Auto Climate control 08 2004 Audi A8 4E Vent Temperature never gets hot
AJTech
C?ID=128065
Ok This car has been driving me a little crazy and off the walls. The story is the cars heat output from the vents never gets to hot or even warm. Engine temp, all interior temp sensors, and actual coolant temps all have been checked and verified to be ok. I can visually watch almost every HVAC control motor operate. If I cant see it I can feel a change in the position of the door by way of air flow. I have completed door motor calibrations. When running the output testing on the doors I can get full range of motion according to stepper motor ranges. The one I'm focused on is the temperature blend door. When I run the output test on this one it functions as normal and Vent Temp output is around 135 F deg, which is fantastic. When running the Auto HVAC system normally no VAG COM connected the Vent temp only gets to around 95 deg. It took me a while to get to this point but I have finally figured out that the difference is the A/C Compressor operation. During the Output test Compressor is not running so the temp is higher. I'm glad I've gotten this far but what else am I missing about this system A/C operation. It should not be blending air when system is set to full Hot. Heater cores are not the issue either. I can physically touch each one and there is around a 15-25 deg temp drop. inlet to outlet. I'm going to look inside the HVAC box with a boroscope today and see if I can see anything. I forgot to do a clear after disconnecting the HVAC unit so there are a lot of communication faults. Also I'm still a bit new on the forum but I see people attaching Auto-scans as a separate box with a scroll bar.. How is that done?
Thanks for any input.
Monday,13,March,2017,16:22:17:64595
VCDS Version: 17.1.3.0 (x64)
Data version: 20170203 DS267.2
VIN: WAUML44E04N021944   License Plate:
Mileage: 451470km-280530mi   Repair Order:
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 0E 0F 15 16 17 19 25 34 36 37 38 42
          46 47 4F 52 53 55 56 61 62 65 72 75 76
VIN: WAUML44E04N021944   Mileage: 451470km-280530miles
00-Steering Angle Sensor -- Status: Sporadic communication error 1000
08-Auto HVAC -- Status: Sporadic communication error 1000
0E-Media Player 1 -- Status: Malfunction 0010
38-Roof Electronics -- Status: Malfunction 0010
53-Parking Brake -- Status: Cannot be reached 1100
Address 01: Engine        Labels: 077-910-560-BFM.clb
   Part No SW: 4E0 910 560 A    HW: 4E0 907 560
   Component: 4.2L V8/5V      G   0070
   Revision: 00000000    Serial number: AUX3Z0D1535583
   Coding: 0007773
   Shop #: WSC 02313 785 00200
   VCID: 1F47EE5ACE418FB9F0-804A
8 Faults Found:
17981 - Left Engine Mount Solenoid Valve (N144)
            P1573 - 004 - Open Circuit - Intermittent
18282 - Valve for Torque Support Mount
            P1874 - 001 - Short to Plus
18057 - Powertrain Data Bus
            P1649 - 008 - Missing Message from ABS Controller - Intermittent
18043 - Powertrain Data Bus
            P1635 - 008 - Missing Message from A/C Controller - Intermittent
17819 - Secondary Air Injection System; Bank 2
            P1411 - 002 - Insufficient Flow
17831 - Secondary Air Injection System; Bank 1
            P1423 - 002 - Insufficient Flow
Readiness: 0000 1100
Address 02: Auto Trans        Labels: 09E-927-156.lbl
   Part No SW: 4E0 910 156 E    HW: 09E 927 156 A
   Component: AG6 09E 4,2L5V USA  0110
   Revision: 00000001    Serial number:        0031690
   Coding: 0000002
   VCID: 244DE1B6E727AC61AD-8070
18290 - Powertrain Data Bus
            P1882 - 000 - Missing Message from Electric Parking Brake Controller
                    (no units): 30.0
                    (no units): 111.0
                    Temperature: 28.0°C
                    T.B. Angle: 0.0°
                    Voltage: 14.16 V
18271 - Powertrain Data Bus
            P1863 - 000 - Missing Message from Steering Angle Sensor - Intermittent
18259 - Powertrain Data Bus
            P1851 - 000 - Missing Message from ABS Controller - Intermittent
                    (no units): 30.0
                    (no units): 111.0
                    Temperature: 28.0°C
                    T.B. Angle: 0.0°
                    Voltage: 14.16 V
Address 03: ABS Brakes        Labels: 4E0-910-517.lbl
   Part No SW: 4E0 910 517 B    HW: 4E0 614 517 N
   Component: ESP 5.7 allrad  H44 0500
   Coding: 0007597
   Shop #: WSC 02313 000 00000
   VCID: 2241E7AEFD33A251DF-8076
Address 05: Acc/Start Auth.        Labels: 4E0-910-131.lbl
   Part No SW: 4E0 910 131     HW: 4E0 907 181 C
   Component:     FBS AUDID3  H12 0200
   Revision: 02005112    Serial number: AUX3Z0D1535583
   Coding: 0263168
   Shop #: WSC 56078 001 1048576
   VCID: 58B58546EBEF3881F1-800C
00288 - Steering Column Lock Actuator (N360)
            014 - Defective
                    Fault Status: 01101110
                    Fault Frequency: 0
                    Mileage: 451456 km
                    Date: 2003.11.05
                    Time: 20:42:08
                    Fault Frequency: 0
                    Reset counter: 148
                    Mileage: 451456 km
                    Date: 2003.12.02
                    Time: 14:18:36
Address 06: Seat Mem. Pass        Labels: None
   Part No SW: 4E0 910 760 C    HW: 4E0 959 760
   Component: Sitzmemory BFS H07  0060
   Revision: 00000000    Serial number: 5DS 008 795-03
   Coding: 3940448
   VCID: 234FE2AAE229AB59D4-8076
Address 07: Control Head        Labels: 4E0-910-7xx-07.lbl
   Part No SW: 4E0 910 729 J    HW: 4E0 035 729
   Component: Interfacebox    H43 0600
   Revision: 00000000    Serial number: 346CF047510631
   Coding: 0000103
   Shop #: WSC 03078 444 00093
   VCID: 2F671E9ABEE11F3940-807A
   Subsystem 1 - Part No: 4E0 910 611
   Component: E0380 BedienteilH01 0050
   Subsystem 2 - Serial number: 00000000039287
   Subsystem 3 - Serial number: 0121.05.070000000100010006ÿ
   Subsystem 4 - Serial number: 010006ÿ
00384 - Optical Databus
                    Fault Status: 00101011
                    Reset counter: 39
                    Mileage: 451465 km
                    Date: 2003.12.02
                    Time: 12:55:30
                Address 08: Auto HVAC       Labels: None
Control Module Part Number: 4E0 910 043 A    HW: 4E0 820 043 B
  Component and/or Version: KLIMAAUTOMAT    016 0300
           Software Coding: 1085761
