57 5B 5F 62 65 6C 6D 6F 72 7F
81 84 85 88 8A 8C 8D 8E 8F 90
VIN: WAUZZZ4H7DN029728 Mileage: 62923km-39098miles
30-Special Function II -- Status: Malfunction 0010
3B-Sensor Elect. -- Status: Malfunction 0010
40-AC Compressor -- Status: Malfunction 0010
48-Seat, Rear, DS -- Status: Malfunction 0010
51-Electric Drive -- Status: Malfunction 0010
5B-Seat,Rear,PS -- Status: Malfunction 0010
7F-Inform. Electr. II -- Status: Malfunction 0010
81-Gear Shift -- Status: Malfunction 0010
84-Night Vision -- Status: Malfunction 0010
88-Multicont. Seat Driver -- Status: Malfunction 0010
8A-Multicont. Seat Rear,DS -- Status: Malfunction 0010
8C-Hybrid Battery -- Status: Malfunction 0010
8D-Multicont. Seat Rear,PS -- Status: Malfunction 0010
8F-Pretens. Frt Left -- Status: Malfunction 0010
90-Pretens. Frt Right -- Status: Malfunction 0010
Address 01: Engine (0-MA--CHJA) Labels: None
Part No SW: 4H0 907 115 B HW: 8R0 907 115 G
Component: 2.0l R4/4V TF H57 0003
Revision: NDH57---
Coding: 0A2A0013652400022000
Shop #: WSC 02446 666 28888
ASAM Dataset: EV_ECM20TFS0114H0907115B 002004
ROD: EV_ECM20TFS0114H0907115B_002.rod
VCID: 2502393724C97869B0-8070
13 Faults Found:
U1113 00 [032] - -
Mileage: 62882 km
Date: 2016.12.13
Time: 01:55:54
Coolant temperature: 21 °C
Intake air temperature: 18 °C
Voltage terminal 30: 12.934 V
Engine operating condition-Channel 87: Idling
Relative load value: 78.89 %
Engine torque: 0.0 Nm
12577 - DC/DC Converter
P0A94 00 [032] - Inadequate Performance
Mileage: 62882 km
Date: 2016.11.30
Time: 00:00:50
Engine speed: 1228.00 /min
Normed load value: 31.8 %
Coolant temperature: 11 °C
Intake air temperature: 5 °C
Voltage terminal 30: 13.216 V
Current speed of electric motor: 1200.5 /min
Operating state of electric drive-Bit 0: 10
Transfer electric drive to combustion drive-Bit 0: 0
Electric drive motor: mode of operation-Bit 0: 4
Operational state of the hybrid battery-Bit 0: 1
High-volt. battery: charge state: abs. value: 40.40 %
Air temperature of high-voltage / hybrid battery: -4.0 °C
17122 - Drive Motor A
P0A90 00 [032] - Performance
Mileage: 62882 km
Date: 2016.11.30
Time: 00:00:50
Current speed of electric motor: 1195.0 /min
4527 - Coolant Fan Control Circuit 1
P0480 00 [040] - Electrical Malfunction
Mileage: 62882 km
Date: 2016.11.30
Time: 00:00:12
Coolant temperature: 24 °C
Intake air temperature: 8 °C
Voltage terminal 30: 12.274 V
Unlearning counter according OBD: 34
CAN status - engine control module-Bit 0: 0
CAN status - transmission control module-Bit 0: 0
CAN status - brake control module 1-Bit 0: 0
CAN status - brake control module 2-Bit 0: 0
Cruise control switch actuation-Bit 0: 0
Cruise control switch actuation-Bit 8: 0
4528 - Coolant Fan Control Circuit 2
P0481 00 [040] - Electrical Malfunction
Mileage: 62882 km
Date: 2016.11.30
Time: 00:00:12
Relative load value: 78.54 %
5456 - Starter Will Not Turn
P3054 00 [229] - Jammed or Electrical Malfunction
Mileage: 62888 km
Date: 2016.12.13
Time: 04:18:45
Coolant temperature: 89 °C
Intake air temperature: 14 °C
Voltage terminal 30: 12.510 V
Relative load value: 71.67 %
5604 - Park/Neutral Switch Input Circuit
P0850 00 [032] - Open or Short to Plus
Mileage: 62882 km
Date: 2016.12.13
Time: 01:56:23
Voltage terminal 30: 11.426 V
17427 - Implausible Data Received from Transmission Control Module
U0402 00 [032] - -
Mileage: 62882 km
Date: 2016.12.13
Time: 01:55:52
Voltage terminal 30: 11.661 V
4629 - ECM Power Relay Load Circuit
P068A 00 [096] - Opens Too Early
Time: 00:00:00
Coolant temperature: 4 °C
Voltage terminal 30: 11.120 V
Current speed of electric motor: 0.0 /min
Status transition of transmission control module sequencing-Bit 0: 0
Status transition of engine control module sequencing-Bit 0: 0
E-machine torque actual value: 0.0 Nm
Emachine_achievable_enginetorque_maximum_value: 0.0 Nm
Clutch K0: Status-Bit 0: 0
17262 - Terminal 30
U140A 00 [032] - Open Circuit
Vehicle speed: 255 km/h
Coolant temperature: -40 °C
Intake air temperature: -40 °C
Ambient air pressure: 0 mbar
Voltage terminal 30: 0.000 V
7786 - Sensor for Ambient Air Temperature (G17)
P0070 00 [040] - Malfunction
Mileage: 62882 km
Date: 2016.11.30
Time: 00:00:14
Unlearning counter according OBD: 36
12584 - HV Components
P0AB9 00 [032] - System Failure
Mileage: 62882 km
Date: 2016.12.12
Time: 00:03:18
Intake air temperature: 9 °C
Voltage terminal 30: 11.355 V
Status transition of engine control module sequencing-Bit 0: 8
Clutch K0: Status-Bit 0: 1
12591 - HV Components
P0AB9 00 [109] - System Failure
Mileage: 62882 km
Date: 2016.12.10
Time: 03:07:39
Coolant temperature: 86 °C
Intake air temperature: 28 °C
Voltage terminal 30: 13.287 V
Current speed of electric motor: 933.0 /min
Status transition of transmission control module sequencing-Bit 0: 1
Status transition of engine control module sequencing-Bit 0: 2
E-machine torque actual value: 82.5 Nm
Emachine_achievable_enginetorque_maximum_value: 208.0 Nm
Transfer electric drive to combustion drive-Bit 0: 7
Readiness: 0010 0101
Address 02: Auto Trans (J217) Labels: None
Part No SW: 4H1 927 158 BP HW: 0BW 927 156 S
Component: 0BW 20TFSIRdW H16 1004
Revision: --H16---
Coding: 000001
ASAM Dataset: EV_TCMAL551511 002022
ROD: EV_TCMAL551511.rod
VCID: 7F4ECB5FE6D502B99A-802A
12483 - System Voltage
P0562 00 [032] - Too Low
Mileage: 62883 km
Date: 2016.10.14
Time: 10:14:30
Voltage terminal 30: 8.942 V
Voltage supply of regulator valves: 8.915 V
Voltage terminal 15: 9.0 V
Engine speed: 0 /min
Transmission input speed: 0.00 /min
Driving position: P
Control Module temperature: 5 °C
selected gear: without traction
Starting clutch status: Kupplung geoeffnet
E-machine cut-out clutch status: geoeffnet
M015_Time Normal Mode: 169 s
M019_Time Since Reset: 7650 ms
M018_Time In Afterrun: 0 s
Transmission fluid temperature: 6 °C
13785 - HV Components
Mileage: 62883 km
Date: 2016.09.20
Time: 06:13:18
Voltage terminal 30: 11.405 V
Transmission input speed: 1173.00 /min
Transmission output speed: 1176.00 /min
Engine torque: -37 Nm
Transmission fluid temperature: 71 °C
Accelerator position: 15 %
Starting clutch status: Kupplung geschlossen
E-machine cut-out clutch status: geregelt geschlossen
Engine speed: 1307 /min
Transfer speed from ESP: 71.06 km/h
Transfer speed from ESP: valid
Address 03: ABS Brakes (J104) Labels: 4H0-907-379.clb
Part No SW: 4H0 907 379 H HW: 4H0 907 379 H
Component: ESP PREMIUM H10 0471
Coding: 10C5CB0008A3D300E300
ASAM Dataset: EV_ESPPremi 005018
ROD: EV_ESPPremi_005_AU64.rod
VCID: 373EE37F8E65FAF912-8062
0089 - Function Restriction due to Faults in Other Modules
U1113 00 [136] - -
