VW passat b6 year 2006 abs
Porelo
Portugal
C?ID=42635
Hi , I need help , I have a passat b6 year 2005 in my workshop and I have a problem with ABS-ESP system , lost coding
any one can help my to find the correct coding
Friday,17,March,2017,16:29:33:52040
VCDS Version: 16.8.3.1
Workshop Code: 784 00051 000000
VIN: WVWZZZ3CZ6E114471   License Plate:
Mileage: 195360km-121391mi   Repair Order: URB
Chassis Type: 3C (3C0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 53 55 56 62 65 72 76
          77 7D
VIN: WVWZZZ3CZ6E114471   Mileage: 195360km-121391miles
Address 01: Engine        Labels: 03G-906-018-BKP.clb
   Part No SW: 03G 906 018     HW: 03G 906 018
   Component: R4 2.0l PPD1.1 G    9722
   Revision: --H01---    Serial number: VWZCZ000000000
   Coding: 0000072
   Shop #: WSC 00044 261 90326
   VCID: 62C03ECEBD84F952CA-8036
18061 - Please check DTC Memory of ABS Controller
            P1653 - 008 -
                    Fault Status: 11011000
                    Reset counter: 45
                    Mileage: 195361 km
                    Date: 2017.03.17
                    Time: 16:50:07
                    Text:      0    Nm
                    Text:  0.0    %
                    Voltage: 11.98 V
                    Bin. Bits: 00000100
                    Text:   1016    Nm
Readiness: N/A
Address 03: ABS Brakes        Labels: 3C0-614-095-C2.clb
   Part No SW: 3C0 614 095 Q    HW: 3C0 614 095 Q
   Component: ESP 440 C2     H015 0003
   Revision:  H015       Serial number: 0658389733
   Coding: 0029986
   Shop #: WSC 00051 784 00000
   VCID: 30648486A3E81BC20C-8064
02841 - Hydraulic Unit
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 44
                    Mileage: 195361 km
                    Date: 2017.03.17
                    Time: 17:23:35
            014 - Defective
                    Reset counter: 44
                    Mileage: 195361 km
                    Date: 2017.03.17
                    Time: 17:23:35
                    Reset counter: 44
                    Mileage: 195361 km
                    Date: 2017.03.17
                    Time: 17:23:35
                    Reset counter: 44
                    Mileage: 195361 km
                    Date: 2017.03.17
                    Time: 17:23:35
                    Reset counter: 44
                    Mileage: 195361 km
                    Date: 2017.03.17
                    Time: 17:23:35
                    Reset counter: 44
                    Mileage: 195361 km
                    Date: 2017.03.17
                    Time: 17:23:35
Address 08: Auto HVAC        Labels: 3C0-907-044.lbl
   Part No SW: 3C0 907 044 Q    HW: 3C0 907 044 Q
   Component: ClimatronicPQ46 042 0202
   Revision: 00042004    Serial number: 00000000000000
   VCID: 2F6687FABED6043A15-807A
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 J    HW: 3C0 937 049 J
   Component: Bordnetz-SG     H37 1301
   Revision: 00H37000    Serial number: 00000002213904
   Coding: E78A8F0700041A00000A00000F000000000B5D435C0000
   Shop #: WSC 05311 000 00000
   Subsystem 1 - Part No: 3C1 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer VW461  012  0503
   Coding: 00065493
   Shop #: WSC 05311
   Subsystem 2 - Part No: 1K0 955 559 T  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 011  1110
   Coding: 00208933
   Shop #: WSC 05311
00924 - Relay for Headlamp Cleaning System (J39)
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 45
                    Mileage: 195361 km
                    Date: 2017.03.17
                    Time: 16:50:00
                    Voltage: 12.00 V
   Part No SW: 3C0 909 605 N    HW: 3C0 909 605 N
   Component: 1R AIRBAG VW8R  032 2522
   Revision: 13032000    Serial number: 003B2P75H3F2
   Coding: 0012626
   Shop #: WSC 00025 261 89618
   VCID: 31628182A8E212CA03-8064
   Subsystem 1 - Serial number: 6332MSME0B776336E
   Subsystem 2 - Serial number: 6342MSME0B490D7FV
   Subsystem 3 - Serial number: 6351HTS67SDI8853D
   Subsystem 4 - Serial number: 6361HTS67SD22772Z
   Subsystem 5 - Serial number: 6371VTS69SDU55B2%
   Part No SW: 3C0 953 549 B    HW: 3C0 953 549 B
   Component: Lenksäulenmodul 005 0010
   Revision: 00005000    Serial number: 3C9953507E
   Coding: 0000112
   VCID: 2B5E93EA8ACE781A39-807E
   Component: Lenkradmodul    007 0050
   Part No SW: 3C0 920 870 Q    HW: 3C0 920 870 Q
   Component: KOMBIINSTRUMENT VD1 4240
