2017 Audi Q7 Developer Mode
   #21
rlarsen
Copenhagen, Denmark
C?ID=78998
I thought there was supposed to be a MIB 1 or MIB 2 work around using SD card which is what I was advised in November of last year ?
As I appreciate the pictures above can this only be seen when the hidden menu is unlocked ?
A little confused now, thank you for all the support you folks have given so far
Yes, you need to enable it in unit 5F to get access to the Green Menu (Hidden Menu) - but VCDS is no help here.
   #22
Eric
HC800000
It is not possible to enable with the VCDS cable on the newest models...
I know - hidden menu (developer menu) is AFAIK also there on the newest models (A4/A5 B8.5
http://mr-fix.info/mmi-hidden-green-menu-2g-3g/
A4/A5 B9 - A6/A7 4G - Q7 4M
   #23
satpat2
C?ID=255340
is VCDS a no go even in the future ? or just at the moment ?
   #24
Hi Dan,
We tested some stuff and I made a lbl file for your 4M1 Q7 part number in addition to Shaun's 8W0 flavor. It certainly isn't complete (no coding at all) but I can e-mail it to you for testing. I take it this is your personal car right?
Best,
Edit, I sent the tester file to the admin@...... e-mail account with the subject 2017 Audi Q7 Developer Mode.
rlarsen
Copenhagen, Denmark
C?ID=78998
No not tired yet :)
Then why has no one then been able to use the VCDS cable for this - until your screen shot today ??
What is your models installed option data for the shown apparently successful activation??
   #26
Eric
HC800000
You just need a label with some macro instructions inside, which Dana just wrote for those two part numbers. If you post a scan showing the need maybe we can make you one too :)
But it's definitely not a matter of writing directly to the EEPROM, just getting the adaptation to be accepted.
   #28
I missed this http://forums.ross-tech.com/showthr...-Reg-Hidden-Menu&p=91194&viewfull=1#post91194
> Address 5F: Information Electr. (J794) Labels: None
> Part No SW: 4G1 035 021 F HW: 4G1 035 021 D
> Component: MU-H-LND-EU 052 0670
> Serial number: A733H0G7504554
> Coding: 017503010000000013111102000A00332F000CE7F1700100DF
> Shop #: WSC 02391 785 00200
> ASAM Dataset: EV_MUHig6C3Gen2HBAS 001115
> ROD: EV_MUHig6C3Gen2HBAS_AU57.rod
> VCID: 1D318F3E0CF36CAAB7-8048
I didn't even look at the 4G/4H part number modules earlier so satpat2 feel free to bump this back up and we can look into that. Hopefully we have Q7 feedback at that time.
   #29
TBAx
C?ID=287144
That's what I meant at the beginning of this thread. :) Thanks for shedding some light there, Eric.
   #30
Dan@EuropaParts
Piscataway, NJ, USA
C?ID=123730
Hi Dan,
Best,
Hi Dana,
I tested it this morning and it worked! The developer mode adaptation can now be set to activated after entering S12345 security code. Consequently, the green menu can be activated by holding NAV/RADIO simultaneously. Thanks a lot for your assistance with this.
Best,
Daniil
P.S. Yes, this is for my personal car.
   #31
satpat2
C?ID=255340
So what info do you need from me to make this happen ? and thanks in advance for helping with this complex issue, you folks are great !
   #32
You have e-mail :)
   #33
satpat2
C?ID=255340
I have ran an autoscan, hope this helps
Thursday,30,March,2017,14:35:26:17058
VCDS Version: 17.3.1.0 (x64)
Data version: 20170320 DS270.2
VIN: xxxx  License Plate: xxxx
Chassis Type: 4G (4G8)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 28 30 34 36 3B 3C 42 44
          46 52 53 55 5F 62 6C 6D 72 82 85 8B 8E 8F 90 AC
VIN: xxxx   Mileage: 6923km-4301miles
Address 01: Engine (J623-CZVA)       Labels: None
   Part No SW: 4G2 907 311 B    HW: 4G2 907 311 A
   Component: 3.0TDI MD1    H24 0003
   Revision: C4H24---
   Coding: 1A254012046601030800
   ASAM Dataset: EV_ECM30TDI0114G2907311B 001007
   ROD: EV_ECM30TDI0114G2907311B.rod
   VCID: 2447BADA2F995D60D9-8070
Address 02: Auto Trans (J217)       Labels: 0B5-927-156.clb
   Part No SW: 4G0 927 166 K    HW: 0B5 927 156 K
   Component: 0B5 30 TDIRdW H03 0006
   Revision: --H03---
   Coding: 100001
   ASAM Dataset: EV_TCMDL501021 001022
   ROD: EV_TCMDL501021.rod
   VCID: 3561779E9403D4E87E-8060
Address 03: ABS Brakes (J104)       Labels: Redir Fail!
