"99" Audi A8 Instrument coding.
Chr15
C?ID=207693
Just looking for some guidance and if its possible.
Got a 99 audi a8 v8.
It's a bit of a project car.
Im looking to try and code out the abs from the instruments, all the abs has been removed but just left with that annoying beep when running.
Is it possible and would anyone know the correct coding. TIA
Saturday,25,March,2017,11:47:05:26527
VCDS Version: 17.2.6.1 (x64)
Data version: 20170320 DS268.2
VIN:    License Plate: T623 JCC
Mileage: 221170km-137428mi   Repair Order:
Chassis Type: 4D - Audi A8 D2 (1994 > 2003)
Scan: 25 01 03 08 11 15 16 17 18 35 37 45 55 56 57 65 67 75 76 77
          02
   Mileage: 221170km-137428miles
Address 25: Immobilizer        Labels: 4B0-953-234.lbl
   Part No: 4B0 953 234
   Component: IMMO AUZ9Z0W4020218 D03
   Coding: 00000
   Shop #: WSC 00584
   VCID: 60CFA4A6E0243C400E-515C
   Part No: 4D0 907 557 P
   Component: 4,2L V8/4V  MOTR AT D01
   Coding: 04273
   Shop #: WSC 02324
   VCID: 397929C2233E0D8869-4B02
Readiness: N/A
Address 08: Auto HVAC        Labels: Redir Fail!
   Part No: 4D0 820 043 K
   Component: D2-KLIMAVOLLAUTOMAT D05
   Coding: 00081
   Shop #: WSC 02314
   VCID: 2447E8B6B4BC60602A-256E
            41-10 - Blocked or No Voltage - Intermittent
00734 - Potentiometer in Central Vent (G142)
            30-00 - Open or Short to Plus
            57-10 - Electric Circuit Failure - Intermittent
Address 17: Instruments        Labels: 4D0-919-033-MYW.lbl
   Part No: 4D0 919 035 N
   Component: D2-KOMBIINSTRUMENT  D52
   Coding: 00483
   Shop #: WSC 19411
   VCID: 316911E2FB4EC5C8D1-5074
Address 35: Centr. Locks        Labels: 8D0-862-257.lbl
   Part No: 8L0 862 257 G
   Component: ZV-Pumpe, DWA, Funk D06
   Coding: 13130
   Shop #: WSC 02314
   VCID: 397929C2233E0D8869-4EEA
9 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
            35-00 -  -
01372 - Alarm triggered by Door Contact Switch; Rear Passenger Side
            35-00 -  -
01370 - Alarm triggered by Interior Monitoring
            35-00 -  -
01368 - Alarm triggered by Luggage Compartment Switch
            35-00 -  -
01366 - Opened Due to Crash Signal
            35-00 -  -
01360 - Switch for Anti-Theft Alarm; Open
            29-00 - Short to Ground
01365 - Lock/Unlock Switch; Interior
00991 - Interior Lights
            28-00 - Short to Plus
00955 - Key 1
            09-00 - Adaptation Limit Surpassed
Address 45: Inter. Monitor        Labels: 4B0-951-173.lbl
   Part No: 8L0 951 173
   Component: Innenraumueberw.    D04
   Coding: 00001
   VCID: 6ED3CA9E2AF09A308C-4B1A
Address 56: Radio        Labels: 8D0-035-1xx-56.lbl
   Part No: 4B0 035 186
   Component:  Radio             0001
   Coding: 00207
   Shop #: WSC 02314
   VCID: 5DB19D52D75611A825-4B02
00856 - Radio Antenna
            36-00 - Open Circuit
00854 - Radio Display Output in dash Panel insert
Since these cars were never produced without ABS, I doubt that's possible.
Guitarman
C?ID=56603
It wouldn't pass an MOT with the ABS pump missing. Unless you are using it as a track car you will have to fix it. Hey, I just checked online and your MOT is coming up next month lol! Don't forget that perishing O/S drive shaft boot from last year ;-)
Gone But Not Forgotten
LOL............:p
OP ........Just fix the ABS ........it's so simple of a system.
Chr15
C?ID=207693
Its not mine its a customers project. not sure what he has in mind for it tbh. (Would of thought its a big tub for a track car)
Would be no issue fixing it not sure if there was even a fault with it before he started removing parts.
Thanks for your MOT Reminder though :thumbs:
Pretty sure it wont be getting another one.
Im an MOT Tester also and it would need more than just the abs and his cv gaiter before i would be passing it.