Reset counter: 22
Mileage: 62883 km
Date: 2016.10.14
Time: 10:18:04
VzRef: 00
Bit Info 1: 00
Bit Info 2: 10
Bit Info 3: 82
Bit Info 4: 00
F-Path: 34
F-Type: 02
Uz: 74
0120 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Reset counter: 24
Mileage: 62883 km
Date: 2016.10.20
Time: 14:37:23
VzRef: 00
Bit Info 1: C0
Bit Info 2: 02
Bit Info 3: 80
Bit Info 4: 00
F-Path: 3B
F-Type: 35
Uz: 90
0462 - Supply voltage
U1011 00 [136] - Voltage too Low
Fault Frequency: 18
Reset counter: 25
Mileage: 62883 km
Date: 2016.10.31
Time: 11:21:01
VzRef: 00
Bit Info 1: 00
Bit Info 2: 12
Bit Info 3: 00
Bit Info 4: 00
F-Path: 03
F-Type: 24
Uz: 58
0773 - Function Restriction due to Implausible Message(s)
U1112 00 [008] - -
Reset counter: 24
Mileage: 62883 km
Date: 2016.10.31
Time: 11:21:00
VzRef: 00
Bit Info 1: 00
Bit Info 2: 12
Bit Info 3: 00
Bit Info 4: 00
F-Path: 3B
F-Type: 34
Uz: 58
0788 - Function Restriction due to Implausible Message(s)
U1112 00 [136] - -
Reset counter: 25
Mileage: 62882 km
Date: 2016.12.13
Time: 01:55:54
VzRef: 00
Bit Info 1: C0
Bit Info 2: 40
Bit Info 3: 82
Bit Info 4: 00
F-Path: 2A
F-Type: 28
Uz: A2
Part No SW: 4H0 907 064 CB HW: 4H0 907 064 CB
Component: BCM2 2.0 H33 0433
Coding: 05C72F46000000000000
VCID: 6B960F0F8AAD8E1926-803E
Fault Frequency: 17
Reset counter: 25
Mileage: 62883 km
Date: 2016.10.10
Time: 17:50:08
Fault Status: 00101101
Fault Frequency: 165
Reset counter: 24
Mileage: 62883 km
Date: 2016.10.14
Time: 10:16:10
Address 06: Seat Mem. Pass (J521) Labels: None
Part No SW: 4H0 959 760 H HW: 4H0 959 760 H
Component: MEM-BFS H09 0163
Revision: AA000000 Serial number: 00000045785147
Coding: C018B60084002201040001010101112909313229283232
VCID: 383CE0438B7BF5811B-806C
03766 - Motor for Seat Belt Height Adjustment
Fault Status: 01100101
Reset counter: 156
Mileage: 53200 km
Date: 2016.08.01
Time: 14:24:08
00532 - Supply Voltage B+
Fault Frequency: 11
Reset counter: 26
Mileage: 62883 km
Date: 2016.10.14
Time: 10:16:08
Reset counter: 23
Mileage: 62883 km
Date: 2016.11.08
Time: 12:23:09
03325 - Switch for Backrest Angle Adjustment: Back
Fault Status: 00100011
Reset counter: 23
03661 - Control Module for Seat Adustment; Rear Passenger-Side
Reset counter: 25
Mileage: 62882 km
Date: 2016.11.30
Time: 01:57:40
Address 08: Auto HVAC (J255) Labels: 4H0-820-043.clb
Part No SW: 4H0 820 043 L HW: 4H0 820 043 L
Component: Klima 3 Zonen H20 0130
Coding: 64810ADE9E
ROD: EV_AirCondiFront_AU64.rod
VCID: 291A350748D15C0994-807C
12 Faults Found:
0326 - Sunlight Photo Sensor
B10E8 15 [008] - Open or Short to Plus
Reset counter: 25
Mileage: 62882 km
Date: 2016.11.30
Time: 00:53:57
Outside air temperature-Data: 7.50 °C
Interior temperature-Data: 6.60 °C
0235 - Supply voltage
Reset counter: 23
Mileage: 62883 km
Date: 2016.10.14
Time: 10:14:54
Voltage terminal 30-Data: 8.5 V
Outside air temperature-Data: 8.00 °C
Engine speed-Data: 0 /min
0315 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 25
Mileage: 62883 km
Date: 2016.09.20
Time: 06:13:28
Voltage terminal 30-Data: 11.9 V
Outside air temperature-Data: 14.00 °C
0280 - Functional Limitation due to Energy Management
B10CD 00 [008] - -
Reset counter: 23
Mileage: 62882 km
Date: 2016.11.30
Time: 00:01:00
Voltage terminal 30-Data: 14.0 V
Outside air temperature-Data: 77.50 °C
Engine speed-Data: 882 /min
0291 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 26
Mileage: 62883 km
Date: 2016.09.20
Time: 06:13:28
0325 - Control Module for Auxiliary Heater
B10C0 16 [008] - Voltage Too Low
Reset counter: 23
Mileage: 62883 km
Date: 2016.10.14
Time: 10:13:41
Voltage terminal 30-Data: 9.9 V
0314 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 26
Mileage: 62883 km
Date: 2016.09.20
Time: 06:13:31
0243 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Fault Frequency: 22
Reset counter: 26
Mileage: 62883 km
Date: 2016.09.20
Time: 06:13:26
0289 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
Reset counter: 23
Mileage: 62883 km
Date: 2016.10.14
Time: 10:14:54
0387 - Sunlight Photo Sensor
Reset counter: 25
Mileage: 62882 km
Date: 2016.11.30
Time: 00:53:57
0390 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Reset counter: 23
Mileage: 62883 km
Date: 2016.11.28
Time: 23:31:48
Voltage terminal 30-Data: 5.8 V
Shut-off valves for coolant: status-Shut-off valve for coolant: interior: target: Open
Shut-off valves for coolant: status-Shut-off valve for coolant: interior: actual: Open
Shut-off valves for coolant: status-Shut-off valve for coolant: battery: target: closed
Shut-off valves for coolant: status-Shut-off valve for coolant: battery: actual: Open
0395 - Function limitation due to crash signal
B1397 00 [008] - -
Reset counter: 23
Mileage: 62883 km
Date: 2016.09.20
Time: 06:13:19
Voltage terminal 30-Data: 12.1 V
Address 09: Cent. Elect. (J519) Labels: 4H0-907-063-V1.clb
Part No SW: 4H0 907 063 CG HW: 4H0 907 063
Component: BCM1 2.0 H12 0130
Revision: 11012002 Serial number: 00000001703134
Coding: 0907201009749FE089810084A0001800009CC30AC8000121800108546F21
VCID: 6FAE1B1FBEB572390A-803A
Subsystem 1 - Part No SW: 4H1 955 119 C HW: 4H1 955 119 A Labels: 1KX-955-119.CLB
Component: WWS641 130207 H35 0080
Serial number: 130223110334
Coding: 0045F7
Subsystem 2 - Part No SW: 8K0 955 559 C HW: 8K0 955 559 C Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 10255601
Coding: 025523
Subsystem 3 - Part No SW: 4H0 941 531 C HW: 4H0 941 531 C
Component: E1 - LDS H07 0044
Serial number: 22 03 2013 00001114
Subsystem 4 - Part No SW: 4G0 907 410 HW: 4H0 907 410
Component: EHL2 V07.03 H30 0030
Serial number: 0000002274537R13ZS01
Subsystem 5 - Part No SW: 4H0 907 472 B HW: 4H0 907 472 B
Component: A31 LED Mod1L H03 0006
Serial number: 00000020031300010493
Coding: 100000
Subsystem 6 - Part No SW: 4H0 907 472 B HW: 4H0 907 472 B
Component: A27 LED Mod1R H03 0006
Serial number: 00000020031300010755
Coding: 100000
Subsystem 7 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Serial number: WA104972000003067664
Coding: 020300
Subsystem 8 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: 6B398B96000000000001
9 Faults Found:
02895 - Supply Voltage for LED Module for DRL and Parking Light; Left
Fault Status: 00101100
Reset counter: 25
Mileage: 62883 km
Date: 2016.10.20
Time: 14:37:00
02897 - Supply Voltage for LED Module for DRL and Parking Light; Right
Reset counter: 25
Mileage: 62883 km
Date: 2016.10.07
Time: 16:54:00
Reset counter: 26
Mileage: 62883 km
Date: 2016.10.21
Time: 11:18:00
Reset counter: 26
Mileage: 62883 km
Date: 2016.10.21
Time: 11:18:00
Fault Frequency: 59
Reset counter: 25
Mileage: 62883 km
Date: 2016.10.20
Time: 14:37:00
