A7 ABS fault codes
bmre90
C?ID=302576
I just replaced steering rack on my A7 after hitting the bump. everything seem to work normal and i did the steering calibration to the best of my knowledge. before there were 3 faults showing up in the dashboard: Steering defective;TPMS Malfunction: Stabalization Fault. Now after the steering rack is replaced, Steering defective code is gone and the Red steering icon is no more on the dashboard. however, there are 3 fault codes when i did full autoscan.
The mistake i did was, didnt recorded and saved my original scan - i know my huge mistake.
Any help? Its all realted to steering control module code, i guess?
Car Info: A7, 2012 ( Prestige Model )
here is the full Auto Scan
Tuesday,14,March,2017,20:22:11:37826
VCDS Version: 17.1.3.0 (x64)  HEX-V2 CB: 0.4334.4
VIN: WAU2GAFC3CNXXXXXX   License Plate:
Chassis Type: FC (4G0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 28 36 3B 3C 42 44 46 47 52
          53 55 56 5F 62 6C 6D 72 8F 90
VIN: WAU2GAFC3CNXXXXXX   Mileage: 79998km-49708miles
Address 01: Engine (J623-CGXB)       Labels: 06E-907-551-CGW.clb
   Part No SW: 4G0 907 551 A    HW: 4G0 907 551 A
   Component: 3.0l V6 TFSI  H07 0006
   Revision: --H07---
   Coding: 1A2A0034052600060000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM30TFS0214G0907551A 002007
   ROD: EV_ECM30TFS0214G0907551A_002.rod
   VCID: 2708F2B9AF64281F4C3-8072
6201 - Function Restriction due to Faults in Other Modules
          U1113 00 [047] - -
                    Mileage: 79867 km
                    Date: 2017.03.10
                    Time: 11:47:40
                    Engine speed: 699.00 /min
                    Normed load value: 9.4 %
                    Coolant temperature: 95 °C
                    Intake air temperature: 33 °C
                    Voltage terminal 30: 13.710 V
                    Engine speed: actual: 1216 /min
                    MAF_ENVD: 294.14117 mg/stroke
                    Coolant temperature (unfiltered): 19.50 °C
                    Engine: operating status: IS
                    Engine load: 35.546875 %
                    Vehicle speed: actual: 0 km/h
6134 - Function Restriction due to Faults in Other Modules
          U1113 00 [109] - -
                    Mileage: 79867 km
                    Date: 2017.03.10
                    Time: 11:52:56
                    Engine speed: 697.00 /min
                    Normed load value: 16.9 %
                    Vehicle speed: 1 km/h
                    Coolant temperature: 96 °C
                    Intake air temperature: 39 °C
                    Voltage terminal 30: 14.015 V
                    Engine speed: actual: 704 /min
                    MAF_ENVD: 190.64705 mg/stroke
                    Coolant temperature (unfiltered): 45.75 °C
                    Engine load: 18.359375 %
                    Vehicle speed: actual: 1 km/h
Address 02: Auto Trans (J217)       Labels: 0BK-927-156.clb
   Part No SW: 4G0 927 158 P    HW: 0BK 927 156 AJ
   Component: 0BK 30TFSIUSA H16 1006
   Revision: --H16---
   Coding: 000002
   ASAM Dataset: EV_TCMAL551211 002018
   VCID: 3B203EC943EC9CFF38B-806E
Address 03: ABS Brakes (J104)       Labels: 4G0-907-379-V1.clb
   Part No SW: 4G0 907 379 H    HW: 4G0 907 379 H
   Component: ESP PREMIUM   H09 0361
   Coding: 44A70F0322E5F0C04B00
   ASAM Dataset: EV_ESPPremiAU57X 004028
   VCID: 36362FFD78CE4197C75-8062
0788 - Control Module Incorrectly Coded
