2012 Audi A8L Starting Issues
bn1990
C?ID=351416
I am trying to diagnose a problem with my car and would like some assistance if possible. Generally the car starts well in the morning after sitting all night. Various times throughout the day it will stutter initially and then die right after starting it. Only way to get it to start is to hold the gas pedal down or pump it until it starts. After that it will run rough and then eventually smooth out and run. The car doesn't feel as responsive as it was when I bought it within the past year. I just went over 100,000 miles this week.
I have the VCDS software at version 19.6.2 and I have been running code scans for the last few months. Today is the first time that it had trouble first thing in the morning. It started very rough and would not idle. It would idle very roughly and then shut off. When running rough the exhaust pipes were visibly shaking and there was vapor coming out the pipes that really didn't have a smell but was dirty. Held my hand to it and it looked like oily water vapor spitting over my hand.
I have posted about this on Audiworld.com and did receive some feedback. One respondent in particular said that he had what seems to be the same issue as mine (his was one year older) and it ended up being the high pressure fuel pumps that needed to be replaced. I have already had the spark plugs replaced and an intake cleaning performed by a repair shop. That did not solve the problem or improve it at all.
I have monitoring the fuel trim (short and long term) using VCDS and the values are clearing out of spec. I just checked it this morning and the long term values are -45% on both banks and the short term is at 25% on both banks. Engine controller codes are reporting rich conditions. The check engine light comes on for a while and after a few engine cycles will go away.
After finally getting the car to run smoothly this morning after the rough idling and dying period, the fuel trim values have changed. Long term on bank 1 is -48% and long term on bank 2 is -0.8%. Short term on bank 1 is 25% and short term on bank 2 is 0.0%. This is the first time that I have seen both banks not be relatively the same for each.
Sitting here idling with my windows open it does seem to smell like it is running rich.
I had the repair shop also change my oil and the car is randomly reporting that the oil level is too high and should be reduced. That is on today but isn't always on.
I have read about the high pressure fuel pump replacement and it seems like something I should be able to do myself assuming VCDS will perform the procedure to reduce the fuel pressure in the fuel lines in order for me to remove the pumps and replace them. Can you please confirm that it can do that?
Here are the results of the full auto-scan. Hoping I am posting this correctly.
Saturday,19,October,2019,12:18:33:32978
VIN: WAURVAFD5CN030737   License Plate:
Chassis Type: FD-AU64 (4H0)
Scan: 01 02 03 05 06 08 09 0E 10 13 15 16 17 19 28 34 36 3B 3C 42
          46 47 48 52 53 56 5B 5F 62 6C 6D 6F 72 81 85 88 89 8A 8B 8D
          8E 8F 90
VIN: WAURVAFD5CN030737   Mileage: 161043km-100067miles
48-Seat, Rear, DS -- Status: OK 0000
5B-Seat,Rear,PS -- Status: OK 0000
8A-Multicont. Seat Rear,DS -- Status: OK 0000
8D-Multicont. Seat Rear,PS -- Status: OK 0000
Address 01: Engine (------CDRA)       Labels:| 079-907-560-CFS.clb
   Part No SW: 4H0 907 560 C    HW: 4H0 907 560
   Component: 4.2l V8/4V    H07 0006
   Revision: N5H07---
   Coding: 0106000A290F0268
   Shop #: WSC 26876 002 1048576
   ASAM Dataset: EV_ECM42FSI0114H0907560C 001007
   ROD: EV_ECM42FSI0114H0907560C.rod
   VCID: 2A0D0154FC772477B73-807E
16501 - Fuel Trim; Bank 2
          P0175 00 [109] - System Too Rich
                    Fault Frequency: 11
                    Mileage: 160206 km
