2013 CC 3.6 4motion P310B error
zoidmk5
C?ID=47344
i have been getting this error for several months in my 2013 CC 3.6 4motion. sometimes the CEL comes on, sometimes it doesn't. often times, the car will also die, sometimes when stopped at a stop light, or even while driving at slow(er) speeds. i have also always noticed a knocking sound coming from the rear for about a year now when stopped and when shutting off the car. a friend told me to replace the below part, which i have twice now:
https://www.pelicanparts.com/cgi-bi...6.cgi?command=DWsearch&description=06j906051c
when i replace it and clear the code, the car doesn't die at all, but i may or may not still get the light after a day or so of driving. i also have this part on the way right now:
https://www.pelicanparts.com/More_I...5PRPq3dMuW4lF0chhlsZgPhA-6AAYqKEaAgYvEALw_wcB
perhaps this will fix the issue??? i'm really curious about the knocking noise i am getting from the rear as well, thinking maybe something is going on with one of the pumps?
here are my logs from VAGCOM
Sunday,31,March,2019,15:44:37:37698
VCDS Version: 18.9.1.0 (x64)
VIN: WVWGU7AN0DE509584   License Plate: 03312019
                Address 01: Engine       Labels: None
Control Module Part Number: 03H 906 023 R    HW: 03H 907 309 A
  Component and/or Version: 3,6 FSI ULEV2 H04 1811
           Software Coding: 001A0012242600000000
            Work Shop Code: WSC 00015 115 00000
              ASAM Dataset: EV_ECM36FSI01103H906023R 002003 (VW46)
                       ROD: EV_ECM36FSI01103H906023AJ.rod
                      VCID: 3162A48260BA18C262-8064
2636 - Low Pressure Fuel regulation
          P310B 00 [236] - Fuel Pressure Outside Specification
                    Mileage: 145579 km
                    Date: 2078.14.19
                    Time: 15:21:33
                    Engine speed: 646.00 /min
                    Normed load value: 23.1 %
                    Coolant temperature: 90 °C
                    Intake air temperature: 30 °C
                    Voltage terminal 30: 14.300 V
                    Fuel pump: specified value: 43.329 %
                    Low fuel pressure: specified value: 437.8 kPa
                    Fuel temperature: 78.8 °C
                    Adaptation of Fuel Pump (FP): 76.6 kPa
                    High fuel pressure: specified value: 4.5000 MPa
                    Fuel low pressure: actual value: 277.0 kPa
                    High pressure regulation: adaptation value: 0.0000 MPa
2637 - Low Pressure Fuel regulation
          P310B 00 [237] - Fuel Pressure Outside Specification
                    Mileage: 145579 km
                    Date: 2078.14.19
                    Time: 15:19:34
                    Engine speed: 647.50 /min
                    Normed load value: 27.5 %
                    Intake air temperature: 23 °C
                    Voltage terminal 30: 14.159 V
                    Fuel pump: specified value: 49.664 %
                    Low fuel pressure: specified value: 371.0 kPa
                    Fuel temperature: 70.5 °C
                    Fuel low pressure: actual value: 366.0 kPa
Readiness: 0000 0100
this is all of the fuel values while sitting idle in my driveway:
Sunday,31,March,2019,15:48:32:37698
VIN: WVWGU7AN0DE509584   License Plate: 03312019 VALUES
                Address 01: Engine  (03H 906 023 R)
15:48:22
  IDE00186   Fuel low pressure: actual value 521.2 kPa
  IDE00188   Fuel high pressure: actual value 4.5105 MPa
  IDE00201   High fuel pressure: specified value 4.5000 MPa
  IDE00202   Low fuel pressure: specified value 509.2 kPa
  IDE00407-ENG57549   Rail pressure regulation: status-Bits 0-7 00000001
  IDE00589   Fuel pressure 4370 kPa rel
  IDE01378   High fuel pressure: control deviation 0.0080 MPa
  IDE01887   Adaptation of Fuel Pump (FP) 11.8 kPa
  IDE01893   Fuel pump: specified value 59.500 %
  IDE01930   High pressure regulation: adaptation value 0.0000 MPa
  IDE01932   High pressure pump injection volume -3.47 mm³
  IDE06040   High fuel pressure: regulator output value -0.0240 MPa
PetrolDave
Westbury, UK
C?ID=1423
A full Auto-Scan might be helpful too, not just a small edited section.