          U1014 00 [137] - -
                    Reset counter: 223
                    Mileage: 79878 km
                    Date: 2017.03.10
                    Time: 18:56:11
                    VzRef: 00
                    Bit Info 1: 80
                    Bit Info 2: 0F
                    Bit Info 3: 22
                    Bit Info 4: 1F
                    F-Path: 01
                    F-Type: AA
                    Uz: 9A
   Part No SW: 4H0 907 064 BR    HW: 4H0 907 064 BR
   Component: BCM2 2.0      H31 0333
   Coding: 0D8A2000000000000000
   VCID: 7AAEFBCD0CD665F763D-802E
   Serial number: 2312000054286001
Address 08: Auto HVAC (J255)       Labels: 4G0-820-043-4Z.clb
   Part No SW: 4G0 820 043 L    HW: 4G0 820 043 L
   Component: KLIMA 4 ZONEN H12 0064
   Serial number: 05041200040563
   Coding: 6603207A48
   ASAM Dataset: EV_AirCondiComfoUDS 002036
   VCID: 280AF185A27A2767459-807C
Address 09: Cent. Elect. (J519)       Labels: 4H0-907-063-V1.clb
   Part No SW: 4H0 907 063 BP    HW: 4H0 907 063
   Component: BCM1 2.0      H12 0111
   Revision: 11012002    Serial number: 00000001270979
   Coding: 0D072091073E9FE081000084A0003820CF9CD208A2090125800308453B00
   VCID: 77A8E2F93FC4789F1C3-8022
   Component: WWS57X 120312  H35 0080
   Serial number:         120319121853
   Coding: 0045F7
   Component: RLS  H04 0003
   Serial number: 20119134
   Coding: 02562B
   Subsystem 3 - Part No SW: 4G0 941 531 E    HW: 4G0 941 531 E
   Component: E1 - LDS  H07 0044
   Serial number: 28 03 2012  00000513
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555R1CJP02
   Subsystem 5 - Part No SW: 8K0 959 772 E    HW: 8K0 959 772
   Component: SLR-B8  H06 0007
   Serial number:           0026135229
   Coding: 853000
   Subsystem 6 - Part No SW: 4G0 907 472     HW: 4G0 907 472
   Component: A31 LED Mod1L  H02 0001
   Serial number: 00000000001202244051
   Subsystem 7 - Part No SW: 4G0 907 472     HW: 4G0 907 472
   Component: A27 LED Mod1R  H02 0001
   Serial number: 00000000001202243882
   Subsystem 8 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0300
   Serial number: WA103085000001116348
   Coding: 020300
   Subsystem 9 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Component: AQ_Hum_Sensor  H02 0002
   Serial number: 1B28C026000000000001
   Subsystem 10 - Part No SW: 4G0 907 472 A    HW: 4G0 907 472 A
   Component: A32 LED Mod2L  H02 0001
   Serial number: 00000000001203072168
   Subsystem 11 - Part No SW: 4G0 907 472 A    HW: 4G0 907 472 A
   Component: A28 LED Mod2R  H02 0001
   Serial number: 00000000001203072439
Address 10: Park/Steer Assist (J446)       Labels: 4H0-919-475-7X2.clb
   Part No SW: 4H0 919 475 Q    HW: 4H0 919 475 C
   Component: PARKHILFE ACC H07 0060
   Revision: 11001001    Serial number: 55901208000328
   Coding: 280104
   ASAM Dataset: EV_EPHVA18AU57X0000 004005
   ROD: EV_EPHVA18AU57X0000_003.rod
   VCID: 40DA49252A0AFF276D9-8014
Address 15: Airbags (J234)       Labels: 4H0-959-655.clb
   Part No SW: 4G0 959 655 A    HW: 4G0 959 655 A
   Component: Airbag10.43   H32 0032
   Revision: --------    Serial number: 003D8001ZBUF
   Coding: 303145313131303030314A55304C34473853
   ROD: EV_AirbaAU10BPAAU64X_AU57.rod
   VCID: 333016E96BBC54BFE0B-8066
   Serial number: 6940000Y150001ES8G0/
   Serial number: 3575HRB4067173JO40J/
   Serial number: 3585HRB4065173JO68SF
   Serial number: 3515JRB40104UHL8C0MI
   Serial number: 3525JRB40104UHL8N0HP
   Serial number: 3554VRB405R18AICBGB.