            Work Shop Code: WSC 02311 785 00200
           Additional Info: 4E0910772A  Sitzluefter  FS H02  010   4E0910772A  Sitzluefter BFS H02  010
                      VCID: 1B3FDA4ADA5993991C-804E
   Part No SW: 4E0 910 772 A    HW: 4E0 820 043 B
   Component: Sitzluefter  FS H02  010
   Revision: 065A0000    Serial number: 898053000
   Subsystem 1 - Part No: 4E0 910 772 A
   Component: Sitzluefter BFS H02  010
   Subsystem 2 - Serial number: 898053000
   Subsystem 3 - Serial number: HO19022004065A000000000135ÿ
   Subsystem 4 - Serial number: 000135ÿ
Address 09: Cent. Elect.        Labels: 4E0-910-279.lbl
   Part No SW: 4E0 910 279 G    HW: 4E0 907 279 G
   Component: ILM Fahrer      H12 0170
   Coding: 0123113
   VCID: 2C5D09968FF7642165-8078
   Subsystem 1 - Part No: 4E1 910 113 B
   Component: Wischer WWS D3  H50 0400
   Coding: 00000035
   Shop #: WSC 02313
   Subsystem 2 - Part No: 4E0 910 557   Labels: 8K0-955-559.CLB
   Component: REGENLICHTSENSORH10 0030
   Coding: 00139548
   Shop #: WSC 02313
01800 - Light Switch (E1)
                    Fault Status: 01101000
                    Fault Frequency: 189
                    Reset counter: 110
                    Mileage: 449444 km
                    Date: 2003.11.27
                    Time: 23:09:34
   Part No SW: 4E0 910 111 C    HW: 4E0 035 111
   Component: CD-Changer      H43 0340
   Revision: 00000501    Serial number: AUZ5ZBD1035314
   VCID: 1933C042D065E1890E-804C
02244 - Button in Control Head is Stuck
            003 - Mechanical Failure
                    Fault Status: 01100011
                    Fault Frequency: 92
                    Reset counter: 150
                    Mileage: 451456 km
                    Date: 2003.10.15
                    Time: 17:20:23
                    Bin. Bits: 00000010
02261 - Data Medium
                    Fault Frequency: 92
                    Reset counter: 150
                    Mileage: 451456 km
                    Date: 2003.10.15
                    Time: 17:20:23
Address 0F: Digital Radio        Labels: 4E0-910-593-XM.lbl
   Part No SW: 4E0 910 593 E    HW: 4E0 035 593 A
   Component: SDAR
   Serial number: AUZ4Z7D7019968
   VCID: 2953F082800571099E-807C
            000 -  -
                    Reset counter: 147
                    Mileage: 451450 km
                    Date: 2003.10.09
                    Time: 20:24:58
Address 15: Airbags        Labels: 4E0-910-655-84.lbl
   Part No SW: 4E0 910 655 A    HW: 4E0 959 655 E
   Component: Airbag 8.4E+    H10 0920
   Coding: 0530707
01742 - Igniter for Knee Airbag; Drivers Side (N295)
01743 - Igniter for Knee Airbag; Pass. Side (N296)
Address 16: Steering wheel        Labels: 4E0-910-549.lbl
   Part No SW: 4E0 910 549     HW: 4E0 953 549 A
   Component: Lenksäulenmodul H13 0040
   Coding: 0012241
   VCID: 65CBBCB2AC9D95697A-8030
   Component: Lenkradmodul    H04 0080
                    Reset counter: 148
                    Mileage: 451465 km
                    Date: 2003.12.02
                    Time: 13:42:41
Address 17: Instruments        Labels: 4E0-910-xxx-17.lbl
   Part No SW: 4E0 910 900     HW: 4E0 920 950 B
   Component: KOMBIINSTR. VDO H44 0090
   Revision: D15         Serial number: AUDID3D2005481
   Coding: 0016233
   Shop #: WSC 63237 001 1048576
   VCID: 5CBD99569FD7D4A1D5-8008
Address 19: CAN Gateway        Labels: 4E0-910-468.clb
   Part No SW: 4E0 910 468 A    HW: 4E0 907 468 C
   Component: Gateway         H07 0040
   Revision: 07          Serial number: 05005042191696
   Coding: FCFE7BDD1B2B04
   Shop #: WSC 03078 444 54376
   VCID: 2649FBBE911B5E71B3-8072
                    Fault Frequency: 114
                    Reset counter: 110
                    Mileage: 451450 km
                    Date: 2003.10.12
                    Time: 13:58:28
                    Reset counter: 110
                    Mileage: 451450 km
                    Date: 2003.10.12
                    Time: 13:58:28
                    Reset counter: 140
                    Mileage: 451458 km
                    Date: 2003.11.05
                    Time: 20:13:01
                    Reset counter: 140
                    Mileage: 451458 km
                    Date: 2003.11.05
                    Time: 20:13:01
                    Reset counter: 148
                    Mileage: 451465 km
                    Date: 2003.12.02
                    Time: 13:42:41
Address 25: Immobilizer        Labels: 4E0-910-131.lbl
   Coding: 0263168
   XXXXXXXXXXX ELV                 XXXX
            014 - Defective
                    Fault Frequency: 0
                    Mileage: 451456 km
                    Date: 2003.11.05
                    Time: 20:42:08
                    Fault Frequency: 0
                    Reset counter: 148
                    Mileage: 451456 km
                    Date: 2003.12.02
                    Time: 14:18:36
Address 34: Level Control        Labels: 4E0-910-553.lbl
   Part No SW: 4E0 910 553 E    HW: 4E0 907 553 E
   Component: LUFTFDR.-CDC    H05 4290
   Coding: 0015510
   VCID: 254BFCB2EC1D5569BA-8070
01400 - Suspension Level Control
                    Fault Status: 00100001
                    Reset counter: 140
                    Reset counter: 140
                    Mileage: 451458 km
                    Date: 2003.11.05
                    Time: 20:13:01
                    Reset counter: 140
                    Mileage: 451458 km
                    Date: 2003.11.05
                    Time: 20:13:01
   Component: Sitzmemory FS  H07  0060
   Coding: 4071522
   Part No SW: 4E0 910 887 K    HW: 4E0 919 887 C
   Component: MNS US          H43 0570
   Revision: 00000000    Serial number: 355CM047516362
   VCID: 356B2CF25CBD25E90A-8060
00003 - Control Module
            014 - Defective
                    Reset counter: 0
                    Mileage: 451450 km
                    Date: 2003.10.09
                    Time: 20:27:19
                    Bin. Bits:     0100
Address 38: Roof Electronics        Labels: 4E0-910-135.lbl
   Part No SW: 4E0 910 135 A    HW: 4E0 907 135
   Component: Dachknoten D3   H01 0090
   Serial number: 00000404400081
   Coding: 0003477
   VCID: 1D3BD452C44D9DA9E2-8048
                    Reset counter: 136
                    Mileage: 262136 km
                    Date: 2003.10.16
                    Time: 02:40:00
