- Joined
- Jan 11, 2018
- Messages
- 17
- Reaction score
- 4
- Location
- Switzerland
- VCDS Serial number
- C?ID=325542
Hi VCDS community
I have an VW Caddy which I fitted with a reverse camera, later I would like PLA but first I have to get the camera working Now I wanted to code it but I am not able to get into Controller 37 (or)/56. When I go in 19-CAN Gateway and check the 37 and 56 and save them I get the message that the coding was successful. Go out and then back in controller 19 they are immediately unchecked.So they are not saved.
Am I doing something wrong ? Could somebody help please.
I`m posting here the VCDS log:
Radio unit is an 5C0 035 680 C
I have also to mention that before this scan I got also this fault code which I deleted.
Reset counter: 141
Mileage: 25168 km
Date: 2017.12.19
Time: 16:45:32
Thank you very much in advance.
Thursday,11,January,2018,12:10:26:23311
VCDS Version: 17.8.1.0 (x64) HEX-V2 CB: 0.4409.4
VIN: WV2ZZZ2KZGX075832 License Plate:xxx
Mileage: 25610km-15913mi Repair Order:
Chassis Type: 2K-VN35 (7N0)
Scan: 01 03 08 09 10 13 15 16 17 19 20 22 25 42 44 46 47 4C 52 5F
61 69 76
VIN: WV2ZZZ2KZGX075832 Mileage: 25610km-15913miles
76-Park Assist -- Status: Cannot be reached 1100
Address 01: Engine (J623-DFSE) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 016 GP HW: 04L 907 309 K
Component: R4 2,0L EDC H20 1670
Revision: 8AH20---
Coding: 01190012043615090000
Shop #: WSC 35110 790 50316
ASAM Dataset: EV_ECM20TDI01104L906016GP 001003
ROD: EV_ECM20TDI01104L906016GJ_001_VN35.rod
VCID: 7DA609179D74DE1F317-8028
17158 - Databus
U1123 00 [040] - Received Error Message
Fault Frequency: 20
Mileage: 24878 km
Date: 2017.12.12
Time: 11:37:15
Engine speed: 1678.00 /min
Normed load value: 26.7 %
Vehicle speed: 53 km/h
Coolant temperature: 88 °C
Intake air temperature: 47 °C
Ambient air pressure: 940 mbar
Voltage terminal 30: 14.920 V
Unlearning counter according OBD: 22
Drivetrain coordinator: ACC fault status-Bit 0: 0
Drivetrain coordinator: ACC fault status-Bit 8: 0
Drivetrain coordinator: brake fault status-Bit 0: 4
Drivetrain coordinator: brake function status-Bit 0: 0
Drivetrain coordinator: brake function status-Bit 8: 0
Acceleration: 0.578 m/s²
12888 - Implausible Data Received from ABS Control Module
U0415 00 [040] - -
Mileage: 24878 km
Date: 2017.12.12
Time: 11:37:15
Engine speed: 1679.50 /min
Normed load value: 25.5 %
Engine status: COENG_RUNNING
Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 3
28991 - No Communications with NOX Sensor 1
U029D 00 [040] - -
Mileage: 25231 km
Date: 2017.12.23
Time: 00:00:09
Coolant temperature: 15 °C
Intake air temperature: 14 °C
Voltage terminal 30: 11.020 V
Unlearning counter according OBD: 19
Limitation: accelerator pedal: 126.6 Nm
CAN status - engine control module-Bit 0: 0
Cruise Control System (CCS): status-Bit 0: 2
CAN status - transmission control module-Bit 0: 8
CAN status - brake control module 1-Bit 0: 0
CAN status - brake control module 2-Bit 0: 0
selected gear-Bit 0: 0
18109 - Oxygen (Lambda) Sensor B1 S1: Heating Circuit
P0031 00 [104] - Short to Ground
Mileage: 25231 km
Date: 2017.12.23
Time: 00:00:09
Intake air temperature: 13 °C
Voltage terminal 30: 11.080 V
Unlearning counter according OBD: 20
Oxyg.sens.bank 1 before oxi cat: sign. qual. pump curr.regul.: 13
Oxyg.sensor bank 1 before oxi cat: signal quality temp regulat.: 13
O2 sen. bank 1 upstrm oxi cat: elec. correct. pump current: 0.0000000 A
Oxygen sensor bank 1 before oxi cat: heater activation: 0.000 %
O2 sen. bank 1 upstrm oxi cat: elec. corrected Urie sen. value: 0.0000 V
Oxygen sensor bank 1 before oxi cat: adjustable resistor: 0.0 Ohm
Oxyg.sensor bank 1 before oxi cat: curr.pump curr.adaptation: 1.0037
Readiness: 0 2 0 0 0
Address 03: ABS Brakes (J104) Labels:. 7E0-907-37x-MK100ESC.clb
Part No SW: 7E0 907 379 P HW: 7E0 907 379 M
Component: ESC H05 0132
Revision: 00000000 Serial number: 43365000001222
Coding: 1079809BB369A483087D0179CD84259378F150