   Part No SW: 4G0 907 379 S    HW: 4G0 907 379 S
   Component: ESP9 Premium  H01 0530
   Coding: 17A6DE4BE8657BD29B00
   ROD: EV_ESP9BOSCHAU57X.rod
   VCID: 4189134ED0CB6848D2-8014
   Part No SW: 4H0 907 064 HN    HW: 4H0 907 064 HN
   Component: BCM2 2.0      H61 0824
   Coding: 01BA704E000000000000
   VCID: 7CF7A2BAFFA9C5A0C1-8028
   Serial number: 3216000137851013
Address 08: Auto HVAC (J255)       Labels: 4G0-820-043-4Z.clb
   Part No SW: 4G0 820 043 CD    HW: 4G0 820 043 CD
   Serial number: 23081600040783
   Coding: 36231178350000
   VCID: 63C5F9C66A171A58E0-8036
Address 09: Cent. Elect. (J519)       Labels: Redir Fail!
   Part No SW: 4H0 907 063 GG    HW: 4H0 907 063 AG
   Component: BCM1 2.0      H20 0368
   Revision: 14020001    Serial number: 00001421234801
   Coding: 0105C01441349FE2C9014083A0001800CF9DC30A2F080201000008946100170200400009090000
   VCID: 73E58986D2F78AD890-8026
   Subsystem 1 - Part No SW: 4G2 955 119     HW: 4G8 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS57X 160622  H38 0080
   Serial number:         160701112001
   Coding: 0045F7
   Serial number: 62161523
   Coding: 02006E
   Subsystem 3 - Part No SW: 4G0 941 531 BG    HW: 4G0 941 531 BG
   Component: E1 - LDS  H07 0044
   Serial number: 12 07 2016  00001786
   Subsystem 4 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
   Component: AQ_Hum_Sensor  H01 0005
   Serial number: F1B9424800PAG0MUFU03
Address 10: Park/Steer Assist (J791)       Labels: None
   Part No SW: 4G0 919 475 H    HW: 4H0 919 475 E
   Component: PARKHILFE PLA H06 0080
   Revision: --------    Serial number: 56231620100794
   Coding: B83B10
   ASAM Dataset: EV_EPHVA2CAU64X0000 001014
   ROD: EV_EPHVA2CAU57X0000.rod
   VCID: 366370928905DFF077-8062
Address 13: Auto Dist. Reg (J428)       Labels: 4H0-907-561.clb
   Part No SW: 4G0 907 561 B    HW: 4G0 907 561
   Component: ACC3          H21 0055
   Coding: 7E04010201
   ASAM Dataset: EV_AdaptCruisContrAU57X 002015
   VCID: 2959ABEE48BB8008EA-807C
Address 15: Airbags (J234)       Labels: 4H0-959-655.clb
   Component: Airbag10.43   H82 0086
   Revision: --------    Serial number: 003P100AX60Z
   Coding: 30333046313130313137554A305234473853
   ROD: EV_AirbaAU10BPAAU64X_AU57.rod
   VCID: 3B7561A6B227029888-806E
   Serial number: 3575HRB400O5703KF0P6
   Serial number: 3585HRB400M5703K712I
   Serial number: 3515JRB4014571NEKH61
   Serial number: 3525JRB40065744AE1IG
   Serial number: 3554VRB4006574IOOGI/
   Serial number: 3564VRB4006574IOMP9$
Address 16: Steering wheel (J527)       Labels: 4H0-953-568.clb
   Revision: --------    Serial number: 90372PG30003B
   Coding: 0000FC
   VCID: 377D7D96860F26F86C-8062
   Subsystem 1 - Part No SW: 8U0 951 528 H    HW: 8U0 951 528 H
   Serial number: 20 07 2016  A0040505
Address 17: Instruments (J285)       Labels: 4H0-920-xxx-17.clb
   Part No SW: 4G8 920 988 D    HW: 4G8 920 988 D
   Component: TDieGb Acc    H14 0218
   Revision: 11001108    Serial number: 658010816596027
   Coding: 338F05021F532600010100
   ASAM Dataset: EV_RBD4K 004060
   ROD: EV_RBD4K.rod
   Part No SW: 4G8 907 468 H    HW: 4G8 907 468
   Revision: --------    Serial number: 00000002350070
   Coding: C0CD078118
   VCID: 3D716FBEAC330CA8B6-8068
   Subsystem 1 - Part No SW: 8S0 915 181 B    HW: 8S0 915 181 B
   Serial number: 7598300804
   Voltage stabilizer:
          U140B 00 [008] - -
                    Reset counter: 203
                    Mileage: 6337 km
                    Date: 2017.03.14
                    Time: 17:08:52
                    Voltage terminal 30: 11.3 V
                    Voltage terminal 15: 11.2 V
                    Control Module temperature: 27 °C
                    System status: Terminal 15 on
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 1
Address 28: HVAC, Rear (E265)       Labels: 4G0-919-158.clb
   Part No SW: 4G0 919 158 Q    HW: 4G0 919 158 Q
   Component: KLIMA FOND    H08 0113
   Serial number: 22081600040912
   Coding: 22
Address 30: Special Function II (J843)       Labels: 8K0-907-440.clb
   Part No SW: 4H0 907 440     HW: 4H0 907 440
   Component: STS           H06 0030