00455 - Control Module for Access and Start Control; Comfort CAN (J518)
                    Reset counter: 136
                    Mileage: 262136 km
                    Date: 2003.10.16
                    Time: 02:40:00
                    Reset counter: 136
                    Mileage: 262136 km
                    Date: 2003.10.16
                    Time: 02:40:00
00457 - Control Module for Network (J519)
                    Reset counter: 136
                    Mileage: 262136 km
                    Date: 2003.10.16
                    Time: 02:40:00
                    Reset counter: 136
                    Mileage: 262136 km
                    Date: 2003.10.16
                    Time: 02:40:00
Address 42: Door Elect, Driver        Labels: 4E1-910-802-42.lbl
   Part No SW: 4E1 910 802     HW: 4E1 959 801
   Component: Türsteuer.FS BRM007 0110
   Coding: 0028196
   Shop #: WSC 02311 785 00200
   VCID: 5EB9935E89CBC6B1BB-800A
00913 - Window Regulator Switch; Front Right Driver (E81)
                    Reset counter: 136
                    Mileage: 451440 km
                    Date: 2003.10.12
                    Time: 14:25:12
                    Reset counter: 136
                    Mileage: 451440 km
                    Date: 2003.10.12
                    Time: 14:25:12
Address 46: Central Conv.        Labels: 4E0-910-289.lbl
   Part No SW: 4E0 910 289 A    HW: 4E0 907 289
   Component: Komfortgeraet   H04 0040
   Revision: 00400004    Serial number:  W040402240150
   Coding: 0065086
   VCID: 2757F6BA9611477988-8072
   Subsystem 1 - Part No: 4E0 910 853
   Component: Heckdeckel      H06 0060
   Subsystem 2 - Part No: 4E0 907 719
   Component: Neigungssensor  H03 0020
10 Faults Found:
                    Reset counter: 109
                    Mileage: 448927 km
                    Date: 2003.11.06
                    Time: 12:24:19
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 110
                    Mileage: 425072 km
                    Date: 2014.08.29
                    Time: 11:32:28
                    Reset counter: 110
                    Mileage: 425072 km
                    Date: 2014.08.29
                    Time: 11:32:28
00984 - Left Tail Light (M4)
            014 - Defective
                    Reset counter: 110
                    Mileage: 451297 km
                    Date: 2003.12.29
                    Time: 22:06:41
                    Reset counter: 110
                    Mileage: 451297 km
                    Date: 2003.12.29
                    Time: 22:06:41
01503 - Bulb for 3rd Brake Light (M25)
                    Fault Frequency: 0
                    Reset counter: 0
                    Raw, Form. N/A: 000 000 000
00985 - Right Tail Light (M2)
                    Fault Frequency: 0
                    Reset counter: 0
00456 - Control Module for Access and Start Control (J518)
                    Fault Frequency: 0
                    Reset counter: 0
                    Fault Frequency: 0
                    Reset counter: 0
                    Fault Frequency: 0
                    Reset counter: 0
Address 47: Sound System        Labels: 4E0-910-223.lbl
   Part No SW: 4E0 910 223 H    HW: 4E0 035 223 B
   Component: DSP-High D3/AUX H13 0370
   Revision: Dev_D01     Serial number: 00000000546188
   Coding: 0000016
Address 4F: Centr. Electr. II        Labels: None
   Part No SW: 4E0 910 280 A    HW: 4E0 907 280 A
   Component: ILM Beifahrer   H09 0040
   Revision:             Serial number: 00000000034617
   Coding: 0010111
   VCID: 1E39D35EC94B86B1FB-804A
                    Reset counter: 140
                    Mileage: 262136 km
                    Date: 2003.11.05
                    Time: 20:13:00
                    Reset counter: 140
                    Mileage: 262136 km
                    Date: 2003.11.05
                    Time: 20:13:00
                    Reset counter: 140
                    Mileage: 262136 km
                    Date: 2003.11.05
                    Time: 20:13:00
02258 - Door Opener Transmitter
                    Fault Frequency: 113
                    Reset counter: 110
                    Mileage: 262136 km
                    Date: 2003.10.12
                    Time: 13:58:00
Address 52: Door Elect, Pass.        Labels: 4E1-910-802-52.lbl
   Part No SW: 4E1 910 802     HW: 4E1 959 802
   Component: Türsteuer.BF BRM007 0110
   Coding: 0028196
Address 53: Parking Brake
Address 55: Headlight Range        Labels: 4E0-910-357.lbl
   Part No SW: 4E0 910 357     HW: 4E0 907 357
   Component: Pre-AFS         H01 0040
   Coding: 0000001
   VCID: 62C1A7AEBDB3E2519F-8036
   Part No SW: 4E0 910 541 C    HW: 4E0 035 541
   Component: TUNER EU/US/RDW H41 0290
   Revision: 00000000    Serial number: 304CH047581802
   Coding: 0000002
   VCID: 2045EDA6F33FB041C9-8074
Address 61: Battery Regul.        Labels: 4E0-910-181.lbl
   Part No SW: 4E0 910 181 B    HW: 4E0 915 181
   Component: ENERGIEMANAGER  H02 0240
   Revision: 00000000    Serial number: 00000001179668
   Shop #: WSC 23134 823 51513
   Subsystem 1 - Part No: 000 915 105 DL
   Component: von VA0  350215F164
   Coding: 303030393135313035444C56413033353032313546313634
Address 62: Door, Rear Left        Labels: 4E0-910-802.lbl
   Part No SW: 4E0 910 802     HW: 4E0 959 801 A
   Component: Türsteuer.HL BRM007 0110
   Coding: 0028196
   VCID: 5DBB945284CDDDA9A2-8008
Address 65: Tire Pressure        Labels: 4E0-910-273.lbl
   Part No SW: 4E0 910 273     HW: 4E0 907 273
   Component: Reifendruck 2   H01 0210
   Coding: 0212127
   VCID: 5FC7AE5A8EC1CFB9B0-800A
Address 72: Door, Rear Right        Labels: 4E0-910-802.lbl
   Part No SW: 4E0 910 802     HW: 4E0 959 802 A
   Component: Türsteuer.HR BRM007 0110
   Coding: 0028196
Address 75: Telematics        Labels: None
   Part No SW: 4E0 910 616     HW: 4E0 035 616 A
   Component: Telematik USA1      0070
   Revision: 00000004    Serial number: 0000ATD3008690
   Coding: 0000005
   Shop #: WSC 03078 444 53274
   VCID: 60C5ADA6B0BFF04189-50C8
01531 - Emergency Battery
            002 - Lower Limit Exceeded - MIL ON
Address 76: Park Assist        Labels: 4E0-910-283.lbl
   Part No SW: 4E0 910 283 A    HW: 4E0 919 283 B
   Component: Parkhilfe 8-Kan H12 0020
   Revision: --.--.--    Serial number: 08730405500686
   Coding: 0001208
   VCID: 2143E8A2F835B949C6-8074
With CODE tags as explained here.