ROD: EV_Brake1ESCCONTIVN75XGP2_011_VN35.rod
VCID: 3FDAB31FD7F80C0F63B-806A
0039 - Front Left Wheel Speed Sensor
C101A 4A [008] - Incorrect component(s) installed
Reset counter: 128
Mileage: 24927 km
Date: 2017.12.12
Time: 21:00:53
0041 - Front Left Wheel Speed Sensor
C101A 29 [008] - Signal Implausible
Reset counter: 144
Mileage: 24878 km
Date: 2017.12.12
Time: 11:37:15
0047 - Front Left Wheel Speed Sensor
Reset counter: 132
Mileage: 24921 km
Date: 2017.12.12
Time: 13:47:29
0297 - Steering angle sensor
B1168 54 [008] - Missing Calibration / Basic Setting
Reset counter: 138
Mileage: 25201 km
Date: 2017.12.22
Time: 00:10:47
4193 - Front Left Wheel Speed Sensor
C101A 14 [008] - Open or Short to Ground
Reset counter: 128
Mileage: 24922 km
Date: 2017.12.12
Time: 20:47:58
Part No SW: 1K8 907 044 BE HW: 1K8 907 044 BE
Component: Climatronic H07 0405
Revision: 00001K04
Coding: 051000C003
ROD: EV_ClimaAutoBasis_VW32.rod
VCID: 73B22F2FAB30986F573-8026
Part No SW: 5K0 937 086 AA HW: 5K0 937 086 AA
Component: BCM PQ35 M+ 122 0183
Revision: BD122001
Coding: 611A0A3A8025086F088800889400896C03D50008426D8120E484C7000041
Shop #: WSC 35110 377 00143
VCID: 73B22F2FABB0986F573-8026
Subsystem 1 - Part No: 2K1 955 119 D Labels: 1KX-955-119.CLB
Component: Wischer 18111 26 0512
Coding: 009795
Subsystem 2 - Part No: 5K7 955 559 B Labels: 5K7-955-559.CLB
Component: RLS 071215 03 37 0059
Coding: 0228DD
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-283.clb
Part No SW: 1K8 919 465 HW: 5Q0 919 283
Component: PARKHILFE 4K H10 0479
Revision: -------- Serial number: 39291533202609
Coding: 0001050101
ASAM Dataset: EV_EPHVA14VW364GP00 001006
ROD: EV_EPHVA14VW364GP00.rod
VCID: 76B4163BB8428D4770D-8022
Address 13: Auto Dist. Reg (J428) Labels:| 7N0-907-572.clb
Part No SW: 7N0 907 572 A HW: 7N0 907 572
Component: ACC Bosch PQx H03 0111
Serial number: 03121577170156
Coding: 00000800FE0339
ASAM Dataset: EV_ACCBEGVW361 001004
ROD: EV_ACCBEGVW361_SK34.rod
VCID: 3430EC33EEBEDF578E9-8060
10 Faults Found:
1067 - Brake Temperature
C10DF 00 [008] - -
Fault Frequency: 20
Reset counter: 143
Mileage: 24878 km
Date: 2017.12.12
Time: 11:37:15
Control Module temperature: 17 °C
Voltage terminal 15: 14.8 V
Vehicle speed: 14.48 m/s
Acceleration: 0.07 m/s²
1058 - Databus
Fault Frequency: 17
Reset counter: 143
Mileage: 24878 km
Date: 2017.12.12
Time: 11:37:15
Vehicle speed: 14.49 m/s
Acceleration: 0.02 m/s²
1059 - Databus
Fault Frequency: 17
Reset counter: 143
Mileage: 24878 km
Date: 2017.12.12
Time: 11:37:15
Acceleration: -0.03 m/s²
1118 - Databus
Fault Frequency: 13
Reset counter: 143
Mileage: 24878 km
Date: 2017.12.12
Time: 11:37:15
1119 - Databus
Reset counter: 132
Mileage: 24927 km
Date: 2017.12.12
Time: 21:00:55
Control Module temperature: 16 °C
Voltage terminal 15: 12.9 V
Vehicle speed: 0.00 m/s
Acceleration: 0.00 m/s²
1081 - Databus
Fault Frequency: 13
Reset counter: 143
Mileage: 24878 km
Date: 2017.12.12
Time: 11:37:15
1082 - Databus
Reset counter: 132
Mileage: 24927 km
Date: 2017.12.12
Time: 21:00:55
1042 - Databus
Reset counter: 143
Mileage: 24927 km
Date: 2017.12.13
Time: 13:50:22
Control Module temperature: 9 °C
Voltage terminal 15: 11.9 V
1542 - Sensor for Automatic Distance Control
Reset counter: 162
Mileage: 24489 km
Date: 2017.11.27
Time: 11:39:11
Control Module temperature: 14 °C
Voltage terminal 15: 14.6 V
Vehicle speed: 11.20 m/s
Acceleration: -0.36 m/s²
1545 - Sensor for Automatic Distance Control
Reset counter: 162
Mileage: 24489 km
Date: 2017.11.27
Time: 11:39:11
Part No SW: 2K5 959 655 A HW: 2K5 959 655 A
Component: VW10Airbag01A 008 0016
Revision: -------- Serial number: 003QX000Z4FU
Coding: 000000000000000000000000000000003141
ASAM Dataset: EV_AirbaVW10BPAVW12X 001028
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 3A2CC20BCCDA2927545-806E
Serial number: 3497ARB405B3QND8D0IN
Serial number: 3507ARB405D3P6GKE1GE
Serial number: 3517ARB405B3QND840H6
Serial number: 3527ARB405B3QND8JGG.
