Hi all, Having trouble with the long coding on the engine ecu as i keep getting a message everytime i do a scan "unable to find a rod file for EV_ECM20TDI01104L906026MT004001(SK48)" and when you open the long coding on 01 (engine) up it hasnt got any info, so as per request here is the scan details my thoughts are its because its a 2017 model year car and no info is available yet. any help would be great, i am using the latest 16.8.3 download and also using a genuine vagcom lead. Cheers Phil
Saturday,05,November,2016,13:11:04:14782
VCDS Version: 16.8.3.1 (x64)
VIN: TMBMJ7NP0H7033063 License Plate:
Mileage: 761km-472mi Repair Order:
Chassis Type: NP (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 2B 36 42 44 52 55 5F
69 6D BB BC
VIN: TMBMJ7NP0H7033063 Mileage: 761km-472miles
Address 01: Engine (J623-DFCA) Labels: None
Part No SW: 04L 906 026 MT HW: 04L 907 309 M
Component: R4 2.0l TDI H24 3076
Revision: B4H24---
Coding: 011D0012047701083000
Shop #: WSC 33361 790 00063
ASAM Dataset: EV_ECM20TDI01104L906026MT 004001
ROD: N/A
VCID: 081BD544B30A8502F4-805C
No ASAM data for: "EV_ECM20TDI01104L906026MT" (SK48)
Part No SW: 0D9 300 013 A HW: 02E 927 770 AQ
Component: DQ250-6A MQB H54 4905
Revision: 06354004 Serial number: TFK01608191713
ROD: EV_TCMDQ250021.rod
VCID: 15258C30F4B828EA7F-8040
Part No SW: 5Q0 614 517 BK HW: 5Q0 614 517 AH
Component: ESC H62 0736
Revision: 00000000 Serial number: 62446000000031
Coding: 1E07929C34230B6F4777070641C64978492CD0E2E082927518615078C20902
ROD: EV_Brake1UDSContiMK100IPB_035_SK37.rod
VCID: 7BF1BA88F2DCDE9AE9-802E
Address 05: Acc/Start Auth. (J518) Labels: 5Q0-959-435.clb
Part No SW: 3Q0 959 435 E HW: 3Q0 959 435 E
Component: VWKESSYMQB 036 0811
Revision: 00036000 Serial number: 0416932305
Coding: 032C0C0F03
VCID: 3C737994B75219A2A0-8068
Address 08: Auto HVAC (E87) Labels: 3V0-907-044.clb
Part No SW: 3V0 907 044 BP HW: 3V0 907 044 BP
Component: AC Automat H34 4003
Revision: 20K07000 Serial number: 00000B00249390
Coding: 1211010400241001100500010010100A
Shop #: WSC 73430 790 00063
ASAM Dataset: EV_ACClimaPrehVW37X 002014
ROD: EV_ACClimaPrehVW37X_SK48.rod
VCID: 0301C2688A2CA65AA1-8056
P1719 00 [008] - -
Reset counter: 78
Mileage: 716 km
Date: 2016.11.02
Time: 07:32:20
Voltage terminal 30: 14.4 V
Auxiliary heater: in stages-Act.value: 2
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-V2.clb
Part No SW: 5Q0 937 084 CG HW: 5Q0 937 084 CG
Component: BCM MQBAB H H34 0236
Serial number: 02001626100875
ROD: EV_BCMBOSCH_017.rod
VCID: 7F094E98E6C4C2BAC5-802A
Subsystem 1 - Part No SW: 3V2 955 119 HW: 3V1 955 119 Labels: 5QX-955-119-V1.CLB
Component: 48x RL 160831 032 0121
Serial number: 00000001608290304924
Coding: 165DDD
Subsystem 2 - Part No SW: 5Q0 955 547 B HW: 5Q0 955 547 B Labels: 5Q0-955-547.CLB
Component: RLHS 042 0105
Serial number: S4Y16M09D21H14M10S11
Coding: 0088DF
Subsystem 3 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Serial number: 000000000ZY162223D5K
Subsystem 4 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Component: Sirene, DWA 005 0313
Serial number: 00000000000036372628
Address 10: Park/Steer Assist (J446) Labels: 5Q0-919-294.clb
Part No SW: 5Q0 919 294 L HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0056
Revision: -------- Serial number: 39361625704495
Coding: 0071051951
VCID: 44830174CFA26162D8-8010
Address 13: Auto Dist. Reg (J428) Labels: 3Q0-907-572.clb
Part No SW: 3Q0 907 572 B HW: 3Q0 907 572 B
Component: ACC BOSCH MQB H04 0194
Coding: 3200678A51FFC428949C8045
ROD: EV_ACCBOSCHVW48X.rod
VCID: 346351B49F02D1E268-8060
Part No SW: 5Q0 959 655 AK HW: 5Q0 959 655 AK
Component: AirbagVW21 005 0130
Serial number: 003Q5R24L4RX
Coding: 98CCC0C0000000005C5400CF00C800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002146
ROD: EV_AirbaVW20SMEVW37X_SK48.rod
VCID: 091DD040A800FC0AEB-805C
Subsystem 1 - Part No SW: ----------- HW: 480 001 309 16
Serial number: 357000000008B2114E1E
Subsystem 2 - Part No SW: ----------- HW: 480 001 509 16
Serial number: 35800000000E38D03E1T
Subsystem 3 - Part No SW: ----------- HW: 480 400 909 16
Serial number: 3510002C9215E1D2229/