zoidmk5
C?ID=47344
this wasn't edited, just a scan straight from the Engine module. everything else in an autoscan is fine
Vehicle Identification No.WVWGU7AN0DE509584
ModelPassat CC 4Motion
CC
Date of production10.05.2012
Year2012
Sales type3584UQ
Engine CodeCNNA
Transmission CodeKFD
Emission standard7GBEmission standard ULEV 2
VIN: WVWGU7AN0DE509584 Mileage: 145579 km <<<<<<<<<<<<< Car under warranty?
Control Module Part Number: 03H 906 023 R HW: 03H 907 309 A <<<<<<<<<<<<<< NOT FOD!
A full auto-scan as aforementioned and OBD2 MODE's 1,3,7 & 9 please.
Did you read this OP & JPPSG?
https://forums.ross-tech.com/showth...uot-JPPSG-quot&p=156577&viewfull=1#post156577
zoidmk5
C?ID=47344
no existing warranty. i know 2.0T CC's have the fuel pump recall, but nothing seems to correlate to the 3.6
here is an autoscan from January i have on my work computer which has the same code:
Sunday,27,January,2019,17:23:59:37698
VCDS Version: 18.9.0.2
Mileage: 143170km-88961mi   Repair Order:
Chassis Type: AN-VW46 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 22 25 2E 36 37 42 44 46 47 4F
          52 53 55 56 61 62 65 6C 72 77
VIN: WVWGU7AN0DE509584   Mileage: 143170km-88961miles
65-Tire Pressure -- Status: Cannot be reached 1100
Address 01: Engine (0-32-CNNA)       Labels: None
   Part No SW: 03H 906 023 R    HW: 03H 907 309 A
   Component: 3,6 FSI ULEV2 H04 1811
   Revision: MFH04---    Serial number: 00000000000000
   Shop #: WSC 00015 115 00000
   VCID: 3162A48260BA18C26A-8064
          P310B 00 [172] - Fuel Pressure Outside Specification
                    Mileage: 143114 km
                    Date: 2019.01.27
                    Time: 13:52:50
                    Engine speed: 647.00 /min
                    Normed load value: 25.1 %
                    Coolant temperature: 88 °C
                    Intake air temperature: 41 °C
                    Voltage terminal 30: 14.206 V
                    Fuel pump: specified value: 53.131 %
                    Low fuel pressure: specified value: 407.5 kPa
                    Fuel temperature: 75.0 °C
                    Adaptation of Fuel Pump (FP): 198.8 kPa
                    Fuel low pressure: actual value: 402.9 kPa
   Part No SW: 09G 927 750 MH    HW: 09G 927 750 MH
   Component: AQ 250 6F           1961
   Revision: 00H90000    Serial number:
   Coding: 0000840
   Shop #: WSC 05311 000 00000
   VCID: 030E3E4A42865A52C8-8056
   Part No SW: 3AA 614 109 AF    HW: 3AA 614 109 AF
   Component: J104   C2 450M V4DF 0023
   Revision: --H07---    Serial number: 00000005675232
   Coding: 0000411
   VCID: 71E26482683A58C22A-8024
   Part No SW: 3AA 907 044 J    HW: 3AA 907 044 J
   Component: Climatronic   H03 0101
   Revision: 00001K03
   Coding: 0010001008
   VCID: 37769A9A8EDEC6F224-8062
          B10AB F0 [009] - Too Low
                    Reset counter: 131
                    Mileage: 139856 km
                    Date: 2018.10.12
                    Time: 15:05:33
Address 09: Cent. Elect.        Labels: None
   VCID: 55AA3012BC9214E2D6-FFFE
No Faults Found
Address 10: Park/Steer Assist (J446)       Labels:| 3AE-919-475.clb
   Part No SW: 3AE 919 475 B    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0016
   Revision: --------    Serial number: 28261211903922
   Coding: 308104
   ASAM Dataset: EV_EPHVA18VW47X0000 001005
   ROD: EV_EPHVA18VW47X0000.rod
   VCID: 3E788FBEA1E4F7BAE7-806A
   Part No SW: 5N0 959 655 T    HW: 5N0 959 655 T
   Component: J234__714 VW10 HI   2118
   Revision: 24017000    Serial number: 003LDP8JK6WI
   Coding: 0012596
   VCID: 4E98DF7ED944673A17-801A
   Subsystem 1 - Part No: 3C8 959 339 A