AJTech
C?ID=128065
Thanks for that, Got it now
mattylondon
United Kingdom
C?ID=219022
Here are label files for front and rear HVAC to help.
Front:
; VAG-COM Label File
; Audi A8 (4E)
; Component: J255 Climatronic control unit
; P/N: 4E0-910-043-???
; includes measuring blocks, coding, adaptation and selective output tests
; created on 26/Feb/2017 by MattyLondon
; status - released for feedback
; last modification: 28/Feb/2017
; requires VAG-COM 10.6.0 or newer
; measuring blocks
001,1,Current N280,regulating valve,in Amperes
; - Readout 0.05 A - Compressor off
; - Readout 0.30 A to 0.65 A - Compressor in control mode
001,2,Duty Cycle N280,regulating valve,%
; - Readout 0 percent - Compressor off
; - Readout 30 … 40 percent to 100 percent - Compressor in control mode
001,3,Duty Cucle G65,high-pressure sender,%
; - Readout 0 percent to 5 percent - Open circuit in wiring / voltage supply or earth connection
;                                  - High-pressure sender G65 defective
; - Readout 5 percent to 12 percent - Pressure in refrigerant circuit too low (system empty)
; - Readout 12 percent to 87.5 percent - Pressure in refrigerant circuit in permissible range
; - Readout above 87.5 ...90 percent - Pressure in refrigerant circuit too high
;                                    - Activation of radiator fan not OK
;                                    - Radiator and/or condenser dirt-clogged
;                                    - Fault in refrigerant circuit
; - Readout 90....100 percent - Short
;                             - Open circuit in voltage supply or earth connection
001,4,Refrigerant Circuit,Pressure,bar absolute
; - Readout below 2.6 bar - Pressure in refrigerant circuit too low (system empty)
;                         - High-pressure sender -G65 defective
; - Readout 2.6 bar to 29 bar - Pressure in refrigerant circuit in permissible range
; - Readout above 29 bar (even for short time) - Pressure in refrigerant circuit too high
002,0,Compressor shut-off conditions
002,1,Current
002,2,Last
002,3,Last but one
002,4,Last but two
; Breakdown of compressor shut-off conditions:
; -  0   Compressor on (no shut-off condition detected)
; -  1   Compressor off (pressure in refrigerant circuit was or is too high)
; -  2   Compressor off (basic setting not performed)
; -  3   Compressor off (pressure in refrigerant circuit is too low)
; -  4   Compressor off (engine has been running for less than 5 sec.)
; -  5   Compressor off (engine speed is below 300 rpm)
; -  6   Compressor off (compressor switched off by ECON function)
; -  7   Compressor off (compressor switched off by OFF function)
; -  8   Compressor off (measured ambient temperature was below 2°C and is still below 5°C, there is no recirculated air request)
; -  9   Compressor off (no readout currently planned)
; - 10   Compressor off (vehicle voltage is below 9.5V)
; - 11   Compressor off (coolant temperature is too high)
; - 12   Compressor off (because of a request from the engine control unit)
; - 13   Compressor off (because of a faulty signal from high-pressure sender G65)
; - 14   Compressor off (because of a fault in the data bus system)
; - 15   Compressor off (the pressure in the refrigerant circuit in this driving period was at least 30 times too high)
; - 16   Compressor off (the measured temperature downstream of the evaporator has for over a minute been below 0°C)
; - 17   Compressor off (the measured temperature downstream of the evaporator is below -5°C)
; - 18   Compressor off (there is no valid measured value for the ambient temperature, e.g. both sensors defective)
; - 19   Compressor off (the engine is not running and the -J255 is in auxiliary heating mode)
; - 20   Compressor off (no readout currently planned)
; - 21   Compressor off (the automatic air recirculation function is set, the measured ambient temperature is between -8°C and 5°C, there is no request for air recirculation
; - 22   Compressor off (the measured ambient temperature is between -8°C and 5°C, there is a request for air recirculation but the measured temperature in the passenger compartment is below 8°C)
; - 23   Compressor off (a fault in the radiator fans activation)
003,0,Recirculated air flap control motor potentiometer (G143)
003,1,Actual,value,In control motor V113
003,2,Specified,value,Calculated by J255
; - Display range 55...205
003,3,Lower stop,value,Determined during basic setting
; - Readout above 55 and below 95
003,4,Upper stop,value,Determined during basic setting
; - Readout above 165 and below 205
004,0,Air flow flap control motor potentiometer (G113)
004,1,Actual,value,In control motor V71
004,2,Specified,value,Calculated by J255
; - Display range 60...200
004,3,Lower stop,value,Determined during basic setting
; - Readout above 60 and below 100
004,4,Upper stop,value,Determined during basic setting
; - Readout above 160 and below 200
005,0,Defroster flap control motor potentiometer (G135)
005,1,Actual,value,In control motor V107
005,2,Specified,value,Calculated by J255
; - Display range 70...195
005,3,Lower stop,value,Determined during basic setting
; - Readout above 70 and below 110
005,4,Upper stop,value,Determined during basic setting
; - Readout above 155 and below 195
006,0,Front left defroster/chest vent shut-off flap (G318)
006,1,Actual,value,In control motor V200
006,2,Specified,value,Calculated by J255
; - Display range 10...250
006,3,Lower stop,value,Determined during basic setting
; - Readout above 10 and below 50
006,4,Upper stop,value,Determined during basic setting
; - Readout above 210 and below 250
007,0,Front right defroster/chest vent shut-off flap (G317)
007,1,Actual,value,In control motor V199
007,2,Specified,value,Calculated by J255
; - Display range 5...250
007,3,Lower stop,value,Determined during basic setting
; - Readout above 5 and below 45
007,4,Upper stop,value,Determined during basic setting
; - Readout above 200 and below 250
008,0,Left footwell flap control motor potentiometer (G139)
008,1,Actual,value,In control motor V108
008,2,Specified,value,Calculated by J255
; - Display range 5 ... 250
008,3,Lower stop,value,Determined during basic setting
; - Readout above 5 and below 50
008,4,Upper stop,value,Determined during basic setting
009,0,Right footwell flap control motor potentiometer (G140)
009,1,Actual,value,In control motor V109
009,2,Specified,value,Calculated by J255
009,3,Lower stop,value,Determined during basic setting
009,4,Upper stop,value,Determined during basic setting
010,0,Temperature flap control motor potentiometer (G92)
010,1,Actual,value,In control motor V68
010,2,Specified,value,Calculated by J255
; - Display range 80...180
010,3,Lower stop,value,Determined during basic setting
; - Readout above 80 and below 120
010,4,Upper stop,value,Determined during basic setting
; - Readout above 140 and below 180
