MY17 Passat R-line 206tsi Australia
AJ240
Australia
First post. Just got my Ross-Tech cable and started looking around.
Already updated the traffic enable but that is the only mod so far.
Wednesday,15,March,2017,18:35:05:19047
VCDS Version: 17.1.3.0 (x64)  HEX-V2 CB: 0.4334.4
Dealer/Shop Name: Anthony J
VIN: WVWZZZ3CZHEXXXXXX   License Plate: aa33aa
Mileage: 2678km-1664mi   Repair Order:
Chassis Type: 3C (5Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 2B 36 3C 42 44 52
          55 5F 69 6C 6D A5 BB BC CA CF
VIN: WVWZZZ3CZHEXXXXXX   Mileage: 2678km-1664miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CJXA)       Labels: 06K-907-425-V1.clb
   Part No SW: 3G0 906 259 B    HW: 06K 907 425 B
   Revision: --H13---
   Coding: 091D00322476050B3004
   Shop #: WSC 08856 002 1048576
   ASAM Dataset: EV_ECM20TFS0203G0906259B 001003
   ROD: EV_ECM20TFS0203G0906259B.rod
   VCID: 2B000D6E5381962FA8B-807E
   Part No SW: 0D9 300 012     HW: 02E 927 770 AQ
   Component: DQ250-6A MQB  H54 4940
   Revision: 06354004    Serial number: TFK01608051634
   Shop #: WSC 05311 115 00073
   ROD: EV_TCMDQ250021.rod
   VCID: 53F0758E2B71EEEFC0B-8006
   Part No SW: 5Q0 614 517 BK    HW: 5Q0 614 517 AH
   Component: ESC           H62 0736
   Revision: 00000000    Serial number: 62266000002972
   Coding: 0FEC938F54251B74477F070241C969F0C92AD8E2E0829675384250B8C2A902
   Shop #: WSC 00015 115 08193
   ROD: EV_Brake1UDSContiMK100IPB_035_VW48.rod
   VCID: 7BA0FD2EE361C6AF78B-802E
16412 - Display for Tire Pressure Monitoring
          C1146 02 [008] - Signal Failure
                    Reset counter: 54
                    Mileage: 22 km
                    Date: 2017.02.23
                    Time: 08:54:10
16413 - Display for Tire Pressure Monitoring
                    Reset counter: 54
                    Mileage: 22 km
                    Date: 2017.02.23
                    Time: 08:54:10
   Part No SW: 3Q0 959 435 E    HW: 3Q0 959 435 E
   Component: VWKESSYMQB    036 0811
   Revision: 00036000    Serial number: 0415721452
   Coding: 0F2000070F
   Shop #: WSC 05311 000 00155
   ASAM Dataset: EV_KessyHellaMQBAB 004039
   VCID: 3C223E32A6EF0197311-8068
   Part No SW: 5G0 907 044 BP    HW: 5G0 907 044 BP
   Component: Climatronic   H04 1601
   Revision: 00001K10
   Coding: 1212002420010001111550000010182A
   ASAM Dataset: EV_ACClimaBHBVW37X 006142
   ROD: EV_ACClimaBHBVW37X_004_VW48.rod
   VCID: 76B6EC1AD8439BC7075-8022
   Air quality sensor:
          B10CD 00 [008] -  -
                    Reset counter: 56
                    Mileage: 24 km
                    Date: 2017.02.24
                    Time: 07:50:56
                    Voltage terminal 30: 11.7 V
                    CAN input signal(s) status-Energy management deactivation stage: Deactivation stage 1
                    CAN input signal(s) status-Back-up light: OFF
Address 09: Cent. Elect. (J519)       Labels: 5Q0-937-08X-V2.clb
   Part No SW: 5Q0 937 086 BH    HW: 5Q0 937 086 BH
   Component: BCM PQ37BOSCH 032 0222
   Revision: --------    Serial number: 865806081600ZU
   ASAM Dataset: EV_BodyContrModul1UDSBosc 017002
   ROD: EV_BCMBOSCH_017.rod
   VCID: 015C8FC6818DAC7F227-8054
   Subsystem 1 - Part No SW: 3G2 955 119 A    HW: 3G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    160703  043 0607
   Serial number:         160714163731
   Component: RLHS  042 0105
   Serial number: S5Y16M08D29H00M42S09
   Coding: 00A8DD
   Subsystem 3 - Part No SW: 3G0 941 633 H    HW: 3G0 941 633 H
   Serial number: 31 05 2016  10001431
   Subsystem 4 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Serial number: 000000000ZY1620417XX
   Component: Sirene, DWA  005 0313
   Serial number: 00000000000066542722