   Subsystem 2 - Serial number: 000000000085BS
   Subsystem 3 - Serial number: 0020.03.120000300000630065ÿ†63
   Subsystem 4 - Serial number: 630065ÿ†6332MTS611130962 ÿ†63
   Subsystem 5 - Serial number: 30962 ÿ†6342MTS682710952 ÿ†63
   Subsystem 6 - Serial number: 10952 ÿ†6351HTS674E72BKR ÿ†63
   Subsystem 7 - Serial number: 72BKR ÿ†6361HTS6BE2U1BKJ ÿ†63
   Subsystem 8 - Serial number: U1BKJ ÿ†63727TS6AAIE1BKJ ÿ†63
   Subsystem 9 - Serial number: E1BKJ ÿ†63827TS66M5F1BKJ ÿ
   Subsystem 10 - Serial number: F1BKJ ÿ
   Part No SW: 3C5 953 501 BG    HW: 5K0 953 569 T
   Revision: FF010041    Serial number: 20120426100291
   Coding: 099A270000
   VCID: 6BDE76EA8216B21210-803E
   Coding: E30000
   Part No SW: 3C8 920 980 T    HW: 3C8 920 980 T
   Component: KOMBI         H04 0407
   Coding: 240F01
   Shop #: WSC 05314 115 12345
12658432 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 124
                    Mileage: 139135 km
                    Date: 2018.10.05
                    Time: 14:24:50
   Part No SW: 7N0 907 530 Q    HW: 1K0 907 951
   Component: J533  Gateway H41 1623
   Revision:   H41       Serial number: 210412F2003480
   Coding: 469006
   Shop #: WSC 05314 000 00000
   VCID: 3E788FBEA9E4F7BAE7-806A
                    Reset counter: 124
                    Mileage: 139135 km
                    Date: 2013.02.25
                    Time: 14:24:56
   Part No SW: 0BS 907 554 C    HW: 0BS 907 554 C
   Component: Haldex 4Motion      4016
   Coding: 0000005
   VCID: 4688E75E3134AF7AAF-8012
   Part No SW: 3AA 959 433 A    HW: 3AA 959 433 A
   Component:    IMMO         042 0400
   Revision: 00042000    Serial number: VWZCZ000000000
   VCID: 37769A9A46DEC6F224-8062
   Revision: A1001003    Serial number: 7662401608
   VCID: 29524CE2406A6002A2-807C
Address 36: Seat Mem. Drvr (J810)       Labels: 3C0-959-760.lbl
   Part No SW: 3C8 959 760 B    HW: 3C8 959 760 B
   Component: Sitzmemory    H02 1001
   Revision: 00H02000
   Coding: 000039
   Shop #: WSC 40022 666 40022
   VCID: 346CAD9697A82DEA01-8060
   Part No SW: 3C8 035 684 E    HW: 3C8 035 684 E
   Component: RNS-MID       H65 3696
   Revision: AB001001    Serial number: VWZ6Z7M9115083
   Coding: 04050002010000A6000F
   VCID: 2D5AB8F274827C224E-8078
                    Fault Frequency: 242
                    Reset counter: 223
                    Mileage: 139128 km
   Part No SW: 3C8 959 701     HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0551
   Revision: 12110009    Serial number: 0004824854
   Coding: 0015BF
   Shop #: WSC 05311 115 00000
   VCID: 6DDA78F2BC02BC220E-8038
   Slave Driver:
   Subsystem 1 - Part No SW: 3C8 959 703 D    HW: 3C8 959 795   Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  004 0501
   Serial number: 00000002842171
   Coding: 010498
   Part No SW: 5N1 909 144 M    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.304 1002
   Revision: 1AH03734    Serial number: 00121050006901
   Coding: 0000258
   VCID: 3C7C85B67FF8E5AAC9-8068
   Component:    KSG PQ47 ELV 042 0634
   Coding: 1B910F8001860E763606141FF08A8F0E105801
   Shop #: WSC 05311 123 12345
   Part No SW: 3C8 035 456 C    HW: 3C8 035 456 C
   Component: DSP 10 Kanal        0070
   Revision: 00H07001    Serial number: 75805005271911
   VCID: 285449E69B60590ABD-807C
                    Fault Status: 00101011
                    Reset counter: 2
                    Mileage: 142862 km
                    Date: 2013.06.01
                    Time: 15:51:37
   Component: EZE_2         H41 1623
   Coding: 01030108
   VCID: 6FE662FABE0E4E323C-803A
   Subsystem 1 - Part No SW: 6R0 959 591     HW: 6R0 959 591
