Audi a6 2006 - 2.7TDI cranking but not starting
Henke
Sweden
C?ID=297201
Ok, here we go agian....,
Fixed the steering shaft module issue first (car totally dead). Then the MMI (2x times, different things), and now this........
Last weekend I replaced the 6x glow plugs. Took it out yesterday for a run. Worked beautifully, until the motor suddenly stopped... It is cranking, but does not start.
I got towed home and run the VCDS, below. I get some faults due to low battery - but that is quite normal after all cranking....:p
Any ideas...? This evening I will check if there is any voltage coming out to the glow plugs. The 80A fuse is fine. Anyone know how to test the glow plug relay (636)?
THANKS!!
Friday,17,March,2017,11:45:56:36004
VCDS Version: 17.1.2.0  HEX-V2 CB: 0.4334.4
Data version: 20170127 DS267.1
VIN: WAUZZZ4F46N131263   License Plate: YAJ429
Mileage: 368940km-229248mi   Repair Order:
Chassis Type: 4F (4F0)
Scan: 01 03 05 07 08 09 0E 0F 15 16 17 19 1E 37 42 46 47 4F 52 53
          55 56 61 62 72 77
VIN: WAUZZZ4F46N131263   Mileage: 368940km-229248miles
   Part No SW: 4F2 910 402 C    HW: 4F0 907 401 B
   Component: 2.7L V6TDI  G000SG  0010
   Revision: --H01---    Serial number:
   Coding: 0011322
   Shop #: WSC 02334 785 00200
   VCID: 1F18E9EBABB516BF349-804A
Readiness: 0 0 0 1 1
Address 03: ABS Brakes        Labels: 4F0-910-517.lbl
   Part No SW: 4F0 910 517 K    HW: 4F0 614 517 K
   Component: ESP 8.0 front   H04 0090
   Coding: 0020871
   Shop #: WSC 02325 785 00200
   VCID: 2C020E27EA03FD27A1B-8078
00493 - ESP-Sensor Unit (G419)
                    Reset counter: 115
                    Mileage: 368946 km
                    Date: 2017.03.16
                    Time: 22:52:09
                    Hex Value: 0x0000
                    Hex Value: 0x10A2
                    Hex Value: 0x001B
                    Hex Value: 0x1063
                    Hex Value: 0x06FF
Address 05: Acc/Start Auth.        Labels: 4F0-910-852.clb
   Part No SW: 4F0 910 852     HW: 4F0 905 852 B
   Component: FBSAUDIC6 ELV   H31 0220
   Revision: 31050601    Serial number: 10604000322778
   Coding: 0000145
   Shop #: WSC 00726 210 88151
   VCID: 6390A51BC75D725F501-8036
   Subsystem 1 - Part No: 4F0 910 131 D
   Component: FBSAUDIC6 EZS   H45 0070
   Subsystem 2 - Part No: 4F0 910 220 D
   Component: FBSAUDIC6 IDG   H39 0040
                    Reset counter: 115
                    Mileage: 368946 km
                    Date: 2017.03.16
                    Time: 22:17:03
Address 07: Control Head        Labels: Redir Fail!
   Part No SW: 4F0 910 769 B    HW: 4F0 035 769 B
   Component: MMI Cockpit     H55 0010
   Revision: C51500BE    Serial number: AUZ6Z3ECAF25R3
   Coding: 0100002
   Shop #: WSC 02323 785 00200
   Component: Bedienteil MMIC6H03 0050
   Subsystem 2 - Serial number: 00000000304893
   Subsystem 3 - Serial number: 0116.12.050000000100010922ÿ
   Subsystem 4 - Serial number: 010922ÿ
Address 08: Auto HVAC        Labels: 4F0-910-043.clb
   Part No SW: 4F0 910 043     HW: 4F2 820 043 H
   Component: KLIMABETAETIGUNGH12 0170
   Revision: 00000030    Serial number: 00000000217408
   Coding: 0001302
   VCID: 5BE09DFBFF2D4A9F181-800E
   Part No SW: 4F0 910 279 D    HW: 4F0 907 279
   Component: ILM Fahrer      H15 0190
   Coding: 0002121
   Shop #: WSC 02335 785 00200
   VCID: 2A0E083FE0F7E317537-807E
   Subsystem 1 - Part No: 4F2 910 113   Labels: 1KX-955-119.CLB
   Component: Wischer AudiC6  H04 0150
   Coding: 00062736
   Shop #: WSC 02335
   Subsystem 2 - Part No: 4E0 910 557 A  Labels: 8K0-955-559.CLB
   Component: REGENLICHTSENSORH13 0090
   Coding: 00141886
   Shop #: WSC 02335
Address 0E: Media Player 1        Labels: Redir Fail!
