VW Caddy MY2012 1,6l CR TDI CAYE Fuel pressure too high?
MartinsX
Riga, Latvia
C?ID=268515
Do anyone have any experience with fault code 10117/P229B Fuel pressure too high?
What is meaning of Fuel Pressure Regulation Valve 2 in fault code description? Is it high pressure regulating valve N276 or fuel metering valve N290 or pressure retention valve in return line? Probably not the last one, but why valve 2? A lot of fault code descriptions include component names as in WD/FSM, but not this time.
Tuesday,21,March,2017,12:25:27:32442
VCDS Version: 17.1.3.0
VIN: WV1ZZZ2KZCX038125   License Plate:
Chassis Type: 2K (7N0)
Scan: 01 03 09 15 16 17 19 25 42 44 46 52 56
VIN: WV1ZZZ2KZCX038125   Mileage: 239230km-148650miles
Address 01: Engine (J623-CAYE)       Labels: 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 PA    HW: 03L 907 425 C
   Component: 1,6l R4 CR td H43 2531
   Revision: --H43---    Serial number: 00000000000000
   Coding: 00114010030400080000
   Shop #: WSC 35110 790 50316
   ASAM Dataset: EV_ECM16TDI02103L906023PA 003005
   ROD: EV_ECM16TDI02103L906023DB.rod
   VCID: 74E7B6EFDFC595E1FD-8020
10117 - Fuel Pressure Regulation Valve 2 Control Difference
          P229B 00 [237] - Pressure too High
                    Mileage: 239211 km
                    Date: 2017.03.20
                    Time: 11:00:30
                    Engine speed: 979.50 /min
                    Normed load value: 20.8 %
                    Vehicle speed: 8 km/h
                    Coolant temperature: 60 °C
                    Intake air temperature: 10 °C
                    Voltage terminal 30: 14.118 V
                    Fuel high pressure: actual value-FUP_FIL: 44.153 MPa
                    Fuel pressure regulator valve: specified value rail pressure-LV_PCV_CTL: 00000001
                    Engine status-SF_ENG_STATE: IS
                    Fuel temperature-TFU: 11 °C
                    Fuel Metering Valve-VCV: 23.492 %
                    Fuel Pressure Regulator Valve-PCV: 0.006 %
                    Fuel high pressure commanded value_1-FUP_SP_KPA_ENVD: 32202.148 kPa
Readiness: 0010 0000
   Part No SW: 1K0 907 379 BH    HW: 1K0 907 379 BH
   Revision: 00H31001
   Coding: 423C200D09250302420C04E6901EC041300000
   Shop #: WSC 35110 377 00142
   VCID: 79F987DBF0A7E889AE-802C
   Part No SW: 2K5 937 085     HW: 2K5 937 085
   Component: BCM PQ35 B+   011 1044
   Revision: BB011001
   Coding: 411A583A8025F36908800082900000640301728852020060648000000040
   VCID: 72EBB0F7ADD19BD1EF-8026
   Subsystem 1 - Part No: 1T1 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer 12081  26  0512
   Coding: 009795
   Subsystem 2 - Part No: 7N0 951 171
   Component: DWA-Sensor 00  002 0205
   Component: VW10Airbag00N H06 0013
   Revision: --------    Serial number: 003HL006XJ7K
   Coding: 00000000000000000000000000000000304E
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 35614BEB943FCCE90A-8060
   Part No SW: 1K5 953 507 M    HW: 5K0 953 549
   Revision: --------    Serial number:  90440KHH00006
   Coding: 0080060000
   ROD: EV_SMLSNGKUDS_VW32.rod
   VCID: 3B755DD3B21B1A99FC-806E
   Part No SW: 2K0 920 865 E    HW: 2K0 920 865 E
   Component: KOMBI         H03 0606
   Coding: 180001
   ROD: EV_Kombi_UDS_VDD_RM09_VN35.rod
   VCID: 306F7AFF6B5DE9C159-8064
   Part No SW: 7N0 907 530 H    HW: 1K0 907 951
   Component: J533  Gateway H42 1620
   Revision:   H42       Serial number: 180811F2002463
   Coding: 357400
   VCID: 35614BEB9C3FCCE90A-8060
   Component: IMMO          H03 0606
   VCID: 6ADBA8978D01531157-803E
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN3.clb
   Part No SW: 1T0 959 701 T    HW: 1T0 959 701 T
   Component: Tuer-SG         009 2109
   Coding: 0000048
   VCID: 489F321F3BCD410161-801C
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 140    3201
   Revision: 00H20000
   VCID: 346776EF5745D5E13D-8060
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN3.clb
   Part No SW: 1T0 959 702 R    HW: 1T0 959 702 R
   Coding: 0000048
   VCID: 479D312336D34E7968-8012
   Part No SW: 5K0 035 156     HW: 5K0 035 156
   Component: Radio         H30 0072
   Revision: R0000000    Serial number: VWZAZ1L3521976
   Coding: 0000020001
   VCID: 64C7C6AF672505616D-8030
                    Fault Status: 00110010
                    Reset counter: 133
                    Mileage: 239025 km
                    Date: 2017.02.09
                    Time: 14:31:01
End-------------------------(Elapsed Time: 02:19)--------------------------
Actually, VW has removed them from most of their own fault code texts (older ones that used to have them), and doesn't seem to use them at all in their newer ones. :(
Gone But Not Forgotten
What he said /\
If in question unplug valves until a DTC is recorded and use the variable resistor to induce and determine faults to identify.
It is often not ref correctly for the HPP system valves in the WD compared to VCDS or VAS 50xx testers.
A special journal is needed to keep.