   Serial number: 3564VRB405R18AICD0ER
Address 16: Steering wheel (J527)       Labels: 4H0-953-568.clb
   Part No SW: 4G0 953 568 A    HW: 4G0 953 568 A
   Component: Lenks.Modul   H05 0201
   Revision: 00000000    Serial number: 20120404000239
   Coding: 000034
   VCID: 303A19E59A2A6FA79D9-8064
   Subsystem 1 - Part No SW: 4G0 951 528 A    HW: 4G0 951 528 A
   Component: E221 - MFL  H08 0009
Address 17: Instruments (J285)       Labels: 4H0-920-xxx-17.clb
   Part No SW: 4G8 920 982 M    HW: 4G8 920 982 M
   Component: TBenUsa       H79 0416
   Revision: 28460177    Serial number: 658290312596014
   Coding: 0BEF01060B03D705020100
   ASAM Dataset: EV_RBD4K 004045
   ROD: EV_RBD4K.rod
   VCID: 3E2637DD50FE89D71F5-806A
   Part No SW: 4G0 907 468 AB    HW: 4G0 907 468 AA
   Component: J533--Gateway H10 0028
   Revision: --------    Serial number: 00000000461944
   Coding: 00C1033000
   ASAM Dataset: EV_GatewPkoUDS 001013
   ROD: EV_GatewPKOUDS_VW51.rod
   VCID: 70BAD9E55A2A2FA7DD9-8024
   Subsystem 1 - Part No SW: 8X0 915 181     HW: 8X0 915 181
   Component: J367-BDM  H07 0141
   Serial number: 00000000003790475562
4906 - Power Steering Control Module
          U101D 00 [008] - No Communication
                    Reset counter: 6
                    Mileage: 79867 km
                    Date: 2017.03.09
                    Time: 10:02:42
                    Voltage terminal 30: 12.2 V
                    Voltage terminal 15: 0.0 V
                    Control Module temperature: 15 °C
                    System status: Awake_Timer_active
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Terminal 15 status via CAN: OFF
                    Terminal 15 status: OFF
                    Datenfeld: 0
Address 28: HVAC, Rear (E265)       Labels: 4G0-919-158.clb
   Part No SW: 4G0 919 158 C    HW: 4G0 919 158 C
   Component: KLIMA FOND    H07 0064
   Serial number: 04041200040104
   Coding: 00
   ASAM Dataset: EV_ClimaContrUnitRearUDS 002018
   VCID: 2F381A998794705F843-807A
   Part No SW: 4G8 959 760 A    HW: 4G8 959 760 A
   Component: MEM-FS        H03 0154
   Revision: AA000000    Serial number: 00000025900634
   Coding: C0581B008F002001000001010101102030303232203232
   VCID: 382A21C5725AB7E7D59-806C
   Part No SW: 4G0 907 637 B    HW: 4G0 907 637 B
   Component: SARA 6D       H02 0009
   Revision: --------    Serial number: EJ1BPA4204E9E+0
   ASAM Dataset: EV_SARA 009017
   ROD: EV_SARA_009.rod
   VCID: 2D0400918D98024FB6F-8078
   Part No SW: 4G0 907 566 J    HW: 4G0 907 566
   Component: J769  SWA MasterH02 0040
   Revision: 00H02000    Serial number: 6PZ 010 287-08
   Coding: 0000007
   VCID: 36362FFD744E4197C75-8062
   Subsystem 1 - Part No: 4G0 907 568 J
   Component: J770  SWA Slave H02 0040
   Subsystem 2 - Serial number: 6PZ 010 287-28
   Subsystem 3 - Serial number: 5F27.03.1200H020003CZ24395ÿ
   Subsystem 4 - Serial number: Z24395ÿ
   Part No SW: 4G8 959 793 E    HW: 4G8 959 793 A
   Component: TSG FA        H05 0212
   Coding: 011F57225E00628002000412
   VCID: 42DE432D2486ED377BD-8016
Address 44: Steering Assist (J500)       Labels: 4G0-909-144.clb
   Component: RCevo         H54 0202
   Revision: 00000002    Serial number: 0000494626
   Coding: 000000000000
   ASAM Dataset: EV_RCEPS 106007
   ROD: EV_RCEPS_106.rod
   VCID: 3A2E3BCD4CD6A5F723D-806E
4205828 - Steering angle sensor
          B1168 54 [008] - Missing Calibration / Basic Setting
                    Reset counter: 7
                    Mileage: 79867 km
                    Date: 2017.03.10
                    Time: 11:50:44
Address 46: Central Conv. (J393)       Labels: 4H0-907-064-46.clb
   Revision: 00002001    Serial number: 0174113818
   Coding: 0126063A20FAF48582B00A80020100000000000000000000000000000000
   Component: GTO BF  H01 0080
   Serial number: 00000000000000078101
   Subsystem 3 - Part No SW: 4G8 959 591     HW: 7P0 959 591 C
   Component: J245 PS40.039  H01 0008
   Serial number:     WOO1561127/
   Coding: 101F00
   Subsystem 4 - Part No SW: 4G0 947 135 G    HW: 4G0 947 135
   Serial number: 0000000AP00001118624
   Subsystem 5 - Part No SW: 4G8 959 252     HW: 4G8 959 252