                    Date: 2019.10.04
                    Time: 14:13:28
                    Engine speed: 1938.00 /min
                    Normed load value: 35.3 %
                    Vehicle speed: 23 km/h
                    Coolant temperature: 106 °C
                    Intake air temperature: 45 °C
                    Voltage terminal 30: 13.122 V
                    AFS dm: 62.2 kg/h
                    Median injection timing: 0.796 ms
                    Engine operating condition: Part. load
                    Engine operating condition-Test_Program_Channel 87: 6
16516 - Fuel Trim; Bank 1
          P0172 00 [109] - System Too Rich
                    Mileage: 160206 km
                    Date: 2019.10.04
                    Time: 14:13:29
                    Engine speed: 1710.50 /min
                    Normed load value: 43.5 %
                    Vehicle speed: 25 km/h
                    Voltage terminal 30: 13.758 V
                    AFS dm: 61.6 kg/h
                    Median injection timing: 0.736 ms
7690 - Oxygen (Lambda) Sensor B2 S1
          P2240 00 [039] - Pump Current Open Circuit
                    Mileage: 161043 km
                    Date: 2019.10.19
                    Time: 11:54:37
                    Engine speed: 661.00 /min
                    Normed load value: 21.6 %
                    Coolant temperature: 66 °C
                    Intake air temperature: 25 °C
                    Voltage terminal 30: 13.970 V
                    AFS dm: 18.4 kg/h
                    Median injection timing: 0.589 ms
16475 - Fuel Trim; Bank 2
                    Mileage: 160197 km
                    Date: 2019.10.04
                    Time: 13:56:48
                    Engine speed: 663.00 /min
                    Normed load value: 29.4 %
                    Coolant temperature: 105 °C
                    Intake air temperature: 35 °C
                    Voltage terminal 30: 13.735 V
                    AFS dm: 24.3 kg/h
                    Median injection timing: 0.579 ms
16497 - Fuel Trim; Bank 1
                    Mileage: 160197 km
                    Date: 2019.10.04
                    Time: 13:56:43
                    Engine speed: 634.00 /min
                    Normed load value: 30.6 %
                    Vehicle speed: 1 km/h
                    Voltage terminal 30: 13.829 V
                    AFS dm: 23.6 kg/h
                    Median injection timing: 0.656 ms
   Part No SW: 4H1 927 158 BR    HW: 0BK 927 156 AF
   Component: 0BK 42 FSIUSA H16 1003
   Revision: --H16---
   Coding: 000002
   ASAM Dataset: EV_TCMALX51011 002018
   ROD: EV_TCMALX51011_002_AU64.rod
   VCID: 015F86F82181072FC69-8054
   Part No SW: 4H0 907 379 E    HW: 4H0 907 379 E
   Component: ESP PREMIUM   H10 0352
   Coding: 44E6F20022674F00E200
   ASAM Dataset: EV_ESPPremi 005013
   ROD: EV_ESPPremi_005_AU64.rod
   VCID: 34311F2C2EB362871DF-8060
   Part No SW: 4H0 907 064 DD    HW: 4H0 907 064 BD
   Component: BCM2 2.0      H31 0510
   Coding: 0D872006000000000000
   Shop #: WSC 11249 001 1048576
   VCID: 6E85CD44009F08572BB-803A
   Serial number: 2312000002556015
00955 - Key 1
                    Reset counter: 25
                    Mileage: 160290 km
                    Date: 2019.10.05
                    Time: 13:04:21
   Part No SW: 4H0 959 760 E    HW: 4H0 959 760 E
   Revision: AA000000    Serial number: 00000023427289
   Coding: C018B60085043201010001010101112131313333283333
   Shop #: WSC 02313 785 00200
   VCID: 3537222825497B8F2A1-8060
03331 - Motor for Backrest Angle Adjustment
                    Reset counter: 0
                    Mileage: 160900 km
                    Date: 2019.10.13
                    Time: 07:48:11
Address 08: Auto HVAC (J255)       Labels:| 4H0-820-043.clb
   Part No SW: 4H0 820 043 L    HW: 4H0 820 043 L
