Confirmed Tweaks on 2016 Jetta 1.4T CZTA Manual "S" with Technology.
Roady900
C?ID=303383
Greetings.
I could not find a tweak thread specific to my "entry" level Jetta, so I thought I would start one. I invite others with the 1.4T to post their findings.
Tweaks verified to be working:
  1. Tear Drop Wipe
  2. Remote Windows (Keyfob Control)
  3. Hide AM from MIB2 Composition Media. "Band" button toggles only FM and Sirius
  4. Celebration (Needle Sweep)
***The adaption or coding to enable hazard lights under emergency breaking was/were accepted, but I have not yet had a chance to confirm that it is working.
Tweaks Wanted:
  1. Enable Wifi (Client? WLAN? UPNP? WLAN Hotspot?) on Composition Media for Wireless Carplay. Is this possible on the Composition Media? (I do have WIRED carplay)
Retrofit Wanted:
  1. Traction Control Button (ie: USP Motorsports) and coding for ABS Brakes. Has anyone confirmed on their 1.4T Jetta?
georgerl
Canada
C?ID=320952
Confirmed. ESP on/off button from USP Motorsports is working 100% on my 1.4t 2016 Jetta 6-speed auto.
In my case the ABS control module needed coding. Following the USP Motorsports directives, I saved the original coding before making the changes, as "Recoding of your module is done at your own risk" and then I changed for the values in Bold.
A14B400C49240003850B02E7921E0041A1180022
voila, when engaged the dash displays ESP off and tires are screaming...
Roady900
C?ID=303383
That's interesting. I installed the USP traction control button about 6 months ago and forgot to update this post. I had made the same coding changes you made. I am able to turn off traction control (I get the indicator that is a car with the wavy lines) but do not get "ESP off" indicator. Do you get the same car with wavy lines at the tire or the words "ESP Off?" After initially engaging the button, are you able to press and hold a second time to get yet another mode?
What Part No do you have? The following is my info along with my original coding, current coding, and your current coding.:
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 CC HW: 1K0 907 379 CC
Component: ESP MK60EC1 H46 0175
Revision: 00H46001
ORIGINAL Coding:
A1 4B 40 0C 49 29 00 03 85 0B 02 E8 92 1B 00 40 21 10 00 12
MY CURRENT CODING:
A1 4B 40 0C 49 29 00 03 85 0B 02 E8 92 1B 00 40 21 18 00 22
YOUR CODING:
A1 4B 40 0C 49 24 00 03 85 0B 02 E7 92 1E 00 41 A1 18 00 22
Shop #: WSC 00066 000 00000
VCID: 75B4E8C555C9F6CF662-8020
While our coding is VERY similar I see 5 variations marked in bold. I wonder if this is because you have an automatic and I have a manual? I wonder what would happen if I tried your entire code. Do you think it would damage anything?
Roady900
C?ID=303383
Revision: 00H46001
ORIGINAL Coding:
MY CURRENT CODING:
YOUR CODING:
So I tried your code making change one at a time. The 4 and the 7 were out of range and the rest were accepted. I reverted back after testing. I still only had the Car icon...
georgerl
Canada
C?ID=320952
You got it, that's it I get the icon with the car, wavy lines and off written under.
Here is my ABS pedigree:
Part No SW: 1K0 907 379 CB HW: 1K0 907 379 CB
Component: ESP MK60EC1 H46 0174
Revision: 00H46001
Coding: A14B400C492700FF850D02EB9221004121180022
Shop #: WSC 00066 123 12345
VCID: 74B122187EBB4AE74E9-8020
georgerl
Canada
C?ID=320952
That is so weird, this coding I just pulled from the car and nothing has been done on it. Last coding I did was the ESP button and I copy paste the coding before and after for backup…
Car has not been in service anywhere and I did myself the last oil change. I was on the same cable and PC.?!? Weird