589592 - Databus
          U1201 00 [008] - No Communications
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-298.clb
   Part No SW: 5QA 919 298     HW: 5Q0 919 298 C
   Component: PLA 3.0 12KH08 0161
   Serial number: 000305183616238
   Coding: 0371167951
   ASAM Dataset: EV_EPHVA2CAU3700000 009017
   ROD: EV_EPHVA2CAU3700000_009.rod
   VCID: 0D44A3F6CDD5F81F56F-8058
13637426 - Databus
                    Reset counter: 54
                    Mileage: 22 km
                    Date: 2017.02.23
                    Time: 08:54:00
Address 13: Auto Dist. Reg (J428)       Labels: 3Q0-907-572.clb
   Part No SW: 3Q0 907 572 B    HW: 3Q0 907 572 B
   Component: ACC BOSCH MQB H04 0194
   Coding: 320467DB59FFC428949C804D
   ASAM Dataset: EV_ACCBOSCHVW48X 001009
   ROD: EV_ACCBOSCHVW48X.rod
   VCID: 343216128EBFC9D7F91-8060
0795 - Databus
                    Reset counter: 54
                    Mileage: 22 km
                    Date: 2017.02.23
                    Time: 08:54:01
                    Control Module temperature: 36 °C
                    Voltage terminal 15: 12.3 V
0803 - Databus
                    Reset counter: 54
                    Mileage: 22 km
                    Date: 2017.02.23
                    Time: 08:54:01
2101 - Databus
                    Reset counter: 54
                    Mileage: 22 km
                    Date: 2017.02.23
                    Time: 08:54:01
1538 - Sensor for Automatic Distance Control
          C110B F0 [008] - Limited Visibility
                    Reset counter: 63
                    Mileage: 731 km
                    Date: 2017.03.03
                    Time: 08:38:42
                    Control Module temperature: 29 °C
                    Voltage terminal 15: 13.0 V
                    Velocity_vehicle_reference: 30.88 m/s
                    Longitudinal_acceleration_vehicle_reference: -0.01 m/s²
                    Status_ACC_System: ACC_activ_controlled
2068 - Databus
                    Reset counter: 54
                    Mileage: 22 km
                    Date: 2017.02.23
                    Time: 08:54:15
   Serial number: 14081641350149
   ROD: EV_DRCONTITEMIC.rod
   VCID: 382A222292D72DB7D59-806C
   Part No SW: 3Q0 959 655 BB    HW: 3Q0 959 655 BB
   Component: Airbag VW20   013 0195
   Revision: --------    Serial number: 003STPFZFQDH
   Coding: 98FCC0C0000000005C540000008800000065
   Shop #: WSC 05314 000 00001
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 7F58093EF779DA8F543-802A
   Subsystem 1 - Part No SW: -----------    HW: 454 000 608 16
   Serial number: 3576U000000B2AF01C1H
   Subsystem 2 - Part No SW: -----------    HW: 454 000 508 16
   Serial number: 3586U000000D72A0CB1M
   Subsystem 3 - Part No SW: -----------    HW: 454 800 408 16
   Serial number: 3516R50B2050C000000Y
   Subsystem 4 - Part No SW: -----------    HW: 454 800 208 16
   Serial number: 3526R25A5050C000000$
   Subsystem 5 - Part No SW: -----------    HW: 454 803 107 16
   Serial number: 3556VE5B2650B000000I
Address 16: Steering wheel (J524)       Labels: 5Q0-953-549.clb
   Part No SW: 3Q0 953 521 DM    HW: 5Q0 953 569 A
   Component: Lenks.Modul   075 0195
   Revision: FF033033    Serial number: 20160816501018
   Coding: 0C10
   Shop #: WSC 00015 115 00001
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 7EA6F43AF073D3875F5-802A
   Part No SW: 3G0 920 791 B    HW: 3G0 920 791 B
   Component: KOMBI         404 2153
   Coding: 27A40818FF88000801886B0B1001000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009052
   VCID: 280AF2624277BD37459-807C
          U1110 00 [008] - -
                    Fault Frequency: 38
                    Reset counter: 87
                    Mileage: 78 km
                    Date: 2017.02.28
