VW 2006 Touareg V6 17225 error code
colin
New Zealand
C?ID=254057
Hi All,
My name is Colin and I am new to this Forum.
I have a 2006 VW Touareg that has a newer Valve body that does not have the transmission fluid pressure sensors G193 and G194.
The transmission operates perfectly, smooth as the day it was new. However, the engine check light is on and the transmission is logging the following error code.
If I clear the code it turns back on again, like clockwork within 10 minutes of driving.
It almost looks like the code is incorrect in the TCM for this valve body, expecting to see the pressure signal and not.
Appreciate any feedback on what may cause this problem
Many Thanks,
Colin
> 2 Faults Found:
> 17225 - Transmission Fluid Pressure Sensor/Switch 1
> P0841 - 010 - Implausible Signal - Intermittent - MIL ON
> 17230 - Transmission Fluid Pressure Sensor/Switch 2
> P0846 - 010 - Implausible Signal - Intermittent - MIL ON
> Best Regards,
> Colin.
 Thursday,30,March,2017,09:21:59:48492
 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64 VCDS
 Version: 16.8.4.2 (x64) Data version: 20161129 DS267.0
 VIN: WVGZZZ7LZ6D050578   License Plate: 123456
 Mileage: 103200km-64125mi   Repair Order:
 Chassis Type: 7L (7L - VW Touareg (2003  11/2006))
 Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
           37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
 VIN: WVGZZZ7LZ6D050578   Mileage: 103200km-64125miles
 Address 01: Engine        Labels: 022-906-032-BMX.lbl
    Part No SW: 022 906 032 GA    HW:
    Component: MOTRONIC ME7.1.1G   6384
    Coding: 0000133
    Shop #: WSC 31414 000 00000
    VCID: 50AF22C3C05E5FC219-5140
 18032 - MIL Request Signal Active (Check TCM for errors too!)
             P1624 - 008 -
 Readiness: 0000 1001
 Address 02: Auto Trans        Labels: 09D-927-750.lbl
    Part No: 09D 927 750 BN
    Component: AL 750 6A           0586
    Coding: 0012328
    VCID: 7BF5A56F39580C9A9C-515E
 Address 03: ABS Brakes        Labels: 7L0-907-379-MK25.lbl
    Part No: 7L0 907 379 G
    Component: ESP ALLRAD MK25     0203
    Coding: 0014338
    VCID: 3D716B7767CCC2AAE2-5140
 Address 05: Acc/Start Auth.        Labels: None
    Part No SW: 7L0 909 135     HW: 5WK 484 91
    Component:    Kessy            6700
    Revision: 67005614    Serial number: VWZ3Z0E2409251
    Coding: 0000232
    Shop #: WSC 29227 002 1048576
    VCID: 6ED39C3B7A2A69322B-5140
 Address 08: Auto HVAC        Labels: 7L6-907-040.clb
    Part No: 7L6 907 040 L
    Component: CLIMAtronic R/L     4017
    Coding: 0000030
    VCID: 39797F6773E4FE8ACE-5140
 Address 09: Cent. Elect.        Labels: 7Lx-937-049-V1.clb
    Part No: 7L6 937 049 M
    Component:                     3001
    Coding: 0232700
    VCID: 4683049B321A8172B3-515E
             000 -  -
    Part No: 3D0 909 601 E
    Component: 0V Airbag 8.4E+ H10 0951
    Coding: 0012374
    VCID: 2541A317EF5C6A6A9A-5140
 Address 16: Steering wheel        Labels: 7L6-953-549.lbl
    Part No: 7L6 953 549 H
    Coding: 0010031
    VCID: 44871E930426B362AD-515E
 Address 17: Instruments        Labels: 7L6-920-xxx-7LA.lbl
    Part No: 7L6 920 871 HX
    Component: KOMBIINSTRUMENT RB8 2111
    Coding: 0007511
    Shop #: WSC 78350 981 90755
    VCID: 1427EED334C6E3E27D-5140
    Part No: 6N0 909 901
    Component: Gateway K<CAN      0101
    Coding: 0000006
    VCID: 70EF8243601E7FC239-5140
    Part No: 0AD 927 755 AJ
    Component: TRANSFERCASE        0100
    VCID: 0305DD8F41A8745AD4-5140
 Address 29: Left Light        Labels: 3D0-909-157.lbl
    Part No: 3D0 909 157
    Component: EVG GDL+AutoLWR(l)  0001
    Coding: 0000002
    VCID: 66C3E41B52DAA17253-5140
 Address 39: Right Light        Labels: 3D0-909-158.lbl
    Part No: 3D0 909 158
    Component: EVG GDL+AutoLWR(r)  0001
    Coding: 0000002
    VCID: 67DDE91F55D0B87A68-515E
 Address 46: Central Conv.        Labels: 7L0-959-933.lbl
    Part No: 7L0 959 933 F
    Component: WY HSG              0300
    Coding: 0000069
    VCID: 3F8D117F6DC0D0BAF0-4B1A
    Subsystem 1 - Part No: 7L0 959 701 K
    Component: Tuersteuergeraet FS 0201
    Subsystem 2 - Part No: 7L0 959 702 K
    Component: Tuersteuergeraet BF 0201
    Subsystem 3 - Part No: 7L6 959 703
    Component: Tuersteuergeraet HL 0202
    Subsystem 4 - Part No: 7L6 959 704
    Component: Tuersteuergeraet HR 0202
    Subsystem 5 - Part No: 7L0 907 719 A
    Subsystem 6 - Part No: 7L6 951 171 B
    Component:    Innenraumsensor  0020
 Address 56: Radio        Labels: 3B7-035-1xx-56.lbl
    Part No: 7L6 035 195
    Component: Radio DE2           0012
    Coding: 0001407
 00857 - CD Changer Unit (R41)
 Address 68: Wiper Electr.        Labels: 7L0-955-119-V2.clb
    Part No: 7L0 955 119 L
    Component: Front Wiper         4027
    Coding: 0000343
    Shop #: WSC 31414 000 376832
    VCID: 3D716B7767CCC2AAE2-515E
    Component: RLS     301013 054  0403
    Coding: 00209069
    Shop #: WSC 31414
    Part No: 7L0 919 283 F
    Component: 0D Einparkhilfe     1107
 End-------------------------(Elapsed Time: 09:37)--------------------------
Try 12392 ...?