Subsystem 4 - Part No SW: ----------- HW: 480 400 609 16
Serial number: 3520002B3215E1D152F%
Subsystem 5 - Part No SW: ----------- HW: 480 400 609 16
Serial number: 3550002AD215E1D510B5
Address 16: Steering wheel (J524) Labels: 5Q0-953-549.clb
Part No SW: 3Q0 953 521 EF HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0235
Revision: FF035035 Serial number: 20160919400383
Coding: 6410
ROD: EV_SMLSVALEOMQB.rod
VCID: 78FBA584C3EAF58284-802C
Part No SW: 3V0 920 911 A HW: 3V0 920 911 A
Component: KOMBI 304 8311
Coding: 27A5081AAF80A60001886B011000000000000000
Shop #: WSC 73430 031 00063
ROD: EV_DashBoardVDDMQBAB_009_SK37.rod
VCID: 306B5DA46B1AEDC20C-8064
Part No SW: 5Q0 907 530 AM HW: 5Q0 907 530 M
Component: GW MQB High 212 2265
Revision: -------- Serial number: 17091610801635
Coding: 030100345F087300EB00025A1C0F00010001070000000000000000000000
Shop #: WSC 33361 790 00114
ROD: EV_GatewConti_013.rod
VCID: 7CF3B994F7D2D9A2E0-8028
Subsystem 2 - Part No SW: 3V0 919 719 B HW: 3V0 919 719 B
Component: E221__MFL-PR6 H02 0150
Serial number: 000000000D0069030916
Subsystem 3 - Part No SW: 5Q0 915 181 K HW: 5Q0 915 181 K
Serial number: 2204760904
Address 22: AWD (J492) Labels: 0CQ-907-554.clb
Part No SW: 0CQ 907 554 H HW: 0CQ 525 130
Serial number: HA1-00010.08.16
Coding: 0301
VCID: 4A9F2F4CED86B71222-801E
Address 2B: Steer. Col. Lock (J764) Labels: 5Q0-905-861.clb
Part No SW: 3Q0 905 861 HW: 3Q0 905 861
Component: ELV-MQBB H05 0032
Serial number: 16000209875012
Coding: 0800000000000000
ROD: EV_ELVMarquMQBB.rod
VCID: 71ED98A0A090A4CA43-8024
Address 36: Seat Mem. Drvr (J810) Labels: None
Part No SW: 5Q0 959 760 B HW: 5Q0 959 760 B
Component: Sitzmemory H08 0020
Serial number: Y0006PI227635
Coding: 0014000000000500018280808080000000008181000000D400
ROD: EV_SeatMemorDriveSide_VW37.rod
Part No SW: 5Q4 959 593 E HW: 5Q4 959 593 B
Component: TSG FS 010 0032
Serial number: 0000219248383
Coding: 001D0820DE01040000001100
VCID: 47991678FE944A7A3D-8012
Part No SW: 5Q0 909 144 T HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 128 1072
Coding: 8107
ROD: EV_SteerAssisMQB_013.rod
VCID: 45851C70C498586ACF-8010
Part No SW: 5Q4 959 592 E HW: 5Q4 959 592 B
Component: TSG BFS 010 0032
Serial number: 0000218958908
Coding: 001D0220DE01040000001100
VCID: 46871B7CF99E5372C6-8012
Address 55: Headlight Range (J745) Labels: 7P6-907-357.clb
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: AFS-ECU H07 0090
Coding: 06EE00003F010000
VCID: 408B0D64DBBA7D42FC-8014
Subsystem 1 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0006
Coding: B20000
Subsystem 2 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0006
Coding: B20000
Address 5F: Information Electr. (J794) Labels: 3V0-035-MIB-HGH2.clb
Part No SW: 3V0 035 020 C HW: 3V0 035 020
Component: MU-H-ND-EU H50 0702
Serial number: A676I0G7520467
Coding: 03840201FF00000051111201008808002F0100C601208100DE
VCID: 2647BBFC59DEB372E6-8072
Subsystem 1 - Part No SW: 3V0 919 606 HW: 3V0 919 606
Component: ABT_High-2 H47 1031
Serial number: SKZ8Z9SLU00GD0
Subsystem 2 - Part No SW: V03 959 801 JL HW: -----------
Component: ECE 2016/2017 --- 0153
Subsystem 3 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote2--- --- 1013
Address 69: Trailer (J345) Labels: 5Q0-907-383.clb
Part No SW: 5Q0 907 383 H HW: 5Q0 907 383 C
Component: Anhaenger H21 0204
Revision: 8B001003 Serial number: 0416488688
Coding: 0100000202000000
Address 6D: Trunk Elect. (J605) Labels: 5Q0-959-107.clb
Part No SW: 5Q0 959 107 J HW: 5Q0 959 107 J
Component: HDSG-Modul H13 0253
Revision: -------- Serial number: 30949220700000
Coding: 0D88
ASAM Dataset: EV_DeckLidCONTIAU736 001012
VCID: 3F890E98A64402BA85-806A
Address BB: Door Rear Drv (J388) Labels: None
Part No SW: 5Q4 959 395 E HW: 5Q4 959 395 B
Component: TSG HFS 011 0032
Serial number: 0000218259558
Coding: 001800208001040000001100
ASAM Dataset: EV_DCURearDriveMAXCONT 006001
Address BC: Door Rear Pass (J389) Labels: None
Component: TSG HBFS 011 0032
Serial number: 0000218259489
ASAM Dataset: EV_DCURearPasseMAXCONT 006001
End-------------------------(Elapsed Time: 05:05)--------------------------