   Component: J245/J878  H04 0054
   Serial number: 215500015795
   Coding: 000006
   Subsystem 2 - Part No SW: 3C8 919 204 A    HW: 3C8 919 204 A
   Component: Analoguhr  005 0003
   Part No SW: 3C8 959 702     HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0551
   Revision: 14110009    Serial number: 0004809238
   Coding: 0015BE
   ROD: EV_TSGBPQ35BRFVW46X_VW46.rod
   VCID: 6ED87FFEB104473A37-803A
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C8 959 704 D    HW: 3C8 959 794   Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  004 0501
   Serial number: 00000002862941
   Coding: 010498
Address 53: Parking Brake
   Component: AFS-ECU       H04 0111
   Coding: 071A00010B000400
   Subsystem 1 - Part No SW: 1T0 941 329     HW: 1T0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H06 0007
   Coding: 350000
   Subsystem 2 - Part No SW: 1T0 941 329     HW: 1T0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H06 0007
   Coding: 350000
                    Reset counter: 223
                    Mileage: 139128 km
   Component: Batt.regelung H41 1623
   Coding: 03260172
   VCID: 71E26482A83A58C22A-8024
   Subsystem 1 - Part No SW: 3AA 915 181 A    HW: 3AA 915 181 A
   Component: J367-BDM  H08 0181
   Serial number: 00000000004970298947
Address 65: Tire Pressure
   Part No SW: 3C8 907 441     HW: 3C8 907 441
   Revision: 00H11000    Serial number: 525PA8-J231719
   Coding: 0120008
   VCID: 67D60ADA56FE967274-8032
   Part No SW: 5K0 035 730 E    HW: 5K0 035 730 E
   Component: TELEFON       H09 2902
   Revision: 1B001001    Serial number: 00007662437720
   Coding: 0A10040000010110
   ASAM Dataset: EV_UHVNA A01719
   ROD: UHVNA.rod
   VCID: 27564ADA5E7E5672B4-8072
End---------------------(Elapsed Time: 04:22, udsna)-----------------------
zoidmk5
C?ID=47344
is this autoscan above good enough to get some sort of input?
If a P code is demonstrated with an illuminated MIL for a system that is interrelated with useful life, is it not under warranty under EPA and CARB?
Are you sure because this warranty is extended for 10-120 and 15-150K?
Please post the data I requested for OBD2 MODE 1,3-7 & 9
Then reset the fault memory and re-post a fresh new auto-scan........
Been here?
http://wiki.ross-tech.com/wiki/index.php/P310B/012555
Dana
Western PA, USA
Yes it is. P310B is specific to the low-side so making sure G410 is OK followed by checking the in-tank fuel pump would be the best place to start. Ideally, you would want to check low side measuring blocks and the actual low-side pressure with a gauge when the car is acting up (which could be difficult).
Edit, although this is an issue with early FSI engines, and the noise in the rear of the car sounds like an in-tank issue worth chasing, make sure the replacement sensors are the correct part numbers:
https://forums.ross-tech.com/showth...High-Thrust-Sensor-quot-There-is-a-difference!
zoidmk5
C?ID=47344
Been here?
yes, i have been to that link, but was seeking more clarity here.
as for the warrenty, i more so meant that there isn't any existing warranty on the car, thats not to say that any individual part warranty, TSB or recall isn't in effect. last i checked, there are no recalls on my car other than the Takata airbag
zoidmk5
C?ID=47344
when this new sensor comes in the mail, hopefully by Wednesday, we will see what result that give me. its often hard to tell if a sensor change gives me a good result, as this other sensor has shown, the physical issues disappear (shutting off, stuttering, etc.) and MIL, but the code often reappears after a day or so of driving
If your car isn't modified it's under warranty!