011,0,Centre vent control motor potentiometer (G138)
011,1,Actual,value,In control motor V102
011,2,Specified,value,Calculated by J255
; - Display range 65...195
011,3,Lower stop,value,Determined during basic setting
; - Readout above 65 and below 105
011,4,Upper stop,value,Determined during basic setting
012,0,Rear left vent warm/cold flap control motor potentiometer (G351)
012,1,Actual,value,In control motor V220
012,2,Specified,value,Calculated by J255
012,3,Lower stop,value,Determined during basic setting
; - Readout above 5 or 35 and below 80
012,4,Upper stop,value,Determined during basic setting
; - Readout above 180 and below 220 or 250
013,0,Rear right vent warm/cold flap control motor potentiometer (G352)
013,1,Actual,value,In control motor V221
013,2,Specified,value,Calculated by J255
013,3,Lower stop,value,Determined during basic setting
013,4,Upper stop,value,Determined during basic setting
014,0,Left central vent control motor potentiometer (G136)
014,1,Actual,value,In control motor V110
014,2,Specified,value,Calculated by J255
; - Display range 25...230
014,3,Lower stop,value,Determined during basic setting
; - Readout above 25 and below 65
014,4,Upper stop,value,Determined during basic setting
; - Readout above 190 and below 230
015,0,Left central vent control motor potentiometer (G137)
015,1,Actual,value,In control motor V111
015,2,Specified,value,Calculated by J255
015,3,Lower stop,value,Determined during basic setting
015,4,Upper stop,value,Determined during basic setting
016,0,Centre vent sensors
016,1,Centre left vent,G347
; - Readout above 5 and below 250
016,2,Centre right vent,G348
017,0,Temperature 1
017,1,Left vent,G150,°C
017,2,Right vent,G151,°C
017,3,Centre vent,G191,°C
018,0,Temperature 2
018,1,Evaporator out-flow,G263,°C
018,2,Fresh air intake,G89,°C
018,3,Ambient,G17,°C
018,4,Ambient,G17,°C
019,1,Dash panel,sensor G56,°C
019,2,Temperature sensor,blower V42,RPM
; - Readout above 2000 rpm - blower speed OK
; - Readout below 2000 rpm - blower -V42 not moving freely replace
019,3,Coolant,temperature,°C
019,4,Idling speed,increase request,Off / On requested by J255 Climatronic
020,1,Engine,speed,RPM
020,2,Vehicle,speed,km/h
020,3,Compressor torque,status,0 = current  1 = outdated
020,4,Engine torque,,Necessary engine torque in Nm calculated by J255 for operation of the compressor
; - with compressor on - 1....25 Nm (control valve N280 is activated)
; - with compressor off - below 1.0 Nm (control valve N280 is not activated)
021,1,Driver seat,ventilation J672,Refer to notes for code explanation
021,2,Passenger seat,ventilation J673,Refer to notes for code explanation
021,3,Terminal 58d,%
021,4,Terminal 58s,%
022,1,Radiator fan,V7,Transmitted request for radiator fan in percent via CAN
022,2,Radiator fan,V7,Received request for radiator fan in percent via CAN
022,3,Air quality,G238
; - Readout = 0 - No signal from sensor G238; sensor G238 defective
; - Readout = 1 - Minor increase in oxidisable gases in the air
; - Readout = 2 - Greater increase in oxidisable gases in the air
; - Readout = 3 - Minor increase in reducible gases in the air
; - Readout = 4 - Greater increase in reducible gases in the air
; - Readout = 5 (or 7) - Fresh air mode, no increased values for air impurities measured
022,4,Air request,,Request for fresh or recirculated air from J255
; - Readout = 0 or 00 (fresh air)
; - Readout = 10 (request for recirculated air received from air quality sensor G238 and being met - recirculated air mode)
; - Readout = 11 or 12 or 13 (request for recirculated air received from air quality sensor G238 and not being met - fresh air mode)
; - Readout = 20, 30, 40 or 50 (request for recirculated air based on a specific setting - recirculated air mode)
; - Readout = 60 (partial recirculated air mode, air flow and recirculated air flaps open)
023,0,Front and rear windscreen
023,1,Rear window,Z1 button,Status of heated rear window button Z1 - 0=Off 1=On
023,2,Heated windscreen,Z2 Signal,Signal to activate heated windscreen Z2 - 0=Off 1=On
023,3,Rear window,Z1 Signal,Signal to activate heated windscreen Z1 - 0=Off 1=On
023,4,Rear blind,E385 button,Status of rear roller blind button E385 - 0=Off 1=On
024,0,G107 Photosensor
024,1,Left side,Volts,Depending on intensity of sunlight penetration 1.9 ...3.2V
024,2,Left side,Watts per m2,Depending on intensity of sunlight penetration 0...1000W
024,3,Right side,Volts,Depending on intensity of sunlight penetration 1.9 ...3.2V
024,4,Right side,Watts per m2,Depending on intensity of sunlight penetration 0...1000W
025,1,Terminal 15,On / Off,Information transmitted by steering column electronics control unit J527
025,2,Terminal 75,On / Off,Information transmitted by steering column electronics control unit J527
025,3,Terminal 15,On / Off,Voltage from terminal 15 at J255 Climatronic control unit
025,4,Terminal 30,Volts
026,1,Standing time,hh:mm,Time span between ignition off and on
026,2,Windscreen,wiper status
; - Readout = 00000 - No windscreen wiper or wash/wipe operation active (wiper at home position)
; - Readout = 00001 - Windscreen wiper intermittent
; - Readout = 00010 - Windscreen wiper stage 1
; - Readout = 00100 - Windscreen wiper stage 2
; - Readout = 01000 - Windscreen wiper wipe/wash
026,3,Left seat,heating,Activation of seat heating. Readout ON or OFF
026,4,Right seat,heating,Activation of seat heating. Readout ON or OFF
027,0,Front left seat climate control
027,1,Heating,0...6
027,2,Ventilation,0...6
027,3,Temperature,(measured)
027,4,Temperature,(specified)
028,0,Front right seat climate control
028,1,Heating,0...6
028,2,Ventilation,0...6
028,3,Temperature,(measured)
028,4,Temperature,(specified)
029,0,Auxiliary heater 1
029,1,Switch ON,signal,Signal to switch ON the auxiliary heater received by the data bus system
029,2,Switch OFF,signal,Signal to switch OFF the auxiliary heater received by the data bus system
029,3,Switch ON,signal,Signal to switch ON the fuel powered auxiliary heater received by the data bus system - diesel only
029,4,Shut-off,condition,Shut-off condition for the fuel powered - diesel only
030,0,Auxiliary heater 2
030,2,Aux heating,request,On/off request calculated by J255 for auxiliary heating and ventilation 00=on 01=off
030,3,V2 blower,aux heating mode,On/off request to switch on the fresh air blower -V2 in auxiliary heating mode
030,4,Remaining,on-time,Maximum remaining permissible on-time of auxiliary heater in seconds
031,0,Auxiliary heating/ventilation
031,1,Signal,,Signal received by the data bus system for auxiliary heating/ventilation
; - Readout 00 (no switch-on time set in dash panel insert or on MMI)
; - Readout 01 (a switch-on time is set in dash panel insert or on MMI)
; - Readout 10 (the preset switch-on time in the dash panel insert or on the MMI has already elapsed)