00910 - Indicator Lamp for Emergency Flashers (K6)
Reset counter: 24
Mileage: 62883 km
Date: 2016.10.14
Time: 10:14:00
Reset counter: 26
Mileage: 62883 km
Date: 2016.09.20
Time: 06:13:00
03608 - Humidity Sensor in Fresh Air Intake Duct
Reset counter: 26
Mileage: 62883 km
Date: 2016.09.20
Time: 06:13:00
03645 - Output Module for LED Headlamps; Left
Fault Frequency: 21
Reset counter: 25
Mileage: 62882 km
Date: 2016.12.10
Time: 07:19:00
Address 0E: Media Player 1 (R161) Labels: None
Part No SW: 4H0 035 108 F HW: 4H0 035 108
Component: DVDCAlpine H42 0200
Revision: AA001001
Coding: 020000
VCID: 2306272F22FD8659DE-8076
Fault Frequency: 7
Reset counter: 23
Mileage: 62883 km
Date: 2016.10.14
Time: 10:16:09
Voltage: 7.00 V
Fault Frequency: 10
Reset counter: 26
Mileage: 62883 km
Date: 2016.10.10
Time: 17:50:26
Voltage: 8.60 V
02261 - Data Medium
Fault Status: 00101110
Fault Frequency: 77
Reset counter: 22
Mileage: 62883 km
Date: 2016.09.20
Time: 07:02:47
Text: 00000000
Address 10: Park/Steer Assist (J446) Labels: 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 AA HW: 4H0 919 475 AG
Revision: 11001001 Serial number: 61061308500888
Coding: A80125
VCID: 71AA1D67A08164C91C-8024
9 Faults Found:
1111828 - Front Left Parking Aid Sensor
B10F7 14 [008] - Open or Short to Ground
Reset counter: 25
Mileage: 62883 km
Date: 2016.09.20
Time: 08:31:28
1112596 - Front Right Parking Aid Sensor
B10FA 14 [008] - Open or Short to Ground
Reset counter: 25
Mileage: 62883 km
Date: 2016.10.20
Time: 14:37:30
1112084 - Front Left Center Parking Aid Sensor
B10F8 14 [008] - Open or Short to Ground
Reset counter: 24
Mileage: 62883 km
Date: 2016.10.20
Time: 14:37:30
1112340 - Front Right Center Parking Aid Sensor
B10F9 14 [008] - Open or Short to Ground
Reset counter: 25
Mileage: 62883 km
Date: 2016.10.20
Time: 14:37:30
1112625 - Front Right Parking Aid Sensor
B10FA 31 [008] - No Signal
Reset counter: 23
Mileage: 62883 km
Date: 2016.09.20
Time: 08:31:28
1112113 - Front Left Center Parking Aid Sensor
B10F8 31 [008] - No Signal
Reset counter: 23
Mileage: 62883 km
Date: 2016.09.20
Time: 08:31:28
1112369 - Front Right Center Parking Aid Sensor
B10F9 31 [008] - No Signal
Reset counter: 23
Mileage: 62883 km
Date: 2016.09.20
Time: 08:31:28
13635840 - Supply voltage
Reset counter: 23
Mileage: 62883 km
Date: 2016.10.14
Time: 10:14:37
U1400 00 [008] - -
Reset counter: 23
Mileage: 62883 km
Date: 2016.10.14
Time: 10:14:37
Address 15: Airbags (J234) Labels: 4H0-959-655.clb
Part No SW: 4H0 959 655 F HW: 4H0 959 655 F
Component: Airbag10.43 H51 0053
Revision: -------- Serial number: 003KB0014JKZ
Coding: 3032373630344E303032554A304C34483053
ASAM Dataset: EV_AirbaAU10BPAAU64X 001023
VCID: 393AE547B871EC89E4-806C
Serial number: 3575HRB40591TEI450IA
Serial number: 3585HRB405B1TEI468KO
Serial number: 3515JRB400650G4GAOL5
Serial number: 3525JRB400A50G4G7117
Serial number: 3554VRB40590I70G0OVS
Serial number: 3564VRB40590I70GN99F
23 Faults Found:
9447424 - Front crash data stored
B1028 00 [136] - -
Mileage: 62883 km
Date: 2016.09.20
Time: 06:13:18
9466352 - Crash Data from Belt Tensioner Stored
B1071 F0 [136] - Unknown Error Elaboration
Mileage: 62883 km
Date: 2016.09.20
Time: 06:13:19
9445397 - Key switch for deactivation of passenger-side airbag
B1020 15 [136] - Open or Short to Plus
Mileage: 62883 km
Date: 2016.11.28
Time: 14:41:02
9446677 - Redundant signal path for airbag shut-off; passenger side
B1025 15 [136] - Open or Short to Plus
Mileage: 62883 km
Date: 2016.11.28
Time: 14:41:03
9443861 - Driver's Front Airbag Crash Sensor
B101A 15 [136] - Open or Short to Plus
Mileage: 62883 km
Date: 2016.10.20
Time: 16:31:13
9444117 - Front Passenger's Front Airbag Crash Sensor
B101B 15 [136] - Open or Short to Plus
Mileage: 62883 km
Date: 2016.10.20
Time: 16:31:13
B1000 1B [136] - Resistance Too High
Mileage: 62883 km
Date: 2016.09.20
Time: 07:09:49
9437201 - Igniter for Driver's Airbag
B1000 11 [136] - Short to Ground
Mileage: 62883 km
Date: 2016.09.20
Time: 06:13:22
9437723 - Igniter for Passenger's Airbag
B1002 1B [136] - Resistance Too High
Mileage: 62883 km
Date: 2016.11.28
Time: 14:41:05
9437713 - Igniter for Passenger's Airbag
B1002 11 [136] - Short to Ground
Mileage: 62883 km
Date: 2016.09.20
Time: 06:13:21
9571867 - Ignitor for Drivers Airbag Release Valve
B120E 1B [136] - Resistance Too High
Mileage: 62883 km
Date: 2016.09.20
Time: 06:13:21
9572123 - Ignitor for Passenger Airbag Release Valve
B120F 1B [136] - Resistance Too High
Mileage: 62883 km
Date: 2016.09.20
Time: 06:13:21
9442587 - Igniter for battery interrupt
B1015 1B [137] - Resistance Too High
Mileage: 62883 km
Date: 2016.09.20
Time: 06:13:21
9442075 - Driver's Belt Force Limiter Igniter
B1013 1B [136] - Resistance Too High
Mileage: 62883 km
Date: 2016.09.20
Time: 06:13:21
9442331 - Passenger's Belt Force Limiter Igniter
B1014 1B [136] - Resistance Too High
Mileage: 62883 km
Date: 2016.09.20
Time: 06:13:21
B1006 1B [136] - Resistance Too High
Mileage: 62883 km
Date: 2016.09.20
Time: 06:13:21
B1007 1B [136] - Resistance Too High
Mileage: 62883 km
Date: 2016.09.20
Time: 06:13:21
9439515 - Seat Belt Tensioner Igniter; rear; driver's side
B1009 1B [136] - Resistance Too High
Mileage: 62883 km
Date: 2016.09.20
Time: 06:13:21
9439259 - Igniter for Seat Belt Tensioner; Rear Passenger's Side
B1008 1B [136] - Resistance Too High
Mileage: 62883 km
Date: 2016.09.20
Time: 06:13:21
9441563 - Rear; driver's side; side-airbag igniter
B1011 1B [136] - Resistance Too High
Mileage: 62882 km
Date: 2016.11.30
Time: 05:39:45
9441307 - Rear; passenger's side; side-airbag igniter
B1010 1B [136] - Resistance Too High
Mileage: 62882 km
Date: 2016.11.30
Time: 05:39:45
1049862 - Databus
Reset counter: 25
Mileage: 62883 km
Date: 2016.10.20
Time: 14:37:30
Reset counter: 23
Mileage: 62883 km
Date: 2016.10.14
Time: 10:15:42
Address 16: Steering wheel (J527) Labels: 4H0-953-568.clb
Part No SW: 4H0 953 568 H HW: 4H0 953 568 H
Component: Lenks.Modul H03 0005
Revision: -------- Serial number: 90815LGA0000H
Coding: 0004B4
Subsystem 1 - Part No SW: 4H0 951 528 L HW: 4H0 951 528 L
Component: E221 - MFL H09 0010
Serial number: 09 01 2013 33330542
00889 - Horn (H)
Fault Status: 00100111
Fault Frequency: 17
Reset counter: 22
Mileage: 62883 km
Date: 2016.09.20
Time: 06:14:19
Fault Frequency: 7
Reset counter: 25
Reset counter: 22
Reset counter: 24
Address 17: Instruments (J285) Labels: 4H0-920-xxx-17.clb
Part No SW: 4H0 920 800 N HW: 4H0 920 800 N
Component: TBenRDW---NV- H52 0515
Revision: 34480076 Serial number: 658220113592040
Coding: 13A7090053450008000300
ASAM Dataset: EV_RBD4K 004046
