Why "Extended UDS fault detail is only supported by current gen. interfaces" MY09?
MartinsX
Riga, Latvia
C?ID=268515
My question is in the title. Why does this show up instead of fault code details/description using HEX-CAN-USB interface and 19.x VCDS on 09' MY Golf, for example?
I can't remember seeing this with older 17.x, 18.x VCDS versions.
One example:
Friday,20,December,2019,21:09:09:32442
VCDS Version: 19.6.1.0
VIN: WVWZZZ1KZ9W535590   License Plate:
Chassis Type: 1K-VW36 (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 77
VIN: WVWZZZ1KZ9W535590   Mileage: 483100km-300184miles
42-Door Elect, Driver -- Status: Sporadic communication error 1000
52-Door Elect, Pass. -- Status: Malfunction 1010
Address 01: Engine (CBD)       Labels: 03L-906-022-CBA.clb
   Part No SW: 03L 906 022 MC    HW: 03L 906 022 G
   Component: R4 2,0L EDC G000SG  3593
   Revision: 13H01---    Serial number:
   Coding: 0000071
   Shop #: WSC 12345 935 999999
   VCID: 72EBB0F76DD19BDF9F-8026
6 Faults Found:
001652 - Cylinder 4 Glow Plug Circuit (Q13)
               P0674 - 000 - Electrical Fault
                    Fault Frequency: 7
                    Mileage: 451300 km
                    Date: 2013.05.17
                    Time: 17:58:34
                    RPM: 1081 /min
                    Voltage: 11.25 V
                    Temperature: -1.8°C
                    Bin. Bits: 10110000
                    Time: 2.52 s
                    Temperature: -1.8°C
008200 - Intake Manifold Flap; Bank 1
               P2008 - 000 - Electrical Malfunction - Intermittent
                    Fault Frequency: 28
                    Mileage: 480008 km
                    Date: 2014.03.17
                    Time: 17:36:37
                    Load: 17.3 %
                    Load: 100.0 %
                    Lambda: 100.2 %
                    Mass Air / Rev.: 0.0 mg/str
                    Temperature: 15.3°C
001575 - Fuel Pump Relay Control Circuit
               P0627 - 000 - Open Circuit - Intermittent
                    Mileage: 481481 km
                    Voltage: 11.78 V
                    Pressure: 8.0 bar
                    Inj. Quantity: 0.0 mg/str
                    Lambda: 15.0 %
                    Lambda: 7.9 %
009778 - Relay for Fuel Pump 2 (J49)
               P2632 - 000 - Open Circuit - Intermittent
                    Mileage: 481481 km
                    Date: 2014.04.12
                    Time: 14:55:37
                    Voltage: 10.49 V
                    Pressure: 0.0 bar
                    Lambda: 31.6 %
                    Lambda: 11.0 %
009571 - Turbocharger Boost Control Position Sensor Circuit
               P2563 - 000 - Implausible Signal - Intermittent
                    Mileage: 481658 km
                    Date: 2014.04.22
                    Time: 21:37:25
                    RPM: 782 /min
                    Voltage: 14.29 V
                    Lambda: 88.4 %
                    Lambda: -20.5 %
                    Bin. Bits: 00011110
                    Voltage: 1.748 V
001674 - ECM Power Relay Load Circuit
               P068A - 000 - Opens Too Early - Intermittent
                    Voltage: 0.00 V
                    Hex Value: 0xFF00
                    Bin. Bits: 00000000
                    Temperature: -90.0°C
Readiness: 0 1 0 0 0
   Part No SW: 1K0 907 379 AD    HW: 1K0 907 379 AD
   Component: ESP MK60EC1   H35 0106
   Revision: 00H35001
   Coding: 113B200D092500FF881004ED901900423000
   VCID: 74E7B6EFD7C595EF8D-8020
   Part No SW: 3C8 907 336     HW: 3C8 907 336
   Component: Climatic      120 0102
   Revision: 00004001
   Coding: 0000000000
   Shop #: WSC 80093 222 69422
   ASAM Dataset: EV_Climatic A01001
   ROD: EV_ClimaBasis_VW36.rod
   VCID: 6ADBA8978D01531F27-803E
9473905 - Motor for Temperature Flap
          B108F 71 [008] - Actuator stuck
                    Fault Frequency: 61
                    Reset counter: 32
                    Mileage: 482177 km
                    Date: 2019.12.11
                    Time: 19:55:40
9477394 - Motor for Air Distribution Flap
          B109D 12 [009] - Short to Plus
                    Reset counter: 253
                    Mileage: 450843 km
                    Date: 2018.12.19
                    Time: 07:32:04
13701488 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 20
                    Mileage: 481481 km
                    Date: 2019.11.19
                    Time: 14:19:06
