04 MkV
siLc
Tallinn, Estonia
C?ID=330192
Hi,
I have a 2004 MkV and have been using RT's products for a while. Recently I had my original immo4a cluster changed to a immo4c -> http://forums.ross-tech.com/showthread.php?850-MKV-full-mfd-retrofit-from-immo4a-to-immo-4c
Everything is working fine except I can't get the "Convenience" menu to show up on the highline MFD. "Lights and Vision" however, is there. In the past, I have changed both CECM and CCCM modules and retrofitted the full factory alarm with the Touran interior monitoring. I have already changed the coding of CCCM byte 18 (unticked bit 5 and 7) but that didn't do the trick. That doesn't show on this autoscan, sorry.
Here's my autoscan:
Thursday,24,July,2014,09:49:37:25051
VCDS Version: 14.7.2.0
Data version: 20140714
Dealer/Shop Name:
Workshop Code: 020 01342 012345
VIN: WVWZZZ1KZ4Wxxxxxx   License Plate:
Mileage: 196460km-122074mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 76
VIN: WVWZZZ1KZ4Wxxxxxx   Mileage: 196460km-122074miles
Address 01: Engine        Labels: 06A-906-033-BGU.lbl
  Part No: 06A 906 033 CA
  Component: SIMOS71 1.6l 2VG    9862
  Revision: --H03---    Serial number:
  Coding: 0000071
  Shop #: WSC 00854 461 86788
  VCID: 60C5A213B322783AE3-8035
Readiness: 0010 1001
  Part No: 1K0 907 379 K
  Component: ESP FRONT MK60      0103
  Coding: 0019073
  Shop #: WSC 01279 785 00200
  VCID: 3A71307B753E42EA8D-806F
  Part No: 1K0 907 044 L
  Component: ClimatronicPQ35 061 0201
  VCID: 30651253A34288BA33-8065
  Subsystem 1 - Part No: 1K0 907 044 L
No Faults Found
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
  Part No SW: 3C0 937 049 AG    HW: 3C0 937 049 AG
  Component: Bordnetz-SG     H52 2002
  Revision: 00H52000    Serial number: 00000005963943
  Coding: 6D8F8F0600041600001400001400000000005D015C0001
  Shop #: WSC 12345 000 00000
  VCID: 6ED9CC2B79F6DE4A61-803B
  Subsystem 1 - Part No: 1K1 955 119 B  Labels: 1KX-955-119.CLB
  Component: Wischer VW350  012  0401
  Coding: 00065493
  Shop #: WSC 12345
  Subsystem 2 - Part No: 1K0 955 559 K  Labels: 1K0-955-559-AF.CLB
  Component: RegenLichtSens 002  0505
  Coding: 00471077
  Shop #: WSC 12345
  Part No SW: 1K0 909 605 A    HW: 1K0 909 605 A
  Component: 0L AIRBAG VW8   022 0500
  Revision: 04022000    Serial number: 0033FD07SRGQ
  Coding: 0012364
  Shop #: WSC 01268 785 00200
  VCID: 2A51003B859EF26AFD-807F
  Subsystem 1 - Serial number: 6332MSME43357400
  Subsystem 2 - Serial number: 6342MSME79311002
  Subsystem 3 - Serial number: 6351HSME68475201
  Subsystem 4 - Serial number: 6361HSME690F4D01
  Part No SW: 1K0 953 549 AQ    HW: 1K0 953 549 AQ
  Coding: 0002042
  VCID: 010387975868D1328C-8054
  Part No SW: 1K8 920 870 D    HW: 1K8 920 870 D
  Component: KOMBIINSTRUMENT VDD 2242
  Revision: V0002000    Serial number:
  Coding: 0005101
  Shop #: WSC 01342 020 12345
  VCID: 3261185BAD4EBAAA45-8067
Address 19: CAN Gateway        Labels: 1K0-907-530-V1.clb
  Part No SW: 1K0 907 530 C    HW: 1K0 907 951
  Component: Gateway         H08 0080
  Revision: 08          Serial number: 210010411986E7
  Coding: 3D3F0740070002
  VCID: 2757F90F968CCF02E2-8072
  Component: IMMO            VDD 2242
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX2.lbl
  Part No: 1K0 959 701 L
  Component: Tuer-SG         024 2467
  Coding: 0000124
  VCID: 3777294F462C5F8272-8062
  Part No: 1K1 909 144 F
  Component: EPS_ZFLS Kl.3       1301
  VCID: 2E590C2BB9769E4A21-807B
Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
  Part No SW: 1K0 959 433 CB    HW: 1K0 959 433 CB
  Component:    KSG PQ35 G2  020 0202
  Coding: 00900A085103487F2D02040420080FC2D0BCA0
  VCID: 72E1D85B6DCEFAAA85-8027
  Subsystem 5 - Part No: 1K0 947 291 F
  Component: Innenraumueberw.009 4809
  Coding: 00000000
  Shop #: WSC 12345
  Subsystem 6 - Part No: 1K0 951 605 A
  Component: LIN BACKUP HORN H01 1201
  Subsystem 7 - Part No: 1K0 907 719 B
  Component: Neigungssensor  004 0003
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX2.lbl
  Part No: 1K0 959 702 L
  Coding: 0000124
  Shop #: WSC 00854 461 81279
  VCID: 38752A734B3250FA7B-806D
  Part No: 1K0 035 186 P
  Component: Radio BVX       017 0023
  Coding: 0040402
  Shop #: WSC 00598 598 04583
  VCID: 336F1D5F5254B3A24E-8066
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN1.lbl
  Part No: 1K0 959 703 C
  Component: Tuersteuergeraet 06 0202
  Coding: 0000080
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN1.lbl
  Part No: 1K0 959 704 C
  Coding: 0000080
  VCID: 31631757A84881B23C-8064
Address 76: Park Assist        Labels: 1K0-919-283.lbl
  Part No: 1K0 919 283 A
  Component: 01 Einparkhilfe     0101
  VCID: 2D5B0B27B470E55218-8078