ROD: EV_RBD4K.rod
VCID: 2D12C1177C39402978-8078
Analog_clock:
Subsystem 1 - Part No SW: 4H0 919 204 H HW: 4H0 919 204 H
Component: Analoguhr D4 H05 0225
Serial number: 2130312002281
Reset counter: 23
Mileage: 62883 km
Date: 2016.10.10
Time: 17:54:11
16773127 - Analog Clock
U1096 00 [008] - No Communications
Reset counter: 24
16776976 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Reset counter: 25
Mileage: 62883 km
Date: 2016.10.20
Time: 14:37:30
1048580 - Button for Trip Odometer Reset
B11FE 13 [008] - Open Circuit
Reset counter: 24
Mileage: 62882 km
Date: 2016.11.30
Time: 06:36:51
Part No SW: 4H1 907 468 B HW: 4H1 907 468 B
Component: J533--Gateway H12 0037
Revision: -------- Serial number: 00000000768920
Coding: 00D10AFF00
ASAM Dataset: EV_GatewPkoUDS 001018
ROD: EV_GatewPKOUDS_VW51.rod
VCID: 312ADD67600124C95C-8064
Subsystem 1 - Part No SW: 4H0 915 181 E HW: 4H0 915 181 E
Component: J367-BDM H08 0181
Serial number: 60066030242071107201
Battery monitoring control unit 2:
10 Faults Found:
5048 - Control Module for Multi-Contour Seat; Rear Driver Side
U1087 00 [008] - No Communications
Reset counter: 25
Mileage: 62882 km
Date: 2016.11.30
Time: 03:46:12
Voltage terminal 30: 11.6 V
Voltage terminal 15: 0.0 V
Control Module temperature: 10 °C
Engine running: OFF
IN ZAS_Te_X: OFF
Terminal 15 status: OFF
Datenfeld: 0
5049 - Control Module for Multi-Contour Seat; Rear Passenger Side
U1089 00 [008] - No Communications
Reset counter: 25
Mileage: 62882 km
Date: 2016.11.30
Time: 01:57:15
Control Module temperature: 13 °C
Engine running: OFF
IN ZAS_Te_X: OFF
Datenfeld: 0
5052 - Control Module for Seat Adjustment Rear Drivers Side
U10B3 00 [008] - No Communication
Reset counter: 25
Mileage: 62882 km
Date: 2016.11.30
Time: 03:46:12
Engine running: OFF
IN ZAS_Te_X: OFF
Datenfeld: 0
5053 - Control Module for Seat Adjustment Rear Passenger Side
U10B4 00 [008] - No Communication
Reset counter: 25
Mileage: 62882 km
Date: 2016.11.30
Time: 01:57:15
Engine running: OFF
IN ZAS_Te_X: OFF
Datenfeld: 0
5701 - High Beam Assistant Control Module
U1070 00 [008] - No Communication
Reset counter: 25
Mileage: 62883 km
Date: 2016.11.30
Time: 04:34:45
Voltage terminal 30: 11.1 V
Voltage terminal 15: 11.1 V
Control Module temperature: -1 °C
System status: Terminal 15 on
Engine running: OFF
IN ZAS_Te_X: OFF
Terminal 15 status: On
Datenfeld: 0
5080 - Front Left belt tensioner control module
U107C 00 [008] - No communication
Reset counter: 25
Mileage: 62882 km
Date: 2016.11.30
Time: 03:57:15
Voltage terminal 15: 11.6 V
Engine running: OFF
IN ZAS_Te_X: On
Datenfeld: 0
5081 - Front Right belt tensioner control module
U107D 00 [008] - No communication
Reset counter: 25
Mileage: 62882 km
Date: 2016.11.30
Time: 03:57:15
Engine running: OFF
IN ZAS_Te_X: On
Datenfeld: 0
0267 - Optical data bus
U1049 00 [008] - Open circuit
Reset counter: 26
Mileage: 62883 km
Date: 2016.11.30
Time: 02:55:51
Voltage terminal 30: 9.1 V
Engine running: OFF
IN ZAS_Te_X: OFF
Datenfeld: 0
0017 - Supply voltage
Reset counter: 23
Mileage: 62883 km
Date: 2016.12.02
Time: 08:40:13
Voltage terminal 30: 7.9 V
Control Module temperature: 4 °C
System status: LIN_active
Engine running: OFF
IN ZAS_Te_X: OFF
Datenfeld: 0
U140B 00 [008] - -
Fault Frequency: 46
Reset counter: 26
Mileage: 62883 km
Date: 2016.11.30
Time: 02:59:51
Voltage terminal 30: 9.9 V
Control Module temperature: -2 °C
Engine running: OFF
IN ZAS_Te_X: OFF
Datenfeld: 3
Address 20: High Beam Assist. (J844) Labels: 8K0-857-511.clb
Part No SW: 8K0 857 511 F HW: 8K0 857 511 A
Component: FLA H04 0020
Revision: AA001002
Coding: 04018B646E6E645A5A253D3E00
VCID: 3424D473971311E137-8060
Address 28: HVAC, Rear (E265) Labels: None
Part No SW: 4H0 919 158 H HW: 4H0 919 158 H
Component: Klima Fond H21 0121
Coding: 3600000000
ROD: EV_AirCondiHeck_AU64.rod
VCID: 3522E977946908E900-8060
0077 - Supply voltage
Reset counter: 23
Mileage: 62883 km
Date: 2016.10.14
Time: 10:15:07
0152 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 25
Mileage: 62882 km
Date: 2016.11.30
Time: 03:57:19
Voltage terminal 30-Data: 11.6 V
Outside air temperature-Data: 11.00 °C
0153 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 25
Mileage: 62882 km
Date: 2016.11.30
Time: 03:57:19
0102 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
Reset counter: 23
Mileage: 62883 km
Date: 2016.10.14
Time: 10:15:07
Address 30: Special Function II (J843) Labels: 8K0-907-440.clb
Part No SW: 4H0 907 440 HW: 4H0 907 440
Component: STS H06 0030
Revision: S0H06000 Serial number: 00000000039350
Coding: 01010101000000000001000102
VCID: 648464336773C16167-8030
Fault Frequency: 15
Reset counter: 25
Mileage: 62883 km
Date: 2016.10.10
Time: 17:49:13
Reset counter: 22
Mileage: 62883 km
Date: 2016.10.14
Time: 10:15:08
Address 34: Level Control (J197) Labels: 4G0-907-553.clb
Part No SW: 4G0 907 553 E HW: 4G0 907 553
Component: LUFE-DAEMPFER H17 0781
Coding: 008000
ROD: EV_AirSuspe_VW51.rod
136194 - Supply voltage
Reset counter: 23
Mileage: 62883 km
Date: 2016.10.14
Time: 10:14:47
C10C8 00 [008] - -
Reset counter: 26
Mileage: 62882 km
Date: 2016.11.30
Time: 00:26:11
136196 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
Reset counter: 23
Time: 00:00:00
Part No SW: 4H0 959 760 E HW: 4H0 959 760 E
Component: MEM-FS H08 0153
Revision: AA000000 Serial number: 00000055473659
Coding: C018BF8085853201070001010101112131313333203333
VCID: 3522E9779C6908E900-8060
Reset counter: 23
Mileage: 62883 km
Date: 2016.10.10
Time: 17:56:13
Fault Frequency: 11
Reset counter: 26
Mileage: 62883 km
Date: 2016.10.14
Time: 10:16:05
03725 - Control Module for Seat Belt Tensioner; Left Front
Reset counter: 25
Mileage: 62882 km
Date: 2016.11.30
Time: 03:57:18
03794 - Switch for Massage
Reset counter: 25
Address 3B: Sensor Elect. (J849) Labels: None
Part No SW: 4H0 907 637 K HW: 4H0 907 637 F
Component: SARA 6D H02 0056
Revision: -------- Serial number: EJ1BPA7700MSAP
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2_VW51.rod
8393216 - Pitch Rate
C10B7 F0 [008] - Gradient too High
Reset counter: 23
Mileage: 62883 km
Date: 2016.09.20
Time: 06:13:18
DCU_Internal_DTC: 80 12 00
Ignition Cycle Count: 14485
DCU Temperature: 37 °C
Voltage terminal 30: 12.6 V
Voltage VBG 22: 2.5 V
Roll rate sensor: -0.00 rad/s
Pitch rate sensor: -0.07 rad/s
Yaw rate sensor: 0.00 rad/s
Yaw rate sensor 2: 0.00 rad/s
Longitudinal acceleration sensor: -42.94 m/s˛
Lateral acceleration sensor 1: -1.07 m/s˛
Lateral acceleration sensor 2: 0.00 m/s˛
Body acceleration sensor: 1.31 m/s˛
Debug Data: 00 00 00 00 00 00 00 00
Address 3C: Lane Change Labels: Redir Fail!