   Revision: S0H06000    Serial number: 00000000096483
   Coding: 01010101000000000001000202
   VCID: 64C7FADA67191D6019-8030
Address 34: Level Control (J197)       Labels: 4G0-907-553.clb
   Coding: 008002
   ROD: EV_AirSuspe_VW51.rod
   VCID: 2F6D45F6765FEE3834-807A
   Revision: AA000000    Serial number: 00000213103628
   Coding: 0078130000006001000001010101102030303232203232
   VCID: 77FDBD96C68FE6F8AC-8022
   Part No SW: 4G0 907 637 K    HW: 4G0 907 637 F
   Component: SARA 6D       H04 0056
   Revision: --------    Serial number: EJ1BPA820BZRH8
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
Address 3C: Lane Change (J769)       Labels: 5Q0-907-566.clb
   Part No SW: 4G0 907 566 M    HW: 4H0 907 566 F
   Component: SWA Master    H08 0070
   Serial number: 0410239592
   Coding: 040312
   VCID: 39797BAEB81B30889A-806C
   Lane Change Assistant 2:
   Subsystem 1 - Part No SW: 4G0 907 568 M    HW: 4H0 907 568 F
   Component: SWA Slave  H08 0070
   Serial number: 0409413292
   Coding: 040312
   Part No SW: 4G8 959 793 H    HW: 4G8 959 793 F
   Component: TSG FA        H04 0511
   Coding: 011F56035E21628002080413
   VCID: 4581075ECCE34468EE-8010
Address 44: Steering Assist (J500)       Labels: 4G0-909-144.clb
   Component: RCevo         H54 0202
   Revision: 00000001    Serial number: 0000194620
   Coding: 101101010001
   ASAM Dataset: EV_RCEPS 106007
   ROD: EV_RCEPS_106_AU57.rod
   VCID: 3A7B64A2BD1D3B9093-806E
Address 46: Central Conv. (J393)       Labels: 4H0-907-064-46.clb
   Revision: 00002001    Serial number: 0412812716
   Coding: 017F0622A0B9B882C3A00A840C010D470000000000000000000000000000
   Subsystem 1 - Part No: 4G0 951 177 B
   Component: Sensor, DWA  005 0002
   Subsystem 3 - Part No SW: 4G0 947 135 B    HW: 4G0 947 135
   Serial number: 0000000AP00023851075
   Subsystem 4 - Part No SW: 4G8 959 252 A    HW: 4G8 959 252
   Component: HSP-SG  H11 0031
   Serial number: WA124729000023711745
03622 - Control Module 2 for Roof Shade
                    Reset counter: 3
                    Mileage: 137 km
                    Date: 2016.09.25
                    Time: 11:12:17
   Component: TSG BF        H03 0511
   Coding: 011F56035E21628002080402
   VCID: 46830052F1E54F70E7-8012
   Part No SW: 4H0 907 801 L    HW: 4H0 907 801 A
   Component: EPB-4         H05 0017
   Revision: --------    Serial number: 00000001936082
   ASAM Dataset: EV_ParkiBrake 001029
   ROD: EV_ParkiBrake_AU57.rod
   VCID: 3169438E606BF8C822-8064
Address 55: Headlight Range (J745)       Labels: 4H4-907-357-V2.clb
   Coding: 05FE02202A170200
   VCID: 34674A9A9F79CDE049-8060
   Subsystem 1 - Part No SW: 7PP 941 472 K    HW: 7PP 941 472 K  Labels: 3D0-941-329.CLB
   Component: LED LeiMo li.  H07 7570
   Coding: E02100
   Subsystem 2 - Part No SW: 7PP 941 472 K    HW: 7PP 941 472 K  Labels: 3D0-941-329.CLB
   Component: LED LeiMo re.  H07 7570
   Coding: E02100
   Matrix Headlamp Powermodule 1 Left:
   Subsystem 3 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
   Component: MxB LeiMo li.  H03 0031
   Coding: E02100
   Matrix Headlamp Powermodule 1 Right:
   Subsystem 4 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
   Component: MxB LeiMo re.  H03 0031
   Coding: E02100
   VCID: 1D318F3E0CF36CA896-8048
   Subsystem 1 - Part No SW: V03 959 801 FC    HW: -----------
   Component: ECE 2017  --- 0157
   Subsystem 2 - Part No SW: 4G1 919 605 B    HW: 4G1 919 605 B
   Component: DU8 C7 SV  H63 0007
   Serial number: AUZ8Z9GY805Q1Y
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 4G2 919 610 F    HW: 4G2 919 610 F
   Serial number: 90349PHC00014
   Compact Disc Database:
   Component: Gracenote2---  --- 1013
   Component: TSG HL        H03 0511
   Coding: 010F14024021628002080002
   VCID: 49990B6EE0FBA0080A-801C
Address 6C: Back-up Cam. (J928)       Labels: None
   Part No SW: 4H0 907 428 E    HW: 7P6 907 441 G
   Component: TopView       H09 0361
   Revision: 11001001    Serial number: 82330JG0189229
   Coding: 0216000001000100000102000000
   ASAM Dataset: EV_CamerSysteTopViewAUDI 008028
Address 6D: Trunk Elect. (----)       Labels: Redir Fail!