                    Time: 06:54:13
   Part No SW: 5Q0 907 530 AM    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2265
   Revision: --------    Serial number: 22081610801754
   Coding: 030300347F085900FB00025A9C0F00010001070000000000000000000000
   ROD: EV_GatewConti_013.rod
   VCID: 7CA2FE32E66FC197711-8028
   Subsystem 2 - Part No SW: 5G0 959 442 N    HW: 5G0 959 442 N  Labels: 3C8-959-537.CLB
   Serial number: 29160001655430056345
   Coding: 2DFFFF
   Serial number: 75410803001608250559
   Analog clock:
   Subsystem 4 - Part No SW: 3G0 919 204 C    HW: 3G0 919 204 C
   Component: Analoguhr  209 2002
   Serial number: HA1-00018.07.16
   Coding: 0301
   VCID: 4ACE68EAFC3BAF27B3D-801E
   Serial number: 16000183526014
   Coding: 0800000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71BCDF06B12DBCFFD27-8024
Address 36: Seat Mem. Drvr (J810)       Labels: None
   Part No SW: 3Q0 959 760 B    HW: 3Q0 959 760 B
   Component: Sitzmemory    H05 0020
   Serial number: Y0006PHB24163
   Coding: 0014000000000500818280808080000000008181000000F400
   ASAM Dataset: EV_SeatMemorDriveSide 002021
   ROD: EV_SeatMemorDriveSide_VW37.rod
   VCID: 3A2E382AACDB3FA723D-806E
Address 3C: Lane Change (J769)       Labels: None
   Part No SW: 3Q0 907 566 C    HW: 3Q0 907 566
   Component: MRR1Rear      H16 0310
   Revision: --------
   Coding: 44C002
   ASAM Dataset: EV_RearRadarS1BoschVW48X 001002
   Serial number: 200816EHJ13677
   Coding: 003F1A20D201020000001000
   VCID: 43D045CEDB117E6F70B-8016
   Coding: 9307
   Shop #: WSC 00015 115 00302
   ROD: EV_SteerAssisMQB_013.rod
   Serial number: 170616EFH00942
   Coding: 003F1020DE01020200001000
   VCID: 42DE40CAC40B77677BD-8016
   Component: AFS-ECU       H01 0120
   Coding: 03A603000F210200
   Shop #: WSC 05311 000 08193
   ROD: EV_HeadlRegulAFSMQBMLB_VW48.rod
   VCID: 3FD8493EB7F91A8F143-806A
   Subsystem 1 - Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
   Component: LED LeiMo li.  H09 0003
   Coding: E02400
   Subsystem 2 - Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
   Component: LED LeiMo re.  H09 0003
   Coding: E02400
   Subsystem 3 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H02 0003
   Coding: E02400
   Subsystem 4 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H02 0003
   Coding: E02400
5275648 - Left/Right Driving Switch-Over Active
          C1080 00 [009] -  -
                    Reset counter: 19
                    Mileage: 78 km
                    Date: 2017.02.27
                    Time: 15:29:06
   Part No SW: 3G0 035 045 C    HW: 3G0 035 045
   Component: MU-H-N-RW     H51 0814
   Serial number: A688H0GB004781
   Coding: 02840208FF00000051510001000808001F0106E601200002DF
   VCID: 1E66D4BA103373873F5-804A
   Component: ABT_High  H63 0032
   Serial number: VWZ8Z9SKL039VR
   Subsystem 2 - Part No SW: V03 959 801 EC    HW: -----------
   Component: ROW 2017  --- 0062
   Compact Disc Database:
   Component: Gracenote2---  --- 4009
Address 69: Trailer (J345)       Labels: 5Q0-907-383.clb
   Part No SW: 5Q0 907 383 J    HW: 5Q0 907 383 B
   Component: Anhaenger     H21 0203
   Revision: 8C001003    Serial number: 0398037618
   Coding: 0300000202000000
   VCID: 3E26343AB0F313871F5-806A
Address 6C: Back-up Cam. (J772)       Labels: 5Q0-980-556.clb
   Part No SW: 5Q0 980 556     HW: 5Q0 980 556
   Component: RVC Compact   H09 0170
   Coding: 0184020163002017000040
   ASAM Dataset: EV_CamSysRVRVCPANAMQBAB 005007
   ROD: EV_CamSysRVRVCPANAMQBAB_VW37.rod
   VCID: 77A8E11EDF49E2CF1C3-8022
Address 6D: Trunk Elect. (J605)       Labels: 5Q0-959-107.clb
   Part No SW: 5Q0 959 107 J    HW: 5Q0 959 107 J
   Component: HDSG-Modul    H13 0253
   Revision: --------    Serial number: 30858757100000
   Coding: 0288
   ASAM Dataset: EV_DeckLidCONTIAU736 001012
Address A5: Frt Sens. Drv. Assist (R242)       Labels: 3Q0-980-65X-A5.clb
   Part No SW: 3Q0 980 654 F    HW: 3Q0 980 654
   Component: MQB_B_MFK     H06 0220
   Serial number: 22081611K11872
   Coding: 000408020000010100022347C050410084000E300000
   ROD: EV_MFKBoschMQBB.rod
1135140 - Databus
                    Reset counter: 54
                    Mileage: 22 km
                    Date: 2017.02.23
                    Time: 08:54:00
                    Control Module temperature: 34 °C
                    Outside air temperature: 22.0 °C
                    Vehicle speed: 0.00 km/h
                    System run time: 447.5 s (second)
                    Voltage terminal 15: 12.4 V
                    mid: 02 65
                    Camera_state: operational
                    Engine_Running_Info: 0
                    Software_Info_4: 0
                    Software_Info_3: 2
                    Software_Info_2: 2
                    Software_Info_1: 0
1135139 - Databus
                    Reset counter: 54
                    Mileage: 22 km
                    Date: 2017.02.23
                    Time: 08:54:00
                    mid: 02 64
                    Software_Info_4: 0
                    Software_Info_3: 2
                    Software_Info_2: 2
                    Software_Info_1: 0
1123173 - Databus
                    Reset counter: 54
                    Mileage: 22 km
                    Date: 2017.02.23
                    Time: 08:54:00
                    System run time: 447.2 s (second)
                    mid: 02 E0
                    Software_Info_4: 0
                    Software_Info_3: 2
                    Software_Info_2: 2
                    Software_Info_1: 0
1123187 - Databus
                    Reset counter: 54
                    Mileage: 22 km
                    Date: 2017.02.23
                    Time: 08:54:00
                    mid: 02 C0
                    Software_Info_4: 0
                    Software_Info_3: 2
                    Software_Info_2: 2
                    Software_Info_1: 0
1123202 - Databus
                    Reset counter: 68
                    Mileage: 1044 km
                    Date: 2017.03.04
                    Time: 14:30:25
                    Control Module temperature: 48 °C
                    System run time: 4347.1 s (second)
                    Voltage terminal 15: 14.0 V
                    mid: 02 C1
                    Engine_Running_Info: 1
                    Software_Info_4: 0
                    Software_Info_3: 2
                    Software_Info_2: 2
                    Software_Info_1: 0
Address BB: Door Rear Drv (J388)       Labels: None
   Serial number: 280716EGS09895
   Coding: 000E10200101020000000000
   VCID: 45D45BD6D525405F5EF-8010
Address BC: Door Rear Pass (J389)       Labels: None
   Serial number: 280716EGS09896
Address CA: Sunroof (J245)       Labels: None
   Part No SW: 4M0 907 594 J    HW: 4M0 907 594
   Component: SAD_STG_1     013 0005
   Coding: 108040748202
   ROD: EV_SunRoofCONTIAU736_005.rod
   VCID: 3D243336BDF5089F06F-8068
Address CF: Lane Chge Asst 2 (J770)       Labels: None
   Part No SW: 3Q0 907 590 C    HW: 3Q0 907 590
   Revision: --------
   Coding: 44C002
   ASAM Dataset: EV_RearRadarS2BoschVW48X 001002
   VCID: 35342B1685C5D0DFCEF-8060
End----------(Elapsed Time: 02:26, VBatt start/end: 12.1V/12.1V)-----------
Address 5F,3G0 035 045 C,channel IDE05111-Fee-based traffic information (TMC),adapted from,65535 ,to,1024 ,
UDS Adaptation Channel: IDE05111-Fee-based traffic information (TMC)
Stored value 1024
Wuxi, P.R.C.
C?ID=265663
Thanks FOR TEH LOG INF.