Part No SW: 4H0 907 566 A HW: 4G0 907 566
Component: J769 SWA MasterH02 0040
Revision: 00H02000 Serial number: 6PZ 010 287-07
Coding: 0000102
VCID: 2E10C61BB93F3B3141-807A
Subsystem 1 - Part No: 4H0 907 568 A
Component: J770 SWA Slave H02 0040
Subsystem 2 - Serial number: 6PZ 010 287-27
Subsystem 3 - Serial number: 5F27.03.1300H02000AMS14465˙
Subsystem 4 - Serial number: S14465˙
Reset counter: 23
Mileage: 62883 km
Date: 2016.10.14
Time: 10:14:54
02857 - Supply Voltage for Lane Change Assistance Control Module 2
Reset counter: 23
Mileage: 62883 km
Date: 2016.10.14
Time: 10:14:57
Reset counter: 23
Mileage: 62883 km
Date: 2016.10.14
Time: 10:14:54
01024 - Rain Sensor (G213)
Reset counter: 25
Mileage: 62882 km
Date: 2016.12.11
Time: 23:55:55
Address 40: AC Compressor (J842) Labels: None
Part No SW: 4G0 260 797 HW: 4G0 260 797
Component: ES34 H01 0001
ASAM Dataset: EV_AirCondiCompr_ES34 S03001
ROD: EV_AirCondiCompr_ES34.rod
VCID: 6A980A0B8D5797115D-803E
U1400 00 [008] - -
Reset counter: 23
Mileage: 62883 km
Date: 2016.10.14
Time: 10:14:40
Voltage terminal 15: 8.9 V
Compressor speed: 0 /min
Compressor current: 0.0 A
Compressor temperature: 0 °C
Compressor main status: Not available
Compressor enabling: Not available
Compressor speed specified value: 0 /min
Availability of high voltage: Not available
Hybrid battery voltage: 100.0 V
Compressor motor current: 0.0 A
Part No SW: 4H0 959 793 R HW: 4H0 959 793 G
Component: TSG FA H06 0273
Revision: -------- Serial number: 0000055808577
Coding: 011F1E015E0062C202083016
VCID: 48DC9083FB9B85016B-801C
Reset counter: 23
Mileage: 62883 km
Date: 2016.10.14
Time: 10:16:01
Reset counter: 25
Mileage: 62882 km
Date: 2016.11.30
Time: 05:39:45
Address 44: Steering Assist (J500) Labels: None
Component: RCEPS H36 0010
Revision: 00001000 Serial number: 0018280133
Coding: 001000010100
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS_009.rod
VCID: 3228D26B65071FD125-8066
18689 - Terminal 30
U140A 00 [008] - Open Circuit
Reset counter: 23
Mileage: 62882 km
Date: 2016.11.30
Time: 00:37:13
valid
Address 46: Central Conv. (J393) Labels: 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0302392575
Coding: 011A0E2000B97D9FB330C7801A03012F0000000000000000000000000000
Subsystem 1 - Part No SW: 4H0 959 719 HW: 4H0 959 719
Component: GTO BF H01 0080
Serial number: 00000000000000133762
Subsystem 2 - Part No: 4H0 951 177
Component: DWA-Sensor H01 0010
Subsystem 4 - Part No SW: 4H4 959 591 HW: 4H4 959 591
Component: J245 007C H06 0005
Serial number: 311400042044
Coding: 020200
Subsystem 5 - Part No SW: 4H0 947 135 R HW: 4H0 947 135 R
Component: Dachelektroni H13 0080
Serial number: A2013000000000691424
Coding: 070000
Subsystem 6 - Part No SW: 4H4 959 591 HW: 4H4 959 591
Component: J394 0014 H06 0005
Serial number: 310300039613
Coding: 020200
Subsystem 7 - Part No SW: 4H4 959 591 HW: 4H4 959 591
Component: J392 006A H06 0005
Serial number: 311400042043
Coding: 020200
Subsystem 8 - Part No SW: 4H4 959 591 HW: 4H4 959 591
Component: J867 00E0 H06 0005
Serial number: 310300039600
Coding: 020200
Subsystem 9 - Part No SW: 3AA 962 243 HW: 3AA 962 243
Component: GEB.F.Heckoef H12 0719
Serial number: 84359194
11 Faults Found:
00218 - Humidity Sensor (G355)
Reset counter: 24
Mileage: 62883 km
Date: 2016.09.20
Time: 06:13:23
02907 - Control Module for Roof Shade (J394)
Fault Status: 00100101
Reset counter: 28
Mileage: 62882 km
Date: 2016.12.13
Time: 01:55:18
03233 - Controls for Garage Door Opener (E284)
Reset counter: 24
Mileage: 62882 km
Date: 2016.12.11
Time: 23:55:54
03932 - Real Lid/Hatch Opening Sensor
Reset counter: 25
Mileage: 62882 km
Date: 2016.12.13
Time: 01:55:18
01512 - Control Module for Sliding Roof
Reset counter: 28
Mileage: 62883 km
Date: 2016.10.14
Time: 10:48:02
02906 - Control Module for Sliding Roof; Rear (J392)
Reset counter: 28
Mileage: 62883 km
Date: 2016.10.14
Time: 10:48:03
03156 - Sensor for Anti-Theft System (G578)
Reset counter: 24
Mileage: 62882 km
Date: 2016.12.11
Time: 22:58:25
01308 - Control Module for Roof Electronics (J528)
Reset counter: 24
Mileage: 62882 km
Date: 2016.12.11
Time: 22:58:25
02201 - Trunk / Luggage Compartment Closing Assist; Position - Unlocked (F332)
Reset counter: 26
Mileage: 62883 km
Date: 2016.11.30
Time: 02:55:44
Reset counter: 22
Mileage: 62883 km
Date: 2016.11.08
Time: 12:27:20
02202 - Trunk / Luggage Compartment Closing Assist; Position - Locked (F332)
Reset counter: 26
Mileage: 62883 km
Date: 2016.11.30
Time: 02:55:41
Part No SW: 4H1 035 465 B HW: 4H1 035 465
Component: BO G3 D4 ANC H03 0150
Revision: 09000000 Serial number: 0012309
Coding: 020101
VCID: 26003E3B51CF7371B9-8072
Subsystem 1 - Part No SW: 4H0 035 466 HW: 4H0 035 466
Component: BO D4 SLAVE H51 0180
Serial number: 00703130023171
11 Faults Found:
Reset counter: 23
Voltage: 8.50 V
Temperature: 23.0°C
Bin. Bits: 00000100
Voltage: 8.50 V
Temperature: 29.0°C
Bin. Bits: 00000001
Bin. Bits: 00000000
Reset counter: 23
Mileage: 62883 km
Date: 2016.10.14
Time: 10:15:15
Voltage: 8.50 V
Temperature: 8.0°C
Bin. Bits: 00000100
Voltage: 10.00 V
Temperature: 9.0°C
Bin. Bits: 00000001
Bin. Bits: 00000000
Fault Status: 00101011
Reset counter: 25
Voltage: 11.60 V
Temperature: 1.0°C
Bin. Bits: 00000100
Voltage: 11.50 V
Temperature: 6.0°C
Bin. Bits: 00000000
Bin. Bits: 00000000
Reset counter: 25
Voltage: 11.60 V
Temperature: 1.0°C
Bin. Bits: 00000100
Voltage: 11.50 V
Temperature: 6.0°C
Bin. Bits: 00000000
Bin. Bits: 00000000
03017 - Motor for Left Front Treble Speaker (V344)
Reset counter: 25
Voltage: 11.60 V
Temperature: 1.0°C
Bin. Bits: 00000100
Voltage: 11.50 V
Temperature: 6.0°C
Bin. Bits: 00000000
Bin. Bits: 00000000
03016 - Motor for Front Right Treble Speaker (V345)
Reset counter: 25
Voltage: 11.60 V
Temperature: 1.0°C
Bin. Bits: 00000100
Voltage: 11.50 V
Temperature: 6.0°C
Bin. Bits: 00000000
Bin. Bits: 00000000
Reset counter: 25
Voltage: 11.80 V
Temperature: 13.0°C
Bin. Bits: 00000100
Voltage: 11.50 V
Temperature: 22.0°C
Bin. Bits: 00000000
Bin. Bits: 00000000
Reset counter: 25
Voltage: 11.50 V
Temperature: 12.0°C
Bin. Bits: 00000100
Voltage: 11.50 V
Temperature: 21.0°C
Bin. Bits: 00000000