   Part No SW: 4G8 959 107 S    HW: 4G8 959 107 H
   Component: HDSG-Modul    H14 0049
   Revision: 11014001    Serial number: 196600373
   Coding: 0A3305C002
   ASAM Dataset: EV_HDSGAu573 001022
   ROD: EV_HDSGAu571.rod
   VCID: 4581075EC4E34468EE-8010
   Component: TSG HR        H03 0511
Address 82: Heads Up Display (J898)       Labels: None
   Part No SW: 4G8 919 604 N    HW: 4G8 919 604 N
   Component: HeadUpDisplay H09 0306
   Coding: C60000
   ASAM Dataset: EV_HUDContiC7 001027
   ROD: EV_HUDContiC7_VW51.rod
   VCID: 3E7368B2A13517B0AF-806A
Address 85: On Board Cam. (J852)       Labels: None
   Component: DPC-SG        H27 0081
   Coding: EA160000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 2C5752FA4749952011-8078
Address 8B: Adaptive Cruise 2 (J428)       Labels: 4H0-907-561.clb
   Part No SW: 4G0 907 541 B    HW: 4G0 907 541
   Coding: 7E04010201
   ASAM Dataset: EV_AdaptCruisContr2AU57X 002013
   VCID: 275DADD65EAFB678FC-8072
Address 8E: Image Processing (J851)       Labels: 4H0-907-107-V2.clb
   Part No SW: 4H0 907 107 H    HW: 4H0 907 107
   Component: BV-SG         H34 0090
   Serial number: 005002452707167
   Coding: 03C23A181111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
   Component: RGS-VL        H16 0080
   Coding: 0066E608031F0376070308004240C2010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   Component: RGS-VR        H16 0080
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   VCID: 326B4C82656DC3D05B-8066
   Part No SW: 4G0 907 355 G    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0013
   Revision: 00000000    Serial number: 161880754
   ROD: EV_RDCMA00100_008.rod
End-------------------------(Elapsed Time: 06:29)--------------------------
satpat2
C?ID=255340
You have e-mail :)
Dana, this worked, absolute legend !, would you possibly be so kind to help me resolve the errors I have below and the window closure, thank again, really appreciate it
   #35
Nice! I can't claim the Legend status though. That was a total team effort that began back here
http://forums.ross-tech.com/showthread.php?6079-Developer-Mode-Access-on-MIB-units
.. but we didn't realize the same applied to the 4H/4G+ vehicles until recently. Sebastian is going to work on the permanent lbl files in that natural order though (4G>8W>4M) so we will eventually get all of those 5Fs covered properly (real redirects and labels with coding info, etc).
In the meanwhile I'm gonna move that window question to your original thread.
TBAx
C?ID=287144
Wow that was "easy". I guess all current and near future Infotainment systems will require the same method...
   #37
satpat2
C?ID=255340
You have e-mail :)
Hey Guys
I have managed to activate the developer mode but no matter what sequence of buttons I press I can't get the unit to restart, enter green menu nor enter engineers mode, what am I doing wrong ?
   #38
rlarsen
Copenhagen, Denmark
C?ID=78998
   #39
satpat2
C?ID=255340
Yes I have tried pressing them together but also one at a time, I have the nav and car button so tried that too, really confused now
   #40
NEtech
Denmark
C?ID=56995
This thread was about Audi Q7 (4M) (8W + FV).
Did you see the models for the buttons ?
Your model is Audi A7 (4G), right ?
From SSP it is like this, I don't know if that can be used for Green Menu.