   Component: Klima 4 Zonen H20 0130
   Coding: 488122BECC
   Shop #: WSC 61659 002 1048576
   VCID: 290FFE58F9712F6FBE9-807C
0194 - Position Sensor in Left Center Vent
          B10E1 15 [009] - Open or Short to Plus
                    Reset counter: 65
                    Mileage: 155614 km
                    Date: 2019.07.23
                    Time: 07:35:07
   Part No SW: 4H0 907 063 BP    HW: 4H0 907 063
   Component: BCM1 2.0      H12 0111
   Revision: 11012002    Serial number: 00000001240093
   Coding: 09072091073C9FE38B000804A0003800009CD308820001218001085C3B00
   VCID: 77ABE8207FC5499FF8D-8022
   Subsystem 1 - Part No SW: 4H1 955 119 C    HW: 4H1 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS641 120119  H35 0080
   Serial number:         120208000638
   Coding: 0045F7
   Component: RLS  H04 0003
   Serial number: 10217127
   Coding: 025523
   Component: E1 - LDS  H07 0044
   Serial number: 15 02 2012  00001559
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555R15BG02
   Serial number: 00000011021200010124
   Coding: 100000
   Serial number: 00000001021200010093
   Coding: 100000
   Subsystem 7 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0300
   Serial number: WA102747000000903898
   Coding: 020300
   Serial number: 26184316000000000001
Address 0E: Media Player 1 (R161)       Labels: None
   Part No SW: 4H0 035 108 E    HW: 4H0 035 108
   Component: DVDCAlpine    H42 0190
   Revision: AA001001
   VCID: 221DE97484C7FC37FF3-8076
   Part No SW: 4H0 919 475 L    HW: 4H0 919 475 C
   Component: PARKHILFE ACC H07 0043
   Revision: 11001001    Serial number: 55901204900577
   Coding: 280902
   ROD: EV_EPHVA18AU57X0000_002_AU64.rod
   VCID: 3B23341003EDADFFDC5-806E
   Part No SW: 4H0 907 561 B    HW: 4H0 907 561
   Component: ACC3          H17 0400
   Coding: 3601020201
   ASAM Dataset: EV_AdaptCruisContrAU64X 002021
   ROD: EV_AdaptCruisContrAU64X_002.rod
12032 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
          C1103 00 [008] - -
          [FAULT_MAR_PRE_MISALIGNMENT]
                    Reset counter: 54
                    Mileage: 155652 km
                    Date: 2019.07.27
                    Time: 13:58:01
                    Control Module temperature: 39 °C
                    Voltage terminal 15: 14.023 V
                    Velocity_vehicle_reference: 11.89 m/s
                    Longitudinal_acceleration_vehicle_reference: 0.18 m/s²
93440 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
          [FAULT_CIS_VIDEO_FAIL]
                    Fault Frequency: 85
                    Reset counter: 15
                    Mileage: 160350 km
                    Date: 2019.10.09
                    Time: 08:41:18
                    Control Module temperature: 6 °C
                    Voltage terminal 15: 14.059 V
                    Velocity_vehicle_reference: -0.01 m/s
   Part No SW: 4H0 959 655 D    HW: 4H0 959 655 D
   Component: Airbag10.43   H44 0041
   Revision: --------    Serial number: 003JS00195XC
   Coding: 303143303230303030314A55304C34483053
   VCID: 372B28203FC5899F38D-8062
   Subsystem 1 - Part No SW: 4H0 959 339 A    HW: 4H0 959 339 A
   Component: BF-Gewichtss.  H03 0040
   Serial number: 5850000R1220203FJZ
   Serial number: 3575HRB4057131GQ48H
   Serial number: 3585HRB4057131GQ491O
   Serial number: 3515JRB404V0P3T448T/
   Serial number: 3525JRB404V0P3T4C0EQ
   Serial number: 3554VRB405911T2S28IL
   Serial number: 3564VRB405B11T2SF1KW
   Revision: --------    Serial number: 90815LBJ0001I
   Coding: 0004BC
   VCID: 38292B1C325B86E7317-806C
   Subsystem 1 - Part No SW: 4H0 951 528 L    HW: 4H0 951 528 L
   Component: E221 - MFL  H09 0009
   Serial number: 23 12 2011  B1034503
   Part No SW: 4H0 920 980 J    HW: 4H0 920 980 J
   Component: TBenUSAACC--- H71 0416