Bin. Bits: 00000000
02753 - Inside Microphone (R74)
Reset counter: 25
Voltage: 11.20 V
Temperature: -4.0°C
Bin. Bits: 00000100
Voltage: 11.00 V
Temperature: 1.0°C
Bin. Bits: 00000000
Bin. Bits: 00000000
Reset counter: 25
Mileage: 62882 km
Date: 2016.12.11
Time: 23:56:09
Voltage: 11.50 V
Temperature: 0.0°C
Bin. Bits: 00000100
Voltage: 11.50 V
Temperature: 7.0°C
Bin. Bits: 00000000
Bin. Bits: 00000000
Reset counter: 25
Mileage: 62882 km
Date: 2016.12.11
Time: 23:56:09
Voltage: 11.50 V
Temperature: 0.0°C
Bin. Bits: 00000100
Voltage: 11.50 V
Temperature: 7.0°C
Bin. Bits: 00000000
Bin. Bits: 00000000
Address 48: Seat, Rear, DS (J876) Labels: None
Part No SW: 4H0 959 860 A HW: 4H0 959 860 A
Component: MEM-FS-Fond H06 0155
Revision: AA000000 Serial number: 00000053984457
Coding: C01892808500300D0B00392038193A2039203B3B202020
VCID: 3228D26B6D071FD125-8066
Reset counter: 23
Mileage: 62883 km
Date: 2016.10.10
Time: 17:50:23
Fault Frequency: 13
Reset counter: 26
Mileage: 62883 km
Date: 2016.10.14
Time: 10:16:07
Address 51: Electric Drive (J841) Labels: None
Part No SW: 4H0 907 080 B HW: 4H0 907 080 B
Component: Audi C7/D4 HY H18 0001
Revision: --------
ASAM Dataset: EV_DMCM03020214H0907080B 001001
ROD: EV_DMCM030202106F907080H.rod
VCID: 26003E3B59CF7371B9-8072
17659 - HV Electronics Coolant Pump Control
P0CEA 00 [032] - Implausible Signal
Mileage: 62882 km
Date: 2016.11.30
Time: 00:00:50
Voltage terminal 30-Battery voltage: 13.780330 V
RPM of electric machine-N_EM: 1197.50 /min
Drive control condition-STATE_EM_MOD_CAN: speed control (external)
Torque: current value-TQI_EM_CAN_MVB: -20.3 Nm
Power electronics heat sink temperature-PIT_S16TEMPERATURE_DCBLP: 12.16 °C
Voltage of intermediate circuit-S16DCLINKVOLTAGE_MVB: 263.69 V
17929 - Invalid Data Received from Diagnostic Gateway Module
U0447 00 [040] - -
Fault Frequency: 20
Mileage: 62883 km
Date: 2016.10.20
Time: 14:37:27
Voltage terminal 30-Battery voltage: 11.668016 V
RPM of electric machine-N_EM: 0.00 /min
Time since terminal 15 ON-T_AST_SAE: 0 s
Electrical drive control module: operating status-ECUM_ESYSTEMSTATE_ENVD: ECUM_Run
Intermediate circuit voltage-DCSP__S16HVVOLTAGE: 264.19 V
5751 - 14V Power System Voltage
P0A8D 00 [032] - too Low
Mileage: 62883 km
Date: 2016.10.14
Time: 10:16:57
Voltage terminal 30-Battery voltage: 8.449253 V
Drive control condition-STATE_EM_MOD_CAN: Standby
Torque: current value-TQI_EM_CAN_MVB: 0.0 Nm
Power electronics heat sink temperature-PIT_S16TEMPERATURE_DCBLP: 6.44 °C
Voltage of intermediate circuit-S16DCLINKVOLTAGE_MVB: 272.38 V
Part No SW: 4H0 959 792 G HW: 4H0 959 792 G
Component: TSG BF H06 0273
Revision: -------- Serial number: 0000055334112
Coding: 011F1E015E0062C202083006
VCID: 3C34FC53BF43D9A1FF-8068
Reset counter: 23
Mileage: 62883 km
Date: 2016.10.14
Time: 10:16:01
Reset counter: 25
Mileage: 62882 km
Date: 2016.11.30
Time: 05:39:45
Part No SW: 4H0 907 801 F HW: 4H0 907 801 A
Component: EPB-4 H03 0013
Revision: -------- Serial number: 00000000632565
ROD: EV_ParkiBrake_VW51.rod
VCID: 2B16CF0F422D4E1966-807E
10554390 - Supply voltage
Fault Frequency: 7
Reset counter: 238
Mileage: 62883 km
Date: 2016.10.14
Time: 10:14:41
Voltage terminal 30: 8.9 V
Internal Fault ID: 40
Red operating lamp: OFF
Red warning lamp: OFF
Green operating lamp: OFF
Yellow warning lamp: OFF
RWU: not active
DSD: not active
HTR: not active
ECD: not active
Auto Adjust: not active
721408 - Terminal 30
Reset counter: 238
Voltage terminal 30: 0.0 V
Internal Fault ID: 61
Vehicle speed: 510 km/h
Network management state: Reset
RWU: not active
DSD: not active
HTR: not active
ECD: not active
Internal Parking Brake state: Emergency running mode
Status ParkingBrake left: Initializing
Status ParkingBrake right: Initializing
461568 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Reset counter: 23
Mileage: 62883 km
Date: 2016.10.20
Time: 14:37:28
Voltage terminal 30: 11.5 V
Internal Fault ID: 147
RWU: not active
DSD: not active
HTR: not active
ECD: not active
Part No SW: 4H0 035 061 Q HW: 4H0 035 061
Component: Radio U DAB H60 0150
Revision: AB001007 Serial number: 440CK0D7520007
Coding: 010103010003000001
VCID: 2C14CC134F2349216F-8078
Reset counter: 23
Mileage: 62883 km
Date: 2016.10.14
Time: 10:16:14
Voltage: 8.50 V
Reset counter: 26
Mileage: 62883 km
Date: 2016.10.10
Time: 17:50:32
Voltage: 8.60 V
Address 57: TV Tuner (R78) Labels: None
Part No SW: 4G0 919 129 C HW: 4G0 919 129
Component: NGTV-DVB H04 0690
Revision: R0043000 Serial number: 06801300372401
Coding: 01000400
VCID: 2D12C1177439402978-8078
Reset counter: 23
Mileage: 62883 km
Date: 2016.10.31
Time: 11:20:17
02283 - Video Connection to Output [End Unit]
Fault Status: 00101010
Reset counter: 24
Mileage: 62882 km
Date: 2016.11.30
Time: 00:10:12
Address 5B: Seat,Rear,PS (J877) Labels: None
Component: MEM-BFS-Fond H06 0155
Revision: AA000000 Serial number: 00000053985998
Coding: C01896808500300D0F00392038193A2039203B3B3B2020
03785 - Remote Control for Rest-Seat
Fault Frequency: 7
Reset counter: 11
Mileage: 54078 km
Date: 2016.08.14
Time: 09:19:07
03795 - Switch Module for Seat Adjustment
Reset counter: 2
Mileage: 57517 km
Date: 2016.08.26
Time: 13:36:54
Fault Frequency: 12
Reset counter: 26
Mileage: 62883 km
Date: 2016.10.14
Time: 10:16:07
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 4H0 035 654 HW: 4H0 035 670 N
Component: H-BNT-EU H45 0939
Revision: -------- Serial number: 179C50D7508766
Coding: 1B0100000001F1EF5DF78B1E00000003080001000000000000
VCID: 6386672F627DC6599E-8036
Subsystem 1 - Part No: 8R0 060 884 DF
Component: EUR 2016 2204
Subsystem 2 - Part No SW: 4F0 910 393 AH HW: 4F0 862 393 E
Component: BTHS H25 0750
Serial number: P13000372727
Subsystem 3 - Part No SW: 4F0 910 393 AH HW: 4F0 862 393 E
Serial number: P13000071540
Subsystem 4 - Part No SW: 4H0 919 604 G HW: 4H0 919 604 G
Component: DU8 D4 SV NB H48 0021
Serial number: AUZ8ZDDC9007AJT
Subsystem 5 - Part No SW: 4H1 919 600 H HW: 4H1 919 600
Component: E380 BDT D4 H09 0065
Serial number: 00000000109088
Subsystem 6 - Part No: 8R0 060 961 E
Component: CD-Database 4949
11 Faults Found:
Reset counter: 156
Mileage: 53200 km
Date: 2016.08.01
Time: 14:24:14