   Coding: 0100002
Address 0F: Digital Radio        Labels: None
   Part No SW: 4E0 910 563 A    HW: 4E0 035 563
   Component: DAB-Tuner       H41 0620
   Revision: 00000001    Serial number: KE1195T7600475
   Coding: 0000001
   VCID: 221EE01F98C73B571B7-8076
Address 15: Airbags        Labels: 4F0-910-655-8R.clb
   Part No SW: 4F0 910 655 E    HW: 4F0 959 655 B
   Component: 4E AIRBAG AUDI8RH29 0280
   Revision: 08H29000    Serial number: 0037LD0C9U3C
   Coding: 0013381
   VCID: 290CF733E5F1E80F5AD-807C
   Subsystem 1 - Serial number: 6332CSME0E223B687
   Subsystem 2 - Serial number: 6342CSME0E084712+
   Subsystem 3 - Serial number: 6352QSME086C1625H
   Subsystem 4 - Serial number: 6362QSME08412D0DJ
   Subsystem 5 - Serial number: 63734SME086C79538
   Subsystem 6 - Serial number: 63834SME086E326FD
   Part No SW: 4F0 910 549     HW: 4F0 953 549 A
   Component: Lenksäulenmodul H07 0230
   Revision: 00H07000    Serial number: 90054053500139
   Coding: 0102042
   VCID: 6696BC0F346F0777B7F-8032
   Component: Lenkradmodul    H07 0090
Address 17: Instruments        Labels: 4F0-910-xxx-17.lbl
   Part No SW: 4F0 910 900 A    HW: 4F0 920 950 L
   Component: KOMBIINSTR. M73 H11 0630
   Revision: 00100000    Serial number: 4RA7A76D5
   Coding: 2308403
   Shop #: WSC 80093 222 69422
   VCID: 1E66D4EFACBF1FB73FF-804A
                    Reset counter: 115
                    Mileage: 368946 km
                    Date: 2017.03.16
                    Time: 22:52:03
Address 19: CAN Gateway        Labels: 4F0-910-468.clb
   Part No SW: 4F0 910 468 A    HW: 4F0 907 468 D
   Component: Gateway         H11 0070
   Revision: 11          Serial number: 1300805C200220
   Coding: 6CEE73C43B3904
   VCID: 2708F10BF3E5DE7F4C9-8072
                    Reset counter: 75
                    Mileage: 368946 km
                    Date: 2017.03.16
                    Time: 22:14:17
Address 1E: Media Player 2        Labels: 4E0-910-111.lbl
   Part No SW: 4E0 910 111 F    HW: 4E0 035 111 A
   Component: CD-Changer      H44 0470
   Revision: 00000000    Serial number: AUZ5ZBE8034463
   VCID: 1C62DEE7BAA30DA7D1B-8048
Address 37: Navigation        Labels: Redir Fail!
   Coding: 0100002
Address 42: Door Elect, Driver        Labels: 4F0-910-793-42.lbl
   Part No SW: 4F0 910 793 E    HW: 4F0 959 793 E
   Component: TSG FA          H12 0080
   Revision: 00000000    Serial number: uu#
   Coding: 0003610
   Shop #: WSC 02327 785 00200
Address 46: Central Conv.        Labels: 4F0-910-289.lbl
   Part No SW: 4F0 910 289 G    HW: 4F0 907 289 G
   Component: Komfortgeraet   H22 0170
   Revision: 01700022    Serial number: 01009571510000
   Coding: 0131835
   VCID: 2E06042FDC1F8F378FF-807A
   Subsystem 2 - Part No: 4F0 910 177
   Component: Innenraumueberw.H01 0020
Address 47: Sound System        Labels: 4F0-910-223-AS.lbl
   Part No SW: 4F0 910 223 C    HW: 4F0 035 223
   Component: Amp.-ASK        H10 0320
   Revision: 33S00001    Serial number: 01912050196130
   Coding: 0000103
   Part No SW: 4F0 910 280     HW: 4F0 907 280 A
   Component: ILM Beifahrer   H10 0080
   Revision:             Serial number: 00000000172574
   Coding: 0001103
   VCID: 5EE694EFEC3F5FB77FF-800A
Address 52: Door Elect, Pass.        Labels: 4F0-910-793-52.lbl
   Part No SW: 4F0 910 793 E    HW: 4F0 959 792 E
   Component: TSG BF          H12 0080
   Revision: 00000000    Serial number: C’#
   Coding: 0003610
Address 53: Parking Brake        Labels: 4F0-910-801.clb
   Part No SW: 4F0 910 801     HW: 4F0 907 801
   Component: EPB  C63C0030   H03 0030
   Revision: C63C0030
   Coding: 0000511
   VCID: 5DE493E3E13944AF665-8008
   Part No: 8P0 907 357 C
   Coding: 0000003
   VCID: 3A2E387F10575397237-806E
00070 - Starting Battery Voltage
                    Reset counter: 115
                    Mileage: 368952 km
                    Date: 2017.03.16
                    Time: 22:17:01
Address 56: Radio        Labels: Redir Fail!