031,2,Signal,,Signal received by the data bus system to switch on the auxiliary heating/ventilation
; - Readout 00 (no signal)
; - Readout 01... 05 (ready or switch on auxiliary heating/ventilation)
; - Readout 06 (switch off auxiliary heating/ventilation)
031,3,Signal,,Signal transmitted by J255 over the data bus system to regulate the output of the auxiliary heater
; - Readout 0 (no signal to reduce the heating power output of the auxiliary heater is received)
; - Readout 1 (the coolant temperature is sufficient to attain the specified heating power,
;             the heating power of the auxiliary heater is reduced by switching from full to partial load operation)
031,4,Signal,,Signal transmitted by J255 over the data bus system to activate the auxiliary ventilation symbol (in the dash panel insert)
; - Readout 0 (do not activate symbol)
; - Readout 1 (activate symbol)
032,1,Signal,,Signal received by the data bus system to assign the ignition key
; - Readout 0 (the ignition was switched on with a key for which the dash panel insert contains no assignment)
; - Readout 1...4 (the ignition was switched on with the key set in the dash panel insert to position 1, 2, 3 or 4)
032,2,Signal,,Signal received from the data bus system to assign the driver by fingerprint
; - Readout 0 (no assignment made)
; - Readout 1....4 (a fingerprint was detected, assigned to position 1, 2, 3 or 4)
032,3,Signal,,Signal received by the data bus system to assign the ignition key
; - Readout 0 (no ignition key is detected, or it is not enabled)
; - Readout 1 (an ignition key is detected and it is enabled)
033,0,Requests received from energy management J644 with engine running
033,1,Last,,Last request received by the data bus system to shut off electrical consumer
033,2,Last,but one,Last but one request received by the data bus system to shut off electrical consumer
033,3,Last,but two,Last but two request received by the data bus system to shut off electrical consumer
; - Readout 0 (no request received from the energy management control unit J644)
; - Readout 1 complete shut-off windscreen heating and additional footwell heater
; - Readout 2 complete shut-off seat heating and rear window heating
; - Readout 3 all consumers of stages 1 and 2
; - Readout 5 reduce the power output windscreen heating and additional footwell heater
; - Readout 6 seat heating and rear window heating
; - Readout 7 all consumers of stages 5 and 6
034,1,Request,,Latest request received by the data bus system to shut off electrical consumers with ignition off or on (no-load current shut-off)
; - Shut-off stage 0 - no shut-off requested by energy management control unit J644
; - Shut-off stage 1...4 - all heating systems off
; - Shut-off stage 5 - auxiliary heating not possible
; - Shut-off stage 6 - no wakeup possible
034,2,Request,,Latest request received by the data bus system to shut off electrical consumers with engine running (As group 033, display 1)
034,3,Energy,balance,Last energy balance of the vehicle electrical system received by the data bus system
; - Readout 0 no restriction, but the system is fully loaded
; - Readout 1 no restriction, there is still a certain reserve of approx. 100 Watts
; - Readout 2 no restriction, there is still a certain reserve of approx. 200 Watts
; - Readout 3 no restriction, there is still a certain reserve of approx. 300 Watts
; - Readout 4 requested to save power and reduce the output of specific consumers, by approx. 400 Watts
; - Readout 5 requested to save power and reduce the output of specific consumers, by approx. 500 Watts
; - Readout 6 requested to save power and reduce the output of specific consumers, by approx. 600 Watts
; - Readout 7 requested to save power and reduce the output of specific consumers, by approx. 700 Watts
034,4,Status,1=active,Status of the request received to shut off electrical consumers
; - Readout 0 (the control is not active)
; - Readout 1 (the control is active)
035,1,Windscreen,Z2,Status received from the data bus system to activate the heated windscreen Z2
; - Readout 0 (no restriction is received from the energy management control unit -J644 for the activation)
; - Readout 254 or 255 (a restriction is received from the energy management J644, the power output for the heated windscreen is reduced or is shut off)
035,2,Heated,seats,Status received from the data bus system to activate the heated seats
035,3,Shut-off,requests,Number of requests received during the last 3 driving periods from the data bus system to shut off electrical consumers
035,4,Shut-off,request,Last request received by the data bus system to shut off electrical consumers with ignition off or on (no-load current shut-off)
036,1,Convenience,CAN,Operating status of convenience system data bus
037,1,Version,,Version number of network management system - working level of convenience system data bus
037,2,Version,,Version of communications matrix in Climatronic control unit J255
038,0,Interior measurements from G355 via J528 roof electronics
038,1,Relative,humidity,
038,2,Cabin,temperature,
038,3,Raw,value,Raw value - ignore readout at present
038,4,Raw,value,Raw value - ignore readout at present
039,1,G355,Status,0000=No fault - As soon as a 1 is displayed at any position there is a fault
039,2,Windscreen,temperature,Calculated by the Climatronic control unit J255
039,3,Windscreen,dew point,Calculated by the Climatronic control unit J255
040,2,N175,opening time,The opening time of the left heat regulation valve N175 in percent
040,3,N176,opening time,The opening time of the right heat regulation valve N176 in percent
040,4,V50,pump,Activation of coolant circulation pump V50 by the Climatronic control unit J255
; Group 041 only with rear Climatronic control unit E265
041,0,Rear left footwell
041,1,Specified,temperature
041,2,Measured,temperature
041,3,Z42 heater,(Amperes)
041,4,Z42 heater,diagnosis,0000 0000 = no faults
; - Vehicle heating diagnosis, left
; - Bit 0: Supply below limit - lower limit not achieved
; - Bit 1: Supply above limit - upper limit surpassed
; - Bit 2: Temperature sensor defective - electrical fault
; - Bit 3: Specified T not attainable - max. heating power
; - Bit 4: Vacant
; - Bit 5: Output stage defective - electrical fault in circuit
; - Bit 6: Overheating - currently not testable
; - Bit 7: Internal control unit error - defective
; Group 042 only with rear Climatronic control unit E265
042,0,Rear right footwell
042,1,Specified,temperature
042,2,Measured,temperature
042,3,Z43 heater,(Amperes)
042,4,Z43 heater,diagnosis,0000 0000 = no faults
; - Vehicle heating diagnosis, right
; - Bit 4: Vacant
043,0,Air flow
043,1,Rear left,footwell,0 ...1.0 kg/h
043,2,Rear right,footwell,0 ...1.0 kg/h
043,3,J126,air blower,Temperature of the regulator in the fresh air blower control unit J126 in °C
044,0,Fresh air blower V2