Part No SW: 5K0 953 521 GE HW: 5K0 953 569 BF
Component: LENKS.MODUL 018 0230
Revision: FF010042 Serial number: 20151124100762
Coding: 1082460008
ROD: EV_SMLSNGVOLWSR8C.rod
VCID: 75B61137A544865F797-8020
Subsystem 1 - Part No SW: 2K0 959 442 HW: 2K0 959 442 Labels: 3C8-959-537.CLB
Component: E221__MFL-TAT H06 0023
Serial number: 3201523525902330BA1B
Coding: 280000
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb
Part No SW: 2K5 920 876 A HW: 2K5 920 876 A
Component: KOMBI H04 1009
Coding: 180A011100
ROD: EV_Kombi_UDS_VDD_RM09_005_VN35.rod
VCID: 3332EF2FEBB0D86F973-8066
Part No SW: 7N0 907 530 BC HW: 7N0 907 530 AN
Component: J533 Gateway H56 1663
Revision: H56 Serial number: 221115F1001085
Coding: 357430
VCID: 72BC2A2BD4AA91675C5-8026
01327 - Control Module for Parking Aid (J446)
Reset counter: 122
Mileage: 25615 km
Date: 2018.01.11
Time: 00:40:37
Reset counter: 122
Mileage: 25617 km
Date: 2018.01.11
Time: 06:14:06
Address 20: High Beam Assist. (J844) Labels:| 8S0-857-511.clb
Part No SW: 7E0 857 511 F HW: 7E0 857 511 C
Component: FLA H10 0003
Revision: AA001001
Coding: 020200E700000000000000
ASAM Dataset: EV_HighBeamAssisAU316 001004
ROD: EV_HighBeamAssisAU316_VW36.rod
VCID: 2D06F9570D948E9FC17-8078
Address 22: AWD (J492) Labels:* 0CQ-907-554.clb
Part No SW: 0AY 907 554 J HW: 0CQ 525 130
Component: Haldex4Motion H52 7540
Serial number: HA1-00029.10.15
Coding: 0501
ROD: EV_AllWheelContrHA1VW37X_002_VW36.rod
VCID: 52FC8AAB746AF167BC5-8006
Component: IMMO H04 1009
VCID: 6A8C324BFCFA59A7E45-803E
Address 42: Door Elect, Driver Labels: None
Part No SW: 2K5 959 701 A HW: 2K5 959 701 A
Component: Tuer-SG 009 2143
Coding: 0136242
VCID: 323CEA2B182AD1679C5-8066
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 140 3501
Revision: 00H22000
VCID: 392EDD07C55C223F5DF-806C
Fault Status: 00101101
Fault Frequency: 14
Reset counter: 143
Mileage: 25270 km
Date: 2017.12.25
Time: 19:55:08
Voltage: 14.88 V
DU
Temperature: 14.0°C
RPM: 1677 /min
Speed: 37.0 km/h
Speed: 37.0 km/h
Address 47: Sound System
Address 4C: Tire Pressure II
Address 52: Door Elect, Pass. Labels: None
Part No SW: 2K5 959 702 A HW: 2K5 959 702 A
Coding: 0136242
VCID: 3332EF2FE730D86F973-8066
Part No SW: 5C0 035 680 C HW: 5C0 035 680 C
Component: MU-S-ND-ER H22 0245
Serial number: VWZAZ2R8074182
Coding: 06330701BE00000011111101008808031F0100C400200100CF
ROD: EV_MUStd4CTSAT_SK25.rod
VCID: 211E1567414C5AFF75F-8074
Part No SW: 7N0 907 534 HW: 7N0 907 530 AN
Component: Batt.regelung H56 1663
Coding: 330F1873
VCID: 71BE2527D1ACAA7FA5F-8024
Subsystem 1 - Part No SW: 1K0 915 181 K HW: 1K0 915 181 K
Component: J367-BDM H07 0223
Serial number: 32324E36498761077103
Address 69: Trailer (J345) Labels:. 1K0-907-383-V2.clb
Part No SW: 1K0 907 383 H HW: 1K0 907 383 G
Component: Anhaenger H12 0130
Revision: 3B001001 Serial number: 00000387901992
Coding: 010D000103000000
VCID: 323CEA2B142AD1679C5-8066
Address 76: Park Assist (J791) Labels:* None
Coding: 0001050101
End----------(Elapsed Time: 01:20, VBatt start/end: 12.4V/12.3V)-----------
Reset counter: 141
Mileage: 25168 km
Date: 2017.12.19
Time: 16:45:32