   Revision: X0033000    Serial number: 00000000000000
   Coding: 0007105
   Shop #: WSC 00044 261 63148
Address 19: CAN Gateway        Labels: 3C0-907-530-V1.clb
   Part No SW: 3C0 907 530 C    HW: 3C0 907 951 A
   Component: Gateway         007 0040
   Revision: 00007000    Serial number: 0700C05A05021F
   Coding: 7DFD3E04C62002
   VCID: 214271C2F802A24A93-8074
   Part No SW: 3C0 959 799 B    HW: 3C0 959 799 B
   Component:    IMMO         067 0364
   Revision: 00067000    Serial number: VWZCZ000000000
   VCID: 3874BCA64B98C38244-806C
   Subsystem 1 - Part No: 3C0 905 861 D
   Component:    ELV          024 0370
   3C0905861D     ELV          024 0370
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX2.lbl
   Part No: 1K0 959 701 L
   Component: Tuer-SG         024 2461
   Coding: 0000247
   VCID: 3776BF9A4686CCFA4D-8062
   Part No: 1K1 909 144 J
   Component: EPS_ZFLS Kl.5   D04 1606
   VCID: 32608E8EADE429D27A-8066
            000 -  -
Address 46: Central Conv.        Labels: 3C0-959-799-46.clb
   Component:    KESSY PQ46 R 067 0211
   Coding: 0191020851430E763804941570084FCE701D00030404A0
   Subsystem 2 - Part No: 3C0 951 171 A
   Component: Neigungssensor  002 0508
   Subsystem 3 - Part No: 3C0 951 171 A
   Component: Innenraumueberw.002 0508
00192 - Rear Left Door Handle Touch Sensor (G417)
                    Reset counter: 45
                    Mileage: 195361 km
                    Date: 2017.03.17
                    Time: 16:50:08
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX2.lbl
   Part No: 1K0 959 702 L
   Coding: 0000246
Address 53: Parking Brake        Labels: 3C0-907-801-53.clb
   Part No SW: 3C0 907 801 B    HW: 3C0 907 801 B
   Component: EPB  VC8HC001   013 0001
   Revision:   013
   Coding: 0000012
            000 -  -  - MIL ON
                    Fault Status: 11100000
                    Fault Frequency: 14
                    Reset counter: 44
                    Mileage: 195344 km
                    Date: 2017.03.16
                    Time: 18:34:47
                    Voltage: 10.46 V
                    Count: 170
                    Fault Status: 11101101
                    Reset counter: 45
                    Mileage: 195344 km
                    Date: 2017.03.13
                    Time: 13:15:11
                    Voltage: 10.77 V
                    Count: 236
Address 55: Headlight Range        Labels: 5M0-907-357-V1.lbl
   Part No SW: 5M0 907 357     HW: 5M0 907 357
   Component: AFS-Steuergeraet    X016
   Revision:   H09       Serial number:
   Coding: 0000001
   Shop #: WSC 05311 000 08193
   VCID: 71E24182686252CA43-8024
   Subsystem 1 - Part No: 7L6 941 329   Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul l    X017
   Coding: 00000035
   Subsystem 2 - Part No: 7L6 941 330
   Component: AFS-Lst.-Modul r    X017
   Coding: 00000035
   Part No: 1K0 035 195 B
   Component: Radio BVX       008 0015
   Coding: 0042400
   VCID: 254A65D2EC2A4E6AEF-8070
   Part No: 3C9 959 703
   Component: Tuer-SG         021 2505
   Coding: 0000144
   VCID: 70E4448663685BC24C-8024
   Component:    RDK              0391
   Coding: 0161211
   Part No: 3C9 959 704
   Coding: 0000144
Address 76: Park Assist        Labels: 3C0-919-283.lbl
   Part No SW: 3C0 919 283 B    HW: 3C0 919 283 B
   Component: Parkhilfe 8-Kan 004 0011
   Revision: 00004000    Serial number: 82930527901861
   Coding: 0000024
   VCID: 28546CE69B385302D4-807C
Address 77: Telephone        Labels: 3C0-035-729.lbl
   Part No SW: 3C0 035 729 E    HW: 3C0 035 729 E
   Component: Telefon             6919
   Revision: 00008000    Serial number: 0000000666166
   Coding: 0016023
00992 - Consumption Cut-Off Active
            000 -  -
                    Reset counter: 45
                    Mileage: 195361 km
                    Date: 2017.03.17
                    Time: 16:50:07
Address 7D: Aux. Heat        Labels: 1K0-963-235.lbl
   Part No SW: 1K0 963 235 E    HW: 1K0 963 235 E
   Component: PTC-Element         0404
   Revision: 00800000    Serial number:
   VCID: 2D5A9DF2B4DA762A27-8078
End-------------------------(Elapsed Time: 02:37)--------------------------
Address 03: DTCs cleared
Address 03,3C0 614 095 Q,recoded (Short coding),from,0029986,to,0046544,(00051/784/00000),
Fixed thread title. Car is clearly a 2006. WVWZZZ3CZ6E114471
Porelo
Portugal
C?ID=42635
The license plate is 2005 month 11.
Porelo
Portugal
C?ID=42635
Ok, Thanks