   Revision: 32081056    Serial number: 658070212592065
   Coding: 0B4608015700D705020000
   ASAM Dataset: EV_RBD4K 004045
   ROD: EV_RBD4K_AU64.rod
   VCID: 323D1934D4A76CB70F3-8066
   Analog_clock:
   Subsystem 1 - Part No SW: 4H0 919 204 G    HW: 4H0 919 204 G
   Component: Analoguhr D4  H05 0224
   Serial number: 1120131001862
   Part No SW: 4H0 907 468 G    HW: 4H0 907 468 C
   Component: J533--Gateway H08 0214
   Revision: --------    Serial number: 00000000405704
   Coding: 00C1034A00
   ROD: EV_GatewUDS_AU57.rod
   VCID: 3537222825C97B8F2A1-8060
   Subsystem 1 - Part No SW: 4H0 915 181     HW: 4H0 915 181
   Component: J367-BDM  H07 0140
   Serial number: 00000000005650606460
Address 28: HVAC, Rear (E265)       Labels:| 4H0-919-158.clb
   Part No SW: 4H0 919 158 D    HW: 4H0 919 158 D
   Component: Klima Fond    H16 0111
   Coding: 0000000000
   ROD: EV_AirCondiHeck_AU64.rod
   VCID: 313F1638D1A157AF769-8064
   Part No SW: 4H0 907 553 E    HW: 4H0 907 553
   Component: LUFE-DAEMPFER H17 0099
   Coding: 008002
   ROD: EV_AirSuspe_VW51.rod
   VCID: 2E050D44C09F48576BB-807A
   Revision: AA000000    Serial number: 00000023427129
   Coding: C018BF8085853201030001010101112131313333203333
   Part No SW: 4H0 907 637     HW: 4H0 907 637
   Component: SARA 6D       H02 0020
   Revision: --------    Serial number: EJ1BPA3101CMXN0
   ASAM Dataset: EV_SARA 009017
   ROD: EV_SARA_009.rod
   VCID: 6C81C74C3603FA4705F-8038
   Part No SW: 4H0 907 566 A    HW: 4G0 907 566
   Component: J769  SWA MasterH02 0040
   Revision: 00H02000    Serial number: 6PZ 010 287-07
   VCID: 2E050D44CC1F48576BB-807A
   Subsystem 1 - Part No: 4H0 907 568 A
   Component: J770  SWA Slave H02 0040
   Subsystem 2 - Serial number: 6PZ 010 287-27
   Subsystem 3 - Serial number: 5F22.02.1200H020003CX25625ÿ
   Subsystem 4 - Serial number: X25625ÿ
   Part No SW: 4H0 959 793 G    HW: 4H0 959 793 G
   Component: TSG FA        H06 0261
   Revision: --------    Serial number: 0000124768631
   Coding: 011F1F005E0062C202003017
   Shop #: WSC 02312 785 00200
   VCID: 3D273A081D79A3CFE21-8068
   Revision: 00002001    Serial number: 0170582038
   Coding: 0106023A00FA7585B0B0C7C0020301000000000000000000000000000000
   Subsystem 1 - Part No SW: 4H0 959 719     HW: 4H0 959 719
   Component: GTO BF  H01 0080
   Serial number: 00000000000000069119
   Subsystem 3 - Part No SW: 4H0 959 591     HW: 4H0 959 591
   Component: J245 PS50.030  H07 0006
   Serial number:     WOO14603794
   Coding: 020200
   Subsystem 4 - Part No SW: 4H0 947 135 BK    HW: 4H0 947 135 BK
   Component: Dachelektroni  H11 0080
   Serial number: A2012000000000528687
   Subsystem 5 - Part No SW: 4H0 959 591 A    HW: 4H0 959 591 A
   Component: V252 PS010  H05 0005
   Serial number:     WOO1000MSTB
03932 - Real Lid/Hatch Opening Sensor
                    Reset counter: 65
                    Mileage: 155614 km
                    Date: 2019.07.23
                    Time: 07:35:16
   Part No SW: 4H0 035 465 A    HW: 4H0 035 465 A
   Component: BO G3 D4      H06 0150
   Revision: 04S00000    Serial number: 0015440
   VCID: 2411EF6C9ED3F2078DF-8070
   Subsystem 1 - Part No SW: 4H0 035 466     HW: 4H0 035 466
   Component: BO D4 SLAVE  H51 0180
   Serial number: 02910110007296
03175 - Invalid Data Set
                    Reset counter: 251
                    Mileage: 148165 km
                    Date: 2019.03.08
                    Time: 17:08:42
                    Voltage: 11.50 V
                    Temperature: 21.0°C
                    Bin. Bits: 00000100
                    Voltage: 12.00 V
                    Temperature: 16.0°C
                    Bin. Bits: 00000001
                    Bin. Bits: 00000000
03389 - Data Set Implausible
                    Reset counter: 15
                    Mileage: 148165 km