044,1,Current,actual,The actual current at the fresh air blower V2 in A (Amperes)
044,2,Solar,usage,The operating time for the fresh air blower V2 via the solar roof in h (hours)
044,3,Voltage,actual,The actual voltage at the fresh air blower V2 in V (Volts)
044,4,Voltage,specified,The specified voltage at the fresh air blower V2 in V (Volts)
045,0,Heated windscreen Z2
045,1,Power,specified,The specified power output in W (Watts) to heat the heated windscreen Z2
045,2,Power,actual,The actual output calculated by J255 based on the signal by J505 to heat windscreen Z2 in W (Watts)
045,3,Current,actual,The current in A (Amperes) drawn to operate the heated windscreen Z2
045,4,Z2,diagnosis,0000 0000 = no faults
; - Windscreen heating diagnosis
; - Bit 2: Overheating - currently not testable
; - Bit 3: Window breakage - mechanical fault
; - Bit 4: Insulation fault - electrical fault in circuit
; - Bit 5: Short to 42V - lower limit not achieved
; - Bit 6: Vacant
046,0,Heated windscreen Z2
046,1,Smallest,resistance,in Ohms
046,2,Largest,resistance,in Ohms
046,3,Instantaneous,resistance,in Ohms
047,0,Versions 1
047,1,J126,Hardware,Blower control unit
047,2,J126,Software,Blower control unit
047,3,J505,Hardware,Heated windscreen
047,4,J505,Software,Heated windscreen
048,0,Versions 2
048,1,Z42,Hardware,Rear left footwell heater element
048,2,Z42,Software,Rear left footwell heater element
048,3,Z43,Hardware,Rear right footwell heater element
048,4,Z43,Software,Rear right footwell heater element
049,0,Requests to rear Climatronic control unit
049,1,Shut-off,Z10,Request sent by J255 to shut off the rear left heated seat Z10
049,2,Shut-off,Z12,Request sent by J255 to shut off the rear right heated seat Z12
049,3,Rear left,vent motor,Specification transmitted by J255 for the setting of the rear left vent control motor V218
049,4,Rear right,vent motor,Specification transmitted by J255 for the setting of the rear right vent control motor V218
050,0,Coding
050,1,Coding,1
050,2,Coding,2
050,3,Coding,3
; coding
C00,Climatronic control unit (J255) Coding
C01,The overall coding is composed of three subcodes added together
C02,------------------------------------------------------------------------------------------
C03,Breakdown of code "1" (optional extras):
C04,+0000001 = No assignment and always set
C05,+0000002 = Vehicle with auxiliary heater
C06,+0000004 = Vehicle with heated windscreen
C07,+0000008 = Vehicle with heat-absorbing glass
C08,+0000016 = Vehicle with rear Climatronic control unit (E265)
C09,+0000032 = Vehicle with Audi one-touch memory (Fingerprint)
C10,+0000064 = Vehicle with rear roller blind
C11,+0000128 = Vehicle with sun roof with solar cells
C12,------------------------------------------------------------------------------------------
C13,Breakdown of code "2" (country version and vehicle model):
C14,+0000000 = Germany & RoW - EXCLUDING USA and Japan *select one
C15,+0000256 = USA & Canada *select one
C16,+0000512 = Japan *select one
C17,+0000768 = Hot climates e.g. Australia and Saudi Arabia *select one
C18,+0001024 = Cold climates e.g. Scandinavia *select one
C19,+0002048 = Diesel Engine
C20,+0004096 = 8 cyl. engine TDi & Petrol
C21,+0008192 = 10 cyl. engine (S8)
C22,+0012288 = 12 cyl. engine (W12)
C23,+0016384 = RHD e.g. UK and Japan
C24,+0032768 = FSI engine
C25,------------------------------------------------------------------------------------------
C26,Breakdown of code "3" (rear seat heating and ventilation and glazing):
C27,+0000000 = without rear Climatronic control unit E265 (with & without heated rear seats)
C28,+0000000 = with rear Climatronic control unit E265 and...
C29,              without control for heated seats & without control for ventilation
C30,+0065536 = with rear Climatronic control unit E265 and...
C31,              with control for heated seats & without control for ventilation
C32,+0196608 = with rear Climatronic control unit E265 and...
C33,              with control for heated seats & with control for ventilation
C34,+1048576 = with 8 cyl. engine & heat insulating glass
C35,+3145728 = with heat insulating glass with infrared characteristic line (PR-VW8)
C36,------------------------------------------------------------------------------------------
; adaptation
A003,0,Compressor shut-off by engine control unit via AC compressor shut-off function
A003,5,Basic setting / factory 001
A003,6,1 = Activation of the AC compressor regulating valve N280 is disabled as soon
A003,7,      as the request is received from the engine control unit.
A003,8,0 = Shut-off of activation of the AC compressor regulating valve N280
A003,9,      based on AC compressor cut-in can be suppressed. (J255 ignores the request)
A006,0,Decision-making aid - auxiliary heating/ventilation
A006,5,Basic setting / factory 000
A006,6,0 = J255 decides at ignition whether the auxiliary heater is started or whether the
A006,7,      system operates in auxiliary ventilation mode.
A006,8,1 = J255 always requests the last set mode regardless of the measured and preset temperatures.
A007,0,Shut-off response, auxiliary heating/ventilation.
A007,5,Basic setting / factory 000
A007,6,0 = The auxiliary heating/ventilation mode is maintained until the
A007,7,      preset operating time has elapsed or is switched off manually.
A007,8,1 = The auxiliary heating/ventilation is switched off when the engine is switched off.
A010,0,Limitation of air temperature control after evaporator
A010,5,Basic setting / factory 010
A010,6,10 = J255 can regulate the output of the air conditioner (dependent on the setting)
A010,7,      from a temperature as low as 10 °C.
A010,8,...
A010,9,05 = The upper control limit for the temperature of the air downstream of the
A010,10,      evaporator is fixed to the preset temperature of 5°C
A010,11,...
A010,12,09 = The upper control limit for the temperature of the air downstream of the
A010,13,      evaporator is fixed to the preset temperature of 9°C
A010,14,Enter value between 05 to 09, or 10
A011,0,Shut off solar function
A011,5,Basic setting / factory 001
A011,6,1 = The line for solar roof operating mode is displayed on the MMI.
A011,7,      Operation of the fresh air blower via the solar roof can be switched on and off.
A011,8,0 = The line for solar roof operating mode is not displayed on the MMI.
A011,9,      If a solar roof is fitted - it cannot be switched off.
A015,0,Fresh air blower speed in auxiliary heating/ventilation mode
A015,5,Basic setting / factory 060
A015,6,60 = 6.0v J255 regulates the maximum voltage at the fresh air blower V2
A015,7,Entre value between 30 to 80 for 3.0v to 8.0v
A016,0,Activation of auxiliary heater in residual heat function
A016,5,Basic setting / factory 000
A016,6,0 = J255 does not activate the auxiliary heater on activating the residual heat function.