   Component: HSP-SG  H11 0028
   Serial number: WA102905000001125798
   Revision: CJ007000    Serial number: 00000000041693
   Coding: 030000
   Shop #: WSC 04038 001 1048576
   VCID: 1D64D051FDB8F2CF26F-8048
   Part No SW: 4G8 959 792 E    HW: 4G8 959 792 A
   Component: TSG BF        H05 0212
   Coding: 011F57225E00628002000402
   VCID: 41DC4C212180F62F627-8014
   Part No SW: 4H0 907 801 E    HW: 4H0 907 801 A
   Component: EPB-4         H03 0012
   Revision: --------    Serial number: 00000000300320
   ROD: EV_ParkiBrake_AU57.rod
   VCID: 2A0E0B8DBC76157753D-807E
7 Faults Found:
721152 - Brake pad replacement mode active
          C1011 00 [000] -  -
333568 - Function Restricted due to Missing Message(s)
          U1111 00 [000] - -
334080 - Function Restricted due to Missing Message(s)
          U1111 00 [000] - -
331264 - Function Restricted due to Missing Message(s)
          U1111 00 [000] - -
331520 - Function Restricted due to Missing Message(s)
          U1111 00 [000] - -
331776 - Function Restricted due to Missing Message(s)
          U1111 00 [000] - -
460800 - Function Restriction due to Faults in Other Modules
          U1113 00 [000] - -
Address 55: Headlight Range (J431)       Labels: 8X0-907-357.clb
   Part No SW: 4H0 907 357 A    HW: 4H0 907 357 A
   Component: ....LWR12.... H02 0013
   Serial number: 120403-0002-040
   Coding: 1223A6601002A400
   ROD: EV_HeadlRegulBasic.rod
   VCID: 2C020D95B6820B47A11-8078
   Component: Radio U SIRIU H53 0133
   Revision: AB001007    Serial number: 236C40C7527699
   Coding: 020007010000000001
   VCID: 2412E5B5DED2C307691-8070
   Part No SW: 4G0 035 746 E    HW: 4G0 035 746
   Component: H-BNT-NA      H48 0735
   Revision: --------    Serial number: 031CP0C7535316
   Coding: 090200040203E1EF55128F3E00000003100001000000000000
   VCID: 290CF481B9F01E6F5A7-807C
   Component: NAR 2011  0505
   Subsystem 2 - Part No SW: 4G0 919 605 B    HW: 4G0 919 605 B
   Component: DU8 C7 SV  H42 0021
   Serial number: AUZ8ZDC94014H6C
   Subsystem 3 - Part No SW: 4G1 919 610 C    HW: 4G1 919 610 C
   Component: E380 BDT C7  H11 0204
   Serial number: 90349LD300054
   Component: CD-Database  3371
   Part No SW: 4G8 959 795 E    HW: 4G8 959 795 A
   Component: TSG HL        H04 0212
   Coding: 010F17224000628002000002
   VCID: 44D245353E92E307491-8010
Address 6C: Back-up Cam.        Labels: 4H0-907-441.clb
   Part No SW: 4G0 907 441 B    HW: 4H0 907 441
   Component: SG Rueckfahrkamera  0061
   Revision: --H06---    Serial number: 525 PA8J23G3AW
   Coding: 1080013
   VCID: 2616FFBDA4EE3117775-8072
Address 6D: Trunk Elect. (----)       Labels: Redir Fail!
   Part No SW: 4G8 959 107 P    HW: 4G8 959 107 G
   Component: HDSG-Modul    H13 0039
   Revision: 12013001    Serial number: 073201048
   Coding: 0A3305C102
   ASAM Dataset: EV_HDSGAu573 001014
   ROD: EV_HDSGAu571.rod
   VCID: 42DE432D2406ED377BD-8016
   Component: TSG HR        H04 0212
   Part No SW: 4H0 980 945 B    HW: 4H0 980 945 B
   Coding: 0006E008031F0300070308014244CA010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 313C1CE191A066AF927-8064
   Part No SW: 4H0 980 946 B    HW: 4H0 980 946 B
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   VCID: 323E13ED94A65DB7EBD-8066
End----------(Elapsed Time: 02:35, VBatt start/end: 13.3V/14.2V)-----------
VCDS saves all Auto-Scans to the Scans sub-folder, whether you ask it to or not. Take a look; it might be there.
bmre90
C?ID=302576
unfortunately the original scan was done by third party and even that didnt stored it . :(
bmre90
C?ID=302576
any pointers what im missing here or how can i troubleshoot it without taking it to the dealer?
I noticed Coding is 000000000000 for 44:Steering Assist
does this coding need to be updated?
or am i missing something while configuring power steering control module
Coding of all zeros is probably not correct, and based on some searches for that part number, it seems that module tends not to set an explicit "Not Coded" or "Incorrectly Coded" DTC. Example here.
Coding of it is somewhat documented if you pull up the Long Coding Helper.
In addition, this page may have some helpful info.