   Coding: 0100002
Address 61: Battery Regul.        Labels: 4F0-910-181.lbl
   Part No SW: 4F0 910 181 E    HW: 4F0 915 181 A
   Component: J0644 BEM       H12 0590
   Revision: 00000000    Serial number: 00000000181061
   Shop #: WSC 00726 210 09313
   VCID: 2310E51B87DD325F101-8076
   Subsystem 1 - Part No: 4F0 915 106 D
   Component: von VA0  2512052432
   Coding: 344630393135313036442056413032353132303532343332
   Shop #: WSC 12345 384 00290
02272 - Quiescent Current Stage 1
            000 -  -  - Intermittent
                    Mileage: 368946 km
                    Date: 2017.03.16
                    Time: 22:15:17
02273 - Quiescent Current Stage 2
                    Mileage: 368946 km
                    Date: 2017.03.16
                    Time: 22:21:09
02276 - Quiescent Current Stage 5
                    Mileage: 368946 km
                    Date: 2017.03.16
                    Time: 22:21:24
02274 - Quiescent Current Stage 3
                    Mileage: 368946 km
                    Date: 2017.03.16
                    Time: 22:21:34
02277 - Quiescent Current Stage 6
                    Mileage: 368946 km
                    Date: 2017.03.16
                    Time: 22:21:44
Address 62: Door, Rear Left        Labels: 4F0-910-795.lbl
   Part No SW: 4F0 910 795 E    HW: 4F0 959 795 E
   Component: TSG HL          H21 0050
   Coding: 0003074
Address 72: Door, Rear Right        Labels: 4F0-910-795.lbl
   Part No SW: 4F0 910 795 E    HW: 4F0 959 794 E
   Component: TSG HR          H21 0050
   Coding: 0003074
Address 77: Telephone
End----------(Elapsed Time: 01:37, VBatt start/end: 11.3V/11.4V)-----------
Jef
HQ
Are you getting fuel into the combustion chamber? Does the lift pump in the fuel tank get power and run? Clogged filter?
What kind of compression does the engine have? 28 BAR or better?
How cold it is? Fuel gel?
Henke
Sweden
C?ID=297201
Not, sure - will check that too. Thanks
I went ut to measure the voltage coming out from one of the ignition wires.... Connected the multi meter to one of the ignition wires and the other to earth. Turned the ignition on without cranking - result - 2.1 V for a few seconds and then 0 V. I guess this is the problem. The 80A fuse is ok, so I´m leaning towards the glow plug relay. Does anyone now how to test/measure this relay?
Gone But Not Forgotten
The procedure is in the repair manual.........
Spray some flammable starting fluid in the intake and give a try.
Do not crank too much or you will potentially flood the cylinders with diesel fuel from excessive cranking cold.
Suddenly stopping bothers me and I would immediately verify basics like Jef advised for compression and fuel delivery.
Henke
Sweden
C?ID=297201
Do not crank too much or you will potentially flood the cylinders with diesel fuel form excessive cranking cold.
Went out again. This time unscrewing the glow plug. Turned ignition on placed glow plug on earth - got glow sure enough (for a few seconds), so I guess the relay is ok after all. I will start looking into the fuel delivery system tomorrow.
Is it safe using starting fluid on an engine like this?
Also, compression issue - I´m not that good on diesel engines, but if I got a bad compression on one cylinder does that mean engine won´t run at all?
You need to brush up on some RTFB sir.
You need to know basics before you can test them.
Spraying a very small amount will not hurt it and it should at least try to start ........if it doesn't I'd be having a look at timing conditions for pump.
Please immediately log for RPM ref of G28 when cranking and verify TV or intake flap is opening.