Text: DU903A,Right,M,0,0,6
00384 - Optical Databus
Reset counter: 24
Time Indication: 15
Voltage: 11.50 V
02067 - Optical Databus; Unpermitted Wake-Up Request
Reset counter: 26
Time Indication: 15
Voltage: 6.80 V
Reset counter: 25
Mileage: 62882 km
Date: 2016.12.10
Time: 01:41:21
Bin. Bits: 00000000 00000000
Bin. Bits: 10000000 00000000
03367 - Supply Voltage for Display Module
Reset counter: 23
Mileage: 62883 km
Date: 2016.10.14
Time: 10:15:34
Voltage: 8.20 V
02168 - Left Front Microphone (R140)
Reset counter: 25
Time Indication: 15
Voltage: 11.20 V
02169 - Front Right Microphone (R141)
Reset counter: 25
Time Indication: 15
Voltage: 11.20 V
01524 - Antenna for Telephone
Reset counter: 25
Mileage: 53210 km
Date: 2016.08.01
Time: 14:45:27
Voltage: 14.00 V
03623 - Invalid Secruity/Release Code
Reset counter: 240
Mileage: 62882 km
Date: 2016.12.10
Time: 04:37:41
Hex Value: 0x0004
Hex Value: 0x0009
Count: 7
03787 - Rotation Mechanism for Display Module Front
Reset counter: 24
Mileage: 62882 km
Date: 2016.11.30
Time: 07:12:28
Voltage: 11.60 V
Reset counter: 24
Time Indication: 15
Voltage: 14.50 V
Part No SW: 4H0 959 795 D HW: 4H0 959 795 D
Component: TSG HL H06 0273
Revision: -------- Serial number: 0000055824397
Coding: 010F1E01420062C202083006
Reset counter: 23
Mileage: 62883 km
Date: 2016.10.14
Time: 10:15:58
Address 65: Tire Pressure (J502) Labels: 3Y0-907-273.clb
Part No SW: 4H0 907 273 HW: 4H0 907 273
Component: RDKBERU25 H09 0700
Serial number: 10000000001829
ROD: EV_RDKBERU25_AU57.rod
VCID: 689C7003935BA5014B-803C
8392961 - TPMS Transceiver in Front Left Wheel Well
C104C 01 [008] - Electrical Failure
Reset counter: 23
Mileage: 62883 km
Date: 2016.11.30
Time: 02:56:37
8393217 - TPMS Transceiver in Front Right Wheel Well
C104D 01 [008] - Electrical Failure
Fault Frequency: 10
Reset counter: 23
Mileage: 62883 km
Date: 2016.11.08
Time: 12:28:12
8393473 - TPMS Transceiver in Rear Left Wheel Well
C104E 01 [008] - Electrical Failure
Fault Frequency: 7
Reset counter: 23
Mileage: 62883 km
Date: 2016.11.08
Time: 12:28:12
8393729 - TPMS Transceiver in Rear Right Wheel Well
C104F 01 [008] - Electrical Failure
Reset counter: 23
Mileage: 62883 km
Date: 2016.11.08
Time: 12:28:12
Address 6C: Back-up Cam. (J928) Labels: None
Part No SW: 4H0 907 428 A HW: 7P6 907 441 D
Component: TopView H05 0150
Revision: 11001001 Serial number: 82330JF0079854
Coding: 020A000001010000000102000000
ASAM Dataset: EV_CamerSysteTopViewAUDI 006025
ROD: EV_CamerSysteTopViewAUDI_005.rod
9616922 - Supply Voltage for Front Surroundings Camera
B1284 14 [008] - Open or Short to Ground
Mileage: 62883 km
Date: 2016.09.20
Time: 06:13:23
Voltage terminal 30: 12.1 V
9617993 - Proximity Camera
B145C 54 [009] - Missing Calibration / Basic Setting
Reset counter: 240
Mileage: 62882 km
Date: 2016.12.12
Time: 04:06:40
Voltage terminal 30: 13.3 V
15729431 - Supply voltage
Reset counter: 23
Mileage: 62883 km
Date: 2016.10.14
Time: 10:15:00
Voltage terminal 30: 8.3 V
9617697 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
Reset counter: 23
Mileage: 62883 km
Date: 2016.10.14
Time: 10:15:00
Address 6D: Trunk Elect. (----) Labels: None
Part No SW: 4H0 959 107 AB HW: 4H0 959 107 M
Component: HDSG-Modul H11 0043
Revision: 10011001 Serial number: 053300739
Coding: 0210044000
ASAM Dataset: EV_DeckLidContrUnit 001032
ROD: EV_DeckLidContrUnit.rod
VCID: 6E90061BB1BF7B3101-803A
0014 - Supply voltage
Reset counter: 23
Mileage: 62883 km
Date: 2016.10.14
Time: 10:14:58
8.66 V
0011 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
Reset counter: 40
Mileage: 62883 km
Date: 2016.10.21
Time: 11:18:25
8.79 V
Address 6F: Centr. Conv. II (J773) Labels: None
Part No SW: 4H0 907 412 HW: 4H0 907 412
Component: ALM H05 0004
Revision: -------- Serial number: 000000101671
Coding: 400000
ASAM Dataset: EV_Ambie 001008
ROD: EV_Ambie.rod
VCID: 6386672F6A7DC6599E-8036
6 Faults Found:
0003 - Supply voltage
Reset counter: 23
Mileage: 62883 km
Date: 2016.10.10
Time: 17:54:11
Voltage terminal 30: 8.4 V
Control Module temperature: 24 °C
Processor load: 37.0 %
Status terminal 58s: OFF
0006 - Front Left Footwell Lighting Color 2
B111D 01 [008] - Electrical Failure
Reset counter: 24
Mileage: 62882 km
Date: 2016.11.30
Time: 06:51:06
Control Module temperature: 16 °C
Processor load: 36.5 %
0008 - Front Right Footwell Lighting Color 1
B111E 01 [008] - Electrical Failure
Reset counter: 26
Mileage: 62882 km
Date: 2016.11.30
Time: 03:16:59
Voltage terminal 30: 13.9 V
Processor load: 37.5 %
Color setting Ambient: Warm white
0010 - Front Right Footwell Lighting Color 2
B111F 01 [008] - Electrical Failure
Reset counter: 24
Mileage: 62883 km
Date: 2016.11.08
Time: 14:11:53
Voltage terminal 30: 11.9 V
0054 - Rear Left Door Sill Lighting
B1135 01 [008] - Electrical Failure
Reset counter: 25
Mileage: 62882 km
Date: 2016.11.30
Time: 03:27:23
Voltage terminal 30: 11.8 V
Processor load: 34.5 %
0056 - Rear Right Door Sill Lighting
B1136 01 [008] - Electrical Failure
Reset counter: 25
Mileage: 62882 km
Date: 2016.11.30
Time: 03:52:44
Voltage terminal 30: 11.4 V
Control Module temperature: 12 °C
Component: TSG HR H06 0273
Revision: -------- Serial number: 0000055824469
Reset counter: 23
Mileage: 62883 km
Date: 2016.10.14
Time: 10:15:57
Address 7F: Inform. Electr. II (J829) Labels: None
Part No SW: 4H0 035 776 G HW: 4H0 035 776 J
Component: H-BN-EU H45 0638
Revision: -------- Serial number: 185CM0D7503010
Coding: 1B010000000100400140001400001300000000000000000000
VCID: 2F2EDB1F7E3532394A-807A
Subsystem 1 - Part No SW: 4H0 919 607 HW: 4H0 919 607
Component: DU10 RSE H41 0021
Serial number: AUZ8ZDD120103E-
Subsystem 2 - Part No SW: 4H4 919 607 HW: 4H4 919 607
Serial number: AUZ8ZDC27008KZ0
Subsystem 3 - Part No SW: 4H0 919 709 C HW: 4H0 919 709 C
Component: E499 BDT 2 H07 0019
Serial number: 90238MCL0000W
Subsystem 5 - Part No: 8R0 060 884 AR
Component: ECE 2013 1505
00658 - Control Head
Reset counter: 22
Mileage: 61801 km
Date: 2016.09.15
Time: 08:22:05
Voltage: 12.60 V
Bin. Bits: 001
03368 - Supply Voltage for Display Module 2
Reset counter: 23
Mileage: 62883 km
Date: 2016.10.31
Time: 11:20:28
Voltage: 7.80 V