15/150?
zoidmk5
C?ID=47344
okay Jack, per your request...Mode's 5 and 6 were grayed out, so i couldn't gather any of that information. can you please explain why going through OBDII is giving me this separate code that is not given through an Autoscan or through the Engine Module? i have never used this function before, so i have trouble understanding it
Monday,01,April,2019,16:18:51:37698
VIN:    License Plate: MODE1
VCDS Release 18.9.1 (x64):  Generic OBD2
Mode 1:Read Data
03:Fuel system 1/2 status     Closed loop,  using O2 sensors  Closed loop,  using O2 sensors
23:Fuel Rail Press (rel)     4410 kPa rel
Mode 03: Emission related fault codes
Address 7E8: 1 Fault Found:
P0089 - Valve for Fuel Metering (N290): Implausible Signal
Address 7E9: No fault code found.
Monday,01,April,2019,16:20:23:37698
VIN:    License Plate: MODE3
Monday,01,April,2019,16:20:49:37698
VIN:    License Plate: MODE7
Mode 07: Pending emission related fault codes
Monday,01,April,2019,16:28:35:37698
VIN: WVWGU7AN0DE509584   License Plate: MODE9
Mode 9 : Calibration Identification
Type 02 - VIN : WVWGU7AN0DE509584 (Address E8)
Type 04 - Calibration ID : 03H906023R Q1811 (Address E8)
Type 04 - Calibration ID : 09G927750MH 1961 (Address E9)
Type 06 - Calibration Verification Number : F2D1C0C2 (Address E8)
Type 06 - Calibration Verification Number : A994B632 (Address E9)
Type 08 - In-use performance tracking :
    OBD Monitoring Conditions Encountered count : 2714
    Ignition cycle count : 6247
    Conditions completion count / Specified conditions encountered count
         Catalyst monitor bank 1 : 4235 / 2714
         Catalyst monitor bank 2 : 4223 / 2712
         O2 Sensor monitor bank 1 : 4326 / 2714
         O2 Sensor monitor bank 2 : 4307 / 2712
         EGR-VVT monitor : 3872 / 2714
         AIR monitor : 0 / 0
         EVAP monitor : 489 / 627
         Secondary O2 Sensor monitor bank 1 : 4280 / 2714
         Secondary O2 Sensor monitor bank 2 : 4265 / 2712
Type 0A - Controller Name : ECM-EngineControl (Address E8)
Type 0A - Controller Name : TCM-TransmisCtrl (Address E9)
Monday,01,April,2019,16:33:57:37698
VIN: WVWGU7AN0DE509584   License Plate: 04012019
Mileage: 145620km-90484mi   Repair Order:
          52 53 55 56 61 62 6C 72 77
VIN: WVWGU7AN0DE509584   Mileage: 145620km-90484miles
Readiness: 1110 0101
   Coding: 0000840
   VCID: 030E3E4A42865A52C0-8056
   Component: J104   C2 450M V43A 0023
   Coding: 0000411
   VCID: 71E26482683A58C222-8024
   Revision: 00001K03
   Coding: 0010001008
   VCID: 37769A9A8EDEC6F22C-8062
   Part No SW: 3AA 937 087 J    HW: 3AA 937 087 J
   Component: BCM PQ47 H++  421 0465
   Revision: BD421001
   Coding: 000800000000000000880281B400090C2055000861200D20E484462400C1
   VCID: 4182F442D81A884292-8014
   Subsystem 1 - Part No SW: 3C8 955 119 F    HW: 3C8 955 119 F  Labels: 1KX-955-119.CLB
   Component: WWS464 300312  010 0604
   Serial number: 300312
   Coding: 00B795
   Subsystem 2 - Part No SW: 7N0 955 559     HW: 7N0 955 559   Labels: 7N0-955-559.CLB
   Component: RLFS  021 0024
   Serial number: Y12M04D24h03m41s54S4
   Coding: 0280DD
   Coding: 308104
   VCID: 3E788FBEA1E4F7BAEF-806A
   Coding: 0012596
   VCID: 4E98DF7ED944673A1F-801A
   Coding: 099A270000
   VCID: 6BDE76EA8216B21218-803E
   Coding: E30000
   Coding: 240F00
   Coding: 469006
   Shop #: WSC 05314 123 12345
   VCID: 3E788FBEA9E4F7BAEF-806A
                    Fault Status: 01110100
                    Reset counter: 0
                    Mileage: 144002 km
                    Date: 2013.07.08
                    Time: 09:40:03
   Coding: 0000005
   VCID: 4688E75E3134AF7AA7-8012
   VCID: 37769A9A46DEC6F22C-8062
   VCID: 29524CE2406A6002AA-807C
   Revision: 00H02000
   Coding: 000039
   VCID: 346CAD9697A82DEA09-8060
   VCID: 2D5AB8F274827C2246-8078