                    Date: 2019.03.08
                    Time: 17:08:42
                    Voltage: 11.50 V
                    Temperature: 21.0°C
                    Bin. Bits: 00000100
                    Voltage: 12.00 V
                    Temperature: 16.0°C
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
Address 48: Seat, Rear, DS (J876)       Labels: None
   Part No SW: 4H0 959 860     HW: 4H0 959 860
   Component: MEM-FS-Fond   H06 0155
   Revision: AA000000    Serial number: 00000023055851
   Coding: 001892800000300D0A00392038193A2039203B3B202020
   VCID: 71BFD63811A117AF369-8024
   Part No SW: 4H0 959 792 G    HW: 4H0 959 792 G
   Component: TSG BF        H06 0261
   Revision: --------    Serial number: 0000124772257
   Coding: 011F1F005E0062C202003007
   VCID: 3C21370C0663AAC7D5F-8068
   Revision: --------    Serial number: 00000000254136
   ROD: EV_ParkiBrake_VW51.rod
   Part No SW: 4H0 035 082 C    HW: 4H0 035 082
   Component: Radio U SIRIU H53 0101
   Revision: AB001007    Serial number: 235BN0C7501262
   Coding: 020007010000000001
   Shop #: WSC 02311 785 00200
   VCID: 211FE67881C1E72FE69-8074
Address 5B: Seat,Rear,PS (J877)       Labels: None
   Component: MEM-BFS-Fond  H06 0155
   Revision: AA000000    Serial number: 00000023055812
   Coding: 001896800000300D0A00392038193A2039203B3B382020
   Part No SW: 4H0 035 746 D    HW: 4H0 035 746
   Component: H-BNT-NA      H48 0423
   Revision: --------    Serial number: 035BW0C7508932
   Coding: 020200000001F9EF7D128B0E00000003140001000000000000
   VCID: 290FFE58F9F12F6FBE9-807C
   Component: NAR 2011  0505
   Subsystem 2 - Part No SW: 4H0 919 604 C    HW: 4H0 919 604 C
   Component: DU8 D4 SV NB  H46 0021
   Serial number: AUZ8ZDB1100CM39
   Subsystem 3 - Part No SW: 4H1 919 600 H    HW: 4H1 919 600
   Component: E380 BDT D4  H09 0065
   Serial number: 00000000069749
   Component: CD-Database  3371
                    Fault Frequency: 73
                    Reset counter: 15
                    Mileage: 161043 km
                    Date: 2019.10.19
                    Time: 11:45:48
                    Bin. Bits: 00000000 00000000
                    Bin. Bits: 00000010 00000000
   Part No SW: 4H0 959 795 D    HW: 4H0 959 795 D
   Component: TSG HL        H06 0262
   Revision: --------    Serial number: 0000124792468
   Coding: 010F1F00420062C202003007
   Part No SW: 4H0 907 441 A    HW: 4H0 907 441
   Revision: --H04---    Serial number: 525 PA8J1ZD00V
   Coding: 1080003
   VCID: 2615F564E4EF001793B-8072
Address 6D: Trunk Elect. (----)       Labels:* None
   Part No SW: 4H0 959 107 R    HW: 4H0 959 107 M
   Component: HDSG-Modul    H11 0039
   Revision: 10011001    Serial number: 042200194
   Coding: 0210044100
   ROD: EV_DeckLidContrUnit.rod
   VCID: 3D273A081DF9A3CFE21-8068
Address 6F: Centr. Conv. II (J773)       Labels:* None
   Revision: --------    Serial number: 000000063169
   ASAM Dataset: EV_Ambie 001008
   ROD: EV_Ambie.rod
   VCID: 6393AC70DBDDB53FB45-8036
   Component: TSG HR        H06 0262
   Revision: --------    Serial number: 0000124792599
Address 81: Gear Shift (J587)       Labels: 3Y0-927-731.clb
   Part No SW: 4H1 927 731 A    HW: 4H1 927 731 A
   Component: GSM-LL        H08 0083
   Revision: 0L0D5013    Serial number: SN111221  0433
   ROD: EV_GSM2x3Mono.rod
   VCID: 2B030450F38D3D7F4C5-807E
   Part No SW: 4G0 907 217     HW: 4H0 907 217 A
   Component: DPC-SG        H25 0036
   Coding: E9060000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 6597B268D5E9CB0F5A1-8030
0300 - Camera Interference
          C1104 00 [009] - -
          [No_connection_to_imager]
                    Reset counter: 15
                    Mileage: 160350 km
                    Date: 2019.10.09
                    Time: 08:41:09
                    Outside air temperature: -45.0 °C