03369 - Supply Voltage for Display Module 3
Reset counter: 23
Mileage: 62883 km
Date: 2016.10.31
Time: 11:20:28
Voltage: 7.80 V
Address 81: Gear Shift (J587) Labels: None
Part No SW: 4H1 927 731 C HW: 4H1 927 731 C
Component: GSM-LL H08 0083
Revision: 0L0D5015 Serial number: SN121106 0274
ROD: EV_GSM2x3Mono.rod
9987 - Supply voltage
Reset counter: 23
Mileage: 62883 km
Date: 2016.10.14
Time: 10:14:39
Address 84: Night Vision (J853) Labels: 4H0-907-547.clb
Part No SW: 4H0 907 547 F HW: 4H0 907 547
Component: NV-ECU-Gen1 H09 0042
Serial number: 0K84AE40093546
Coding: 1200
ASAM Dataset: EV_NightVisioGen1 001002
ROD: EV_NightVisioGen1.rod
Night vision system camera:
Subsystem 1 - Part No SW: 4H0 980 552 A HW: 4H0 980 552
Component: NV-CAM-Gen1 H09 0008
Serial number: 00000000001305600143
4097 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
Reset counter: 23
Mileage: 62883 km
Date: 2016.10.14
Time: 10:14:57
Voltage terminal 15: 8.5 V
Image processor: temperature: 9 °C
Image processor: error number: 00 01
8704 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Fault Frequency: 10
Reset counter: 25
Mileage: 62882 km
Date: 2016.12.11
Time: 23:55:53
12306 - Video Cable for Night Vision System
B11E1 29 [008] - Signal Implausible
Fault Frequency: 74
Reset counter: 25
Mileage: 62883 km
Date: 2016.09.20
Time: 06:13:19
Voltage terminal 15: 12.4 V
Image processor: temperature: 44 °C
Image processor: error number: 00 00
9730 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Fault Frequency: 21
Reset counter: 23
Mileage: 62883 km
Date: 2016.10.20
Time: 14:37:30
9475 - Local Data Bus
U10B8 00 [008] - Defective
Reset counter: 25
Mileage: 62883 km
Date: 2016.09.20
Time: 07:26:16
Address 85: On Board Cam. (J852) Labels: None
Part No SW: 4G0 907 217 A HW: 4H0 907 217 A
Component: DPC-SG H26 0038
Revision: -------- Serial number: 262130025421000
Coding: E1060000
ROD: EV_OnBoardCamerDPC.rod
0001 - Front Heater for Lane-Holding Assist
C1101 15 [008] - Open or Short to Plus
Reset counter: 25
Mileage: 62882 km
Date: 2016.12.11
Time: 23:56:46
Outside air temperature: -46.0 °C
Voltage terminal 15: 13.4 V
Control Module temperature: 9.0 °C
Address 88: Multicont. Seat Driver (J873) Labels: None
Part No SW: 4H0 907 182 H HW: 4H0 907 182 H
Component: IVB H07 0042
Serial number: 00010538196102
Coding: 764FF2
ROD: EV_IVBDriveSideFrnt.rod
VCID: 2F2EDB1F763532394A-807A
0018 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 25
Mileage: 62882 km
Date: 2016.11.30
Time: 05:39:48
0002 - Supply voltage
Reset counter: 23
Mileage: 62883 km
Date: 2016.10.14
Time: 10:14:37
0004 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
Fault Frequency: 23
Reset counter: 26
Mileage: 62883 km
Date: 2016.10.10
Time: 17:48:55
Address 8A: Multicont. Seat Rear,DS (J875) Labels: None
Part No SW: 4H0 907 182 G HW: 4H0 907 182 G
Component: IVB H08 0042
Serial number: 00010539189402
Coding: 304F00
ASAM Dataset: EV_IVBDriveSideRear 001003
VCID: 2E10C61B713F3B3141-807A
Reset counter: 23
Mileage: 62883 km
Date: 2016.10.14
Time: 10:14:37
U1400 00 [008] - -
Fault Frequency: 21
Reset counter: 26
Mileage: 62883 km
Date: 2016.10.10
Time: 17:48:55
Address 8C: Hybrid Battery (J840) Labels: None
Part No SW: 8R0 915 591 HW: 8R0 915 591
Component: BMS H08 0543
Coding: 120200
Shop #: WSC 62190 001 1048576
ASAM Dataset: EV_BECM0722011 004016
ROD: EV_BECM0722011_004.rod
VCID: 78BC2043C3FB3581DB-802C
13775 - Reversible crash shut-off was triggered
P168A 00 [032] - -
Reset counter: 142
Mileage: 62883 km
Date: 2016.09.20
Time: 06:13:18
Pack Voltage: 279.8 V
Pack Current: 15.68 A
Isolation Resistance: 1016 KOhm
Maximum discharge current limit: 156 A
BMS_MaxDyn_EntladeStorm: 180 A
Contactor Voltage: 278 V
Crash status: 00
FAN status: 01
Pilot Line Status: 00
Fuse Status: 00
(Minus) Contactor Status: 01
(Plus) Contactor Status: 01
Terminal 15 status: 01
DFCC: 13775
Max Cell Temperature: 35 °C
Min Cell Temperature: 34 °C
Air inlet temperature: 30 °C
Air outlet temperature: 34 °C
LV Battery Voltage: 13.2 V
Min.cell voltage: 3.875 V
Max.cell Voltage: 3.890 V
Max.cell SOC: 74 %
Min.cell SOC: 73 %
Max Charge Pack Current(10s duration): 65 A
Max Discharge Pack Current(10s duration): 16 A
Max Pack Voltage: 284 V
Min Pack Voltage(10s duration): 272 V
Max.cell Voltage(10s duration): 3.946 V
Min.cell Voltage(10s duration): 3.796 V
Accelerator Pedal Position D: 14.9 %
Calculated LOAD Value: 7.1 %
Engine coolant temperature: 94 °C
Engine RPM: 1597.50 /min
Vehicle Speed Sensor: 74 km/h
Absolute Throtle Position: 14.1 %
distance traveld since fault memory last cleared: 9683 km
control module system voltage: 13.279 V
absolute load: 15.7 %
Time After Engine Start: 3262 /min
8402 - 14V Power System Voltage
Reset counter: 142
Mileage: 62883 km
Date: 2016.10.14
Time: 10:15:51
Pack Voltage: 271.5 V
Pack Current: -0.04 A
Maximum discharge current limit: 105 A
Contactor Voltage: 270 V
Crash status: 00
FAN status: 00
Fuse Status: 00
DFCC: 8402
Max Cell Temperature: 6 °C
Min Cell Temperature: 6 °C
Air inlet temperature: 6 °C
Air outlet temperature: 6 °C
LV Battery Voltage: 8.2 V
Min.cell voltage: 3.767 V
Max.cell Voltage: 3.781 V
Max.cell SOC: 65 %
Min.cell SOC: 63 %
Max Charge Pack Current(10s duration): 0 A
Max Discharge Pack Current(10s duration): 0 A
Max Pack Voltage: 270 V
Min Pack Voltage(10s duration): 270 V
Max.cell Voltage(10s duration): 3.782 V
Min.cell Voltage(10s duration): 3.766 V
Calculated LOAD Value: 0.0 %
Engine coolant temperature: 4 °C
Engine RPM: 0.00 /min
Vehicle Speed Sensor: 0 km/h
Absolute Throtle Position: 16.1 %
control module system voltage: 8.274 V
absolute load: 0.0 %
Time After Engine Start: 0 /min
13744 - HV Battery Pack Air Flow Valve 1
P0AD5 00 [032] - Electrical Malfunction
Reset counter: 142
Mileage: 62883 km
Date: 2016.10.14
Time: 10:17:58
Crash status: 00
FAN status: 00
Fuse Status: 00
DFCC: 13744
LV Battery Voltage: 8.6 V
Max.cell SOC: 65 %
Min.cell SOC: 63 %
Max.cell Voltage(10s duration): 3.781 V
control module system voltage: 8.681 V
Address 8D: Multicont. Seat Rear,PS (J874) Labels: None
Serial number: 00010539176701
Coding: 304F00
ASAM Dataset: EV_IVBPasseSideRear 001003