13701504 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 31
                    Mileage: 482134 km
                    Date: 2019.12.07
                    Time: 15:13:59
   Part No SW: 1K0 937 085     HW: 1K0 937 085
   Component: BCM PQ35  B+  020 0360
   Revision: 00020000
   Coding: 46180A3A90251A9040000080100000E445010088524D8960648000000000
   Shop #: WSC 79103 146 83050
   VCID: 6CD7AE8F8FF54D2F55-8038
   Component: Wischer 13030  21  0501
   Coding: 009795
00984 - Left Tail Light (M4)
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Fault Frequency: 76
                    Reset counter: 6
                    Mileage: 482229 km
                    Date: 2014.05.07
                    Time: 19:24:36
                    Voltage: 14.40 V
                        Term 50 Off
03266 - Control Circuit for Signal Horn
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 248
                    Mileage: 482229 km
                    Date: 2014.05.07
                    Time: 19:24:36
                    Voltage: 14.40 V
                        Term 50 Off
                    Fault Frequency: 26
                    Reset counter: 45
                    Mileage: 482229 km
                    Date: 2014.05.07
                    Time: 20:15:11
                    Voltage: 11.90 V
                        Term 50 Off
   Part No SW: 5K0 959 655     HW: 5K0 959 655
   Component: AirbagVW10    033 0604
   Serial number: 003C2R36057M
   Coding: 00003135
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01009
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 77FD81E3CEB3FEF7A8-8022
   Component: S.Sens.Fahr.V  U01 ----
   Serial number: 5F280243ZZZZZZZZZZZZ
   Component: S.Sens.Beif.V  U01 ----
   Serial number: 19523146ZZZZZZZZZZZZ
   Serial number: 12231C11ZZZZZZZZZZZZ
   Serial number: 16041E0EZZZZZZZZZZZZ
   Part No SW: 1K0 953 549 BK    HW: 1K0 953 549 BK
   Coding: 0001042
   VCID: 7CF79ECF3F95DDAFC5-8028
   Part No SW: 5K0 920 860 E    HW: 5K0 920 860 E
   Component: KOMBI         H21 0030
   Coding: 170A00
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04020
   VCID: 2E5364877169FF3F3B-807A
   Component: J533__Gateway   H16 0210
   Revision:   H16       Serial number: 3400K09316059F
   Coding: E9801F06000602000002
   VCID: 377D41E346333EF768-8062
01304 - Radio
                    Reset counter: 5
                    Mileage: 450177 km
                    Date: 2013.05.04
                    Time: 00:02:05
                    Reset counter: 19
                    Mileage: 481481 km
                    Date: 2014.04.11
                    Time: 14:19:05
                    Reset counter: 30
                    Mileage: 482134 km
                    Date: 2014.04.29
                    Time: 15:13:59
00469 - Infotainment Databus in Single Wire Operation
                    Reset counter: 5
                    Mileage: 478411 km
                    Date: 2014.02.22
                    Time: 22:11:07
Address 25: Immobilizer (J334)       Labels:. 5K0-920-xxx-25.clb
   Component: IMMO          H21 0030
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03002
   Part No SW: 1K0 959 701 AM    HW: 1K0 959 701 AM
   Component: Tuer-SG         008 2041
   Coding: 0000118
   VCID: 79F987DB30A7E887DE-802C
   Part No: 1K0 909 144 C
   Component: EPS_ZFLS Kl. 69     2301
   Revision: 00H15000
   VCID: 2A5B68978581931FE7-807E
   Part No SW: 1K0 959 702 AM    HW: 1K0 959 702 AM
   Coding: 0000118
   VCID: 7AFB98D735A1E39FD7-802E
00940 - Mirror Adjust Motor; Passenger Side (V150)
Address 56: Radio
Address 77: Telephone (J738)       Labels:. 1K8-035-730.clb
   Part No SW: 1K8 035 730 B    HW: 1K8 035 730 B
   Component: Telefon       H08 5400
   Revision: 00008000    Serial number: 20389520082400
   Coding: 001120
   VCID: 285F929F5B8DA10FF1-807C
03427 - Right Audio Channel
                    Reset counter: 238
                    Mileage: 450177 km
                    Date: 2013.05.04
                    Time: 00:01:30
01304 - Radio
                    Reset counter: 5
                    Mileage: 450177 km
                    Date: 2013.05.04
                    Time: 00:02:08
End-------------------------(Elapsed Time: 02:19)--------------------------
Older versions did not have the "Extended UDS fault detail" at all. I don't remember exactly at what version it got added, but it was definitely after the older HEX+CAN had been discontinued, and we elected to implement it only for current interfaces.