colin
New Zealand
C?ID=254057
Try 12392 ...?
Thanks for the reply, just tried that and the problem is the same, unless there is some special procedure for coding that isn't immediately obvious from the prompts.
This is what the autoscan for the fault looks like now.
The error code pops up within 100 metres of driving.
Regards,
Colin
Coding: 0012392
colin
New Zealand
C?ID=254057
Thank you for the reply,
Please could you let me know where the fuses are for these sensors?
Regards,
Colin
colin
New Zealand
C?ID=254057
Hi again,
These sensors are not installed in this version of valve body, are the fuses still present and monitored?
Regards,
Colin
NEtech
Denmark
C?ID=56995
I don't understand why you say these sensors are not installed.
Have you looked at the wiring diagram and checked pin 24 and 25 on TCM?
Fuses are probably C29 and C51, so you have checked all your fuses, none are blown.
NostraJackAss
I think it is very possible to have a bad wire/connection at the module or trans & a bad ATF temp sensor internally can happen.
Please check the TCU for water ingress............very common!
colin
New Zealand
C?ID=254057
Pre 2005 month 11 these two sensors are installed in the valve body. Post 2005 month 11 the valve bodys do not have these sensors in the valve body. If you look at pictures of the two different valve bodys you can see they are physically not there anymore.
Without the sensors physically installed I don't know what is generating the error codes. I have worked on both types of valve bodies and in the newer valve bodies the sensors are physically not present.
From the transmission technical document:
ELECTRONIC COMPONENTS (CONT'D)
Pressure Switches 1 (G193) And 2 (G194)
Some 09G/09M transaxles are equipped with two
pressure switches that screw into the valve body
casting in the locations shown in Figure 7. Both
switches are "normally open" switches that connect to
ground when pressure exceeds approx. 44 psi and are
used to verify valve movement in the valve body
assembly.
Pressure Switch 1 (G193) is used to verify activation
of the K-1 clutch.
Pressure Switch 2 (G194) is used to verify activation
of the B-2 clutch. Therefore, pressure switch 2 is
closed in tiptronic mode only, 1st gear. The only other
time the B-2 clutch is required is in reverse (R) gear.
Pressure Switch 2 does not close in the reverse
position, as reverse is engaged by the manual valve
hydraulically.
Note: Both pressure switches were eliminated in all
09G transaxles from June 2004 on.
If they're not there, but the TCU still looking for them, I would expect it to throw fault codes.
That's why I suggested you try the later coding, but apparently that's not enough to convince the TCU to not look for them.
colin
New Zealand
C?ID=254057
Yes I thought that would be enough as well, but there must be something else that is still looking for the sensor signals and getting nothing then flagging both sensors as faulty.
Is there any way with VCDS I can monitor various signals from/to the TCU to see what may be generating the error codes? i.e. can I view the G193/4 sensors signals, that shouldn't be there, but are (virtual) and are being expected anyway?
There
NEtech
Denmark
C?ID=56995
Have you changed the original transmission ?
Why do you think you have 09G transmission ?
So you have checked the wiring for the sensors, are not in place in your TCM controller ?
NZDubNurd
New Zealand
C?ID=230482
Was something done that triggered the code?
Or was it all happy as larry, then one day the MIL came on and these codes were there?
colin
New Zealand
C?ID=254057
Hi There,
Does anybody have copies of the transmission wiring diagram for a Toureg 2006 please?
I have tried erwin without success.
Regards,
Colin
colin
New Zealand
C?ID=254057
I drained the oil and removed the transmission sump cover to check the wiring and sensors called by the error
code. The Valve body that is installed doesn't have either of the sensors G193 or G194. Also, all the technical
documentation I have read has said the 09G valve bodies were used in all 2006 Touaregs onwards.
colin
New Zealand
C?ID=254057
The car was imported and arrived with a faulty key ignition start system. I don't have the history of the car.
VW locally installed new electronics and key modules that had to be imported from Germany.
I took the car back to VW and explained the problem. They kept the car for an hour and said it must be the valve
body at fault and to replace it and the wiring loom. I told them the valve body changes gears and behaves perfectly.
They could not explain where the false codes were coming from.
My experience with VW service cantres is that they have no concern for the cost of repairs and always throw new
parts at every problem, regardless of the price.
I have had many such run ins with them in the past, they are useless and basically just trained part swappers, (if there is such a word)
I could write a book on my experiences with VW, BMW, Mercedes etc stealerships and how they fleece customers unnecessarily because
they couldn't be bothered to efficiently and cost effectively repair their brands.
I'll stop there.........
colin
New Zealand
C?ID=254057
Hello Again,
Something interesting I have noticed.
If I always put the car into neutral as
I am about to stop the error never occurs, seems odd.
Does anybody know what is happening with the transmission as you stop that could cause this?
Colin