                    Fault Frequency: 109
                    Reset counter: 57
                    Mileage: 144008 km
   Coding: 0015BF
   VCID: 6DDA78F2BC02BC2206-8038
   Slave Driver:
   Coding: 010498
   Coding: 0000258
   VCID: 3C7C85B67FF8E5AAC1-8068
   Coding: 1B910F8001860E763606141FF08A8F0E107801
   VCID: 285449E69B60590AB5-807C
                    Reset counter: 96
                    Mileage: 145554 km
                    Date: 2013.08.14
                    Time: 18:37:19
   Coding: 01030108
   VCID: 6FE662FABE0E4E3234-803A
   Coding: 000006
   Coding: 0015BE
   VCID: 6ED87FFEB104473A3F-803A
   Slave Passenger:
   Coding: 010498
   Revision:   H19       Serial number: 00000000158915
   Coding: 0022156
   VCID: 3668979E41D43FFA37-8062
   Shop #: WSC 05311 115 12345
   Coding: 350000
   Coding: 350000
                    Reset counter: 57
                    Mileage: 144008 km
   Coding: 03260172
   VCID: 71E26482A83A58C222-8024
   Coding: 0120008
   VCID: 67D60ADA56FE96727C-8032
   ROD: UHVNA.rod
   VCID: 27564ADA5E7E5672BC-8072
End-------------------------(Elapsed Time: 04:04)--------------------------
Strange huh, most likely the stack in the ECU is inconsistent but to get clarity from RT just in case a label file is an issue?
  • On some engines, the N276 may be refered to as the N290 in the factory wiring diagram.
Well I'm led to believe that the HPP or cam follower are for shit and most likely under useful life warranty even if a bad pump in tank or regulator with filter & as an AECD aren't you?
Does your maintenance manual require a filter with regulator to be changed as maintenance?
zoidmk5
C?ID=47344
thats the way it would seem. the HPFP on the 3.6 isn't nearly as easy to take apart to inspect as the 2.0T was in my MKV. and luckily the follower in these are a roller instead of a flat surface like the older versions. my new sensor should be here tomorrow and we'll see what that does. going out of town for the weekend and when i get back, might fool with the HPFP if time and weather permits.
zoidmk5
C?ID=47344
sensor came in and i installed it last night. put about 15 miles on the car, and so far so good. lets hope this solved it
Are you going to get reimbursed for such a AECD failure part and repair & needed under useful life warranty, is the real question?
zoidmk5
C?ID=47344
well, took a road trip to my brothers house over the weekend, (2 hours each way), and the CEL came back on with the same code. i found a thread from about a year ago on VWVortex about someone having the same issue, and he took it to the dealer and they replaced the intank pump, which cost him close to $800 for parts and labor.
how would YOU go about getting the dealer to either do the work under the useful life warranty, or submitting to be reimbursed for it?
Wouldn't you see a professional that is licensed, which can verify diagnosis for the problem & that is indeed covered an or related to the warranty or TSB for reimbursement & further contact the OEM advocate email center to start a claim + dealer for such clarity of diagnosis again all in writing to start the attempt?
zoidmk5
C?ID=47344
rather than going to a third party "licensed professional", why should i not go straight to the dealer and have it squared away that way? i'm not fully understanding what you are trying to say.
to ask the same question in further detail. the guy in that thread had them fix the issue and was charged for such. according to you, this should be covered under the EPA/CARB warranty. how would i go about going straight to the dealer, without third party involvement, and have them diagnose and fix the issue, be in intank pump, HPFP, etc., and have it covered under said warranty? what literature would i need to stand on to ensure that they cover the cost of this repair?
