"Key not in range!" message. Remote won't unlock, lock or start car...
quailallstar
Ormond Beach, FL
C?ID=53119
Well, I've finally been plagued by the "Key not in range!" Kessy bug of issues facing countless other MK7 owners - across the globe.
Background info:
I replaced remote 1's battery two weeks ago and it's been woking perfectly since. Until that point, my Kessy hatch opening was a true hit or miss - but perfect once a new battery was put in. Now today all of a sudden I'm unable to lock/unlock or start my car via the same remote with a fresh battery. The only way to start the car is by using the emergency procedure (hold key up to the steering column).
Spare key doesn't work either and neither does the procedure outlined within the owners manual used to have the car re-learn its keys
Ran a VCDS scan and the only issue coming up is some fault related to Car-Net which I don't have active.
Address 75: Telematics (J949)       Labels: 5QE-035-285.clb
   Component: OCULowMQBUS   007 0568
   Coding: 02730002C2863A01000002000000
   Shop #: WSC 12345 123 61029
   ROD: EV_OCULowMQB.rod
   VCID: 438F311FCA0C3A59B4-8016
2566 - GPS Antenna
          B1054 13 [009] - Open Circuit
                    Reset counter: 173
                    Mileage: 18490 km
                    Date: 2017.04.01
                    Time: 19:15:05
Is there any way to reprogram the keys through VCDS? I avoid the dealer as much as possible.
Tips, tricks or advice would be greatly appreciated!
Mind posting your Kessy data despite there being no fault codes?
I think it might be educational for us to look at some of the measuring values in there.
quailallstar
Ormond Beach, FL
C?ID=53119
@Uwe
Here you go! Can you tell me if you see any coding that could be incorrectly coded? Should I attempt to have the keys relearned? http://wiki.ross-tech.com/wiki/index.php/Immobilizer_III_Key_Matching_(Kessy)
Additional vehicle info: Chassis Type: AU (5Q0) 2016 NAR Golf Sportwagen TSI - Build date 1/26/2016
   Revision: 00021000    Serial number: 0381142691
   Coding: 030C1C
   Shop #: WSC 01383 790 50316
   VCID: 3A714CFBBDC67B91E7-806E
quailallstar
Ormond Beach, FL
C?ID=53119
Fixed the issue!!!
For some odd reason, 09-Central Electronics byte 8/bit 0-1 was coded ROW and not North America. This was causing all keys to not be recognized as a result. Reverted back to NAR and all is well. Two cups of coffee helped for sure :thumbs:
