2006 Touareg cat aging test?
Drksderob
Canada
C?ID=32822
I have a 2006 Touareg 3.2 and cannot figure out how to perform the test for catalytic converter or oxygen sensor through vag-com.
Thanks,
Rob
Codes showing are
p0068 p0420 p0430
Drksderob
Canada
C?ID=32822
Thursday,16,March,2017,12:39:18:57762
VCDS Version: 17.1.3.0
Workshop Code: 000 12345 000000
VIN: WVGZG77L56D046089   License Plate:
Chassis Type: 7L (7L - VW Touareg (2003 > 11/2006))
Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
          37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
VIN: WVGZG77L56D046089   Mileage: 167780km-104253miles
Address 01: Engine        Labels: 022-906-032-BMX.lbl
   Part No SW: 022 906 032 GT    HW:
   Component: MOTRONIC ME7.1.1G   7532
   Revision: 00000000    Serial number: VWZ3Z0E2434924
   Coding: 0000133
   Shop #: WSC 31414 000 00000
   VCID: 63C59DF3A1B41A5994-5122
001056 - Catalyst System; Bank 1
               P0420 - 001 - Efficiency Below Threshold - MIL ON
                    Fault Status: 11100001
                    RPM: 1606 /min
                    Load: 43.5 %
                    Speed: 69.0 km/h
                    Temperature: 84.0°C
                    Temperature: 11.0°C
                    Absolute Pres.: 930.0 mbar
                    Voltage: 0.000 V
001072 - Catalyst System; Bank 2
               P0430 - 001 - Efficiency Below Threshold - MIL ON
000104 - MAP/MAF <-> Throttle Position Correlation
               P0068 - 002 -
Address 02: Auto Trans        Labels: 09D-927-750.lbl
   Part No: 09D 927 750 DS
   Component: AL 750 6A           0893
   Coding: 0004216
   Shop #: WSC 31912 037 68369
   VCID: 020BB8775EEEB351FF-5122
Address 03: ABS Brakes        Labels: 7L0-907-379-MK25.lbl
   Part No: 7L0 907 379 G
   Component: ESP ALLRAD MK25     0203
   Coding: 0014338
   VCID: 3D710B8B67900CA9C2-5122
Address 05: Acc/Start Auth.        Labels: None
   Part No SW: 7L0 909 135 A    HW: 5WK 485 01
   Component:    Kessy            6700
   Revision: 67005715    Serial number: VWZ3Z0E2434924
   Coding: 0000232
   VCID: 2F6D21C3BDFCEE3940-5122
Address 08: Auto HVAC        Labels: 7L6-907-040.clb
   Part No: 7L6 907 040 L
   Component: CLIMAtronic R/L     4017
   Coding: 0020030
   VCID: 39791F9B73B83089EE-5122
Address 09: Cent. Elect.        Labels: 7Lx-937-049-V1.clb
   Part No: 7L6 937 049 M
   Component:                     3001
   Coding: 0100447
   VCID: 4683646732464F7193-5122
            000 -  -
   Part No: 3D0 909 601 H
   Component: 05 Airbag 8.4E++H01 0562
   Revision: BB38727     Serial number: 0006822>
   Coding: 0012341
   VCID: 285FCADF9812B90181-5122
   Subsystem 1 - Part No: 7L0 959 339 C
   Component: BF-Gewichtsens. 006 0008
                    Reset counter: 39
Address 16: Steering wheel        Labels: 7L6-953-549.lbl
   Part No: 7L6 953 549 H
   Coding: 0000031
   VCID: 44877E6F047A7D618D-5122
Address 17: Instruments        Labels: 7L6-920-xxx-7LA.lbl
   Part No: 7L6 920 971 G
   Component: KOMBIINSTRUMENT RB8 2111
   Coding: 0007231
   VCID: 3C77068F7C8A05A1F5-5122
01304 - Radio
   Part No: 6N0 909 901
   Coding: 0000006
   VCID: 70EFE2BF6042B1C119-5122
01304 - Radio
Address 1C: Position Sensing        Labels: 7L6-919-879.lbl
   Part No: 7L6 919 879 A
   Component: JCI PathPoint       2200
   VCID: 4581636B0F4044699A-5122
   Part No: 0AD 927 755 AT
   Component: TRANSFERCASE        0114
   VCID: 0D119B4B17B0FC2992-5122
Address 46: Central Conv.        Labels: 7L0-959-933.lbl
   Part No: 7L0 959 933 J
   Component:    HSG              5115
   Coding: 0000085
   Shop #: WSC 19400 444 57734
   VCID: 43857D7301747A59B4-4AE4
   Subsystem 1 - Part No: 7L0 959 701 F
   Component: Tuersteuergeraet FS 0201
   Subsystem 2 - Part No: 7L0 959 702 F
   Component: Tuersteuergeraet BF 0201
   Subsystem 3 - Part No: 7L0 959 703 C
   Component: Tuersteuergeraet HL 0201
   Subsystem 4 - Part No: 7L0 959 704 C
   Component: Tuersteuergeraet HR 0201
Address 68: Wiper Electr.        Labels: 7L0-955-119-V2.clb
   Part No: 7L0 955 119 K
   Component: Front Wiper         4027
   Coding: 0000341
   Shop #: WSC 31414 000 376832
   VCID: 3C77068F7C8A05A1F5-5140
   Subsystem 2 - Part No: 1K0 955 559 T  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 011  1110
   Coding: 00208933
   Shop #: WSC 31414
Address 6E: Ctrl Head Roof        Labels: None
   Part No: 7L6 919 044 N
   Component: DACHDISPLAY         0539
   Revision: 00800539    Serial number: 2009289.07
   VCID: 428B78771E6E7351BF-5140
End-------------------------(Elapsed Time: 09:02)--------------------------
Personally, I would try to address this first:
000104/ P0068 - MAP/MAF <-> Throttle Position Correlation.
Also, the Set Readiness procedure for your engine should guide you through Oxygen Sensor Aging tests.
Gone But Not Forgotten
Agreed Uwe this indicates false air and maybe not a bad MAF so check for the leaks first......