A016,7,1 = J255 activates the auxiliary heater on activation of the residual heat function if
A016,8,      additional heat energy is required to achieve or maintain the set temperature.
A018,0,Deactivation of electrical consumers when requested by J644
A018,5,Basic setting / factory 000
A018,6,0 = The request is implemented.
A018,7,1 = The request is not implemented.
A018,8,      But the power output for the consumers is limited to 600 watts.
A019,0,Activation of auxiliary heater on vehicles with diesel engine
A019,5,Basic setting / factory 000
A019,6,0 = Auxiliary heater is activated by J255 if additional heat energy is required
A019,7,      to achieve or maintain the set temperature.
A019,8,1 = J255 does not activate Auxiliary heater in Econ mode (setting on MMI).
A022,0,Adaption of fresh air blower characteristic
A022,5,Basic setting / factory 000
A022,6,0 = Fresh air blower runs at the speed assigned to that coding.
A022,7,1 = Fresh air blower runs at a somewhat lower speed across the full characteristic line.
A022,8,2 = Fresh air blower runs at a somewhat higher speed across the full characteristic line.
A023,0,Adaption of temperature characteristic
A023,5,Basic setting / factory 000
A023,6,0 = J255 regulates the temperature to the values assigned to that coding.
A023,7,1 = Temperature in Winter is regulated to a somewhat warmer temperature characteristic.
A023,8,2 = Temperature in Summer is regulated to a somewhat warmer temperature characteristic. (USA Coding)
; selective output test (sorry folks, coming soon..)
;T???,Heated rear window (Z1)
;T???,Heated windscreen (Z2)
;T???,Rear left footwell heater element (Z42)
;T???,Rear right footwell heater element (Z43)
;T???,Air recirculation flap control motor (V113)
;T???,Motor for air flow flap (V71)
;T???,Defroster flap control motor (V107)
;T???,Front left defroster/chest vent shut-off flap control motor (V200)
;T???,Front right defroster/chest vent shut-off flap control motor (V199)
;T???,Left footwell flap control motor (V108)
;T???,Right footwell flap control motor (V109)
;T???,Motor for temperature flap (V68)
;T???,Central vents control motor (V102)
;T???,Rear left vent warm/cold flap control motor (V220)
;T???,Rear right vent warm/cold flap control motor (V221)
;T???,Centre left vent control motor (V110)
;T???,Centre right vent control motor (V111)
;T???,A/C compressor regulator valve (N280)
;T???,Fresh air blower (V2)
;T???,Left heat regulation valve (N175)
;T???,Right heat regulation valve (N176)
;T???,Coolant circulation pump (V50)
;T???,Blower for temperature sensor (V42)
;T???,Radiator fan control unit stages 1+2 (J293)
;T???,Front left heated seat (Z45)
;T???,Front right heated seat (Z46)
;T???,Front left seat fan actuator
;T???,Front right seat fan actuator
;T???,Segment test
Rear
; Audi A8 (4E)
; Component: E265 Operating and display unit for rear Climatronic
; P/N: 4E0-910-158-???
; requires VAG-COM 505.1 or newer
; measuring blocks
001,0,G349 potentiometer in V218 Rear left vent control motor
001,1,Actual,value,Actual feedback value of potentiometer G349 (in control motor V218)
001,2,Specified,value,Specified feedback value for potentiometer G349 (calculated by J255)
001,3,Lower stop,value,Determined during basic setting
001,4,Upper stop,value,Determined during basic setting
002,0,G350 potentiometer in V219 Rear left vent control motor
002,1,Actual,value,Actual feedback value of potentiometer G350 (in control motor V219)
002,2,Specified,value,Specified feedback value for potentiometer G350 (calculated by J255)
002,3,Lower stop,value,Determined during basic setting
002,4,Upper stop,value,Determined during basic setting
003,0,Temperature 1
003,1,Left centre,G311,Measured value of the rear left centre console temperature sensor G311 in °C
003,2,Right centre,G312,Measured value of the rear right centre console temperature sensor G312 in °C
003,3,Left,Specified,Specified temperature set on the rear Climatronic E265 for left side in °C (or Lo/Hi)
003,4,Right,Specified,Specified temperature set on the rear Climatronic E265 for right side in °C (or Lo/Hi)
004,0,Rear left seat
004,1,Heating,level,Rear left seat heating level preset on E265
004,2,Specified,temperature,°C
004,3,Actual,temperature,Actual temperature of heating element in rear left heated seat measured by temperature sensor G94
004,4,Ventilation,level,Rear left seat ventilation level preset on E265
005,0,Rear right seat
005,1,Heating,level,Rear right seat heating level preset on E265
005,2,Specified,temperature,°C
005,3,Actual,temperature,Actual temperature of heating element in rear gight heated seat measured by temperature sensor G95
005,4,Ventilation,level,Rear right seat ventilation level preset on E265
006,0,Rear seat occupancy and shut-off
006,1,Left,occupancy,0=unoccupied 1=occupied
006,2,Right,occupancy,0=unoccupied 1=occupied
006,3,Left,shut-off,0=heating off 1=heating on
006,4,Right,shut-off,0=heating off 1=heating on
007,0,Bit infomation
007,1,Left,,Refer to bit breakdown in lable file
007,2,Right,,Refer to bit breakdown in lable file
; xxxxxxx0 - No shut-off of seat ventilation because of too low temperature in seat
; xxxxxxx1 - Shut-off of seat ventilation because of too low temperature in seat
; xxxxxx0x - No shut-off of seat ventilation because seat unoccupied
; xxxxxx1x - Shut-off of seat ventilation because seat unoccupied
; xxxxx0xx - Seat heating off
; xxxxx1xx - Seat heating on
; xxxx0xxx - Seat side bolster heater off
; xxxx1xxx - Seat side bolster heater on
; x000xxxx - Seat heating and ventilation off
; x001xxxx - Seat heating and ventilation off due to a fault in the seat ventilation or seat heating
; x010xxxx - Seat and seat side bolster heating is provided at up to approx. 50% of maximum output, seat ventilation on
; x110xxxx - Seat and seat side bolster heating is provided at up to approx. 100% of maximum output, seat ventilation on
; x100xxxx - Seat and seat side bolster heating off, seat ventilation on. Control break in seat and seat side bolster heating
;            (the actual seat temperature is higher than the preselected temperature)
; 0xxxxxxx - There is no request to shut off the seat heating or seat ventilation from the energy management control unit J644
; 1xxxxxxx - There is a request to shut off the seat heating or seat ventilation from the energy management control unit J644
             (The seat heating and ventilation are shut off to relieve the load on the alternator)
Uwe, if these labels are acceptable please add them to the VCDS distribution.
AJTech
C?ID=128065
Wow That will help a lot too Thanks