                    Voltage terminal 15: 13.4 V
                    Control Module temperature: 4.0 °C
   Serial number: 00004606079102
   Coding: 764FF2
   ROD: EV_IVBDriveSideFrnt.rod
   VCID: 2F3B1040C795415F60D-807A
   Serial number: 00004606079302
   Coding: 364FF2
Address 8A: Multicont. Seat Rear,DS (J875)       Labels:* None
   Part No SW: 4H0 907 182 G    HW: 4H0 907 182 G
   Component: IVB           H08 0042
   Serial number: 00004608234902
   Coding: 200F00
   ASAM Dataset: EV_IVBDriveSideRear 001003
   Part No SW: 4H0 907 541 B    HW: 4H0 907 541
   Coding: 3601020201
   ASAM Dataset: EV_AdaptCruisContr2AU64X 002018
   ROD: EV_AdaptCruisContr2AU64X_002.rod
   VCID: 2809FB5CE27B1667A17-807C
Address 8D: Multicont. Seat Rear,PS (J874)       Labels:* None
   Serial number: 00004608226702
   Coding: 200F00
   ASAM Dataset: EV_IVBPasseSideRear 001003
   Part No SW: 4G0 907 107 D    HW: 4H0 907 107
   Component: BV-SG         H30 0038
   Serial number: 005000051302127
   Coding: 02A19A000111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
   VCID: 270BF860EF65191FA8D-8072
0161 - Video Cable for Image Processing
          C1107 02 [009] - Signal Failure
          [No_camera_found_on_startup]
                    Fault Frequency: 74
                    Reset counter: 15
                    Mileage: 160350 km
                    Date: 2019.10.09
                    Time: 08:41:18
                    Outside air temperature: 10.5 °C
                    Voltage terminal 15: 14.1 V
                    Control Module temperature: 10.0 °C
   Part No SW: 4H0 980 945 B    HW: 4H0 980 945 B
   Coding: 0066F609031F037E070308014240C2010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
End----------(Elapsed Time: 03:07, VBatt start/end: 14.7V/14.7V)-----------
Any help will be much appreciated with this diagnosis. Trying to avoid an expensive dealership visit.
Thank you.
HMC
C?ID=28246
Hi bn1990,
Are you ignoring " 7690 - Oxygen (Lambda) Sensor B2 S1 P2240 00 [039] - Pump Current Open Circuit" for any particular reason? Have you checked any live data for the O2 sensors?
Regards HMC
bn1990
C?ID=351416
Not ignoring the oxygen sensor code. After all of the checking I have done this is the first time that I have seen that come up. It has consistently been the rich condition codes for both banks. Definitely looking at this. I am not sure where that sensor is located.
The thing that is puzzling to me is that I consistently see codes for rich conditions on both banks so the suggestions about the cause being both high pressure pumps doesn't seem to make sense unless it is common for them to fail at the same time.
Do you know which live data values I should check to look at the O2 sensors more closely on this car?
Thanks.
I would start with these:
IDE00559-ENG167462 -- Current of oxygen sensor bank 1 sensor 1 (broadband sensor)
IDE00560-MAS0412 -- Oxygen sensor bank 1 sensor 2 (jump sensor) - Voltage
IDE00560-MAS04122 -- Oxygen sensor bank 1 sensor 2 (jump sensor) - Short term adaptation of mixture formation
IDE00565-ENG167462 -- Current of oxygen sensor bank 2 sensor 1 (broadband sensor)
IDE00566-MAS04121 -- Oxygen sensor bank 2 sensor 2 (jump sensor) - Voltage
IDE00566-MAS04122 -- Oxygen sensor bank 2 sensor 2 (jump sensor) - Short term adaptation of mixture formation
bn1990
C?ID=351416
Thank you Uwe. Since I am not a mechanic could you possibly let me know what values for each of these would be considered normal? I will take a look at them and I can post the results here but it would be nice to know as I am looking at it.
As I do not have an engine like yours, no I can't really tell you what you should expect to see there.
OP did you JPPSG?
Isn't this indicative of faulty injectors and HPP issues plus the need for CATs and all OXS sensors under useful life warranty?
